ccs 5.3 fails to install on Ubuntu 10.04
Studied the CCS documentation and found that it has been tested to run on Ubuntu 10.04 so I reformatted a machine to the proper OS
Tried to install CCS 5.3 and got the following error and need help to get past this
Error in action ExecuteAction
Error in action ExecuteScript
Error in action ExecuteExternalProgram_Join
couldn't execute "/home/dave/ti/ccsv5/eclipse/jre/bin/java": no such file or directory
    while executing
"::InstallJammer::actions::$component $this"
    while executing
    while executing
"$obj execute"
    (procedure "::InstallJammer::ExecuteActions" line 69)
    invoked from within
"::InstallJammer::ExecuteActions $action -parent $id -conditions $eval"
    (procedure "::InstallJammer::actions::ExecuteAction" line 35)
    invoked from within
    while executing
"$obj execute"
    invoked from within
    invoked from within
    while executing
    while executing
    while executing
"$obj execute"
    invoked from within
    invoked from within
    while executing
"$obj execute"
    invoked from within
    invoked from within
    while executing
"$obj execute"
    invoked from within
"::InstallJammer::ExecuteActions $id -when $when"
    (procedure "::InstallJammer::RaiseEventHandler" line 93)
    invoked from within
"::InstallJammer::RaiseEventHandler  .wizard"
    (command bound to event)
  • Hi David,
    may I please ask for a bit further information.  Have you been installing as sudo with full privileges?  May I confirm you have been through this wiki for all dependencies?  One tip is to check for antivirus interference.
    http://processors.wiki.ti.com/index.php/Linux_Host_Support#Installation_Instructions
    The best, however, would be to be able to see the install logs.
    If you're installing as a non-root user, these are in ~/.installjammerinfo/. If you're root, it goes in /var/lib/installjammer/
    You should see a ccsv5 folder.
    Lisa
  • I believe that I have solved the issue by installing the unzip package.
  • Hi David,
    ok, thanks for the update and glad you hear you seem to have found the issue.
    All the best with development.
    Lisa
