Error workspace
Other Parts Discussed in Thread: CCSTUDIO
Hi! I'm starting to use CCS v5. I've installed CCS v5 and now I need to running first time. The program create by default my workspace an d then this windows appears:
Can anyone help me, please?? I don't know what to do!
thanks!
Carmen
  • Hi Carmen,
    without furhter information here are some tips
    - try the latest ccs version, v5.3
    - does this occur with all workspaces
    - check for permissions and antivirus interference/issues
    One thing that might help us to debug is if you could send the error log file the message refers to.  You can also try deleting the metadata.
    There is further error logging that can be turned on (see wiki below) for more information and logs that would help us, however you need to be able to have ccs open to enable these
    http://processors.wiki.ti.com/index.php/Troubleshooting_CCS
    Please keep us informed.
    Lisa
  • hi again!
    the error persist and I don't know what is the solution...I try tu delete metadata, but the error persist.
    Now I'll send you the error file, so maybe you can help me.
    !SESSION 2013-02-19 15:59:55.478 -----------------------------------------------
    eclipse.buildId=I20110613-1736
    java.version=1.6.0_13
    java.vendor=Sun Microsystems Inc.
    BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=es_ES
    Framework arguments:  -product com.ti.ccstudio.branding.product
    Command-line arguments:  -os win32 -ws win32 -arch x86 -product com.ti.ccstudio.branding.product
    !ENTRY org.eclipse.osgi 4 0 2013-02-19 16:00:07.095
    !MESSAGE An error occurred while automatically activating bundle com.ti.ccstudio.debug.server (329).
    !STACK 0
    org.osgi.framework.BundleException: Exception in com.ti.ccstudio.debug.server.DebugServerPlugin.start() of bundle com.ti.ccstudio.debug.server.
        at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
        at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
        at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
        at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
        at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
        at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
        at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
        at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:462)
        at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
        at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
        at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:476)
        at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
        at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
        at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
        at java.lang.ClassLoader.loadClass(Unknown Source)
        at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:345)
        at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
        at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1207)
        at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
        at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
        at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
        at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
        at com.ti.ccstudio.core.CCStudioPlugin.getXPCOMRuntimeAdapter(CCStudioPlugin.java:85)
        at com.ti.ccstudio.core.BaseCCSPlugin.initializeXPCOMRuntime(BaseCCSPlugin.java:29)
        at com.ti.ccstudio.core.BaseCCSPlugin.internalStart(BaseCCSPlugin.java:20)
        at com.ti.common.core.BaseTIPlugin.start(BaseTIPlugin.java:41)
        at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
        at java.security.AccessController.doPrivileged(Native Method)
        at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
        at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
        at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:473)
        at java.lang.ClassLoader.loadClassInternal(Unknown Source)
        at com.ti.ccstudio.ui.BaseCCSUIPlugin.internalStart(BaseCCSUIPlugin.java:21)
        at com.ti.common.ui.BaseTIUIPlugin.start(BaseTIUIPlugin.java:41)
        at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:191)
        at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
        at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
        at java.lang.reflect.Method.invoke(Unknown Source)
        at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
        at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
        at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
    Caused by: java.lang.UnsatisfiedLinkError: C:\ti\ccsv5\ccs_base\DebugServer\bin\win32\LibraryLoader.dll: No se pudo iniciar la aplicación; la configuración en paralelo no es correcta. Consulte el registro de eventos de la aplicación o use la herramienta sxstrace.exe de la línea de comandos para obtener más detalles
        at java.lang.ClassLoader$NativeLibrary.load(Native Method)
        at java.lang.ClassLoader.loadLibrary0(Unknown Source)
        at java.lang.ClassLoader.loadLibrary(Unknown Source)
        at java.lang.Runtime.load0(Unknown Source)
        at java.lang.System.load(Unknown Source)
        at com.ti.debug.engine.xpcom.DLLPreLoader.load(DLLPreLoader.java:40)
        at com.ti.debug.engine.xpcom.Runtime.preXPCOMInit(Runtime.java:244)
        at com.ti.debug.engine.xpcom.Runtime.startBare(Runtime.java:191)
        at com.ti.debug.engine.xpcom.Runtime.startBare(Runtime.java:148)
        at com.ti.debug.engine.xpcom.Runtime.setRuntimeLocation(Runtime.java:67)
        at com.ti.ccstudio.debug.server.internal.XPCOMRuntimeManager$1.run(XPCOMRuntimeManager.java:48)
        at com.ti.ccstudio.debug.server.internal.XPCOMRuntimeManager.initializeXPCOMRuntime(XPCOMRuntimeManager.java:67)
        at com.ti.ccstudio.debug.server.internal.XPCOMRuntimeAdapter.initializeRuntime(XPCOMRuntimeAdapter.java:21)
        ... 82 more
    Root exception:
    Thank you again!
    Carmen
  • hello everybody! I just want to tell you I've solved the problem.
    I've downloaded and installed the eclipse and then, when I've run the ccs.v5, the program works perfectly.
    Thank you, anyway :)
    Carmen
