I did a clean install of CCSv5.3 under WinXP and imported my existing CCSV5.2.1 sysbios projects.
The projects refuse to build and I get errors such as the following. I have no missing RTSC repos and all paths seem proper...whats the problem?
**** Build of configuration Debug for project HERA_ARM ****
"C:\\ti\\ccsv5\\utils\\bin\\gmake" -k all
making ../src/sysbios/sysbios.lib ...
gmake[1]: *** No rule to make target `BIOS.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `family/arm/HwiCommon.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `family/arm/IntrinsicsSupport.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `family/arm/TaskSupport.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `hal/Hwi.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `hal/Hwi_stack.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `hal/Hwi_startup.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `hal/Timer.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `hal/Cache.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `knl/Clock.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `knl/Idle.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `knl/Intrinsics.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `knl/Queue.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `knl/Semaphore.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `knl/Swi.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `knl/Swi_andn.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `knl/Task.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `timers/timer64/Timer.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `timers/timer64/TimestampProvider.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `gates/GateHwi.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `gates/GateAll.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `gates/GateSwi.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `gates/GateMutexPri.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `gates/GateMutex.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `syncs/SyncSem.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `family/arm/arm9/Cache.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `family/arm/arm9/Mmu.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `family/arm/da830/Hwi.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `family/arm/da830/TimerSupport.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `family/arm/exc/Exception.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `xdcruntime/GateThreadSupport.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `heaps/HeapMem.c', needed by `BIOS.obj'.
gmake[1]: *** No rule to make target `family/arm/IntrinsicsSupport_asm.asm', needed by `arm_IntrinsicsSupport_asm.obj'.
gmake[1]: *** No rule to make target `family/arm/TaskSupport_asm.asm', needed by `arm_TaskSupport_asm.obj'.
gmake[1]: *** No rule to make target `family/arm/HwiCommon_asm.asm', needed by `arm_HwiCommon_asm.obj'.
gmake[1]: *** No rule to make target `family/arm/exc/Exception_asm.asm', needed by `exc_Exception_asm.obj'.
gmake[1]: *** No rule to make target `family/arm/da830/Hwi_asm.s470', needed by `da830_Hwi_asm.obj'.
gmake[1]: *** No rule to make target `family/arm/dm6446/Hwi_asm.s470', needed by `dm6446_Hwi_asm.obj'.
gmake[1]: *** No rule to make target `family/arm/omap1030/Hwi_asm.s470', needed by `omap1030_Hwi_asm.obj'.
gmake[1]: *** No rule to make target `family/arm/sim1030/Hwi_asm.s470', needed by `sim1030_Hwi_asm.obj'.
gmake[1]: *** No rule to make target `family/arm/sim1030/Clobber_asm.s470', needed by `sim1030_Clobber_asm.obj'.
gmake[1]: *** No rule to make target `family/arm/arm9/Mmu_asm.asm', needed by `arm9_Mmu_asm.obj'.
gmake[1]: *** No rule to make target `family/arm/arm9/Cache_asm.asm', needed by `arm9_Cache_asm.obj'.
gmake[1]: *** No rule to make target `timers/timer64/Timer_asm.s470', needed by `timer64_Timer_asm.obj'.
gmake[1]: *** No rule to make target `timers/dmtimer/Timer_asm.s470', needed by `dmtimer_Timer_asm.obj'.
gmake[1]: Target `all' not remade because of errors.
gmake: *** [../src/sysbios/sysbios.lib] Error 2
making ../src/ipc/ipc.lib ...
gmake[1]: *** No rule to make target `ipc/Ipc.c', needed by `Ipc.obj'.
gmake[1]: *** No rule to make target `utils/NameServer.c', needed by `Ipc.obj'.
gmake[1]: *** No rule to make target `utils/NameServerRemoteNull.c', needed by `Ipc.obj'.
gmake[1]: *** No rule to make target `utils/MultiProc.c', needed by `Ipc.obj'.
gmake[1]: *** No rule to make target `utils/List.c', needed by `Ipc.obj'.
gmake[1]: *** No rule to make target `ipc/GateMP.c', needed by `Ipc.obj'.
gmake[1]: *** No rule to make target `ipc/MessageQ.c', needed by `Ipc.obj'.
gmake[1]: *** No rule to make target `ipc/SharedRegion.c', needed by `Ipc.obj'.
gmake[1]: *** No rule to make target `ipc/ListMP.c', needed by `Ipc.obj'.
gmake[1]: *** No rule to make target `ipc/Notify.c', needed by `Ipc.obj'.
gmake[1]: *** No rule to make target `ipc/heaps/HeapBufMP.c', needed by `Ipc.obj'.
gmake[1]: *** No rule to make target `ipc/heaps/HeapMemMP.c', needed by `Ipc.obj'.
gmake[1]: *** No rule to make target `ipc/gates/GatePeterson.c', needed by `Ipc.obj'.
gmake[1]: *** No rule to make target `ipc/gates/GateMPSupportNull.c', needed by `Ipc.obj'.
gmake[1]: *** No rule to make target `ipc/notifyDrivers/NotifyDriverShm.c', needed by `Ipc.obj'.
gmake[1]: *** No rule to make target `ipc/family/da830/NotifySetup.c', needed by `Ipc.obj'.
gmake[1]: *** No rule to make target `ipc/family/da830/InterruptArm.c', needed by `Ipc.obj'.
gmake[1]: *** No rule to make target `ipc/transports/TransportShm.c', needed by `Ipc.obj'.
gmake[1]: *** No rule to make target `ipc/transports/TransportShmSetup.c', needed by `Ipc.obj'.
gmake[1]: *** No rule to make target `ipc/nsremote/NameServerRemoteNotify.c', needed by `Ipc.obj'.
gmake: *** [../src/ipc/ipc.lib] Error 2
gmake: Target `all' not remade because of errors.
**** Build Finished ****
