Problem view not reporting build errors
I am using CCSv5.3 latest and I am having an annoying issue in which the problem viewer is not reporting any of the errors in the code.  They show up in the build log but not in the Problems tab.
This is only occurring on one workspace.  I am working two related codebases on the same (real-life) project, separated in two different CCS projects, each in its own workspace (so that I can debug both simultaneously).  The project/workspace that I've been working on the most recently has this problem in the last week or so; the other one, which I had not built for a while until this morning to test, does not have the problem.
After attempting full clean/rebuild cycles, then restarting the program, (and not having found anything in a quick search of these forums) I decided to try updating CCS (I was probably on 5.2 or something -- it took quite a while to download all the updates).  Well, that was a big failure and ate most of my day yesterday :(.  The updater hung hard so I eventually had to kill it.  Then of course CCS had major errors, as did the installer I tried to re-run.  And the uninstaller.  Finally I downloaded the full 1.3GB installer and manually deleted CCS and some registry entries so that it would reinstall.  That finally went, but I still have the original problem.  (Over the course of the day I tried the advice here: http://processors.wiki.ti.com/index.php/Troubleshooting_CCSv5 - particularly the whole "InstallJammer" bit.  Good name - exactly what it did.  Jammed up my install.)
I found (and copied pertinent parts of :)) a similar post here: http://e2e.ti.com/support/development_tools/code_composer_studio/f/81/t/197977.aspx .  However, there are some differences between their issue and mine.  I have now tried resetting my perspective, doing a -clean launch, cleaning and starting a new workspace.  Still the same behaviour.
Does anybody have any ideas?  Thanks in advance.
Signed,
Very Frustrated
  • Hi Chris,
    sorry to hear you have hit so many issues.
    Without any details provided, my first thought is that the "problem" project/workspace may not be a pure ccs project.  Could this be the case?  If so our error parser only works with pure ccs projects.
    Please keep us informed and any information (even sending the project which has the issue offline) would help here.
    Lisa
  • No, it is and always has been a CCS project, although it has been upgraded through a few versions of CCS.
    What other details will help?
    Chris
  • Hi Chris,
    a couple next things we would like to verify with you.
    Do you have the error parser enabled for the project/workspace?  This related thread has instructions how to enable it.
    http://e2e.ti.com/support/development_tools/code_composer_studio/f/81/p/254588/900541.aspx#900541
    Could you verify a fresh/project/workspace/example does not exhibit this behaviour.   Just to double check it is not a problem with your installation/environment.
    Lisa
  • Hi Lisa,
    Thanks for the reply.  The first 3 TI parsers are enabled, but the XDC is not.  Is that important for the MSP-430?  (That is not a setting that I have ever messed with.)
    Well, it randomly started working sometime today.  I will post again if it crops up again...
    Thanks again,
    Chris
  • Hi Chris,
    ok, should you find consistant problems again, just create a new post and things can go from there.  Sorry for the inconvenience.
    Lisa
