Questions on using eclipsec to build the project in CMD
I successfully build my project in CMD using eclipsec. However, if I change the install root, such as from C:\ti\... to C:\myti\... when I use eclipsec to build my project, I find it's still trying to make the project from this path: C:\ti\ccsv5\utils\bin\gmake and find the link from this patch: C:\ti\ccsv5\tools\complier. Therefore, the project can not be built.
Does anyone know how to solve this problem?
    How are you doing this? are you just manually renaming the folder? Or do you have multiple installs of CCS in those folders?
    ki
  • Hello Ki,
    I am sorry that I made my question confused. I manually rename the folder from C:\ti to C:\myti.
    Before renaming, I use eclipsec to build my project and it works successfully.
    After renaming, even if I change the path for eclipsec in CMD, it fails in building. I see the reason is that it's still trying to find gmake from this path: C:\ti\ccsv5\utils\bin\gmake and find the link from this patch: C:\ti\ccsv5\tools\complier.
    I would recommend against doing this. CCS relies on various environment variables which point to directories inside the original installation path. You break these variables by manually renaming the folder.
    ki
