How to eliminate "if continue " or "if break" statements in loop ?
hi,ti optimization experts!
Now I always find many "if continue " and " if break " statements in my algorithms.These statements prevented to produce software pipeline in loops and has poor
performance.for example:
how to optimize code like this:
for(...)
if (A) continue;
if(B)  break;
when I compilered these code,I would found feedback information like this  "Disqualified loop: Loop contains control code "; So, I couldn't know how to eliminate
"if break" and "if continue" to produce software pipeline.
  • There is no simple answer. In general you can't just remove them. You need to re-design your algorithm. Software pipeline works best with data frames. Can you give us some more specific example?
    Maciej
    Maciej
    for example:
    for(index_i = 0; index_i < NUM_COUNT; index_i ++)
        for(index_j = 0; index_j < NUM_COUNT; index_j ++)
             if(pStr[index_j].id == 0 || index_i == index_j)
            continue;
           if( pStr[index_j].wx0 == pStr[index_i].wx0 \
          && pStr[index_j].wx1 == pStr[index_i].wx1 \
          && pStr[index_j].wy0 == pStr[index_i].wy0 \
         && pStr[index_j].wy1 == pStr[index_i].wy1)
         pStr[index_i].id = 0;
    statements like below contains"if continue",
            continue;
    so, That couldn't produce software pipeline. how to eliminate the "if continue"??
  • A continue can always be turned into an if statement, possibly with an added variable.  In this case, it's particularly simple:
             if (!(pStr[index_j].id == 0 || index_i == index_j))
    However, that's still a pretty complicated conditional test.  I'd be surprised if the compiler could software pipeline that.
  • if removal of first IF will not affect numerical stability and correctness you can use just:
    pStr[index_i].id = (pStr[index_j].wx0 ^ pStr[index_i].wx0 ) & ([index_j].wx1 ^ pStr[index_i].wx1 ) & ( pStr[index_j].wy0 ^ pStr[index_i].wy0 ) & ( pStr[index_j].wy1 ^ pStr[inde x_i].wy1)
    Maciej
    thx,But in fact what I expected was how to modify if statements to produce software pipeline,
    so what you modified still couldn't produce software pipeline.
    Maciej
     MaciejKucia,thx!
    But were you sure you understand my if statements.I didn't think you were wright.I guessed you forgot the condition ---
    if (!(pStr[index_j].id == 0 || index_i == index_j)).Please check it.
  • I said:
    If you want zeroes on diagonal you can further multiply (or logical AND) by anty-identity matrix (not sure English name).
    [/quote]
    if code like below:
          continue;
    How to eliminate "if(pStr[index_j].id == 0 || index_i == index_j) continue;"   I felt it was very hard to eliminate to produce software pipeline.
  • hi,MaciejKucia:
    Do you agree that however nested if statements such as if continue statement and  if break statement  are complex they definitely can be eliminate.
    And when these nested if statements are be compiled by DSP  compiler.the codes can produce software pipeline.
    So,here involved another problem. When I optimized algorithms on TI DSP such as C6000 C64x+ cpu ,my only goal was that made all codes and loops or functions
    produce software pipeline. If software pipeline couldn't be produced the performance of algorithms was rather poor.So my question was: Could any nested if statements contained in  loops
    and functions  be eliminated.
  • Typical DSP algorithm does not have any IF.
    Maybe those two materials will be an use for you:
    http://www.ti.com/lit/an/spra666/spra666.pdf
    http://www.ti.com/lit/ug/spru352g/spru352g.pdf
    Maciej
    But , in my application the condition that "Typical DSP algorithm does not have any IF." couldn't always be satisfied .
  • Not every loop can be software pipelined.  As a guideline, loops that have a constant increment and contain minimal conditional code in the body have the best chance of being software pipelined, but this is not a guarantee.  Some loops with conditional code can be software pipelined, but the more complicated a conditional is, the less likely the loop can be software pipelined.
  • Try this:
                if ((~(index_i ^ index_j)
                     | (pStr[index_j].wx0 ^ pStr[index_i].wx0)
                     | (pStr[index_j].wx1 ^ pStr[index_i].wx1)
                     | (pStr[index_j].wy0 ^ pStr[index_i].wy0)
                     | (pStr[index_j].wy1 ^ pStr[index_i].wy1)) == 0)
    I'm very appreciated that you give me reply.First,I agreed with you very much that not every loop can be software pipelined.
    In my daily work. it was always puzzled that how to judge whether loops and functions in my code could be software pipelined.
    I got some information form C6x programmer's guide.All of them said loops couldn't contain functions or control code (for example  if continue  if  break),If loops contained functions and control code,software pipeline couldn't be produced ,But was it possible? How hard we achieve that goal! I thought it was impossible to  guarantee that  every loop didn't have any function and control code .
          So. some loops that can be software pipelined can be optimized and get high performance.but some other loops cannot be software pipelined however.
