Hi
I am working with ccs5 and TFS plugin for eclipse . Everything worked fine , until tomorrow I changed the local path in TFS .
I build my projects from command line and from IDE .
The original path was e:\dev , I change it to e:\dev_full
Today I change back the TFS local path to original e:\dev , but the command line build stop working
I got the following error “ A error has occurred, see the log file .. metadata”
The build from IDE works perfect .
The commnad build projects from c:\dev_full\ also works perfect ..
My command line builds is:
C:\ti\ccsv5\eclipse\eclipsec –noSplash -data "E:\DEV\DSP_5.3\Bsp" -application com.ti.ccstudio.apps.projectBuild -ccs.projects "Flash" -ccs.buildType "clean" -ccs.configuration "Debug"
C:\ti\ccsv5\eclipse\eclipsec –noSplash -data "E:\DEV\DSP_5.3\Bsp" -application com.ti.ccstudio.apps.projectBuild -ccs.projects "Flash" -ccs.buildType "full" -ccs.configuration "Debug"
C:\ti\ccsv5\eclipse\eclipsec –noSplash -data "E:\DEV\DSP_5.3\Bsp" -application com.ti.ccstudio.apps.projectBuild -ccs.projects "Gpio" -ccs.buildType "clean" -ccs.configuration "Debug"
C:\ti\ccsv5\eclipse\eclipsec –noSplash -data "E:\DEV\DSP_5.3\Bsp" -application com.ti.ccstudio.apps.projectBuild -ccs.projects "Gpio" -ccs.buildType "full" -ccs.configuration "Debug"
I notices , that the environment variable from “help\tfs explorer support\ diagnostic data\environment variables” still contain the wrong path
For example :
Property Value
IVT_CONFIG_FILE E:\DEV_full\3rdParty\SiemensLib\Dev_Ivt.ini
But supposed to be :
IVT_CONFIG_FILE E:\DEV\3rdParty\SiemensLib\Dev_Ivt.ini
The log file from metadata is:
!SESSION 2013-04-25 17:32:34.926 -----------------------------------------------
eclipse.buildId=I20120608-1200
java.version=1.6.0_13
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=iw_IL
Framework arguments: צnoSplash -application com.ti.ccstudio.apps.projectBuild -ccs.projects Flash -ccs.buildType clean -ccs.configuration Debug
Command-line arguments: -os win32 -ws win32 -arch x86 צnoSplash -data E:\DEV\DSP_5.3\Bsp -application com.ti.ccstudio.apps.projectBuild -ccs.projects Flash -ccs.buildType clean -ccs.configuration Debug
!ENTRY org.eclipse.osgi 4 0 2013-04-25 17:32:35.834
!MESSAGE An error occurred while automatically activating bundle com.ti.common.project.core (442).
!STACK 0
org.osgi.framework.BundleException: Exception in com.ti.common.project.core.internal.CommonProjectCorePlugin.start() of bundle com.ti.common.project.core.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:263)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:469)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:461)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.java:188)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClassHoldingLock(ClasspathManager.java:632)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:614)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:568)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:492)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:465)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:464)
at com.ti.ccstudio.project.core.internal.variables.CCSPathVariableResolver__EXTERNAL_BUILD_ARTIFACT.getValue(CCSPathVariableResolver__EXTERNAL_BUILD_ARTIFACT.java:33)
at org.eclipse.core.internal.resources.ProjectVariableProviderManager$Descriptor.getValue(ProjectVariableProviderManager.java:61)
at org.eclipse.core.internal.resources.ProjectPathVariableManager.internalGetValue(ProjectPathVariableManager.java:152)
at org.eclipse.core.internal.resources.ProjectPathVariableManager.resolveVariable(ProjectPathVariableManager.java:226)
at org.eclipse.core.internal.resources.ProjectPathVariableManager.resolveVariable(ProjectPathVariableManager.java:211)
at org.eclipse.core.internal.resources.ProjectPathVariableManager.resolveURI(ProjectPathVariableManager.java:278)
at org.eclipse.core.internal.resources.AliasManager.addToLocationsMap(AliasManager.java:360)
at org.eclipse.core.internal.resources.AliasManager.buildLocationsMap(AliasManager.java:399)
at org.eclipse.core.internal.resources.AliasManager.startup(AliasManager.java:689)
at org.eclipse.core.internal.resources.Workspace.startup(Workspace.java:2516)
at org.eclipse.core.internal.resources.Workspace.open(Workspace.java:2251)
at org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPlugin.java:439)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:167)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:679)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:191)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Caused by: java.lang.ClassCircularityError: org/eclipse/core/resources/IWorkspaceRunnable
at com.ti.common.project.core.internal.events.ProjectStateMonitor.initialize(ProjectStateMonitor.java:403)
at com.ti.common.project.core.internal.CommonProjectCorePlugin.doStart(CommonProjectCorePlugin.java:148)
at com.ti.common.core.BaseTIPlugin.start(BaseTIPlugin.java:42)
... 106 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2013-04-25 17:32:35.839
!MESSAGE An error occurred while automatically activating bundle org.eclipse.core.resources (91).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
Caused by: java.lang.NoClassDefFoundError: com/ti/common/project/core/util/CTIProjectCoreUtils
... 59 more
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle com.ti.common.project.core (442).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)
... 90 more
Caused by: org.osgi.framework.BundleException: Exception in com.ti.common.project.core.internal.CommonProjectCorePlugin.start() of bundle com.ti.common.project.core.
... 100 more
... 106 more
Root exception:
... 90 more
... 100 more
... 106 more
!ENTRY org.eclipse.osgi 4 0 2013-04-25 17:32:35.841
!MESSAGE An error occurred while automatically activating bundle org.eclipse.cdt.core (42).
!STACK 0
org.osgi.framework.BundleException: The activator org.eclipse.cdt.core.CCorePlugin for bundle org.eclipse.cdt.core is invalid
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:172)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/core/resources/IWorkspaceRunnable
... 37 more
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.core.resources (91).
... 43 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
... 53 more
... 59 more
... 90 more
... 100 more
... 106 more
Root exception:
... 43 more
... 53 more
... 59 more
... 90 more
... 100 more
... 106 more
!ENTRY org.eclipse.osgi 4 0 2013-04-25 17:32:35.956
!MESSAGE Application error
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "com.ti.ccstudio.apps" was unable to instantiate class "com.ti.ccstudio.apps.internal.project.Build".
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:188)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/cdt/core/index/IndexerSetupParticipant
... 15 more
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.cdt.core (42).
... 21 more
Caused by: org.osgi.framework.BundleException: The activator org.eclipse.cdt.core.CCorePlugin for bundle org.eclipse.cdt.core is invalid
... 31 more
... 37 more
... 43 more
... 53 more
... 59 more
... 90 more
... 100 more
... 106 more
!SESSION 2013-04-25 17:32:37.408 -----------------------------------------------
Framework arguments: צnoSplash -application com.ti.ccstudio.apps.projectBuild -ccs.projects Flash -ccs.buildType full -ccs.configuration Debug
Command-line arguments: -os win32 -ws win32 -arch x86 צnoSplash -data E:\DEV\DSP_5.3\Bsp -application com.ti.ccstudio.apps.projectBuild -ccs.projects Flash -ccs.buildType full -ccs.configuration Debug
!ENTRY org.eclipse.osgi 4 0 2013-04-25 17:32:38.335
!STACK 0
... 106 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2013-04-25 17:32:38.340
!STACK 0
... 59 more
... 90 more
... 100 more
... 106 more
Root exception:
... 90 more
... 100 more
... 106 more
!ENTRY org.eclipse.osgi 4 0 2013-04-25 17:32:38.342
!STACK 0
... 37 more
... 43 more
... 53 more
... 59 more
... 90 more
... 100 more
... 106 more
Root exception:
... 43 more
... 53 more
... 59 more
... 90 more
... 100 more
... 106 more
!ENTRY org.eclipse.osgi 4 0 2013-04-25 17:32:38.457
!STACK 1
... 15 more
... 21 more
... 31 more
... 37 more
... 43 more
... 53 more
... 59 more
... 90 more
... 100 more
... 106 more
!SESSION 2013-04-25 17:32:40.939 -----------------------------------------------
Framework arguments: צnoSplash -application com.ti.ccstudio.apps.projectBuild -ccs.projects Gpio -ccs.buildType clean -ccs.configuration Debug
Command-line arguments: -os win32 -ws win32 -arch x86 צnoSplash -data E:\DEV\DSP_5.3\Bsp -application com.ti.ccstudio.apps.projectBuild -ccs.projects Gpio -ccs.buildType clean -ccs.configuration Debug
!ENTRY org.eclipse.osgi 4 0 2013-04-25 17:32:41.852
!STACK 0
... 106 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2013-04-25 17:32:41.857
!STACK 0
