Version Control in CCS 5.4
Is there a nice way to increment software versions within this tool?  I am sure it is really obvious but my web searches have failed me.  I know that this is probably an easy answer so just an informational link or even and search string would get you a "Verify Answer"!
EDIT:  I think I am actually just looking for a simple way to increment a build/version number within the tool itself.  Right now, I am incrementing a suffix on the project title, there has to be a better way!
  • Hi William,
    I'm not quite sure I understand what you are trying to do here. Where exactly are you trying to increment a version number? In your source?
  • Is there a way to automatically increment a version/build number every time the build function completes?
  • Not a version or build number. But you can have a timestamp of sorts using the compiler __DATE__ and __TIME__ macros
  • Where would I use these macros?  Would I be able to append the date to the end of the name of the out or map files?
    Right in your source code
    Not using the macros I specified. You can use a post build step to rename the out and map files to whatever format you wish using environment variables.
