Hello everybody,
we installed the CCS Uniflash on a WinXp SP3 machine, without any error during the installation procedure.
But now, when we start the software, it opens the main window and suddenly close it.
The log error is the following. Anybody have an idea about the solution?
Thanks a lot. Regards.
# An unexpected error has been detected by Java Runtime Environment:
# EXCEPTION_ILLEGAL_INSTRUCTION (0xc000001d) at pc=0x0c651616, pid=2280, tid=2284
# Java VM: Java HotSpot(TM) Client VM (11.3-b02 mixed mode windows-x86)
# Problematic frame:
# C [fsutiljni.dll+0x1616]
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x00386800): JavaThread "main" [_thread_in_native, id=2284, stack(0x00030000,0x00130000)]
siginfo: ExceptionCode=0xc000001d
Registers:
EAX=0x0c651610, EBX=0x0733b758, ECX=0x00386914, EDX=0x00387108
ESP=0x0012f424, EBP=0x0012f460, ESI=0x0733b758, EDI=0x00386800
EIP=0x0c651616, EFLAGS=0x00010206
Top of Stack: (sp=0x0012f424)
0x0012f424: 00386800 0733b758 009b9b71 00386914
0x0012f434: 0012f468 0038717c 00387180 0012f440
0x0012f444: 0733b758 0012f46c 0733b958 00000000
0x0012f454: 0733b758 00000000 0012f470 0012f498
0x0012f464: 009b2e4b 0733b8f8 009b8069 02af49a0
0x0012f474: 02af49a0 0012f478 0733a204 0012f49c
0x0012f484: 0733a408 00000000 0733a210 0012f470
0x0012f494: 0012f4a0 0012f4c8 009b2ecf 00000001
Instructions: (pc=0x0c651616)
0x0c651606: cc cc cc cc cc cc cc cc cc cc 83 ec 08 0f 57 c0
0x0c651616: 66 0f 13 04 24 ff 15 f4 60 65 0c 8b 54 24 04 83
Stack: [0x00030000,0x00130000], sp=0x0012f424, free space=1021k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
j com.ti.utility.filesystem.FSUtil.CreateFSUtil()Lcom/ti/utility/filesystem/SWIGTYPE_p_FSUtil;+4
j com.ti.debug.engine.xpcom.Runtime.getFSUtil()Lcom/ti/utility/filesystem/SWIGTYPE_p_FSUtil;+85
j com.ti.debug.engine.xpcom.Runtime.getAppDataDir()Ljava/lang/String;+0
j com.ti.uniflash.views.MainView.getRuntimeAppDir()Ljava/lang/String;+3
j com.ti.uniflash.views.MainView.getWorkspaceDir()Ljava/lang/String;+4
j com.ti.uniflash.rcp.Application.setupWorkspaceFolder()V+12
j com.ti.uniflash.rcp.Application.start(Lorg/eclipse/equinox/app/IApplicationContext;)Ljava/lang/Object;+5
j org.eclipse.equinox.internal.app.EclipseAppHandle.run(Ljava/lang/Object;)Ljava/lang/Object;+135
j org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(Ljava/lang/Object;)Ljava/lang/Object;+103
j org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ljava/lang/Object;)Ljava/lang/Object;+29
j org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/lang/Object;)Ljava/lang/Object;+149
j org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/lang/String;Ljava/lang/Runnable;)Ljava/lang/Object;+183
v ~StubRoutines::call_stub
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j com.ti.utility.filesystem.FSUtilJNI.CreateFSUtil()J+0
j sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+0
j sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+87
j sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+6
j java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+161
j org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lang/String;[Ljava/net/URL;)V+211
j org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/String;)V+126
j org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+4
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x0b54d800 JavaThread "[Timer] - Main Queue Handler" daemon [_thread_blocked, id=2344, stack(0x0c140000,0x0c240000)]
0x0b500400 JavaThread "Worker-JM" daemon [_thread_blocked, id=2336, stack(0x0bb30000,0x0bc30000)]
0x0b4c7800 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=2332, stack(0x0ba30000,0x0bb30000)]
0x0b476400 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=2328, stack(0x0b890000,0x0b990000)]
0x0b47f400 JavaThread "State Data Manager" daemon [_thread_blocked, id=2324, stack(0x0b790000,0x0b890000)]
0x0b478c00 JavaThread "Framework Active Thread" [_thread_blocked, id=2320, stack(0x0b690000,0x0b790000)]
0x0ab45000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=2312, stack(0x0b1b0000,0x0b2b0000)]
0x0ab3ec00 JavaThread "CompilerThread0" daemon [_thread_blocked, id=2308, stack(0x0b0b0000,0x0b1b0000)]
0x0ab3d400 JavaThread "Attach Listener" daemon [_thread_blocked, id=2304, stack(0x0afb0000,0x0b0b0000)]
0x0ab3c000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=2300, stack(0x0aeb0000,0x0afb0000)]
0x0ab2c400 JavaThread "Finalizer" daemon [_thread_blocked, id=2296, stack(0x0adb0000,0x0aeb0000)]
0x0ab27800 JavaThread "Reference Handler" daemon [_thread_blocked, id=2292, stack(0x0acb0000,0x0adb0000)]
=>0x00386800 JavaThread "main" [_thread_in_native, id=2284, stack(0x00030000,0x00130000)]
Other Threads:
0x0ab22800 VMThread [stack: 0x0abb0000,0x0acb0000] [id=2288]
0x0ab58c00 WatcherThread [stack: 0x0b2b0000,0x0b3b0000] [id=2316]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 960K, used 811K [0x02a30000, 0x02b30000, 0x02f10000)
eden space 896K, 89% used [0x02a30000, 0x02af7cd8, 0x02b10000)
from space 64K, 18% used [0x02b20000, 0x02b23030, 0x02b30000)
to space 64K, 0% used [0x02b10000, 0x02b10000, 0x02b20000)
tenured generation total 4096K, used 3899K [0x02f10000, 0x03310000, 0x06a30000)
the space 4096K, 95% used [0x02f10000, 0x032dec98, 0x032dee00, 0x03310000)
compacting perm gen total 12288K, used 9262K [0x06a30000, 0x07630000, 0x0aa30000)
the space 12288K, 75% used [0x06a30000, 0x0733b978, 0x0733ba00, 0x07630000)
No shared spaces configured.
Dynamic libraries:
0x00400000 - 0x0044e000 C:\Programmi\ti\uniflashv2\eclipse\uniflash.exe
0x7c910000 - 0x7c9c8000 C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c901000 C:\WINDOWS\system32\kernel32.dll
0x7e390000 - 0x7e421000 C:\WINDOWS\system32\USER32.dll
0x77e40000 - 0x77e89000 C:\WINDOWS\system32\GDI32.dll
0x773a0000 - 0x774a3000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.6028_x-ww_61e65202\COMCTL32.dll
0x77be0000 - 0x77c38000 C:\WINDOWS\system32\msvcrt.dll
0x77f40000 - 0x77feb000 C:\WINDOWS\system32\ADVAPI32.dll
0x77da0000 - 0x77e33000 C:\WINDOWS\system32\RPCRT4.dll
0x77f10000 - 0x77f21000 C:\WINDOWS\system32\Secur32.dll
0x77e90000 - 0x77f06000 C:\WINDOWS\system32\SHLWAPI.dll
0x76340000 - 0x7635d000 C:\WINDOWS\system32\IMM32.DLL
0x72000000 - 0x7200d000 C:\Programmi\ti\uniflashv2\eclipse\plugins\org.eclipse.equinox.launcher.win32.win32.x86_1.1.200.v20120522-1813\eclipse_1503.dll
0x77bd0000 - 0x77bd8000 C:\WINDOWS\system32\VERSION.dll
0x6d800000 - 0x6da56000 C:\Programmi\ti\uniflashv2\eclipse\jre\bin\client\jvm.dll
0x76b00000 - 0x76b2e000 C:\WINDOWS\system32\WINMM.dll
0x7c340000 - 0x7c396000 C:\Programmi\ti\uniflashv2\eclipse\jre\bin\MSVCR71.dll
0x6d290000 - 0x6d298000 C:\Programmi\ti\uniflashv2\eclipse\jre\bin\hpi.dll
0x76bb0000 - 0x76bbb000 C:\WINDOWS\system32\PSAPI.DLL
0x6d7b0000 - 0x6d7bc000 C:\Programmi\ti\uniflashv2\eclipse\jre\bin\verify.dll
0x6d330000 - 0x6d34f000 C:\Programmi\ti\uniflashv2\eclipse\jre\bin\java.dll
0x6d7f0000 - 0x6d7ff000 C:\Programmi\ti\uniflashv2\eclipse\jre\bin\zip.dll
0x68000000 - 0x68036000 C:\WINDOWS\system32\rsaenh.dll
0x76980000 - 0x76a35000 C:\WINDOWS\system32\USERENV.dll
0x5bc70000 - 0x5bcc5000 C:\WINDOWS\system32\netapi32.dll
0x6d610000 - 0x6d623000 C:\Programmi\ti\uniflashv2\eclipse\jre\bin\net.dll
0x71a30000 - 0x71a47000 C:\WINDOWS\system32\WS2_32.dll
0x71a20000 - 0x71a28000 C:\WINDOWS\system32\WS2HELP.dll
0x719d0000 - 0x71a10000 C:\WINDOWS\System32\mswsock.dll
0x76ee0000 - 0x76f07000 C:\WINDOWS\system32\DNSAPI.dll
0x76d20000 - 0x76d39000 C:\WINDOWS\system32\iphlpapi.dll
0x76f70000 - 0x76f78000 C:\WINDOWS\System32\winrnr.dll
0x76f20000 - 0x76f4d000 C:\WINDOWS\system32\WLDAP32.dll
0x76f80000 - 0x76f86000 C:\WINDOWS\system32\rasadhlp.dll
0x5b180000 - 0x5b1b8000 C:\WINDOWS\system32\uxtheme.dll
0x746b0000 - 0x746fc000 C:\WINDOWS\system32\MSCTF.dll
0x752e0000 - 0x7530e000 C:\WINDOWS\system32\msctfime.ime
0x774b0000 - 0x775ee000 C:\WINDOWS\system32\ole32.dll
0x6d630000 - 0x6d639000 C:\Programmi\ti\uniflashv2\eclipse\jre\bin\nio.dll
0x10000000 - 0x10008000 C:\Programmi\ti\uniflashv2\ccs_base\DebugServer\bin\LibraryLoader.dll
0x0c250000 - 0x0c2d5000 C:\WINDOWS\system32\MSVCP110.dll
0x0c2e0000 - 0x0c3b6000 C:\WINDOWS\system32\MSVCR110.dll
0x12000000 - 0x121f2000 C:\Programmi\ti\uniflashv2\ccs_base\common\bin\xerces-c_2_5_0.dll
0x78130000 - 0x781cb000 C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_44262b86\MSVCR80.dll
0x0c3e0000 - 0x0c40f000 C:\Programmi\ti\uniflashv2\ccs_base\common\bin\ti_logger.dll
0x0c420000 - 0x0c495000 C:\Programmi\ti\uniflashv2\ccs_base\common\bin\C4DLL.DLL
0x76360000 - 0x763aa000 C:\WINDOWS\system32\comdlg32.dll
0x7c9d0000 - 0x7d1ee000 C:\WINDOWS\system32\SHELL32.dll
0x0c5b0000 - 0x0c5c7000 C:\Programmi\ti\uniflashv2\ccs_base\common\bin\CCReg.dll
0x0c5e0000 - 0x0c638000 C:\Programmi\ti\uniflashv2\ccs_base\common\bin\fsutil.dll
0x0c650000 - 0x0c65e000 C:\Programmi\ti\uniflashv2\ccs_base\common\bin\fsutiljni.dll
0x0c670000 - 0x0c681000 C:\Programmi\ti\uniflashv2\ccs_base\common\bin\MiniDump.dll
0x0c6a0000 - 0x0c88a000 C:\Programmi\ti\uniflashv2\ccs_base\common\bin\setup_parser.dll
0x0c8a0000 - 0x0c8ad000 C:\Programmi\ti\uniflashv2\ccs_base\common\bin\ti_targetdb_parser.dll
0x78480000 - 0x7850e000 C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_31a54e43\MSVCP90.dll
0x78520000 - 0x785c3000 C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_31a54e43\MSVCR90.dll
VM Arguments:
jvm_args: -Dccs.debugServerDir=${RUNTIME_ROOT}
java_command: <unknown>
Launcher Type: generic
Environment Variables:
PATH=C:\Programmi\ti\uniflashv2\ccs_base\common\bin;C:\Programmi\ti\uniflashv2\ccs_base\common\uscif;C:\Programmi\ti\uniflashv2\ccs_base\DebugServer\license;C:/Programmi/ti/uniflashv2/eclipse/jre/bin/client;C:/Programmi/ti/uniflashv2/eclipse/jre/bin;C:/Programmi/ti/uniflashv2/eclipse/jre/lib/i386;C:\Xilinx\11.1\common\bin\nt;C:\Xilinx\11.1\ProgrammingTools\bin\nt;C:\Xilinx\11.1\ProgrammingTools\lib\nt;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Programmi\Metrowerks\CodeWarrior\DSP56800x_EABI_Tools\Command_Line_Tools\;C:\Programmi\ti\uniflashv2\eclipse;
USERNAME=User
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 6 Model 10 Stepping 0, AuthenticAMD
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 3
CPU:total 1 (1 cores per cpu, 1 threads per core) family 6 model 10 stepping 0, cmov, cx8, fxsr, mmx, sse, mmxext, 3dnow, 3dnowext
Memory: 4k page, physical 1048052k(733520k free), swap 1734800k(1498112k free)
vm_info: Java HotSpot(TM) Client VM (11.3-b02) for windows-x86 JRE (1.6.0_13-b03), built on Mar 9 2009 01:15:24 by "java_re" with MS VC++ 7.1
time: Fri May 17 17:22:29 2013
elapsed time: 2 seconds
