CCS 5 lost XDC tools
my CCS 5 lost its connection to the xdc tools. The XDCTools were working, and the XDC tools installation directory is existing and still in the search path, looking at Window/ Preferences.
When I open a project (OMAP L138/ ARM) usign DSP BIOS, I see that no  XDC tools are known. When I try to re-import the XDC tools, I get the message "No tools selected!".
Please see attached file for version information and screenshots.
Thanks for any help.
Alexander
xdctools_verloren (1).pdf
  • I also tried copying the XDC Tools directory from a colleague where the CCS + XDC work. No effect.
  • Hello Alexander,
    Have you tried using a new workspace? It should clear out the cache and force CCS to rediscover any components again.
    I also suggest updating your CCS installation if you can.
    ki
  • Hallo Ki,
    I created a new workspace with a single ARM project. XDCTools is still unknown.
    Updating the toolchain is not an option for me, since I work together with several colleagues and we need to have exactly the same. Is there a single suggested update to the eclipse environment that should solve the problem?
    Strangest thing to me is that the manual import of the tools does not work. What exactly does CCS search for? Which system variables are needed?
    Alexander
  • Sorry for the late response.
    I got some feedback for one of the CCS developers. This can happen if for some reason some of the eclipse directories in CCSv5 become read-only or if files get modified/corrupted inside the .\ccsv5\eclipse/configuration directory. Later versions of CCSv5 guard against such issues better. We would normally recommend an upgrade but since you would like to stick to the existing version, you can try a reinstall of CCS
    ki
