C66 preferring slow MPYSP2DP to fast SPDP/FMPYDP
I believe the C66 compiler 7.4.2 is making some bad choices wrt MPYSPDP and MPYSP2DP.  This might be a carry over from the odd way the C67 compiler handles:
float x, y;
double z0 = x * y; // uses MPYSP and SPDP
double z1 = (double) x * y; // uses MPYSP2DP
Here's a stripped down example to demonstrate-- it could probably be stripped down more.
#pragma FUNC_INTERRUPT_THRESHOLD(-1)
inline float DF2TFilter(double in, double b0, double b1, double b2, double a1, double a2,
  double w0, double w1,
  double& restrict w0out, double& restrict w1out)
  double result = b0 * in + w1;
  double acc1 = b1 * in;
  acc1 += w0;
  acc1 -= a1 * result;
  w1out = acc1;
  double acc0 = b2 * in;
  acc0 -= a2 * result;
  w0out = acc0;
  return result;
int f(float* restrict outputs,
  const float* restrict inputs,
  const float* restrict coeffs,
  double* restrict states,
  int num)
  const double* restrict inStates = states;
  double* restrict outStates = states;
  std::_nassert(num > 0);
  std::_nassert((intptr_t(coeffs) % 8) == 0);
  std::_nassert((intptr_t(inputs) % 8) == 0);
  std::_nassert((intptr_t(outputs) % 8) == 0);
  for (int i = 0; i < num; ++i)
    const float* restrict c = &coeffs[6 * i];
    double b0 = c[0];
    double b1 = c[1];
    double b2 = c[2];
    double a1 = c[3];
    double a2 = c[4];
    double in = inputs[i];
    const double* restrict s = &inStates[2 * i];
    double w0 = s[0];
    double w1 = s[1];
    double ow0, ow1;
    outputs[i] = DF2TFilter(in, b0, b1, b2, a1, a2, w0, w1, ow0, ow1);
    outStates[2 * i + 0] = ow0;
    outStates[2 * i + 1] = ow1;
;*   SOFTWARE PIPELINE INFORMATION
;*      Loop found in file               : ../main.cpp
;*      Loop source line                 : 42
;*      Loop opening brace source line   : 43
;*      Loop closing brace source line   : 58
;*      Known Minimum Trip Count         : 16
;*      Known Maximum Trip Count         : 16
;*      Known Max Trip Count Factor      : 16
;*      Loop Carried Dependency Bound(^) : 5
;*      Unpartitioned Resource Bound     : 10
;*      Partitioned Resource Bound(*)    : 12
;*      Resource Partition:
;*                                A-side   B-side
;*      .L units                     1        0
;*      .S units                     2        2
;*      .D units                     5        4
;*      .M units                     6        4
;*      .X cross paths               4        3
;*      .T address paths             6        5
;*      Long read paths              0        0
;*      Long write paths             0        0
;*      Logical  ops (.LS)           3        3     (.L or .S unit)
;*      Addition ops (.LSD)          1        0     (.L or .S or .D unit)
;*      Bound(.L .S .LS)             3        3
;*      Bound(.L .S .D .LS .LSD)     4        3
;*      Searching for software pipeline schedule at ...
;*         ii = 12 Schedule found with 3 iterations in parallel
;*      Register Usage Table:
;*          |AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA|BBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBB|
;*          |00000000001111111111222222222233|00000000001111111111222222222233|
;*          |01234567890123456789012345678901|01234567890123456789012345678901|
;*       0: |    ** ***      **  ***         |    * ****      *               |
;*       1: |    **  **      **  ***         |    * ****      **              |
;*       2: |     *  **      *******         |      ****      * ****          |
;*       3: |   * *  **      *******         |      ****      * ****          |
;*       4: |     *  **      *******         |      ****      * ****          |
;*       5: |   *    **      *******         |      ****      * ****          |
;*       6: |      ****      *******         |      ****      *   **          |
;*       7: |   *****        *******         |    ******      *   **          |
;*       8: |   *****        *******         |      ****      *               |
;*       9: |    **          **  ***         |      ****      *               |
;*      10: |        **      **  ***         |    ******      *   **          |
;*      11: |    ******      **  ***         |      ****      * ****          |
;*      Done
;*      Loop will be splooped
;*      Collapsed epilog stages       : 0
;*      Collapsed prolog stages       : 0
;*      Minimum required memory pad   : 0 bytes
;*      Minimum safe trip count       : 1
;*      Min. prof. trip count  (est.) : 3
;*      Mem bank conflicts/iter(est.) : { min 0.000, est 0.000, max 0.000 }
;*      Mem bank perf. penalty (est.) : 0.0%
;*      Total cycles (est.)         : 24 + min_trip_cnt * 12 = 216
;*       SETUP CODE
;*                  MV              B9,A17
;*                  ADD             8,A17,A17
;*                  MV              A21,B7
;*                  ADDK            36,B7
;*                  MV              A21,A16
;*                  ADDK            28,A16
;*                  ADDK            24,A21
;*                  MV              A20,B6
;*                  ADD             8,A20,A20
;*        SINGLE SCHEDULED ITERATION
;*        $C$C57:
;*   0              LDW     .D1T1   *A21++(24),A3     ; |16|
;*   1              LDW     .D2T2   *B8++,B16         ; |55|
;*   2              NOP             3
;*   5              SPDP    .S1     A3,A5:A4          ; |16|
;*   6              MV      .D1X    B16,A3            ; |55| Define a twin register
;*   7              MPYSPDP .M1     A3,A5:A4,A19:A18  ; |16|
;*   8              LDNDW   .D1T2   *A16++(24),B17:B16 ; |56|
;*   9              NOP             3
;*  12              SPDP    .S2     B16,B19:B18       ; |55|
;*  13              DADD    .L1X    0,B17:B16,A5:A4   ; |56| Define a twin register
;*  14              LDDW    .D1T1   *A20++(16),A7:A6  ; |16|
;*  15              MPYSPDP .M1X    A5,B19:B18,A9:A8  ; |56|
;*  16              MPYSPDP .M2     B16,B19:B18,B19:B18 ; |57|
;*  17              LDDW    .D2T2   *B6++(16),B21:B20 ; |57|
;*  18              LDNDW   .D2T1   *B7++(24),A7:A6   ; |56|
;*  19              NOP             1
;*  20              FADDDP  .L1     A7:A6,A19:A18,A5:A4 ; |16|
;*  21              NOP             2
;*  23              DPSP    .L1     A5:A4,A3          ; |55|
;*     ||           DADD    .S2X    0,A7:A6,B5:B4     ; |56| Define a twin register
;*     ||           MPYSPDP .M1     A7,A5:A4,A7:A6    ; |56|
;*     ||           FADDDP  .L2     B21:B20,B19:B18,B21:B20 ; |57|
;*  24              MPYSPDP .M2X    B4,A5:A4,B5:B4    ; |57|
;*  25              NOP             2
;*  27              STW     .D1T1   A3,*A22++         ; |55|
;*  28              NOP             2
;*  30              FSUBDP  .L1     A9:A8,A7:A6,A5:A4 ; |56|
;*  31              FSUBDP  .L2     B21:B20,B5:B4,B5:B4 ; |57|
;*  32              NOP             1
;*  33              STDW    .D2T1   A5:A4,*B9++(16)   ; |56|
;*  34              STDW    .D1T2   B5:B4,*A17++(16)  ; |57|
;*     ||           SPBR            $C$C57
;*  35              NOP             1
;*  36              ; BRANCHCC OCCURS {$C$C57}        ; |42|
As you see, even though the arguments to DF2TFilter are double, the compiler is treating them as single.  Even the superfluous double b0 = c[0];... doesn't help.  This is yielding an ii of 12.
Here's some linear assembly which uses SPDP and fast DP operations and gets an ii of 6.
        .global fasm
fasm .cproc  outputs, inputs, coeffs, states, num
        .no_mdep
        .reg thisCoeff, thisState, outputState
        .reg input, output
        .reg coeffB0L, coeffB0H, coeffB1L, coeffB1H
        .reg coeffB2L, coeffB2H
        .reg coeffA1L, coeffA1H, coeffA2L, coeffA2H
        .reg inH, inL
        .reg coeffA1f, coeffA2f
        .reg coeffB0f, coeffB1f
        .reg coeffB2f, ignore
        .reg w0L, w0H
        .reg w1L, w1H
        .reg filterOutput
        .reg temp0L, temp0H, temp1L, temp1H
        .reg resultL, resultH
        .reg inStates
        MV            states, inStates
inner:    .trip        1
        LDDW        *coeffs++, coeffA2f:coeffA1f
        LDDW        *coeffs++, coeffB1f:coeffB0f
        LDDW        *coeffs++, ignore:coeffB2f
        SPDP        coeffA1f, coeffA1H:coeffA1L
        SPDP        coeffA2f, coeffA2H:coeffA2L
        SPDP        coeffB0f, coeffB0H:coeffB0L
        SPDP        coeffB1f, coeffB1H:coeffB1L
        SPDP        coeffB2f, coeffB2H:coeffB2L
        LDW            *inputs++, input
        SPDP        input, inH:inL
        LDDW        *inStates++, w0H:w0L
        LDDW        *inStates++, w1H:w1L
        MV            thisState, outputState
        FMPYDP        coeffB0H:coeffB0L, inH:inL, resultH:resultL
        FADDDP        resultH:resultL, w1H:w1L, resultH:resultL
        FMPYDP        coeffB1H:coeffB1L, inH:inL, w1H:w1L
        FADDDP        w1H:w1L, w0H:w0L, w1H:w1L
        FMPYDP        coeffA1H:coeffA1L, resultH:resultL, temp1H:temp1L
        FSUBDP        w1H:w1L, temp1H:temp1L, w1H:w1L
        FMPYDP        coeffB2H:coeffB2L, inH:inL, w0H:w0L
        FMPYDP        coeffA2H:coeffA2L, resultH:resultL, temp0H:temp0L
        FSUBDP        w0H:w0L, temp0H:temp0L, w0H:w0L
        DPSP        resultH:resultL, filterOutput
        STDW        w0H:w0L, *states++
        STDW        w1H:w1L, *states++
        STW            filterOutput, *outputs++
        SUB            num, 1, num
[num]    B            inner
        .endproc
;*      Loop found in file               : ../test.sa
;*      Loop source line                 : 27
;*      Loop closing brace source line   : 60
;*      Unpartitioned Resource Bound     : 6
;*      Partitioned Resource Bound(*)    : 6
;*                                A-side   B-side
;*      .L units                     0        1
;*      .S units                     6*       6*
;*      .D units                     6*       3
;*      .M units                     4        1
;*      .X cross paths               5        2
;*      .T address paths             6*       3
;*      Logical  ops (.LS)           4        1     (.L or .S unit)
;*      Addition ops (.LSD)          0        0     (.L or .S or .D unit)
;*      Bound(.L .S .LS)             5        4
;*      Bound(.L .S .D .LS .LSD)     6*       4
;*         ii = 6  Schedule found with 5 iterations in parallel
;*       0: |   *******      ******* **  *** |    ***           **** **       |
;*       1: |   *******        **  ****  *** |      *         **  ** **       |
;*       2: |   **** **        ********  *** |    **          **  ** **       |
;*       3: |   *******        ********  *** |    **  **          ** **       |
;*       4: |   *******      *************** |    * ****          **  *       |
;*       5: |   *  ****        ****  **  *** |      *           *******       |
;*      Done
;*      Total cycles (est.)         : 24 + trip_cnt * 6
;*       SETUP CODE
;*                  MV              A30,A25
;*                  ADD             8,A25,A25
;*                  MV              A28,A24
;*                  ADD             8,A24,A24
;*                  MV              B20,A3
;*                  ADDK            16,A3
;*                  MV              B20,B21
;*                  ADD             8,B21,B21
;*        $C$C26:
;*   0              LDDW    .D2T2   *B21++(24),B23:B22 ; |28|
;*   1              LDW     .D1T1   *A29++,A22        ; |36|
;*   2              NOP             1
;*   3              LDDW    .D1T1   *A3++(24),A7:A6   ; |29|
;*   4              NOP             1
;*   5              LDDW    .D2T2   *B20++(24),B7:B6  ; |27|
;*     ||           SPDP    .S2     B22,B17:B16       ; |32|
;*     ||           LDDW    .D1T1   *A25++(16),A9:A8  ; |40|
;*   6              SPDP    .S1     A22,A21:A20       ; |37|  ^
;*   7              NOP             1
;*   8              SPDP    .S1     A6,A17:A16        ; |34|
;*     ||           LDDW    .D1T1   *A30++(16),A23:A22 ; |39|
;*     ||           FMPYDP  .M1X    B17:B16,A21:A20,A17:A16 ; |43|  ^
;*   9              SPDP    .S2     B23,B19:B18       ; |33|
;*  10              SPDP    .S1X    B7,A5:A4          ; |31|
;*     ||           FMPYDP  .M1     A17:A16,A21:A20,A19:A18 ; |49|  ^
;*  11              NOP             1
;*  12              FADDDP  .L1     A17:A16,A9:A8,A7:A6 ; |44|  ^
;*     ||           FMPYDP  .M1X    B19:B18,A21:A20,A5:A4 ; |45|
;*  13              SPDP    .S2     B6,B9:B8          ; |30|
;*  14              NOP             1
;*  15              FMPYDP  .M1     A5:A4,A7:A6,A7:A6 ; |50|  ^
;*  16              FADDDP  .L1     A5:A4,A23:A22,A9:A8 ; |46|
;*     ||           FMPYDP  .M2X    B9:B8,A7:A6,B5:B4 ; |47|
;*  17              DADD    .L2X    0,A7:A6,B5:B4     ; |44| Define a twin register
;*  18              DPSP    .L2     B5:B4,B4          ; |52|
;*  19              FSUBDP  .L1     A19:A18,A7:A6,A27:A26 ; |51|  ^
;*  20              NOP             1
;*  21              FSUBDP  .L1X    A9:A8,B5:B4,A7:A6 ; |48|
;*  22              STDW    .D1T1   A27:A26,*A28++(16) ; |54|
;*     ||           STW     .D2T2   B4,*B24++         ; |57|
;*  23              NOP             1
;*  24              STDW    .D1T1   A7:A6,*A24++(16)  ; |55|
;*     ||           SPBR            $C$C26
;*  25              NOP             5
;*  30              ; BRANCHCC OCCURS {$C$C26}        ; |60|
I'm not sure if there are ever cases where MPYSP2DP/MPYSPDP are a win on the C66, but I've seen one where it was a tie.
  • Thank you for bringing this to our attention, and for a good test case.  I can use it to reproduce your results.  I filed SDSCM00047299 in the SDOWP system to have this performance issue addressed.  Feel free to follow it with the SDOWP link below in my signature.
    Thanks and regards,
    -George
