I had a problem in matlab while building a project in CCS v3.1 that enables RTDX, i couldn't figure out the issue.
i use CCSv3.1, my target is C6713.
Haddadi,
I’m not familiar with MATLAB + RTDX so have sent out some queries to try to find someone that can help.
That said, the errors imply that the problem can be resolved by closing all instances of CCS and retrying. Did you try that? Also, did you try rebooting in case some CCS components were still running in the background, causing the error?
Scott
Hadaddi,
You are using some older TI software products and neither RTDX nor Matlab integration are really supported any longer. However, it appears that you may be experiencing some kind of generic CCS issue and so I have moved this thread over to the CCS forum in hopes that you might get some further advice there.
Haddadi,
The first error indicates that you need to close CCS before running your simulink script. Please shut down all instances of cc_app.exe.
The other errors that follow could be related to the first so try resolving that one first
ki
