CCSv5.3 I can't build a .out file
C28xx: GEL: Encountered a problem loading file: C:\Users\Mariana\workspace_v5_3\Secante\Debug\Secante.out Could not open file
**** Build of configuration Debug for project Secante ****
"C:\\ti\\ccsv5\\utils\\bin\\gmake" -k all
'Building file: ../Secante.c'
'Invoking: C2000 Compiler'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --preinclude="libc.a" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programação/Comuns/Headers" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="Secante.pp" "../Secante.c"
Fatal error #5: could not open source file "libc.a"
1 fatal error detected in the compilation of "../Secante.c".
Compilation terminated.
>> Compilation failure
gmake: *** [Secante.obj] Error 1
'Building file: ../Sources/DSP2802x_Adc.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --preinclude="libc.a" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programação/Comuns/Headers" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="Sources/DSP2802x_Adc.pp" "../Sources/DSP2802x_Adc.c"
1 fatal error detected in the compilation of "../Sources/DSP2802x_Adc.c".
>> Compilation failure
gmake: *** [DSP2802x_Adc.obj] Error 1
'Building file: ../Sources/DSP2802x_CpuTimers.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --preinclude="libc.a" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programação/Comuns/Headers" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="Sources/DSP2802x_CpuTimers.pp" "../Sources/DSP2802x_CpuTimers.c"
1 fatal error detected in the compilation of "../Sources/DSP2802x_CpuTimers.c".
>> Compilation failure
gmake: *** [DSP2802x_CpuTimers.obj] Error 1
'Building file: ../Sources/DSP2802x_DefaultIsr.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --preinclude="libc.a" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programação/Comuns/Headers" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="Sources/DSP2802x_DefaultIsr.pp" "../Sources/DSP2802x_DefaultIsr.c"
1 fatal error detected in the compilation of "../Sources/DSP2802x_DefaultIsr.c".
>> Compilation failure
gmake: *** [DSP2802x_DefaultIsr.obj] Error 1
'Building file: ../Sources/DSP2802x_EPwm.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --preinclude="libc.a" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programação/Comuns/Headers" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="Sources/DSP2802x_EPwm.pp" "../Sources/DSP2802x_EPwm.c"
1 fatal error detected in the compilation of "../Sources/DSP2802x_EPwm.c".
>> Compilation failure
gmake: *** [DSP2802x_EPwm.obj] Error 1
'Building file: ../Sources/DSP2802x_GlobalVariableDefs.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --preinclude="libc.a" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programação/Comuns/Headers" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="Sources/DSP2802x_GlobalVariableDefs.pp" "../Sources/DSP2802x_GlobalVariableDefs.c"
1 fatal error detected in the compilation of "../Sources/DSP2802x_GlobalVariableDefs.c".
>> Compilation failure
gmake: *** [DSP2802x_GlobalVariableDefs.obj] Error 1
'Building file: ../Sources/DSP2802x_Gpio.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --preinclude="libc.a" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programação/Comuns/Headers" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="Sources/DSP2802x_Gpio.pp" "../Sources/DSP2802x_Gpio.c"
1 fatal error detected in the compilation of "../Sources/DSP2802x_Gpio.c".
>> Compilation failure
gmake: *** [DSP2802x_Gpio.obj] Error 1
'Building file: ../Sources/DSP2802x_I2C.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --preinclude="libc.a" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programação/Comuns/Headers" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="Sources/DSP2802x_I2C.pp" "../Sources/DSP2802x_I2C.c"
1 fatal error detected in the compilation of "../Sources/DSP2802x_I2C.c".
>> Compilation failure
gmake: *** [DSP2802x_I2C.obj] Error 1
'Building file: ../Sources/DSP2802x_MemCopy.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --preinclude="libc.a" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programação/Comuns/Headers" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="Sources/DSP2802x_MemCopy.pp" "../Sources/DSP2802x_MemCopy.c"
1 fatal error detected in the compilation of "../Sources/DSP2802x_MemCopy.c".
>> Compilation failure
gmake: *** [DSP2802x_MemCopy.obj] Error 1
'Building file: ../Sources/DSP2802x_PieCtrl.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --preinclude="libc.a" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programação/Comuns/Headers" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="Sources/DSP2802x_PieCtrl.pp" "../Sources/DSP2802x_PieCtrl.c"
1 fatal error detected in the compilation of "../Sources/DSP2802x_PieCtrl.c".
>> Compilation failure
gmake: *** [DSP2802x_PieCtrl.obj] Error 1
'Building file: ../Sources/DSP2802x_PieVect.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --preinclude="libc.a" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programação/Comuns/Headers" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="Sources/DSP2802x_PieVect.pp" "../Sources/DSP2802x_PieVect.c"
1 fatal error detected in the compilation of "../Sources/DSP2802x_PieVect.c".
>> Compilation failure
gmake: *** [DSP2802x_PieVect.obj] Error 1
'Building file: ../Sources/DSP2802x_SysCtrl.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --preinclude="libc.a" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programação/Comuns/Headers" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="Sources/DSP2802x_SysCtrl.pp" "../Sources/DSP2802x_SysCtrl.c"
1 fatal error detected in the compilation of "../Sources/DSP2802x_SysCtrl.c".
>> Compilation failure
gmake: *** [DSP2802x_SysCtrl.obj] Error 1
gmake: Target `all' not remade because of errors.
**** Build Finished ****
How can I solve this problem?
Thanks!
  • Hi Mariana,
    I am wondering whether this might be due to one of two issues:
    - permissions (you will notice the file access problem
    - the user accout/file path with special characters
    Please double check both of these and keep us informed.  I understand moving things/using a different account may not be easy but might be necessary.
    Lisa
    I suspect you have added libc.a to the --preinclude compiler option in error. The --preinclude option is used to include the source code of a file at the beginning of compilation typically used to establish macro definitions. Please see the C2000 Compiler Users Guide for details.
    lib.c, on the other hand, is an index library used to find and link in an appropriate runtime library. So I don't see how it can be used with the preinclude option. If you remove that file from the preinclude option (under Proejct Properties->Build->Compiler->Include Options) you should be able to get past this error.
  • I removed libc.a from preinclude options, and didn't solve the problem yet.
    Look this
    **** Build of configuration Debug for project Bisection ****
    'Building file: ../Bisection.c'
    "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --optimize_with_debug=on --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programacao/Comuns/Headers" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="Bisection.pp" "../Bisection.c"
    'Finished building: ../Bisection.c'
    'Building file: ../main.c'
    "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --optimize_with_debug=on --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programacao/Comuns/Headers" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="main.pp" "../main.c"
    'Finished building: ../main.c'
    "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --optimize_with_debug=on --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programacao/Comuns/Headers" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="Sources/DSP2802x_Adc.pp" --obj_directory="Sources" "../Sources/DSP2802x_Adc.c"
    'Finished building: ../Sources/DSP2802x_Adc.c'
    'Building file: ../Sources/DSP2802x_CodeStartBranch.asm'
    "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --optimize_with_debug=on --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programacao/Comuns/Headers" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="Sources/DSP2802x_CodeStartBranch.pp" --obj_directory="Sources" "../Sources/DSP2802x_CodeStartBranch.asm"
    'Finished building: ../Sources/DSP2802x_CodeStartBranch.asm'
    "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --optimize_with_debug=on --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programacao/Comuns/Headers" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="Sources/DSP2802x_CpuTimers.pp" --obj_directory="Sources" "../Sources/DSP2802x_CpuTimers.c"
    'Finished building: ../Sources/DSP2802x_CpuTimers.c'
    "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --optimize_with_debug=on --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programacao/Comuns/Headers" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="Sources/DSP2802x_DefaultIsr.pp" --obj_directory="Sources" "../Sources/DSP2802x_DefaultIsr.c"
    'Finished building: ../Sources/DSP2802x_DefaultIsr.c'
    "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --optimize_with_debug=on --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programacao/Comuns/Headers" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="Sources/DSP2802x_EPwm.pp" --obj_directory="Sources" "../Sources/DSP2802x_EPwm.c"
    'Finished building: ../Sources/DSP2802x_EPwm.c'
    "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --optimize_with_debug=on --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programacao/Comuns/Headers" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="Sources/DSP2802x_GlobalVariableDefs.pp" --obj_directory="Sources" "../Sources/DSP2802x_GlobalVariableDefs.c"
    'Finished building: ../Sources/DSP2802x_GlobalVariableDefs.c'
    "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --optimize_with_debug=on --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programacao/Comuns/Headers" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="Sources/DSP2802x_Gpio.pp" --obj_directory="Sources" "../Sources/DSP2802x_Gpio.c"
    'Finished building: ../Sources/DSP2802x_Gpio.c'
    "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --optimize_with_debug=on --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programacao/Comuns/Headers" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="Sources/DSP2802x_I2C.pp" --obj_directory="Sources" "../Sources/DSP2802x_I2C.c"
    'Finished building: ../Sources/DSP2802x_I2C.c'
    "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --optimize_with_debug=on --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programacao/Comuns/Headers" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="Sources/DSP2802x_MemCopy.pp" --obj_directory="Sources" "../Sources/DSP2802x_MemCopy.c"
    'Finished building: ../Sources/DSP2802x_MemCopy.c'
    "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --optimize_with_debug=on --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programacao/Comuns/Headers" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="Sources/DSP2802x_PieCtrl.pp" --obj_directory="Sources" "../Sources/DSP2802x_PieCtrl.c"
    'Finished building: ../Sources/DSP2802x_PieCtrl.c'
    "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --optimize_with_debug=on --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programacao/Comuns/Headers" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="Sources/DSP2802x_PieVect.pp" --obj_directory="Sources" "../Sources/DSP2802x_PieVect.c"
    'Finished building: ../Sources/DSP2802x_PieVect.c'
    "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --optimize_with_debug=on --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programacao/Comuns/Headers" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="Sources/DSP2802x_SysCtrl.pp" --obj_directory="Sources" "../Sources/DSP2802x_SysCtrl.c"
    'Finished building: ../Sources/DSP2802x_SysCtrl.c'
    'Building file: ../Sources/DSP2802x_usDelay.asm'
    "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --optimize_with_debug=on --include_path="C:/Users/Mariana/Documents/UTFPR/IC/Config programacao/Comuns/Headers" --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="Sources/DSP2802x_usDelay.pp" --obj_directory="Sources" "../Sources/DSP2802x_usDelay.asm"
    'Finished building: ../Sources/DSP2802x_usDelay.asm'
    'Building target: Bisection.out'
    'Invoking: C2000 Linker'
    "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -mt -g --optimize_with_debug=on --diag_warning=225 --display_error_number -z --stack_size=0x300 -m"Bisection.map" -i"C:/ti/ccsv5/tools/compiler/c2000_6.1.0/lib" -i"C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --reread_libs --display_error_number --rom_model -o "Bisection.out" "./Sources/DSP2802x_usDelay.obj" "./Sources/DSP2802x_SysCtrl.obj" "./Sources/DSP2802x_PieVect.obj" "./Sources/DSP2802x_PieCtrl.obj" "./Sources/DSP2802x_MemCopy.obj" "./Sources/DSP2802x_I2C.obj" "./Sources/DSP2802x_Gpio.obj" "./Sources/DSP2802x_GlobalVariableDefs.obj" "./Sources/DSP2802x_EPwm.obj" "./Sources/DSP2802x_DefaultIsr.obj" "./Sources/DSP2802x_CpuTimers.obj" "./Sources/DSP2802x_CodeStartBranch.obj" "./Sources/DSP2802x_Adc.obj" "./main.obj" "./Bisection.obj" -llibc.a -l"rts2800_ml.lib" "../DSP2802x_Headers_nonBIOS.cmd" "../F28027_Flash_Casaro.cmd"
    <Linking>
    error #10056: symbol "_main" redefined: first defined in "./main.obj";
    redefined in "./Bisection.obj"
    >> Compilation failure
    error #10010: errors encountered during linking; "Bisection.out" not built
    gmake: *** [Bisection.out] Error 1
  • Hi Mariana,
    have you double checked you do not have two main functions?
    Lisa
  • Hi Lisa, I checked and I have only one main function. I dont need two main functions for my program!
    Mariana
  • Hi Mariana
    we strongly suspect you have two mains.  Check the bisection file/code ... I suspect there is one there, perhaps from an example.
    Lisa
  • Hi Lisa, your suspect was right, i had two main functions!
    Thanks a lot
    Best Regards
    Mariana
  • Hi Mariana,
    great, very happy to hear you were able to find the second main causing the issues.  All the best with development.
    Lisa
