Licensing CCS for TMDXDOCK28M36
I purchased the TMDXDOCK28M36 H63C2 Concerto Experimenter Kit and I got it today.
http://www.ti.com/tool/tmdxdock28m36
I cannot found Code Composer StudioTM IDE v5 in my package so I downloaded it from:
http://processors.wiki.ti.com/index.php/Download_CCS
When installation finished:
I wanna ask. where could I retrieve an activation code for this? my order number is 246398.
Or Did I do something wrong? Please let me know what should I do next.
  • Hello!
    For all I know TI provides three variants of CCS:
    1 Free 90-day variant without code size limited.
    2 Free variant with code size limited and without time limit.
    3 Purchase variant without code & time limit (at this case you get the activation code).
    Igor
    as Igor posted you will need to
    - try ccs on the demo license
    - purchase a license
    However, I believe with your kit, you have an onboard ez emulator/xds100 in which case you can choose the free limited license (limitation in this case being the hardware not ccs capability.  this license is for the xds100 and a few onboard emulators)
    Activation codes are normally only for a purchased ccs license.
    Does this help clarify?
    Lisa
  • Thank you all for your reply,
    As I found little information about the kit after I actually purchased.
    I will keep everyone in the loop if I found any update on it.
    Even i have the same kit with me with very similar problem, but i have already used both the 30 days free trial and 90 days license and it has expired. Now I am not able to run any program in my ccs. I have a project to be submitted.
    Kindly help me.
    Sudharsan
  • Hi Sudharsan,
    first just to let you know it is much better to  start a new thread as otherwise things can get lost.
    Have you tried using the "free limited license"?   If you go to Help->Code Composer Studio Licensing information, the upgrad tab should have the "launch license setup" button.
    Remove the demo license(s) and give that a try selecting "free limited license".  The limitation being the hardware allowed.
    Lisa
