CCS 5.4.0.00091 on Ubuntu 10.04 VM.
After a recent crash and a restart, I find I cant close CCS and instead get the error in the error log:
Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
Associated exception stack trace is:
java.lang.NoSuchFieldError: activeTA
at com.ti.dvt.trace.TracePlugin.closeAllTraceSolutions(TracePlugin.java:845)
at com.ti.dvt.trace.TracePlugin.preShutdown(TracePlugin.java:1272)
at org.eclipse.ui.internal.Workbench$10.run(Workbench.java:912)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.ui.internal.Workbench.firePreShutdown(Workbench.java:910)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1050)
at org.eclipse.ui.internal.Workbench.access$15(Workbench.java:1040)
at org.eclipse.ui.internal.Workbench$25.run(Workbench.java:1284)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1282)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1254)
at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchWindow.java:727)
at org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWindow.java:715)
at org.eclipse.ui.internal.WorkbenchWindow$6.run(WorkbenchWindow.java:867)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:865)
at org.eclipse.jface.window.Window.handleShellCloseEvent(Window.java:741)
at org.eclipse.jface.window.Window$3.shellClosed(Window.java:687)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:98)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1276)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1300)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1285)
at org.eclipse.swt.widgets.Shell.closeWidget(Shell.java:617)
at org.eclipse.swt.widgets.Shell.gtk_delete_event(Shell.java:1191)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1750)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:5116)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4369)
at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:8307)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:1192)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Native Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS.java:2332)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3177)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
and session data:
eclipse.buildId=M20120914-1540
java.version=1.6.0_13
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Framework arguments: -product com.ti.ccstudio.branding.product
Command-line arguments: -os linux -ws gtk -arch x86 -product com.ti.ccstudio.branding.product
Whats the solution to this?
