Other Parts Discussed in Thread: CONTROLSUITE
I decided to see why my PWM wasn't working by backtracking to the PWM example project for the F28069.
I am using CCS v5.4.0.00091 on Windows 7 - 64-bit, and my compiler is v6.1.4.
When I import the project, I receive the following error:
Unrecognized product of type 'com.ti.rtsc.XDAIS' is required of project 'Example_2806xEPwmTimerInt' - please install at least one product of this type before building this project.
What does this mean, and what am I to do?
If I continue, the project builds fine, but when I run it on my TI eval board (Docking-stn USB-EMU [R3]) with a TI F28069 controlCARD Release 1.1), I see no PWM activity.
I tried it on our own hardware, with the same negative result.
Should it have worked? What can I do to make it work?
Looking at the forums, I saw some entries about XDAIS (which we don't need), that suggested running the "Check For Updates" function. When I do that, I get:
Some sites could not be found. See the error log for more detail.
No repository found at file:/C:/Users/km6xu/AppData/Local/Temp/ijtmp_6B5DB922-B91C-45C9-8E61-8B6181ECDD0D/dvtRepo.
No repository found at file:/C:/Users/km6xu/AppData/Local/Temp/ijtmp_6B5DB922-B91C-45C9-8E61-8B6181ECDD0D/gmfRepo.
Might this be part of the problem? If so, how is it resolved?
Thanks -- Mark
