In CCS v5.2.1 I'm unable to export an example project and import it and build that code. Here are my steps:
1) Import Existing CCS Eclipse Projects > browse to find C:\ti\pdk_C6678_1_1_2_6\packages\ti\drv\exampleProjects\PA_emacExample_exampleProject , leave Copy projects into workspace unchecked, > Finish
2) Clean, build, see that build is successful. Console output below:
**** Clean-only build of configuration Debug for project PA_emacExample_exampleProject ****
C:\ti\ccsv5\utils\bin\gmake -k clean
DEL /F "configPkg\compiler.opt" "configPkg\linker.cmd" "PA_emacExample_exampleProject.out"
The system cannot find the file specified.
gmake: [clean] Error 1 (ignored)
RMDIR /S/Q "configPkg\"
gmake: [clean] Error 2 (ignored)
DEL /F "classify1_bin.pp" "classify2_bin.pp" "cppi_device.pp" "cppi_qmss_mgmt.pp" "cpsw_mgmt.pp" "cpsw_singlecore.pp" "pa_mgmt.pp" "pam_bin.pp" "qmss_device.pp" "singlecore_osal.pp" "view_ale_table.pp"
Could Not Find C:\ti\pdk_C6678_1_1_2_6\packages\ti\drv\exampleProjects\PA_emacExample_exampleProject\Debug\classify1_bin.pp
DEL /F "classify1_bin.obj" "classify2_bin.obj" "cppi_device.obj" "cppi_qmss_mgmt.obj" "cpsw_mgmt.obj" "cpsw_singlecore.obj" "pa_mgmt.obj" "pam_bin.obj" "qmss_device.obj" "singlecore_osal.obj" "view_ale_table.obj"
Could Not Find C:\ti\pdk_C6678_1_1_2_6\packages\ti\drv\exampleProjects\PA_emacExample_exampleProject\Debug\classify1_bin.obj
'Finished clean'
**** Build Finished ****
**** Build of configuration Debug for project PA_emacExample_exampleProject ****
C:\ti\ccsv5\utils\bin\gmake -k all
'Building file: C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample/cpsw_example.cfg'
'Invoking: XDCtools'
"C:/ti/xdctools_3_24_06_63/xs" --xdcpath="C:/ti/edma3_lld_02_11_05_02/packages;C:/ti/ipc_1_24_03_32/packages;C:/ti/bios_6_33_06_50/packages;C:/ti/pdk_C6678_1_1_2_6/packages;C:/ti/ccsv5/ccs_base;" xdc.tools.configuro -o configPkg -t ti.targets.elf.C66 -p ti.sdo.ipc.examples.platforms.evm6678.core0 -r debug -c "C:/ti/ccsv5/tools/compiler/c6000_7.4.2" "C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample/cpsw_example.cfg"
making package.mak (because of package.bld) ...
generating interfaces for package configPkg (because package/package.xdc.inc is older than package.xdc) ...
configuring cpsw_example.xe66 from package/cfg/cpsw_example_pe66.cfg ...
cle66 package/cfg/cpsw_example_pe66.c ...
'Finished building: C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample/cpsw_example.cfg'
'Building file: C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/fw/classify1_bin.c'
'Invoking: C6000 Compiler'
"C:/ti/ccsv5/tools/compiler/c6000_7.4.2/bin/cl6x" -mv64+ --abi=eabi -g --include_path="C:/ti/ccsv5/tools/compiler/c6000_7.4.2/include" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/cppi" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/qmss" --display_error_number --diag_warning=225 --diag_wrap=off --preproc_with_compile --preproc_dependency="classify1_bin.pp" --cmd_file="./configPkg/compiler.opt" "C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/fw/classify1_bin.c"
'Finished building: C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/fw/classify1_bin.c'
'Building file: C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/fw/classify2_bin.c'
"C:/ti/ccsv5/tools/compiler/c6000_7.4.2/bin/cl6x" -mv64+ --abi=eabi -g --include_path="C:/ti/ccsv5/tools/compiler/c6000_7.4.2/include" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/cppi" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/qmss" --display_error_number --diag_warning=225 --diag_wrap=off --preproc_with_compile --preproc_dependency="classify2_bin.pp" --cmd_file="./configPkg/compiler.opt" "C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/fw/classify2_bin.c"
'Finished building: C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/fw/classify2_bin.c'
'Building file: C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/cppi/device/cppi_device.c'
"C:/ti/ccsv5/tools/compiler/c6000_7.4.2/bin/cl6x" -mv64+ --abi=eabi -g --include_path="C:/ti/ccsv5/tools/compiler/c6000_7.4.2/include" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/cppi" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/qmss" --display_error_number --diag_warning=225 --diag_wrap=off --preproc_with_compile --preproc_dependency="cppi_device.pp" --cmd_file="./configPkg/compiler.opt" "C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/cppi/device/cppi_device.c"
'Finished building: C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/cppi/device/cppi_device.c'
'Building file: C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample/cppi_qmss_mgmt.c'
"C:/ti/ccsv5/tools/compiler/c6000_7.4.2/bin/cl6x" -mv64+ --abi=eabi -g --include_path="C:/ti/ccsv5/tools/compiler/c6000_7.4.2/include" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/cppi" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/qmss" --display_error_number --diag_warning=225 --diag_wrap=off --preproc_with_compile --preproc_dependency="cppi_qmss_mgmt.pp" --cmd_file="./configPkg/compiler.opt" "C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample/cppi_qmss_mgmt.c"
'Finished building: C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample/cppi_qmss_mgmt.c'
'Building file: C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample/cpsw_mgmt.c'
"C:/ti/ccsv5/tools/compiler/c6000_7.4.2/bin/cl6x" -mv64+ --abi=eabi -g --include_path="C:/ti/ccsv5/tools/compiler/c6000_7.4.2/include" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/cppi" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/qmss" --display_error_number --diag_warning=225 --diag_wrap=off --preproc_with_compile --preproc_dependency="cpsw_mgmt.pp" --cmd_file="./configPkg/compiler.opt" "C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample/cpsw_mgmt.c"
'Finished building: C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample/cpsw_mgmt.c'
'Building file: C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample/cpsw_singlecore.c'
"C:/ti/ccsv5/tools/compiler/c6000_7.4.2/bin/cl6x" -mv64+ --abi=eabi -g --include_path="C:/ti/ccsv5/tools/compiler/c6000_7.4.2/include" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/cppi" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/qmss" --display_error_number --diag_warning=225 --diag_wrap=off --preproc_with_compile --preproc_dependency="cpsw_singlecore.pp" --cmd_file="./configPkg/compiler.opt" "C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample/cpsw_singlecore.c"
"C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample/cpsw_singlecore.c", line 273: warning #112-D: statement is unreachable
"C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample/cpsw_singlecore.c", line 149: warning #179-D: variable "ct_show_ale" was declared but never referenced
'Finished building: C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample/cpsw_singlecore.c'
'Building file: C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample/pa_mgmt.c'
"C:/ti/ccsv5/tools/compiler/c6000_7.4.2/bin/cl6x" -mv64+ --abi=eabi -g --include_path="C:/ti/ccsv5/tools/compiler/c6000_7.4.2/include" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/cppi" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/qmss" --display_error_number --diag_warning=225 --diag_wrap=off --preproc_with_compile --preproc_dependency="pa_mgmt.pp" --cmd_file="./configPkg/compiler.opt" "C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample/pa_mgmt.c"
'Finished building: C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample/pa_mgmt.c'
'Building file: C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/fw/pam_bin.c'
"C:/ti/ccsv5/tools/compiler/c6000_7.4.2/bin/cl6x" -mv64+ --abi=eabi -g --include_path="C:/ti/ccsv5/tools/compiler/c6000_7.4.2/include" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/cppi" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/qmss" --display_error_number --diag_warning=225 --diag_wrap=off --preproc_with_compile --preproc_dependency="pam_bin.pp" --cmd_file="./configPkg/compiler.opt" "C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/fw/pam_bin.c"
'Finished building: C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/fw/pam_bin.c'
'Building file: C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/qmss/device/qmss_device.c'
"C:/ti/ccsv5/tools/compiler/c6000_7.4.2/bin/cl6x" -mv64+ --abi=eabi -g --include_path="C:/ti/ccsv5/tools/compiler/c6000_7.4.2/include" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/cppi" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/qmss" --display_error_number --diag_warning=225 --diag_wrap=off --preproc_with_compile --preproc_dependency="qmss_device.pp" --cmd_file="./configPkg/compiler.opt" "C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/qmss/device/qmss_device.c"
'Finished building: C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/qmss/device/qmss_device.c'
'Building file: C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample/singlecore_osal.c'
"C:/ti/ccsv5/tools/compiler/c6000_7.4.2/bin/cl6x" -mv64+ --abi=eabi -g --include_path="C:/ti/ccsv5/tools/compiler/c6000_7.4.2/include" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/cppi" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/qmss" --display_error_number --diag_warning=225 --diag_wrap=off --preproc_with_compile --preproc_dependency="singlecore_osal.pp" --cmd_file="./configPkg/compiler.opt" "C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample/singlecore_osal.c"
'Finished building: C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample/singlecore_osal.c'
'Building file: C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample/view_ale_table.c'
"C:/ti/ccsv5/tools/compiler/c6000_7.4.2/bin/cl6x" -mv64+ --abi=eabi -g --include_path="C:/ti/ccsv5/tools/compiler/c6000_7.4.2/include" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/cppi" --include_path="C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/qmss" --display_error_number --diag_warning=225 --diag_wrap=off --preproc_with_compile --preproc_dependency="view_ale_table.pp" --cmd_file="./configPkg/compiler.opt" "C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample/view_ale_table.c"
'Finished building: C:/ti/pdk_C6678_1_1_2_6/packages/ti/drv/pa/example/emacExample/view_ale_table.c'
'Building target: PA_emacExample_exampleProject.out'
'Invoking: C6000 Linker'
"C:/ti/ccsv5/tools/compiler/c6000_7.4.2/bin/cl6x" -mv64+ --abi=eabi -g --display_error_number --diag_warning=225 --diag_wrap=off -z -m"PA_emacExample_exampleProject.map" -i"C:/ti/ccsv5/tools/compiler/c6000_7.4.2/lib" -i"C:/ti/ccsv5/tools/compiler/c6000_7.4.2/include" --reread_libs --warn_sections --display_error_number --diag_wrap=off --rom_model -o "PA_emacExample_exampleProject.out" -l"./configPkg/linker.cmd" "./view_ale_table.obj" "./singlecore_osal.obj" "./qmss_device.obj" "./pam_bin.obj" "./pa_mgmt.obj" "./cpsw_singlecore.obj" "./cpsw_mgmt.obj" "./cppi_qmss_mgmt.obj" "./cppi_device.obj" "./classify2_bin.obj" "./classify1_bin.obj" -l"libc.a"
<Linking>
'Finished building target: PA_emacExample_exampleProject.out'
3) Export... > File System > leave all checked, and select local destination , Finish
4) Delete project, ( leave Delete project contents on disk unchecked)
5) Import... > Existing CCS Projects > Enter the directory of the locally saved Exported project ( C:\work\ti\pa_emac_example_rfr\PA_emacExample_exampleProject in my case), leave copy projects into workspace unchecked > Finish
6) Clean project > Build project , see output below:
Could Not Find C:\work\ti\pa_emac_example_rfr\PA_emacExample_exampleProject\Debug\classify1_bin.pp
Could Not Find C:\work\ti\pa_emac_example_rfr\PA_emacExample_exampleProject\Debug\classify1_bin.obj
'Finished clean'
gmake: *** No rule to make target `C:/ti/drv/pa/fw/classify1_bin.c', needed by `classify1_bin.obj'.
gmake: *** No rule to make target `C:/ti/drv/pa/example/emacExample/cpsw_example.cfg', needed by `configPkg/compiler.opt'.
gmake: *** No rule to make target `C:/ti/drv/pa/fw/classify2_bin.c', needed by `classify2_bin.obj'.
gmake: *** No rule to make target `C:/ti/drv/cppi/device/cppi_device.c', needed by `cppi_device.obj'.
gmake: *** No rule to make target `C:/ti/drv/pa/example/emacExample/cppi_qmss_mgmt.c', needed by `cppi_qmss_mgmt.obj'.
gmake: *** No rule to make target `C:/ti/drv/pa/example/emacExample/cpsw_mgmt.c', needed by `cpsw_mgmt.obj'.
gmake: *** No rule to make target `C:/ti/drv/pa/example/emacExample/cpsw_singlecore.c', needed by `cpsw_singlecore.obj'.
gmake: *** No rule to make target `C:/ti/drv/pa/example/emacExample/pa_mgmt.c', needed by `pa_mgmt.obj'.
gmake: *** No rule to make target `C:/ti/drv/pa/fw/pam_bin.c', needed by `pam_bin.obj'.
gmake: *** No rule to make target `C:/ti/drv/qmss/device/qmss_device.c', needed by `qmss_device.obj'.
gmake: *** No rule to make target `C:/ti/drv/pa/example/emacExample/singlecore_osal.c', needed by `singlecore_osal.obj'.
gmake: *** No rule to make target `C:/ti/drv/pa/example/emacExample/view_ale_table.c', needed by `view_ale_table.obj'.
gmake: Target `all' not remade because of errors.
What's going on here? I can see one obvious thing is that it's looking for C:/ti/drv/pa/example/emacExample/...., and the C:/ti/drv path doesn't exist. There is clearly some relative path, but I imagine the export project process is supposed to capture translate relative paths somehow.
Ryan
