Other Parts Discussed in Thread: MATHLIB
Hi
XP, C6472
I did a complete re-install of ccv5.4. I also have CCSv4 installed with all the RTSC products we've used during development. But now its time to work on the next product so we need CCSv5
The problem is that I get the error below when after it finds products in the c:\Program Files\Texas Instruments folder
Operation details
Your original request has been modified.
"DSP/BIOS (IDE Client)" will be ignored because a newer version is already installed.
"SYS/BIOS (IDE Client)" will be ignored because a newer version is already installed.
"IPC (Multicore and I/O) (IDE Client)" will be ignored because a newer version is already installed.
"System Analyzer (UIA Target) (IDE Client)" will be ignored because a newer version is already installed.
"Third-Party Components for GMF Runtime " will be ignored because a newer version is already installed.
"RTSC/XDCtools (IDE Client)" will be ignored because a newer version is already installed.
Cannot complete the install because of a conflicting dependency.
Software being installed: IPC (Multicore and I/O) 1.23.2.27 (com.ti.ipc_1.23.feature.group 1.23.2.27)
Software currently installed: IPC (Multicore and I/O) (IDE Client) 1.24.3.32 (com.ti.rtsc.IPC.product.ui.feature.group 1.24.3.32)
Only one of the following can be installed at once:
IPC (Multicore and I/O) IDE Tooling 1.24.3.32 (com.ti.rtsc.IPC.product.ui 1.24.3.32)
IPC (Multicore and I/O) UI Plugin 1.22.5.27 (com.ti.rtsc.IPC.product.ui 1.22.5.27)
IPC (Multicore and I/O) UI Plugin 1.23.2.27 (com.ti.rtsc.IPC.product.ui 1.23.2.27)
Cannot satisfy dependency:
From: IPC (Multicore and I/O) 1.23.2.27 (com.ti.ipc_1.23.feature.group 1.23.2.27)
To: com.ti.rtsc.IPC.product.ui [1.23.2.27]
From: IPC (Multicore and I/O) (IDE Client) 1.24.3.32 (com.ti.rtsc.IPC.product.ui.feature.group 1.24.3.32)
To: com.ti.rtsc.IPC.product.ui [1.24.3.32]
The second problem is CCSv5 sees my ipc version 1.24.3.32 in the error output below, but won't install it (can't see it in Window->preferences->Code Composer->RTSC. And why does it say these versions can't be installed together? They are different versions.
Operation details
Software being installed: IPC (Multicore and I/O) 1.22.5.27 (com.ti.ipc_1.22.feature.group 1.22.5.27)
From: IPC (Multicore and I/O) 1.22.5.27 (com.ti.ipc_1.22.feature.group 1.22.5.27)
To: com.ti.rtsc.IPC.product.ui [1.22.5.27]
