CCS5.3 fails to start after updating C6000 compiler 7.4.4
Hello everybody,
I used the update feature of CCS 5.3 to update my C6000 compiler to version 7.4.4.
Now, after closing and restarting, CCS fails to start with following error.
Could anybody help, pls?
BR,
Alex
  • Hi Alex,
    could you please send the logs from the installjammer registry directory?   That folder might be hidden and is under program files or program files(x86)
    best regards,
    Lisa
  • Hi Lisa,
    attached you find the corresponding log file.
    THX,
    Alex
    ------ ccs_update_5.3.0.00076 Installation -------------
    07/25/2013 11:25:43AM -
    07/25/2013 11:25:43AM - InstallID      : 01F2A638-A656-4A71-B2E9-C7475A87C962
    07/25/2013 11:25:43AM - Installer      : C:\TexasInstruments\ccsv5\eclipse\downloads\ccs_update_5.3.0.00076.exe
    07/25/2013 11:25:43AM - BuildName      : ccs_update_5.3.0.00076.exe
    07/25/2013 11:25:43AM - Install version: 5.3.0.00076
    07/25/2013 11:25:43AM - Install source : C:\TexasInstruments\ccsv5\eclipse\downloads
    07/25/2013 11:25:43AM - OS             : Windows
    07/25/2013 11:25:43AM - UserName       : ibj
    07/25/2013 11:25:43AM - Update?        : 0
    07/25/2013 11:25:43AM - testmode       : <%testmode%>
    07/25/2013 11:25:43AM - testurl        : <%testurl%>
    07/25/2013 11:25:43AM - http info      : -accept */* -proxyfilter http::ProxyRequired -proxyhost {} -proxyport {} -urlencoding utf-8 -useragent {Tcl http client package 2.5.3}
    07/25/2013 11:25:43AM - InstallURL     : <%InstallURL%>
    07/25/2013 11:25:43AM - Command line   : /installkitvfs/main.tcl 0
    07/25/2013 11:25:43AM - Checking conditions for 3A18DFFF-E127-407E-987E-23B777277223 - Check for McAfee - Before Action is Executed
    07/25/2013 11:25:43AM - Checking condition 60C48044-51FA-4487-BFBF-5E5276E11AA6 - Platform Condition
    07/25/2013 11:25:43AM - Checking to see if <%Platform%> is Windows
    07/25/2013 11:25:43AM - ** Checking to see if Windows is Windows
    07/25/2013 11:25:43AM - Condition passed
    07/25/2013 11:25:43AM - Executing action 3A18DFFF-E127-407E-987E-23B777277223 - Check for McAfee
    07/25/2013 11:25:43AM - Registry key HKEY_LOCAL_MACHINE\SOFTWARE\McAfee does not exist unable to open key: Das System kann die angegebene Datei nicht finden.
    07/25/2013 11:25:43AM - Checking conditions for 6D910536-6D94-48FC-9FB6-DEC5FBC0E6B9 - Set Update variables if needed - Before Action is Executed
    07/25/2013 11:25:43AM - Checking condition A2DF4B22-7FD5-40DD-A8C7-744CDD290075 - String Equal Condition
    07/25/2013 11:25:43AM - Checking to see if <%InstallPrefix%> equals ccs_update
    07/25/2013 11:25:43AM - ** Checking to see if ccs_update equals ccs_update
    07/25/2013 11:25:43AM - Executing action 6D910536-6D94-48FC-9FB6-DEC5FBC0E6B9 - Set Update variables if needed
    07/25/2013 11:25:43AM - eclipse C:/TexasInstruments/ccsv5/eclipse
    07/25/2013 11:25:43AM - C:/TexasInstruments/ccsv5/eclipse/ccs_config.xml
    07/25/2013 11:25:43AM - Can't find eclipse dir, doesn't look like a valid ccs installation
    07/25/2013 11:25:43AM - Checking conditions for FD9BA738-0681-4F8C-A99E-D9630FE9317A - Get InstallDir - Before Action is Executed
    07/25/2013 11:25:43AM - Checking condition 96501BA3-2DAB-4133-BEAD-86FCA44BFE84 - String Is Condition
    07/25/2013 11:25:43AM - Checking to see if <%UpdateMode%> is true
    07/25/2013 11:25:43AM - ** Checking to see if 0 is true
    07/25/2013 11:25:43AM - Condition failed
    07/25/2013 11:25:43AM - Skipping action FD9BA738-0681-4F8C-A99E-D9630FE9317A - Get InstallDir - conditions failed
    07/25/2013 11:25:43AM - Checking conditions for 5A908E3F-6B9A-4311-B8CA-15578F03CEC9 - Set Native_Eclipse_Selected - Before Action is Executed
    07/25/2013 11:25:43AM - Checking condition A2036039-9CCB-492A-8247-6D07128AEE2F - Command Line Test Condition
    07/25/2013 11:25:43AM - Checking to see if eclipseprefix was passed on the command line
    07/25/2013 11:25:43AM - Skipping action 5A908E3F-6B9A-4311-B8CA-15578F03CEC9 - Set Native_Eclipse_Selected - conditions failed
    07/25/2013 11:25:43AM - Checking conditions for 99A470ED-DD5C-4D41-BA90-A04A061322EB - Set Native Eclipse Variable - Before Action is Executed
    07/25/2013 11:25:43AM - Checking condition DF6C1A44-866A-4053-A6D4-D810A1260FFA - String Is Condition
    07/25/2013 11:25:43AM - Skipping action 99A470ED-DD5C-4D41-BA90-A04A061322EB - Set Native Eclipse Variable - conditions failed
    07/25/2013 11:25:43AM - Checking conditions for 0E76BDFA-AE33-4D11-80D4-021EEE28FADA - Set Valid Eclipse Variable - Before Action is Executed
    07/25/2013 11:25:43AM - Checking condition A0F1E771-08C1-4655-89F3-A760BAE68E12 - String Is Condition
    07/25/2013 11:25:43AM - Skipping action 0E76BDFA-AE33-4D11-80D4-021EEE28FADA - Set Valid Eclipse Variable - conditions failed
    07/25/2013 11:25:43AM - Checking conditions for F0A046CD-8A59-4F7D-B025-7ED78FD8C0F3 - Execute Response File Action - Before Action is Executed
    07/25/2013 11:25:43AM - Checking condition C434E3F3-C405-466D-9713-A8F99B3BCC12 - Command Line Test Condition
    07/25/2013 11:25:43AM - Checking to see if response-file was passed on the command line
    07/25/2013 11:25:43AM - Skipping action F0A046CD-8A59-4F7D-B025-7ED78FD8C0F3 - Execute Response File Action - conditions failed
    07/25/2013 11:25:43AM - Checking conditions for 73286838-ADC5-44C6-9BF4-3D00C32317F7 - Set Windows information - Before Action is Executed
    07/25/2013 11:25:43AM - Checking condition DDEDDBE3-895A-4F08-B242-B5CEB39360F2 - Platform Condition
    07/25/2013 11:25:43AM - Executing action 73286838-ADC5-44C6-9BF4-3D00C32317F7 - Set Windows information
    07/25/2013 11:25:43AM - Checking System Info...
    07/25/2013 11:25:43AM - Registry key WindowsCSDVersionString does not exist
    07/25/2013 11:25:43AM - WindowsProductName=
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion
        ProductName    REG_SZ    Windows 7 Ultimate
      WindowsCurrentVersion= 6.1
      WindowsCSDVersionString= -
      WindowsCSDVersionDWord= 256
      WindowsPlatform= Windows7
    07/25/2013 11:25:43AM - Checking conditions for 22F60A3C-BD94-46EA-A08B-8DE1A6DE012D - Check For Reboots (Windows) - Before Action is Executed
    07/25/2013 11:25:43AM - Checking condition 4759E3D6-FA8F-4285-8B95-F54DBEA3EEC5 - Platform Condition
    07/25/2013 11:25:43AM - Executing action 22F60A3C-BD94-46EA-A08B-8DE1A6DE012D - Check For Reboots (Windows)
    07/25/2013 11:25:43AM - Executing actions C5310624-D7B0-49EA-8FC1-2DF23B182604 - Check For Reboots
    07/25/2013 11:25:43AM - Checking conditions for 016A4B32-BA79-4C2C-AA91-28D2449B2E9F -  - Before Action is Executed
    07/25/2013 11:25:43AM - Checking condition DA033291-4AA6-4BE3-9455-49F48C711785 - Platform Condition
    07/25/2013 11:25:43AM - Executing action 016A4B32-BA79-4C2C-AA91-28D2449B2E9F - Check registry keys
    07/25/2013 11:25:43AM - Checking for reboots ...
    07/25/2013 11:25:43AM - Registry key PendingFileRenameOperations does not exist unable to open key: Das System kann die angegebene Datei nicht finden.
    07/25/2013 11:25:43AM - Registry key UpdateExeVolatile does not exist unable to open key: Das System kann die angegebene Datei nicht finden.
    07/25/2013 11:25:43AM - Registry key rebootrequired does not exist unable to open key: Das System kann die angegebene Datei nicht finden.
    07/25/2013 11:25:43AM - Checking conditions for 177AA845-805E-424B-A48A-6E2BFD6C9CD6 -  - Before Action is Executed
    07/25/2013 11:25:43AM - Checking condition 05370712-1717-4B2A-A7F9-359FCCA2E57B - String Is Condition
    07/25/2013 11:25:43AM - Checking to see if <%GuiMode%> is true
    07/25/2013 11:25:43AM - ** Checking to see if 1 is true
    07/25/2013 11:25:43AM - Checking condition 0459569F-EDC5-4A4D-93EE-0FB7BE84B4C9 - String Is Condition
    07/25/2013 11:25:43AM - Checking to see if <%UpdateMode%> is false
    07/25/2013 11:25:43AM - ** Checking to see if 0 is false
    07/25/2013 11:25:43AM - Checking condition 50A21EBD-54A7-45F4-8988-7791D76EC6A3 - String Is Condition
    07/25/2013 11:25:43AM - Checking to see if <%FoundReboot%> is true
    07/25/2013 11:25:43AM - ** Checking to see if false is true
    07/25/2013 11:25:43AM - Skipping action 177AA845-805E-424B-A48A-6E2BFD6C9CD6 - Reboot Message - conditions failed
    07/25/2013 11:25:43AM - Checking conditions for E52C2017-2ED3-4B74-BBE2-86BB2E723383 -  - Before Action is Executed
    07/25/2013 11:25:43AM - Checking condition 0FAA39B6-E52E-4D19-B9EC-7071A6697A0C - String Is Condition
    07/25/2013 11:25:43AM - Checking to see if <%GuiMode%> is false
    07/25/2013 11:25:43AM - ** Checking to see if 1 is false
    07/25/2013 11:25:43AM - Skipping action E52C2017-2ED3-4B74-BBE2-86BB2E723383 - Reboot Message - conditions failed
    07/25/2013 11:25:43AM - Checking conditions for CC5D72E4-5258-41C5-9C78-AB886C2F8673 -  - Before Action is Executed
    07/25/2013 11:25:43AM - Checking condition 9D5BB820-1691-42D3-8ADE-0DC2304F9BCD - String Equal Condition
    07/25/2013 11:25:43AM - Checking to see if <%Answer%> equals No
    07/25/2013 11:25:43AM - Skipping action CC5D72E4-5258-41C5-9C78-AB886C2F8673 - Exit - conditions failed
    07/25/2013 11:25:43AM - Executing action 1409F691-5623-49F1-99EB-D4ED15870571 - Set BuildName (default)
    07/25/2013 11:25:43AM - Executing action B087353F-2657-49B6-97D9-BF29BDEAA7C0 - Execute Script
    07/25/2013 11:25:43AM - mode = Standard
    07/25/2013 11:25:43AM - Setting active setup type to New Setup Type (B6E0CE8C-4E6F-4885-953A-32946A051105).
    07/25/2013 11:25:43AM - Activating component D253A697-7480-46F3-AF71-AB63991129FD
    07/25/2013 11:25:43AM - Executing actions A0AAD47D-43D9-43F8-9439-47A03F6F4E2B - Startup Actions
    07/25/2013 11:25:43AM - Executing action 13EDEC6E-8DA0-4447-BDEA-CA07B2E6C024 - Run Common Startup Actions
    07/25/2013 11:25:43AM - Executing actions 0C7AA01C-904A-49D5-A05B-E0AE9CC22448 - Common Startup Actions
    07/25/2013 11:25:43AM - Executing action 1C82CB44-08EC-4BAE-BCF7-719902E9C236 - Execute Windows Startup
    07/25/2013 11:25:43AM - Checking conditions for AED7E1E0-3E40-41B5-A471-FAAFD73529F8 - Windows Startup Action - Before Action is Executed
    07/25/2013 11:25:43AM - Checking condition BDCBFA61-EF65-4DF4-A4C3-1CD5758BDD79 - Platform Condition
    07/25/2013 11:25:43AM - Executing actions AED7E1E0-3E40-41B5-A471-FAAFD73529F8 - Windows Startup Action
    07/25/2013 11:25:43AM - Executing action C4D1AB2C-8D0E-4AF0-BA43-2DF6CA3D3A1C - Check Memory
    07/25/2013 11:25:43AM - Checking Memory...
    07/25/2013 11:25:43AM - Checking conditions for 98FB6613-1F73-4BCB-8DDB-B431EBD71496 -  - Before Action is Executed
    07/25/2013 11:25:43AM - Checking condition 17D28D55-F95F-4DD0-AC94-EF4CDE6400D2 - Execute Script Condition
    07/25/2013 11:25:43AM - C:/Users/ibj/AppData/Local/Temp is writable ? 1 or  1
    07/25/2013 11:25:43AM - C:/Users/ibj/AppData/Local/Temp/ijtmp_973DA65E-8489-4E36-8183-A5A728A82A34 exists? 1
    07/25/2013 11:25:43AM - C:/Users/ibj/AppData/Local/Temp/ijtmp_973DA65E-8489-4E36-8183-A5A728A82A34 is writable ? 1
    07/25/2013 11:25:43AM - making C:/Users/ibj/AppData/Local/Temp/ijtmp_973DA65E-8489-4E36-8183-A5A728A82A34/baserepo
    07/25/2013 11:25:43AM - Skipping action 98FB6613-1F73-4BCB-8DDB-B431EBD71496 - Exit if no access to TEMP dir  - conditions failed
    07/25/2013 11:25:43AM - Checking conditions for 1514399D-CAAF-4087-9E82-A65109B675F8 -  - Before Action is Executed
    07/25/2013 11:25:43AM - Checking condition 245ABF90-7270-43B9-A0A7-17F7DAAB3466 - Command Line Test Condition
    07/25/2013 11:25:43AM - Skipping action 1514399D-CAAF-4087-9E82-A65109B675F8 - Execute Look for EclipseDir - conditions failed
    07/25/2013 11:25:43AM - Executing action 7A1CB0AB-04A3-41C0-8655-22F6AE6A972A - Full CCS or Component install test
    07/25/2013 11:25:43AM - .*_setup_5.3.*
    07/25/2013 11:25:43AM - found_ccs = false
    07/25/2013 11:25:43AM - component installer
    07/25/2013 11:25:43AM - Checking conditions for 390AFA53-7D35-4C26-A453-27B7CEBB834E -  - Before Action is Executed
    07/25/2013 11:25:43AM - Checking condition AB402A5E-1927-4722-B563-CAF54B6E53AA - Platform Condition
    07/25/2013 11:25:43AM - Executing action 390AFA53-7D35-4C26-A453-27B7CEBB834E - Unpack Setup xml file
    07/25/2013 11:25:43AM - Unpacking C:/Users/ibj/AppData/Local/Temp/ijtmp_973DA65E-8489-4E36-8183-A5A728A82A34/ccs_installini.xml
    07/25/2013 11:25:44AM - Checking conditions for F4C790E5-5B05-43B4-ABC4-B4B9C1C01A59 -  - Before Action is Executed
    07/25/2013 11:25:44AM - Checking condition D1A276F0-17F4-498A-B707-E9B7CDAF7109 - Platform Condition
    07/25/2013 11:25:44AM - Checking to see if <%Platform%> is Linux-x86
    07/25/2013 11:25:44AM - ** Checking to see if Windows is Linux-x86
    07/25/2013 11:25:44AM - Condition failed
    07/25/2013 11:25:44AM - Skipping action F4C790E5-5B05-43B4-ABC4-B4B9C1C01A59 - Unpack Setup xml file - conditions failed
    07/25/2013 11:25:44AM - Executing action 1FDA0E1A-FA6B-40B5-934E-553F9ABDC49B - Set InstallIni file name
    07/25/2013 11:25:44AM - InstallSource = C:/TexasInstruments/ccsv5/eclipse/downloads
    07/25/2013 11:25:44AM - InstallIni file = C:/Users/ibj/AppData/Local/Temp/ijtmp_973DA65E-8489-4E36-8183-A5A728A82A34/ccs_installini.xml C:/Users/ibj/AppData/Local/Temp/ijtmp_973DA65E-8489-4E36-8183-A5A728A82A34/ccs_installini.xml
    07/25/2013 11:25:44AM - Executing action C325767C-1961-4AB1-8037-7C19CB4BA543 - Get Setup Types
    07/25/2013 11:25:44AM - Executing action D6E650CF-E79A-4C23-86E7-FE0AF5BB288C - Set USERPROFILE variable
    07/25/2013 11:25:44AM - userprofile = C:\Users\ibj
    07/25/2013 11:25:44AM - Checking conditions for DCC432F6-3409-4694-A45A-ADE2F727D197 - Run Main Startup Actions - Before Action is Executed
    07/25/2013 11:25:44AM - Checking condition 811E0FCC-5436-4EF1-B100-38D48AEDAEDB - String Is Condition
    07/25/2013 11:25:44AM - Checking to see if <%UpdateMode%> is false
    07/25/2013 11:25:44AM - ** Checking to see if 0 is false
    07/25/2013 11:25:44AM - Condition passed
    07/25/2013 11:25:44AM - Executing action DCC432F6-3409-4694-A45A-ADE2F727D197 - Run Main Startup Actions
    07/25/2013 11:25:44AM - Executing actions 4BA19292-8FFD-40DE-8CA5-B8FC9CDD9A15 - Main Startup Actions
    07/25/2013 11:25:44AM - Executing action 164527E4-7D70-4D17-BBF9-D2D79EA6EC93 - Run Manifest File Actions
    07/25/2013 11:25:44AM - Executing actions 2E15C1E1-4FB2-4D3F-8401-2D82FB9F0AF6 - Manifest File Actions
    07/25/2013 11:25:44AM - Checking conditions for 25BA989D-274D-4302-A91E-48B8454834E4 -  - Before Action is Executed
    07/25/2013 11:25:44AM - Checking condition 45766827-6E1C-43A5-AE55-3EDC12383C2C - Platform Condition
    07/25/2013 11:25:44AM - Skipping action 25BA989D-274D-4302-A91E-48B8454834E4 - Unpack Manifest xml file - conditions failed
    07/25/2013 11:25:44AM - Checking conditions for 1C65743D-E0A5-4787-B152-3A21723C2002 -  - Before Action is Executed
    07/25/2013 11:25:44AM - Checking condition 9B003E01-3775-4A7C-ABAD-252F786C62F6 - Platform Condition
    07/25/2013 11:25:44AM - Checking to see if <%Platform%> is Windows
    07/25/2013 11:25:44AM - ** Checking to see if Windows is Windows
    07/25/2013 11:25:44AM - Executing action 1C65743D-E0A5-4787-B152-3A21723C2002 - Unpack Manifest xml file
    07/25/2013 11:25:44AM - Unpacking C:/Users/ibj/AppData/Local/Temp/ijtmp_973DA65E-8489-4E36-8183-A5A728A82A34/ccs_manifest.xml
    07/25/2013 11:25:44AM - Checking conditions for 64C32BE4-E5A9-49DE-B300-99E89DCD537B -  - Before Action is Executed
    07/25/2013 11:25:44AM - Checking condition 6CB61E0B-777D-4323-B690-2D6B7EC21739 - String Is Condition
    07/25/2013 11:25:44AM - Checking to see if <%ComponentInstaller%> is false
    07/25/2013 11:25:44AM - ** Checking to see if true is false
    07/25/2013 11:25:44AM - Skipping action 64C32BE4-E5A9-49DE-B300-99E89DCD537B - Set Manifest file name (Main) - conditions failed
    07/25/2013 11:25:44AM - Checking conditions for 2237DB6B-9676-4FDA-8BBB-9CD0741C175B -  - Before Action is Executed
    07/25/2013 11:25:44AM - Checking condition 15FF209F-7BBD-4D5E-BDC0-36EE302F2496 - String Is Condition
    07/25/2013 11:25:44AM - Checking to see if <%ComponentInstaller%> is true
    07/25/2013 11:25:44AM - ** Checking to see if true is true
    07/25/2013 11:25:44AM - Executing action 2237DB6B-9676-4FDA-8BBB-9CD0741C175B - Set Manifest file name (Component)
    07/25/2013 11:25:44AM - Manifest file = C:/TexasInstruments/ccsv5/eclipse/downloads/com.ti.cgt.c6000.7.4.win32_manifest.xml C:/TexasInstruments/ccsv5/eclipse/downloads/com.ti.cgt.c6000.7.4.win32_manifest.xml 0 0
    07/25/2013 11:25:44AM - Checking conditions for CB39A277-9A24-430C-8680-A15529B595BE -  - Before Action is Executed
    07/25/2013 11:25:44AM - Checking condition 016B1F93-7184-4FC3-8688-0A1889957CA9 - String Is Condition
    07/25/2013 11:25:44AM - Checking condition FFD4BBBB-AE77-41B3-B36C-F3039A0AC3E0 - String Is Condition
    07/25/2013 11:25:44AM - Checking to see if <%FoundManifest%> is false
    07/25/2013 11:25:44AM - Skipping action CB39A277-9A24-430C-8680-A15529B595BE - Exit - conditions failed
    07/25/2013 11:25:44AM - Executing action 02082184-215D-4D0A-9DA8-3288BFC36931 - Run Get URL Name
    07/25/2013 11:25:44AM - Executing actions C6771919-CB79-4C4F-A842-7560C1B039E5 - Get URL Name
    07/25/2013 11:25:44AM - Executing action C6771919-CB79-4C4F-A842-7560C1B039E5 - Get URL Name
    07/25/2013 11:25:44AM - P2version =
    07/25/2013 11:25:44AM - Reading manifest file C:/TexasInstruments/ccsv5/eclipse/downloads/com.ti.cgt.c6000.7.4.win32_manifest.xml
    07/25/2013 11:25:44AM - tsvar = domNode027F9078
    07/25/2013 11:25:44AM - urlname = |Code Generation Tools Updates|
    07/25/2013 11:25:44AM - repotype = single
    07/25/2013 11:25:44AM - ts = 2013_28_24_10:28:40
    07/25/2013 11:25:44AM - setlocal = false
    07/25/2013 11:25:44AM - Executing action 618B18B2-BF4D-45A2-819F-E7339E124226 - Run Look for Local Repository
    07/25/2013 11:25:44AM - Executing actions C3322C75-C36B-4CAA-99B6-D10C70E75CED - Look for Local Respository
    07/25/2013 11:25:44AM - Executing action C3322C75-C36B-4CAA-99B6-D10C70E75CED - Look for Local Respository
    07/25/2013 11:25:44AM - updaterepo =
    07/25/2013 11:25:44AM - local repo = C:\TexasInstruments\ccsv5\eclipse\downloads/featurerepo
    07/25/2013 11:25:44AM - localbaserepo = C:\TexasInstruments\ccsv5\eclipse\downloads
    07/25/2013 11:25:44AM - localrepo = C:\TexasInstruments\ccsv5\eclipse\downloads
    07/25/2013 11:25:44AM - Executing action 23557737-FFE9-4727-A3B7-022578B08DFC - Run Read Manifest file
    07/25/2013 11:25:44AM - Executing actions 0606F3A6-B4B3-430D-BF58-90FD8DC7E9D0 - Read Manifest file
    07/25/2013 11:25:44AM - Executing action 0606F3A6-B4B3-430D-BF58-90FD8DC7E9D0 - Read Manifest file
    07/25/2013 11:25:44AM - LocalRepository_Exists = 1
    07/25/2013 11:25:44AM - install url info does not exist
    07/25/2013 11:25:44AM - Component url CGT_DEFAULTLIBS_C6000 = C:/TexasInstruments/ccsv5/eclipse/downloads
    07/25/2013 11:25:44AM - baseurl = http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32
    07/25/2013 11:25:44AM - Executing action 064CDB88-8721-4CDA-B246-37D052A32298 - Debug information
    07/25/2013 11:25:44AM - Manifest file: C:/TexasInstruments/ccsv5/eclipse/downloads/com.ti.cgt.c6000.7.4.win32_manifest.xml
    07/25/2013 11:25:44AM - Setup file   : C:/Users/ibj/AppData/Local/Temp/ijtmp_973DA65E-8489-4E36-8183-A5A728A82A34/ccs_installini.xml
    07/25/2013 11:25:44AM - Installer: ccs_update_5.3.0.00076.exe
    07/25/2013 11:25:44AM - ccs_update_5.3.0.00076.exe
    07/25/2013 11:25:44AM - C:\Users\ibj
    07/25/2013 11:25:44AM - Checking conditions for 8F539122-507F-4B01-8ABD-1443E5E641D6 -  - Before Action is Executed
    07/25/2013 11:25:44AM - Checking condition ECCFACBA-E04C-48D6-9BD9-2BA9B3C509E1 - String Is Condition
    07/25/2013 11:25:44AM - Checking to see if <%ShowSetupPane%> is false
    07/25/2013 11:25:44AM - Skipping action 8F539122-507F-4B01-8ABD-1443E5E641D6 - Execute Get Edition Details - conditions failed
    07/25/2013 11:25:44AM - Checking conditions for A0354A16-79FB-457B-9363-CED6124ADDCA -  - Before Action is Executed
    07/25/2013 11:25:44AM - Checking condition C483848C-C11F-41BC-AB86-7D4A0C24A5BA - String Is Condition
    07/25/2013 11:25:44AM - Skipping action A0354A16-79FB-457B-9363-CED6124ADDCA - Execute Setup Panes to Display - conditions failed
    07/25/2013 11:25:44AM - Checking conditions for EECE82E1-6B6F-468C-A6BA-5AB21E7F19E8 -  - Before Action is Executed
    07/25/2013 11:25:44AM - Checking condition 2660F337-EF5C-4F78-92FA-E0B8EE28FC23 - Platform Condition
    07/25/2013 11:25:44AM - Skipping action EECE82E1-6B6F-468C-A6BA-5AB21E7F19E8 - Non-admin Message (linux) - conditions failed
    07/25/2013 11:25:44AM - Checking conditions for 1EEDE33F-FA96-434E-A408-3A858B0CFE41 -  - Before Action is Executed
    07/25/2013 11:25:44AM - Checking condition B2E179AA-7558-48D7-8D00-0E27D34F3026 - Platform Condition
    07/25/2013 11:25:44AM - Skipping action 1EEDE33F-FA96-434E-A408-3A858B0CFE41 - Non-admin Message (linux) - conditions failed
    07/25/2013 11:25:44AM - Checking conditions for AABD8C8E-3C88-4987-B89C-D6747C9394D5 -  - Before Action is Executed
    07/25/2013 11:25:44AM - Checking condition 474FB0CF-0071-4661-AC05-9DBF4E4BFED2 - Platform Condition
    07/25/2013 11:25:44AM - Skipping action AABD8C8E-3C88-4987-B89C-D6747C9394D5 - Exit - conditions failed
    07/25/2013 11:25:44AM - Executing action 17AAAD6D-433F-4CC7-A9E2-5EB0008F5832 - Set ARM MPU BU flag
    07/25/2013 11:25:44AM - test armurl = http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32/baserepo/arm_mpu.txt
    07/25/2013 11:25:44AM - http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32/baserepo/arm_mpu.txt
  • Hi Alex,
    Can you rename the downloads folder to something else and try opening CCS, please?
    Danish
  • Hi Danish,
    I deleted some the lastest download files from folder "downloads" and now CCS starts without any trouble.
    Thanks a lot for the immediate help!
    BR,
    Alex
  • Glad that helped.
    Alex, if you can, please post the install logs from c:\program files\installjammer registry\ccsv5. It helps us figure out what went wrong with the update.
    Thanks again!
    Danish
