Code Composer crash
Other Parts Discussed in Thread: CODECOMPOSER
Code сomposer crash at startup. Immediately after starting the IDE fails and execution stops. Four log file attached
# An unexpected error has been detected by Java Runtime Environment:
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x3f229c98, pid=1260, tid=2532
# Java VM: Java HotSpot(TM) Client VM (11.3-b02 mixed mode windows-x86)
# Problematic frame:
# C  [mshtml.dll+0x209c98]
# If you would like to submit a bug report, please visit:
#   http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
---------------  T H R E A D  ---------------
Current thread (0x008f6c00):  JavaThread "main" [_thread_in_native, id=2532, stack(0x00030000,0x00130000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x00000000
Registers:
EAX=0x00000000, EBX=0x00000113, ECX=0x3247d558, EDX=0x00000000
ESP=0x0012efd8, EBP=0x0012efdc, ESI=0x0022b970, EDI=0x30642060
EIP=0x3f229c98, EFLAGS=0x00210246
Top of Stack: (sp=0x0012efd8)
0x0012efd8:   00000000 0012efec 3f264984 00000000
0x0012efe8:   0000031a 0012effc 3f11db60 30646060
0x0012eff8:   00001012 0012f020 3f11db6c 00002000
0x0012f008:   0012f088 3f0f512a 00000000 00000000
0x0012f018:   000000cb 00000000 0012f04c 7e368734
0x0012f028:   0004061e 00000083 00002000 00000000
0x0012f038:   3f0f512a dcbaabcd 00000000 0012f088
0x0012f048:   3f0f512a 0012f0b4 7e368816 3f0f512a
Instructions: (pc=0x3f229c98)
0x3f229c88:   90 90 90 8b ff 55 8b ec 51 8b 40 10 83 65 fc 00
0x3f229c98:   8b 08 56 8d 55 fc 52 68 d0 9c 22 3f 50 ff 11 8b
Stack: [0x00030000,0x00130000],  sp=0x0012efd8,  free space=1019k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C  [mshtml.dll+0x244984]
C  [mshtml.dll+0xfdb60]
C  [mshtml.dll+0xfdb6c]
C  [USER32.dll+0x8734]
C  [USER32.dll+0x8816]
C  [USER32.dll+0x89cd]
C  [USER32.dll+0x8a10]
C  [swt-win32-3833.dll+0x3a64]
j  org.eclipse.swt.internal.win32.OS.DispatchMessageW(Lorg/eclipse/swt/internal/win32/MSG;)I+0
j  org.eclipse.swt.internal.win32.OS.DispatchMessage(Lorg/eclipse/swt/internal/win32/MSG;)I+7
j  org.eclipse.swt.widgets.Display.readAndDispatch()Z+64
j  org.eclipse.jface.window.Window.runEventLoop(Lorg/eclipse/swt/widgets/Shell;)V+23
j  org.eclipse.jface.window.Window.open()I+49
j  com.ti.ccstudio.debug.ui.licensing.LicenseMonitor.showLicenseDialog(Lorg/eclipse/swt/widgets/Shell;Lcom/ti/license/ILicenseAction;Z)V+191
j  com.ti.ccstudio.debug.ui.licensing.LicenseMonitor$LicenseDialogJob.runInUIThread(Lorg/eclipse/core/runtime/IProgressMonitor;)Lorg/eclipse/core/runtime/IStatus;+22
j  org.eclipse.ui.progress.UIJob$1.run()V+53
j  org.eclipse.swt.widgets.RunnableLock.run()V+11
j  org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Z)Z+29
j  org.eclipse.swt.widgets.Display.runAsyncMessages(Z)Z+5
j  org.eclipse.swt.widgets.Display.readAndDispatch()Z+91
j  org.eclipse.ui.internal.Workbench.runEventLoop(Lorg/eclipse/jface/window/Window$IExceptionHandler;Lorg/eclipse/swt/widgets/Display;)V+9
j  org.eclipse.ui.internal.Workbench.runUI()I+555
j  org.eclipse.ui.internal.Workbench.access$4(Lorg/eclipse/ui/internal/Workbench;)I+1
j  org.eclipse.ui.internal.Workbench$7.run()V+73
j  org.eclipse.core.databinding.observable.Realm.runWithDefault(Lorg/eclipse/core/databinding/observable/Realm;Ljava/lang/Runnable;)V+12
j  org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+18
j  org.eclipse.ui.PlatformUI.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+2
j  org.eclipse.ui.internal.ide.application.IDEApplication.start(Lorg/eclipse/equinox/app/IApplicationContext;)Ljava/lang/Object;+108
j  org.eclipse.equinox.internal.app.EclipseAppHandle.run(Ljava/lang/Object;)Ljava/lang/Object;+135
j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(Ljava/lang/Object;)Ljava/lang/Object;+103
j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ljava/lang/Object;)Ljava/lang/Object;+29
j  org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/lang/Object;)Ljava/lang/Object;+149
j  org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/lang/String;Ljava/lang/Runnable;)Ljava/lang/Object;+183
v  ~StubRoutines::call_stub
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j  sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+0
j  sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+87
j  sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+6
j  java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+161
j  org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lang/String;[Ljava/net/URL;)V+211
j  org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/String;)V+126
j  org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+4
---------------  P R O C E S S  ---------------
Java Threads: ( => current thread )
  0x05355400 JavaThread "Scripting Console - Rhino" [_thread_in_native, id=2568, stack(0x33730000,0x33830000)]
  0x038a6400 JavaThread "Worker-7" [_thread_blocked, id=1396, stack(0x066f0000,0x067f0000)]
  0x04253800 JavaThread "Worker-6" [_thread_blocked, id=764, stack(0x065f0000,0x066f0000)]
  0x05417400 JavaThread "Worker-5" [_thread_blocked, id=3736, stack(0x064f0000,0x065f0000)]
  0x04264800 JavaThread "Worker-4" [_thread_blocked, id=2912, stack(0x063f0000,0x064f0000)]
  0x04264000 JavaThread "Worker-3" [_thread_blocked, id=1036, stack(0x04d40000,0x04e40000)]
  0x0542e400 JavaThread "Worker-2" [_thread_blocked, id=3932, stack(0x04a20000,0x04b20000)]
  0x03750800 JavaThread "Bundle File Closer" daemon [_thread_blocked, id=3772, stack(0x06010000,0x06110000)]
  0x04387800 JavaThread "Worker-1" [_thread_blocked, id=2492, stack(0x04c40000,0x04d40000)]
  0x041ef800 JavaThread "Worker-0" [_thread_blocked, id=2132, stack(0x03e80000,0x03f80000)]
  0x038e7800 JavaThread "Worker-JM" [_thread_blocked, id=2828, stack(0x04480000,0x04580000)]
  0x038b3400 JavaThread "[Timer] - Main Queue Handler" daemon [_thread_blocked, id=3936, stack(0x03f80000,0x04080000)]
  0x0382c000 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=2180, stack(0x03d80000,0x03e80000)]
  0x0381e800 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=504, stack(0x03be0000,0x03ce0000)]
  0x037efc00 JavaThread "State Data Manager" daemon [_thread_blocked, id=2632, stack(0x03ae0000,0x03be0000)]
  0x03824400 JavaThread "Framework Active Thread" [_thread_blocked, id=2212, stack(0x039e0000,0x03ae0000)]
  0x02eb4800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=3108, stack(0x03520000,0x03620000)]
  0x02eaec00 JavaThread "CompilerThread0" daemon [_thread_blocked, id=2732, stack(0x03420000,0x03520000)]
  0x02ead400 JavaThread "Attach Listener" daemon [_thread_blocked, id=2948, stack(0x03320000,0x03420000)]
  0x02eac000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=1972, stack(0x03220000,0x03320000)]
  0x02e9c400 JavaThread "Finalizer" daemon [_thread_blocked, id=616, stack(0x03120000,0x03220000)]
  0x02e97800 JavaThread "Reference Handler" daemon [_thread_blocked, id=3996, stack(0x03020000,0x03120000)]
=>0x008f6c00 JavaThread "main" [_thread_in_native, id=2532, stack(0x00030000,0x00130000)]
Other Threads:
  0x02e92800 VMThread [stack: 0x02f20000,0x03020000] [id=4084]
  0x02ebec00 WatcherThread [stack: 0x03620000,0x03720000] [id=3968]
VM state:at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread:  ([mutex/lock_event])
[0x008f5a08] UNKNOWN - owner thread: 0x02e92800
[0x008f5e68] UNKNOWN - owner thread: 0x05417400
Heap
 def new generation   total 6592K, used 109K [0x08010000, 0x08730000, 0x09d90000)
  eden space 5888K,   1% used [0x08010000, 0x0802b590, 0x085d0000)
  from space 704K,   0% used [0x085d0000, 0x085d0000, 0x08680000)
  to   space 704K,   0% used [0x08680000, 0x08680000, 0x08730000)
 tenured generation   total 86736K, used 35973K [0x09d90000, 0x0f244000, 0x20010000)
   the space 86736K,  41% used [0x09d90000, 0x0c0b1790, 0x0c0b1800, 0x0f244000)
 compacting perm gen  total 46592K, used 46484K [0x20010000, 0x22d90000, 0x30010000)
   the space 46592K,  99% used [0x20010000, 0x22d75318, 0x22d75400, 0x22d90000)
No shared spaces configured.
Dynamic libraries:
0x00400000 - 0x0040d000 	C:\ti\ccsv5\eclipse\ccstudio.exe
0x7c900000 - 0x7c9b3000 	C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c8f8000 	C:\WINDOWS\system32\kernel32.dll
0x7e360000 - 0x7e3f1000 	C:\WINDOWS\system32\USER32.dll
0x77f10000 - 0x77f59000 	C:\WINDOWS\system32\GDI32.dll
0x5d5b0000 - 0x5d64a000 	C:\WINDOWS\system32\COMCTL32.dll
0x77dc0000 - 0x77e6c000 	C:\WINDOWS\system32\ADVAPI32.dll
0x77e70000 - 0x77f03000 	C:\WINDOWS\system32\RPCRT4.dll
0x77fe0000 - 0x77ff1000 	C:\WINDOWS\system32\Secur32.dll
0x77c00000 - 0x77c58000 	C:\WINDOWS\system32\MSVCRT.dll
0x76360000 - 0x7637d000 	C:\WINDOWS\system32\IMM32.DLL
0x72000000 - 0x7200d000 	C:\ti\ccsv5\eclipse\plugins\org.eclipse.equinox.launcher.win32.win32.x86_1.1.200.v20120522-1813\eclipse_1503.dll
0x77bf0000 - 0x77bf8000 	C:\WINDOWS\system32\VERSION.dll
0x08000000 - 0x08009000 	C:\Program Files\Yandex\Punto Switcher\pshook.dll
0x77f60000 - 0x77fdc000 	C:\WINDOWS\system32\SHLWAPI.dll
0x76c80000 - 0x76ca8000 	C:\WINDOWS\system32\imagehlp.dll
0x746e0000 - 0x7472c000 	C:\WINDOWS\system32\MSCTF.dll
0x75310000 - 0x7533e000 	C:\WINDOWS\system32\msctfime.ime
0x774d0000 - 0x7760e000 	C:\WINDOWS\system32\ole32.dll
0x6d800000 - 0x6da56000 	C:\ti\ccsv5\eclipse\jre\bin\client\jvm.dll
0x76b20000 - 0x76b4e000 	C:\WINDOWS\system32\WINMM.dll
0x7c360000 - 0x7c3b6000 	C:\WINDOWS\system32\MSVCR71.dll
0x6d290000 - 0x6d298000 	C:\ti\ccsv5\eclipse\jre\bin\hpi.dll
0x76be0000 - 0x76beb000 	C:\WINDOWS\system32\PSAPI.DLL
0x6d7b0000 - 0x6d7bc000 	C:\ti\ccsv5\eclipse\jre\bin\verify.dll
0x6d330000 - 0x6d34f000 	C:\ti\ccsv5\eclipse\jre\bin\java.dll
0x6d7f0000 - 0x6d7ff000 	C:\ti\ccsv5\eclipse\jre\bin\zip.dll
0x68000000 - 0x68036000 	C:\WINDOWS\system32\rsaenh.dll
0x769a0000 - 0x76a55000 	C:\WINDOWS\system32\USERENV.dll
0x5bd50000 - 0x5bda6000 	C:\WINDOWS\system32\netapi32.dll
0x6d610000 - 0x6d623000 	C:\ti\ccsv5\eclipse\jre\bin\net.dll
0x71a90000 - 0x71aa7000 	C:\WINDOWS\system32\WS2_32.dll
0x71a80000 - 0x71a88000 	C:\WINDOWS\system32\WS2HELP.dll
0x71a30000 - 0x71a70000 	C:\WINDOWS\System32\mswsock.dll
0x76f10000 - 0x76f37000 	C:\WINDOWS\system32\DNSAPI.dll
0x76d50000 - 0x76d69000 	C:\WINDOWS\system32\iphlpapi.dll
0x76fa0000 - 0x76fa8000 	C:\WINDOWS\System32\winrnr.dll
0x76f50000 - 0x76f7d000 	C:\WINDOWS\system32\WLDAP32.dll
0x76fb0000 - 0x76fb6000 	C:\WINDOWS\system32\rasadhlp.dll
0x6d630000 - 0x6d639000 	C:\ti\ccsv5\eclipse\jre\bin\nio.dll
0x04580000 - 0x045f0000 	C:\ti\ccsv5\eclipse\configuration\org.eclipse.osgi\bundles\306\2\.cp\swt-win32-3833.dll
0x77110000 - 0x7719b000 	C:\WINDOWS\system32\OLEAUT32.dll
0x76380000 - 0x763c9000 	C:\WINDOWS\system32\comdlg32.dll
0x773c0000 - 0x774c3000 	C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.6028_x-ww_61e65202\COMCTL32.dll
0x7c9c0000 - 0x7e33a000 	C:\WINDOWS\system32\SHELL32.dll
0x72fc0000 - 0x72fe6000 	C:\WINDOWS\system32\WINSPOOL.DRV
0x75540000 - 0x755ab000 	C:\WINDOWS\system32\USP10.dll
0x3f9e0000 - 0x3fae5000 	C:\WINDOWS\system32\WININET.dll
0x03d70000 - 0x03d79000 	C:\WINDOWS\system32\Normaliz.dll
0x45020000 - 0x45157000 	C:\WINDOWS\system32\urlmon.dll
0x40080000 - 0x4026b000 	C:\WINDOWS\system32\iertutil.dll
0x77a70000 - 0x77b06000 	C:\WINDOWS\system32\CRYPT32.dll
0x77b10000 - 0x77b22000 	C:\WINDOWS\system32\MSASN1.dll
0x04890000 - 0x048ad000 	C:\ti\ccsv5\eclipse\configuration\org.eclipse.osgi\bundles\306\2\.cp\swt-gdip-win32-3833.dll
0x4ebe0000 - 0x4ed8b000 	C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.6002.22509_x-ww_c7dad023\gdiplus.dll
0x5b260000 - 0x5b298000 	C:\WINDOWS\system32\uxtheme.dll
0x61880000 - 0x618ba000 	C:\WINDOWS\system32\oleacc.dll
0x05000000 - 0x0500f000 	C:\ti\ccsv5\eclipse\configuration\org.eclipse.osgi\bundles\90\2\.cp\jWinHttp-1.0.0.dll
0x4d550000 - 0x4d5a9000 	C:\WINDOWS\system32\WINHTTP.dll
0x76ed0000 - 0x76f0c000 	C:\WINDOWS\system32\RASAPI32.DLL
0x76e80000 - 0x76e92000 	C:\WINDOWS\system32\rasman.dll
0x76ea0000 - 0x76ecf000 	C:\WINDOWS\system32\TAPI32.dll
0x76e70000 - 0x76e7e000 	C:\WINDOWS\system32\rtutils.dll
0x77c60000 - 0x77c85000 	C:\WINDOWS\system32\msv1_0.dll
0x76770000 - 0x7677c000 	C:\WINDOWS\system32\cryptdll.dll
0x05ab0000 - 0x05dd7000 	C:\WINDOWS\system32\xpsp2res.dll
0x76350000 - 0x76355000 	C:\WINDOWS\system32\msimg32.dll
0x067f0000 - 0x067f6000 	C:\ti\ccsv5\ccs_base\DebugServer\bin\LibraryLoader.dll
0x7c420000 - 0x7c4a7000 	C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_44262b86\MSVCP80.dll
0x78130000 - 0x781cb000 	C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_44262b86\MSVCR80.dll
0x06820000 - 0x06a12000 	C:\ti\ccsv5\ccs_base\common\bin\xerces-c_2_5_0.dll
0x06a30000 - 0x06a53000 	C:\ti\ccsv5\ccs_base\common\bin\ti_logger.dll
0x06a70000 - 0x06ae5000 	C:\ti\ccsv5\ccs_base\common\bin\C4DLL.DLL
0x06c00000 - 0x06c10000 	C:\ti\ccsv5\ccs_base\common\bin\CCReg.dll
0x06c50000 - 0x06c97000 	C:\ti\ccsv5\ccs_base\common\bin\fsutil.dll
0x06cb0000 - 0x06cb8000 	C:\ti\ccsv5\ccs_base\common\bin\fsutiljni.dll
0x06cd0000 - 0x06cda000 	C:\ti\ccsv5\ccs_base\common\bin\MiniDump.dll
0x06cf0000 - 0x06e64000 	C:\ti\ccsv5\ccs_base\common\bin\setup_parser.dll
0x76fc0000 - 0x7703f000 	C:\WINDOWS\system32\CLBCATQ.DLL
0x06e80000 - 0x06f55000 	C:\WINDOWS\system32\COMRes.dll
0x40270000 - 0x40d06000 	C:\WINDOWS\system32\ieframe.dll
0x7e690000 - 0x7e748000 	C:\WINDOWS\system32\SXS.DLL
0x076a0000 - 0x07ae1000 	C:\WINDOWS\system32\msi.dll
0x71d20000 - 0x71d3b000 	C:\WINDOWS\system32\ACTXPRXY.DLL
0x07b80000 - 0x07bd0000 	C:\ti\ccsv5\ccs_base\DebugServer\bin\ti_xpcom.dll
0x59c60000 - 0x59d01000 	C:\WINDOWS\system32\DBGHELP.DLL
0x77680000 - 0x776a1000 	C:\WINDOWS\system32\NTMARTA.DLL
0x71bd0000 - 0x71be3000 	C:\WINDOWS\system32\SAMLIB.dll
0x07dd0000 - 0x07f70000 	C:\ti\ccsv5\ccs_base\DebugServer\bin\mdex.dll
0x71ab0000 - 0x71aba000 	C:\WINDOWS\system32\WSOCK32.dll
0x07f80000 - 0x07f9f000 	C:\ti\ccsv5\ccs_base\DebugServer\bin\XPCOMUtility.dll
0x30010000 - 0x3028d000 	C:\ti\ccsv5\ccs_base\DebugServer\license\mdexutil.dll
0x71f40000 - 0x71f48000 	C:\WINDOWS\system32\snmpapi.dll
0x77910000 - 0x77a04000 	C:\WINDOWS\system32\SETUPAPI.dll
0x74eb0000 - 0x74eb8000 	C:\WINDOWS\system32\wbem\wbemprox.dll
0x75250000 - 0x75287000 	C:\WINDOWS\system32\wbem\wbemcomn.dll
0x74e90000 - 0x74e9e000 	C:\WINDOWS\system32\wbem\wbemsvc.dll
0x698b0000 - 0x69908000 	C:\WINDOWS\system32\hnetcfg.dll
0x71a70000 - 0x71a78000 	C:\WINDOWS\System32\wshtcpip.dll
0x75660000 - 0x756d6000 	C:\WINDOWS\system32\wbem\fastprox.dll
0x76050000 - 0x760b5000 	C:\WINDOWS\system32\MSVCP60.dll
0x76780000 - 0x76794000 	C:\WINDOWS\system32\NTDSAPI.dll
0x76c20000 - 0x76c4e000 	C:\WINDOWS\system32\WINTRUST.dll
0x77b30000 - 0x77b52000 	C:\WINDOWS\system32\appHelp.dll
0x3f020000 - 0x3f5d7000 	C:\WINDOWS\system32\mshtml.dll
0x74680000 - 0x746a7000 	C:\WINDOWS\system32\msls31.dll
0x75da0000 - 0x75e31000 	C:\WINDOWS\system32\mlang.dll
0x30720000 - 0x30778000 	C:\Program Files\Internet Explorer\pdm.dll
0x309d0000 - 0x30a12000 	C:\WINDOWS\system32\msdbg2.dll
0x72ce0000 - 0x72ce9000 	C:\WINDOWS\system32\wdmaud.drv
0x72cd0000 - 0x72cd8000 	C:\WINDOWS\system32\msacm32.drv
0x77bd0000 - 0x77be5000 	C:\WINDOWS\system32\MSACM32.dll
0x77bc0000 - 0x77bc7000 	C:\WINDOWS\system32\midimap.dll
0x32370000 - 0x323e1000 	C:\WINDOWS\system32\jscript.dll
0x32700000 - 0x33027000 	C:\WINDOWS\system32\Macromed\Flash\Flash11e.ocx
0x73ed0000 - 0x73f2c000 	C:\WINDOWS\system32\DSOUND.dll
0x4fd70000 - 0x4ff16000 	C:\WINDOWS\system32\d3d9.dll
0x6df20000 - 0x6df26000 	C:\WINDOWS\system32\d3d8thk.dll
0x73af0000 - 0x73b05000 	C:\WINDOWS\system32\mscms.dll
0x33470000 - 0x3347c000 	C:\WINDOWS\system32\ImgUtil.dll
0x33480000 - 0x3348e000 	C:\WINDOWS\system32\pngfilt.dll
0x6d790000 - 0x6d798000 	C:\ti\ccsv5\eclipse\jre\bin\sunmscapi.dll
0x334a0000 - 0x334ad000 	C:\Documents and Settings\user\Local Settings\TEMP\ext1786711395430827427.dll
VM Arguments:
jvm_args: -Dosgi.requiredJavaVersion=1.5 -Dosgi.instance.area.default=@user.home/workspace_v5_3 -Dorg.eclipse.equinox.http.jetty.customizer.class=com.ti.ccstudio.gui.composer.http.jetty.MaqettaJettyCustomizer -Xms40m -Xmx384m -XX:MaxPermSize=256M
java_command: <unknown>
Launcher Type: generic
Environment Variables:
PATH=C:\ti\ccsv5\ccs_base\common\bin;C:\ti\ccsv5\ccs_base\common\uscif;C:\ti\ccsv5\ccs_base\DebugServer\license;C:/ti/ccsv5/eclipse/jre/bin/client;C:/ti/ccsv5/eclipse/jre/bin;C:/ti/ccsv5/eclipse/jre/lib/i386;C:\Program Files\PC Connectivity Solution\;C:\Program Files\Common Files\Siemens\bin;C:\Program Files\Common Files\Siemens\Sqlany;C:\Program Files\Siemens\Step7\S7bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Common Files\Acronis\SnapAPI\;C:\WINDOWS\system32\WindowsPowerShell\v1.0;"C:\Program Files\PKWARE\pkzipc";C:\PROGRA~1\Borland\Delphi6\Bin;C:\PROGRA~1\Borland\Delphi6\Projects\Bpl;C:\Program Files\Mercurial\;C:\Program Files\gEDA\gEDA\bin;C:\Program Files\gEDA\UnxUtils\usr\local\wbin;C:\Program Files\gEDA\GhostScript\bin;C:\Program Files\gEDA\GhostScript\lib;C:\ti\ccsv5\eclipse;
USERNAME=user
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 6 Model 42 Stepping 7, GenuineIntel
---------------  S Y S T E M  ---------------
OS: Windows XP Build 2600 Service Pack 3
CPU:total 2 (8 cores per cpu, 2 threads per core) family 6 model 10 stepping 7, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, ht
Memory: 4k page, physical 2003012k(1174960k free), swap 3943524k(3160624k free)
vm_info: Java HotSpot(TM) Client VM (11.3-b02) for windows-x86 JRE (1.6.0_13-b03), built on Mar  9 2009 01:15:24 by "java_re" with MS VC++ 7.1
time: Fri Aug 23 10:28:33 2013
elapsed time: 17 seconds
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x3f229c98, pid=2952, tid=1668
Current thread (0x00ad6c00):  JavaThread "main" [_thread_in_native, id=1668, stack(0x00030000,0x00130000)]
Registers:
EAX=0x00000000, EBX=0x00000113, ECX=0x32580af8, EDX=0x00000000
ESP=0x0012f1c8, EBP=0x0012f1cc, ESI=0x001ac418, EDI=0x305b0060
Top of Stack: (sp=0x0012f1c8)
0x0012f1c8:   00000000 0012f1dc 3f264984 00000000
0x0012f1d8:   0000031a 0012f1ec 3f11db60 305b4060
0x0012f1e8:   00001012 0012f210 3f11db6c 00002001
0x0012f1f8:   0012f278 3f0f512a 00000000 00000000
0x0012f208:   00000000 00000000 0012f23c 7e368734
0x0012f218:   000d0412 00000083 00002001 00000000
0x0012f228:   3f0f512a dcbaabcd 00000000 0012f278
0x0012f238:   3f0f512a 0012f2a4 7e368816 3f0f512a
Stack: [0x00030000,0x00130000],  sp=0x0012f1c8,  free space=1020k
  0x04247c00 JavaThread "Scripting Console - Rhino" [_thread_blocked, id=2680, stack(0x32390000,0x32490000)]
  0x040f2c00 JavaThread "Worker-7" [_thread_blocked, id=1084, stack(0x06700000,0x06800000)]
  0x038fe400 JavaThread "Worker-6" [_thread_blocked, id=3112, stack(0x06600000,0x06700000)]
  0x038dc400 JavaThread "Worker-5" [_thread_blocked, id=2980, stack(0x06500000,0x06600000)]
  0x03830000 JavaThread "Worker-4" [_thread_blocked, id=1860, stack(0x06400000,0x06500000)]
  0x0392e800 JavaThread "Worker-3" [_thread_blocked, id=2704, stack(0x04d40000,0x04e40000)]
  0x041b2000 JavaThread "Worker-2" [_thread_blocked, id=732, stack(0x04a20000,0x04b20000)]
  0x05377c00 JavaThread "Bundle File Closer" daemon [_thread_blocked, id=376, stack(0x06000000,0x06100000)]
  0x0436f400 JavaThread "Worker-1" [_thread_blocked, id=2784, stack(0x04c40000,0x04d40000)]
  0x0386a000 JavaThread "Worker-0" [_thread_blocked, id=3076, stack(0x03e70000,0x03f70000)]
  0x0392a800 JavaThread "Worker-JM" [_thread_blocked, id=1908, stack(0x04470000,0x04570000)]
  0x038d5400 JavaThread "[Timer] - Main Queue Handler" daemon [_thread_blocked, id=1288, stack(0x03f70000,0x04070000)]
  0x03802800 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=3888, stack(0x03d70000,0x03e70000)]
  0x03843000 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=644, stack(0x03c70000,0x03d70000)]
  0x03841400 JavaThread "State Data Manager" daemon [_thread_blocked, id=380, stack(0x03b70000,0x03c70000)]
  0x03831400 JavaThread "Framework Active Thread" [_thread_blocked, id=2940, stack(0x03a70000,0x03b70000)]
  0x02ec3c00 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=2708, stack(0x03530000,0x03630000)]
  0x02ebec00 JavaThread "CompilerThread0" daemon [_thread_blocked, id=3300, stack(0x03430000,0x03530000)]
  0x02ebd400 JavaThread "Attach Listener" daemon [_thread_blocked, id=1296, stack(0x03330000,0x03430000)]
  0x02ebc000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=3752, stack(0x03230000,0x03330000)]
  0x02eac400 JavaThread "Finalizer" daemon [_thread_blocked, id=1212, stack(0x03130000,0x03230000)]
  0x02ea7800 JavaThread "Reference Handler" daemon [_thread_blocked, id=1076, stack(0x03030000,0x03130000)]
=>0x00ad6c00 JavaThread "main" [_thread_in_native, id=1668, stack(0x00030000,0x00130000)]
Other Threads:
  0x02ea2800 VMThread [stack: 0x02f30000,0x03030000] [id=1904]
  0x02ec6c00 WatcherThread [stack: 0x03630000,0x03730000] [id=2700]
[0x00ad5a08] UNKNOWN - owner thread: 0x02ea2800
[0x00ad5e68] UNKNOWN - owner thread: 0x0436f400
Heap
 def new generation   total 6848K, used 307K [0x08010000, 0x08770000, 0x09d90000)
  eden space 6144K,   4% used [0x08010000, 0x0805cca0, 0x08610000)
  from space 704K,   0% used [0x086c0000, 0x086c0000, 0x08770000)
  to   space 704K,   0% used [0x08610000, 0x08610000, 0x086c0000)
 tenured generation   total 89396K, used 36381K [0x09d90000, 0x0f4dd000, 0x20010000)
   the space 89396K,  40% used [0x09d90000, 0x0c117450, 0x0c117600, 0x0f4dd000)
 compacting perm gen  total 48640K, used 48552K [0x20010000, 0x22f90000, 0x30010000)
   the space 48640K,  99% used [0x20010000, 0x22f7a130, 0x22f7a200, 0x22f90000)
Dynamic libraries:
0x04570000 - 0x045e0000 	C:\ti\ccsv5\eclipse\configuration\org.eclipse.osgi\bundles\306\2\.cp\swt-win32-3833.dll
0x045e0000 - 0x045e9000 	C:\WINDOWS\system32\Normaliz.dll
0x04ff0000 - 0x04fff000 	C:\ti\ccsv5\eclipse\configuration\org.eclipse.osgi\bundles\90\2\.cp\jWinHttp-1.0.0.dll
0x05aa0000 - 0x05dc7000 	C:\WINDOWS\system32\xpsp2res.dll
0x04b20000 - 0x04b26000 	C:\ti\ccsv5\ccs_base\DebugServer\bin\LibraryLoader.dll
0x06800000 - 0x069f2000 	C:\ti\ccsv5\ccs_base\common\bin\xerces-c_2_5_0.dll
0x04b80000 - 0x04ba3000 	C:\ti\ccsv5\ccs_base\common\bin\ti_logger.dll
0x06a00000 - 0x06a75000 	C:\ti\ccsv5\ccs_base\common\bin\C4DLL.DLL
0x06b80000 - 0x06b90000 	C:\ti\ccsv5\ccs_base\common\bin\CCReg.dll
0x06ba0000 - 0x06be7000 	C:\ti\ccsv5\ccs_base\common\bin\fsutil.dll
0x06c00000 - 0x06c08000 	C:\ti\ccsv5\ccs_base\common\bin\fsutiljni.dll
0x06c20000 - 0x06c2a000 	C:\ti\ccsv5\ccs_base\common\bin\MiniDump.dll
0x06c40000 - 0x06db4000 	C:\ti\ccsv5\ccs_base\common\bin\setup_parser.dll
0x06e90000 - 0x06f65000 	C:\WINDOWS\system32\COMRes.dll
0x076b0000 - 0x07af1000 	C:\WINDOWS\system32\msi.dll
0x07b90000 - 0x07be0000 	C:\ti\ccsv5\ccs_base\DebugServer\bin\ti_xpcom.dll
0x07de0000 - 0x07f80000 	C:\ti\ccsv5\ccs_base\DebugServer\bin\mdex.dll
0x07f90000 - 0x07faf000 	C:\ti\ccsv5\ccs_base\DebugServer\bin\XPCOMUtility.dll
0x30690000 - 0x306e8000 	C:\Program Files\Internet Explorer\pdm.dll
0x30950000 - 0x30992000 	C:\WINDOWS\system32\msdbg2.dll
0x30dd0000 - 0x30e41000 	C:\WINDOWS\system32\jscript.dll
0x32790000 - 0x330b7000 	C:\WINDOWS\system32\Macromed\Flash\Flash11e.ocx
0x334f0000 - 0x334fc000 	C:\WINDOWS\system32\ImgUtil.dll
0x33500000 - 0x3350e000 	C:\WINDOWS\system32\pngfilt.dll
0x33520000 - 0x3352d000 	C:\Documents and Settings\user\Local Settings\TEMP\ext1343078557914614030.dll
VM Arguments:
USERNAME=user
OS=Windows_NT
Memory: 4k page, physical 2003012k(1182212k free), swap 3943524k(3158436k free)
time: Fri Aug 23 10:29:39 2013
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x3f229c98, pid=2988, tid=304
Current thread (0x008f6c00):  JavaThread "main" [_thread_in_native, id=304, stack(0x00030000,0x00130000)]
Registers:
EAX=0x00000000, EBX=0x00000113, ECX=0x32c40008, EDX=0x00000000
ESP=0x0012efe8, EBP=0x0012efec, ESI=0x0023ec58, EDI=0x3231f860
Top of Stack: (sp=0x0012efe8)
0x0012efe8:   00000000 0012effc 3f264984 00000000
0x0012eff8:   0000031a 0012f00c 3f11db60 32305860
0x0012f008:   00001012 0012f030 3f11db6c 00002000
0x0012f018:   0012f098 3f0f512a 00000000 00000000
0x0012f028:   00000001 00000000 0012f05c 7e368734
0x0012f038:   000a04c2 00000083 00002000 00000000
0x0012f048:   3f0f512a dcbaabcd 00000000 0012f098
0x0012f058:   3f0f512a 0012f0c4 7e368816 3f0f512a
Stack: [0x00030000,0x00130000],  sp=0x0012efe8,  free space=1019k
J  org.eclipse.swt.widgets.Display.readAndDispatch()Z
  0x0438a800 JavaThread "Thread-4" [_thread_blocked, id=2728, stack(0x31d80000,0x31e80000)]
  0x03725400 JavaThread "Scripting Console - Rhino" [_thread_blocked, id=1744, stack(0x31c80000,0x31d80000)]
  0x06943400 JavaThread "Worker-6" [_thread_blocked, id=2644, stack(0x30410000,0x30510000)]
  0x066e1c00 JavaThread "Worker-5" [_thread_in_native, id=3460, stack(0x07480000,0x07580000)]
  0x040c3800 JavaThread "Worker-4" [_thread_in_native, id=3296, stack(0x07380000,0x07480000)]
  0x043cb400 JavaThread "Worker-3" [_thread_blocked, id=3100, stack(0x063d0000,0x064d0000)]
  0x04179000 JavaThread "Worker-2" [_thread_blocked, id=3112, stack(0x05a10000,0x05b10000)]
  0x065b8400 JavaThread "Bundle File Closer" daemon [_thread_blocked, id=2560, stack(0x06f60000,0x07060000)]
  0x04328000 JavaThread "Worker-1" [_thread_blocked, id=2596, stack(0x062d0000,0x063d0000)]
  0x02ec3800 JavaThread "Worker-0" [_thread_blocked, id=2804, stack(0x05910000,0x05a10000)]
  0x04185000 JavaThread "[ThreadPool Manager] - Idle Thread" daemon [_thread_blocked, id=1084, stack(0x05700000,0x05800000)]
  0x040b5000 JavaThread "Worker-JM" [_thread_blocked, id=356, stack(0x04490000,0x04590000)]
  0x0385fc00 JavaThread "[Timer] - Main Queue Handler" daemon [_thread_blocked, id=2792, stack(0x03f90000,0x04090000)]
  0x0380d000 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=3844, stack(0x03d80000,0x03e80000)]
  0x03805c00 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=3284, stack(0x03be0000,0x03ce0000)]
  0x037de400 JavaThread "State Data Manager" daemon [_thread_blocked, id=2680, stack(0x03ae0000,0x03be0000)]
  0x0380e400 JavaThread "Framework Active Thread" [_thread_blocked, id=3132, stack(0x039e0000,0x03ae0000)]
  0x02eb4800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=2584, stack(0x03520000,0x03620000)]
  0x02eaec00 JavaThread "CompilerThread0" daemon [_thread_blocked, id=3864, stack(0x03420000,0x03520000)]
  0x02ead400 JavaThread "Attach Listener" daemon [_thread_blocked, id=3052, stack(0x03320000,0x03420000)]
  0x02eac000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=3884, stack(0x03220000,0x03320000)]
  0x02e9c400 JavaThread "Finalizer" daemon [_thread_blocked, id=2544, stack(0x03120000,0x03220000)]
  0x02e97800 JavaThread "Reference Handler" daemon [_thread_blocked, id=2268, stack(0x03020000,0x03120000)]
=>0x008f6c00 JavaThread "main" [_thread_in_native, id=304, stack(0x00030000,0x00130000)]
Other Threads:
  0x02e92800 VMThread [stack: 0x02f20000,0x03020000] [id=3852]
  0x02ebec00 WatcherThread [stack: 0x03620000,0x03720000] [id=2552]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
 def new generation   total 6784K, used 2899K [0x08010000, 0x08760000, 0x09d90000)
  eden space 6080K,  40% used [0x08010000, 0x0827e358, 0x08600000)
  from space 704K,  58% used [0x086b0000, 0x08716b60, 0x08760000)
  to   space 704K,   0% used [0x08600000, 0x08600000, 0x086b0000)
 tenured generation   total 88960K, used 36404K [0x09d90000, 0x0f470000, 0x20010000)
   the space 88960K,  40% used [0x09d90000, 0x0c11d148, 0x0c11d200, 0x0f470000)
 compacting perm gen  total 49152K, used 49151K [0x20010000, 0x23010000, 0x30010000)
   the space 49152K,  99% used [0x20010000, 0x2300fe20, 0x23010000, 0x23010000)
Dynamic libraries:
0x03e80000 - 0x03ef0000 	C:\ti\ccsv5\eclipse\configuration\org.eclipse.osgi\bundles\306\2\.cp\swt-win32-3833.dll
0x03ef0000 - 0x03ef9000 	C:\WINDOWS\system32\Normaliz.dll
0x047b0000 - 0x047cd000 	C:\ti\ccsv5\eclipse\configuration\org.eclipse.osgi\bundles\306\2\.cp\swt-gdip-win32-3833.dll
0x5b260000 - 0x5b298000 	C:\WINDOWS\system32\UxTheme.dll
0x04af0000 - 0x04bc5000 	C:\WINDOWS\system32\COMRes.dll
0x04bd0000 - 0x04d97000 	C:\WINDOWS\system32\shdocvw.dll
0x76650000 - 0x766e4000 	C:\WINDOWS\system32\CRYPTUI.dll
0x64e40000 - 0x64e61000 	C:\Program Files\AVAST Software\Avast\ashShell.dll
0x04f30000 - 0x05371000 	C:\WINDOWS\system32\msi.dll
0x05380000 - 0x05429000 	C:\WINDOWS\System32\cscui.dll
0x765d0000 - 0x765ed000 	C:\WINDOWS\System32\CSCDLL.dll
0x55df0000 - 0x55dfd000 	C:\WINDOWS\system32\AcSignIcon.dll
0x782e0000 - 0x783ef000 	C:\WINDOWS\WinSxS\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_150c9e8b\MFC80U.DLL
0x75f50000 - 0x7604e000 	C:\WINDOWS\system32\browseui.dll
0x75da0000 - 0x75e31000 	C:\WINDOWS\system32\MLANG.dll
0x71b00000 - 0x71b12000 	C:\WINDOWS\system32\MPR.dll
0x75f30000 - 0x75f37000 	C:\WINDOWS\System32\drprov.dll
0x71bf0000 - 0x71bfe000 	C:\WINDOWS\System32\ntlanman.dll
0x71cb0000 - 0x71cc7000 	C:\WINDOWS\System32\NETUI0.dll
0x71c70000 - 0x71cb0000 	C:\WINDOWS\System32\NETUI1.dll
0x71c60000 - 0x71c67000 	C:\WINDOWS\System32\NETRAP.dll
0x71bd0000 - 0x71be3000 	C:\WINDOWS\System32\SAMLIB.dll
0x75f40000 - 0x75f4a000 	C:\WINDOWS\System32\davclnt.dll
0x05660000 - 0x056a1000 	C:\WINDOWS\system32\portabledeviceapi.dll
0x05ca0000 - 0x05fc7000 	C:\WINDOWS\system32\xpsp2res.dll
0x73b60000 - 0x73b74000 	C:\WINDOWS\system32\sti.dll
0x74aa0000 - 0x74aa7000 	C:\WINDOWS\system32\CFGMGR32.dll
0x76960000 - 0x76968000 	C:\WINDOWS\system32\LINKINFO.dll
0x76970000 - 0x76996000 	C:\WINDOWS\system32\ntshrui.dll
0x76b00000 - 0x76b11000 	C:\WINDOWS\system32\ATL.DLL
0x55fe0000 - 0x56032000 	C:\Program Files\Common Files\Autodesk Shared\AcSignCore16.dll
0x056b0000 - 0x056bc000 	C:\WINDOWS\system32\btncopy.dll
0x723f0000 - 0x7240b000 	C:\WINDOWS\system32\mydocs.dll
0x05c90000 - 0x05c9f000 	C:\ti\ccsv5\eclipse\configuration\org.eclipse.osgi\bundles\90\2\.cp\jWinHttp-1.0.0.dll
0x05b10000 - 0x05b16000 	C:\ti\ccsv5\ccs_base\DebugServer\bin\LibraryLoader.dll
0x07580000 - 0x07772000 	C:\ti\ccsv5\ccs_base\common\bin\xerces-c_2_5_0.dll
0x05b60000 - 0x05b83000 	C:\ti\ccsv5\ccs_base\common\bin\ti_logger.dll
0x07780000 - 0x077f5000 	C:\ti\ccsv5\ccs_base\common\bin\C4DLL.DLL
0x07180000 - 0x07190000 	C:\ti\ccsv5\ccs_base\common\bin\CCReg.dll
0x07910000 - 0x07957000 	C:\ti\ccsv5\ccs_base\common\bin\fsutil.dll
0x07970000 - 0x07978000 	C:\ti\ccsv5\ccs_base\common\bin\fsutiljni.dll
0x07990000 - 0x0799a000 	C:\ti\ccsv5\ccs_base\common\bin\MiniDump.dll
0x079b0000 - 0x07b24000 	C:\ti\ccsv5\ccs_base\common\bin\setup_parser.dll
0x07fa0000 - 0x07ff0000 	C:\ti\ccsv5\ccs_base\DebugServer\bin\ti_xpcom.dll
0x31610000 - 0x317b0000 	C:\ti\ccsv5\ccs_base\DebugServer\bin\mdex.dll
0x317b0000 - 0x317cf000 	C:\ti\ccsv5\ccs_base\DebugServer\bin\XPCOMUtility.dll
0x317e0000 - 0x31a5d000 	C:\ti\ccsv5\ccs_base\DebugServer\license\mdexutil.dll
VM Arguments:
USERNAME=user
OS=Windows_NT
Memory: 4k page, physical 2003012k(1163952k free), swap 3943524k(3151136k free)
time: Fri Aug 23 10:26:52 2013
elapsed time: 130 seconds
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x3f229c98, pid=3972, tid=2676
Current thread (0x008f6c00):  JavaThread "main" [_thread_in_native, id=2676, stack(0x00030000,0x00130000)]
Registers:
EAX=0x00000000, EBX=0x00000113, ECX=0x314f0560, EDX=0x00000000
ESP=0x0012db08, EBP=0x0012db0c, ESI=0x30c441b0, EDI=0x30cd0860
EIP=0x3f229c98, EFLAGS=0x00010246
Top of Stack: (sp=0x0012db08)
0x0012db08:   00000000 0012db1c 3f264984 00000000
0x0012db18:   0000031a 0012db2c 3f11db60 30c62860
0x0012db28:   00001012 0012db50 3f11db6c 00002000
0x0012db38:   0012dbb8 3f0f512a 00000000 00000000
0x0012db48:   00000102 00000000 0012db7c 7e368734
0x0012db58:   0004051c 00000083 00002000 00000000
0x0012db68:   3f0f512a dcbaabcd 00000000 0012dbb8
0x0012db78:   3f0f512a 0012dbe4 7e368816 3f0f512a
Stack: [0x00030000,0x00130000],  sp=0x0012db08,  free space=1014k
j  org.eclipse.jface.dialogs.MessageDialog.open()I+1
j  org.eclipse.jface.dialogs.MessageDialog.open(ILorg/eclipse/swt/widgets/Shell;Ljava/lang/String;Ljava/lang/String;I)Z+41
j  org.eclipse.jface.dialogs.MessageDialog.openInformation(Lorg/eclipse/swt/widgets/Shell;Ljava/lang/String;Ljava/lang/String;)V+5
j  com.ti.ccstudio.debug.ui.licensing.LicenseMonitor.showLicenseDialog(Lorg/eclipse/swt/widgets/Shell;Lcom/ti/license/ILicenseAction;Z)V+75
j  org.eclipse.swt.widgets.Shell.WM_ENTERIDLE(II)Lorg/eclipse/swt/internal/win32/LRESULT;+30
J  org.eclipse.swt.widgets.Control.windowProc(IIII)I
j  org.eclipse.swt.widgets.Canvas.windowProc(IIII)I+45
j  org.eclipse.swt.widgets.Decorations.windowProc(IIII)I+61
j  org.eclipse.swt.widgets.Shell.windowProc(IIII)I+131
J  org.eclipse.swt.widgets.Display.windowProc(IIII)I
J  org.eclipse.swt.internal.win32.OS.DefWindowProcW(IIII)I
J  org.eclipse.swt.internal.win32.OS.DefWindowProc(IIII)I
j  org.eclipse.swt.widgets.Shell.callWindowProc(IIII)I+166
  0x038e6400 JavaThread "Worker-8" [_thread_in_Java, id=496, stack(0x06930000,0x06a30000)]
  0x05495400 JavaThread "Worker-7" [_thread_blocked, id=3792, stack(0x06830000,0x06930000)]
  0x05495800 JavaThread "Worker-6" [_thread_blocked, id=3920, stack(0x06730000,0x06830000)]
  0x0386c800 JavaThread "Worker-5" [_thread_blocked, id=396, stack(0x06630000,0x06730000)]
  0x040fe800 JavaThread "Worker-4" [_thread_in_native, id=380, stack(0x06530000,0x06630000)]
  0x0436cc00 JavaThread "Worker-3" [_thread_in_native, id=788, stack(0x04f80000,0x05080000)]
  0x0391e400 JavaThread "Worker-2" [_thread_blocked, id=2852, stack(0x04be0000,0x04ce0000)]
  0x05463400 JavaThread "Bundle File Closer" daemon [_thread_blocked, id=2388, stack(0x06140000,0x06240000)]
  0x04332400 JavaThread "Worker-1" [_thread_blocked, id=3996, stack(0x04e80000,0x04f80000)]
  0x0425d400 JavaThread "[ThreadPool Manager] - Idle Thread" daemon [_thread_blocked, id=4044, stack(0x04d80000,0x04e80000)]
  0x02e86000 JavaThread "Worker-0" [_thread_blocked, id=3748, stack(0x04ae0000,0x04be0000)]
  0x04083000 JavaThread "Worker-JM" [_thread_blocked, id=2856, stack(0x04480000,0x04580000)]
  0x0384e800 JavaThread "[Timer] - Main Queue Handler" daemon [_thread_blocked, id=2840, stack(0x03f80000,0x04080000)]
  0x03811c00 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=2756, stack(0x03d80000,0x03e80000)]
  0x037ef400 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=2752, stack(0x03be0000,0x03ce0000)]
  0x03837400 JavaThread "State Data Manager" daemon [_thread_blocked, id=2748, stack(0x03ae0000,0x03be0000)]
  0x037fe000 JavaThread "Framework Active Thread" [_thread_blocked, id=2744, stack(0x039e0000,0x03ae0000)]
  0x02eb4800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=2732, stack(0x03520000,0x03620000)]
  0x02eaec00 JavaThread "CompilerThread0" daemon [_thread_blocked, id=2724, stack(0x03420000,0x03520000)]
  0x02ead400 JavaThread "Attach Listener" daemon [_thread_blocked, id=2728, stack(0x03320000,0x03420000)]
  0x02eac000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=392, stack(0x03220000,0x03320000)]
  0x02e9c400 JavaThread "Finalizer" daemon [_thread_blocked, id=2704, stack(0x03120000,0x03220000)]
  0x02e97800 JavaThread "Reference Handler" daemon [_thread_blocked, id=2700, stack(0x03020000,0x03120000)]
=>0x008f6c00 JavaThread "main" [_thread_in_native, id=2676, stack(0x00030000,0x00130000)]
Other Threads:
  0x02e92800 VMThread [stack: 0x02f20000,0x03020000] [id=2696]
  0x02ebec00 WatcherThread [stack: 0x03620000,0x03720000] [id=2736]
Heap
 def new generation   total 4736K, used 1299K [0x08010000, 0x08530000, 0x09d90000)
  eden space 4224K,  18% used [0x08010000, 0x080d4cc8, 0x08430000)
  from space 512K, 100% used [0x08430000, 0x084b0000, 0x084b0000)
  to   space 512K,   0% used [0x084b0000, 0x084b0000, 0x08530000)
 tenured generation   total 62320K, used 38412K [0x09d90000, 0x0da6c000, 0x20010000)
   the space 62320K,  61% used [0x09d90000, 0x0c313260, 0x0c313400, 0x0da6c000)
 compacting perm gen  total 43520K, used 43489K [0x20010000, 0x22a90000, 0x30010000)
   the space 43520K,  99% used [0x20010000, 0x22a88690, 0x22a88800, 0x22a90000)
Dynamic libraries:
0x04790000 - 0x047ad000 	C:\ti\ccsv5\eclipse\configuration\org.eclipse.osgi\bundles\306\2\.cp\swt-gdip-win32-3833.dll
0x050d0000 - 0x050df000 	C:\ti\ccsv5\eclipse\configuration\org.eclipse.osgi\bundles\90\2\.cp\jWinHttp-1.0.0.dll
0x05be0000 - 0x05f07000 	C:\WINDOWS\system32\xpsp2res.dll
0x04d50000 - 0x04d56000 	C:\ti\ccsv5\ccs_base\DebugServer\bin\LibraryLoader.dll
0x06a70000 - 0x06c62000 	C:\ti\ccsv5\ccs_base\common\bin\xerces-c_2_5_0.dll
0x06c80000 - 0x06ca3000 	C:\ti\ccsv5\ccs_base\common\bin\ti_logger.dll
0x06cc0000 - 0x06d35000 	C:\ti\ccsv5\ccs_base\common\bin\C4DLL.DLL
0x06e50000 - 0x06e60000 	C:\ti\ccsv5\ccs_base\common\bin\CCReg.dll
0x06e70000 - 0x06eb7000 	C:\ti\ccsv5\ccs_base\common\bin\fsutil.dll
0x06ed0000 - 0x06ed8000 	C:\ti\ccsv5\ccs_base\common\bin\fsutiljni.dll
0x06ef0000 - 0x06efa000 	C:\ti\ccsv5\ccs_base\common\bin\MiniDump.dll
0x06f10000 - 0x07084000 	C:\ti\ccsv5\ccs_base\common\bin\setup_parser.dll
0x070a0000 - 0x07175000 	C:\WINDOWS\system32\COMRes.dll
0x078c0000 - 0x07d01000 	C:\WINDOWS\system32\msi.dll
0x07da0000 - 0x07df0000 	C:\ti\ccsv5\ccs_base\DebugServer\bin\ti_xpcom.dll
0x30010000 - 0x301b0000 	C:\ti\ccsv5\ccs_base\DebugServer\bin\mdex.dll
0x301b0000 - 0x301cf000 	C:\ti\ccsv5\ccs_base\DebugServer\bin\XPCOMUtility.dll
0x301e0000 - 0x3045d000 	C:\ti\ccsv5\ccs_base\DebugServer\license\mdexutil.dll
0x304a0000 - 0x304f8000 	C:\Program Files\Internet Explorer\pdm.dll
0x30510000 - 0x30552000 	C:\WINDOWS\system32\msdbg2.dll
0x30ba0000 - 0x30bad000 	C:\Documents and Settings\user\Local Settings\TEMP\ext7077545307268229384.dll
0x313e0000 - 0x31451000 	C:\WINDOWS\system32\jscript.dll
0x31800000 - 0x32127000 	C:\WINDOWS\system32\Macromed\Flash\Flash11e.ocx
0x32570000 - 0x3257c000 	C:\WINDOWS\system32\ImgUtil.dll
0x32790000 - 0x3279e000 	C:\WINDOWS\system32\pngfilt.dll
0x73b80000 - 0x73b86000 	C:\WINDOWS\system32\dciman32.dll
VM Arguments:
USERNAME=user
OS=Windows_NT
Memory: 4k page, physical 2003012k(1233360k free), swap 3943588k(3271024k free)
time: Fri Aug 23 10:44:34 2013
elapsed time: 75 seconds
PS: CCS5.3.0.00090_win32
    Can you attach the screenshot with the error?
    Gautam
  • I think a screen shot will not help you, because the main IDE window disappears (it is not visible). And the operating system does not display a windows error. Tomorrow I will record video and posted on the forum.
    Roman.
  • Ok, i guess re-installing will surely help you!
    Gautam
  • Hi Roman,
    Thanks for the logs.  We will post feedback as soon as we can.  Note my recommendation is also for the latest version.
    Lisa
  • After reinstalling.
    from WinDbg log:
    (bf0.378): Access violation - code c0000005 (first chance)
    First chance exceptions are reported before any exception handling.
    This exception may be expected and handled.
    eax=00000000 ebx=00000113 ecx=309f6da8 edx=00860608 esi=00152c88 edi=001521b8
    eip=3f229c98 esp=0012ef38 ebp=0012ef3c iopl=0         nv up ei pl zr na pe nc
    cs=001b  ss=0023  ds=0023  es=0023  fs=003b  gs=0000             efl=00210246
    *** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\system32\mshtml.dll -
    mshtml!Ordinal104+0x97e38:
    3f229c98 8b08            mov     ecx,dword ptr [eax]  ds:0023:00000000=????????
    0:000> g
    eax=00000001 ebx=00000000 ecx=7c8137fd edx=7c980620 esi=7c90de6e edi=00000001
    eip=7c90e514 esp=0012e908 ebp=0012ea04 iopl=0         nv up ei pl zr na pe nc
    cs=001b  ss=0023  ds=0023  es=0023  fs=003b  gs=0000             efl=00200246
    ntdll!KiFastSystemCallRet:
    7c90e514 c3              ret
    0:000> g
           ^ No runnable debuggees error in 'g'
    WinDbg log: 8780.WinDbg.css.5.3.output_cp1251.log
    error log:
    #  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x3f229c98, pid=4044, tid=2576
    Current thread (0x008d6c00):  JavaThread "main" [_thread_in_native, id=2576, stack(0x00030000,0x00130000)]
    Registers:
    EAX=0x00000000, EBX=0x00000113, ECX=0x31bbda98, EDX=0x00000000
    ESP=0x0012f1c8, EBP=0x0012f1cc, ESI=0x0019a678, EDI=0x3004e060
    0x0012f1d8:   0000031a 0012f1ec 3f11db60 30053060
    0x0012f208:   7751b0f6 00000000 0012f23c 7e368734
    0x0012f218:   0026042c 00000083 00002001 00000000
      0x2bf6f800 JavaThread "Thread-4" [_thread_blocked, id=2912, stack(0x30f30000,0x31030000)]
      0x2c00bc00 JavaThread "Scripting Console - Rhino" [_thread_blocked, id=2568, stack(0x30330000,0x30430000)]
      0x2d0bcc00 JavaThread "[ThreadPool Manager] - Idle Thread" daemon [_thread_blocked, id=2656, stack(0x2fc80000,0x2fd80000)]
      0x2b619c00 JavaThread "Worker-9" [_thread_in_native, id=2528, stack(0x2e7c0000,0x2e8c0000)]
      0x2bec2c00 JavaThread "Worker-8" [_thread_blocked, id=3752, stack(0x2e6c0000,0x2e7c0000)]
      0x2be8d000 JavaThread "Worker-7" [_thread_blocked, id=2688, stack(0x2e5c0000,0x2e6c0000)]
      0x2c142000 JavaThread "Worker-6" [_thread_blocked, id=3020, stack(0x2e4c0000,0x2e5c0000)]
      0x2b776c00 JavaThread "Worker-5" [_thread_blocked, id=360, stack(0x2e3c0000,0x2e4c0000)]
      0x2d0f4c00 JavaThread "Worker-4" [_thread_in_native, id=3232, stack(0x2e2c0000,0x2e3c0000)]
      0x2b768c00 JavaThread "Worker-3" [_thread_blocked, id=324, stack(0x2cdf0000,0x2cef0000)]
      0x2b6b0800 JavaThread "Worker-2" [_thread_blocked, id=3108, stack(0x2cb50000,0x2cc50000)]
      0x2cf5c800 JavaThread "Bundle File Closer" daemon [_thread_blocked, id=1088, stack(0x2d970000,0x2da70000)]
      0x2b7b0000 JavaThread "Worker-1" [_thread_blocked, id=3660, stack(0x2ccf0000,0x2cdf0000)]
      0x2c03d400 JavaThread "Worker-0" [_thread_blocked, id=2584, stack(0x2ca50000,0x2cb50000)]
      0x2beb8800 JavaThread "Worker-JM" [_thread_blocked, id=1824, stack(0x2c330000,0x2c430000)]
      0x2b74e800 JavaThread "[Timer] - Main Queue Handler" daemon [_thread_blocked, id=1196, stack(0x2bd60000,0x2be60000)]
      0x2b6d4c00 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=1384, stack(0x2bb60000,0x2bc60000)]
      0x2b6af000 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=3136, stack(0x2ba60000,0x2bb60000)]
      0x2b6b4800 JavaThread "State Data Manager" daemon [_thread_blocked, id=3120, stack(0x2b960000,0x2ba60000)]
      0x2b68b000 JavaThread "Framework Active Thread" [_thread_blocked, id=1844, stack(0x2b860000,0x2b960000)]
      0x2ad55000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=1268, stack(0x2b3c0000,0x2b4c0000)]
      0x2ad4ec00 JavaThread "CompilerThread0" daemon [_thread_blocked, id=1860, stack(0x2b2c0000,0x2b3c0000)]
      0x2ad4d400 JavaThread "Attach Listener" daemon [_thread_blocked, id=2788, stack(0x2b1c0000,0x2b2c0000)]
      0x2ad4c000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=2780, stack(0x2b0c0000,0x2b1c0000)]
      0x2ad3c400 JavaThread "Finalizer" daemon [_thread_blocked, id=2960, stack(0x2afc0000,0x2b0c0000)]
      0x2ad37800 JavaThread "Reference Handler" daemon [_thread_blocked, id=1924, stack(0x2aec0000,0x2afc0000)]
    =>0x008d6c00 JavaThread "main" [_thread_in_native, id=2576, stack(0x00030000,0x00130000)]
    Other Threads:
      0x2ad32800 VMThread [stack: 0x2adc0000,0x2aec0000] [id=3472]
      0x2ad56c00 WatcherThread [stack: 0x2b4c0000,0x2b5c0000] [id=2868]
    Heap
     def new generation   total 6208K, used 3300K [0x02a20000, 0x030d0000, 0x047a0000)
      eden space 5568K,  58% used [0x02a20000, 0x02d487a8, 0x02f90000)
      from space 640K,  10% used [0x03030000, 0x03040978, 0x030d0000)
      to   space 640K,   0% used [0x02f90000, 0x02f90000, 0x03030000)
     tenured generation   total 81436K, used 37389K [0x047a0000, 0x09727000, 0x1aa20000)
       the space 81436K,  45% used [0x047a0000, 0x06c235b0, 0x06c23600, 0x09727000)
     compacting perm gen  total 49408K, used 49237K [0x1aa20000, 0x1da60000, 0x2aa20000)
       the space 49408K,  99% used [0x1aa20000, 0x1da35728, 0x1da35800, 0x1da60000)
    Dynamic libraries:
    0x2c430000 - 0x2c4a0000 	C:\ti\ccsv5\eclipse\configuration\org.eclipse.osgi\bundles\306\2\.cp\swt-win32-3833.dll
    0x2c4b0000 - 0x2c4b9000 	C:\WINDOWS\system32\Normaliz.dll
    0x2bc60000 - 0x2bc7d000 	C:\ti\ccsv5\eclipse\configuration\org.eclipse.osgi\bundles\306\2\.cp\swt-gdip-win32-3833.dll
    0x2c7a0000 - 0x2c7af000 	C:\ti\ccsv5\eclipse\configuration\org.eclipse.osgi\bundles\90\2\.cp\jWinHttp-1.0.0.dll
    0x2da80000 - 0x2dda7000 	C:\WINDOWS\system32\xpsp2res.dll
    0x2cc50000 - 0x2cc56000 	C:\ti\ccsv5\ccs_base\DebugServer\bin\LibraryLoader.dll
    0x2e8c0000 - 0x2eab2000 	C:\ti\ccsv5\ccs_base\common\bin\xerces-c_2_5_0.dll
    0x2ccb0000 - 0x2ccd3000 	C:\ti\ccsv5\ccs_base\common\bin\ti_logger.dll
    0x2eac0000 - 0x2eb35000 	C:\ti\ccsv5\ccs_base\common\bin\C4DLL.DLL
    0x2ec40000 - 0x2ec50000 	C:\ti\ccsv5\ccs_base\common\bin\CCReg.dll
    0x2ec60000 - 0x2eca7000 	C:\ti\ccsv5\ccs_base\common\bin\fsutil.dll
    0x2ecc0000 - 0x2ecc8000 	C:\ti\ccsv5\ccs_base\common\bin\fsutiljni.dll
    0x2ece0000 - 0x2ecea000 	C:\ti\ccsv5\ccs_base\common\bin\MiniDump.dll
    0x2ed00000 - 0x2ee74000 	C:\ti\ccsv5\ccs_base\common\bin\setup_parser.dll
    0x2ef30000 - 0x2f005000 	C:\WINDOWS\system32\COMRes.dll
    0x2f750000 - 0x2fb91000 	C:\WINDOWS\system32\msi.dll
    0x2fc30000 - 0x2fc80000 	C:\ti\ccsv5\ccs_base\DebugServer\bin\ti_xpcom.dll
    0x30190000 - 0x30330000 	C:\ti\ccsv5\ccs_base\DebugServer\bin\mdex.dll
    0x30440000 - 0x3045f000 	C:\ti\ccsv5\ccs_base\DebugServer\bin\XPCOMUtility.dll
    0x30470000 - 0x306ed000 	C:\ti\ccsv5\ccs_base\DebugServer\license\mdexutil.dll
    0x30a60000 - 0x30ab8000 	C:\Program Files\Internet Explorer\pdm.dll
    0x30bd0000 - 0x30c12000 	C:\WINDOWS\system32\msdbg2.dll
    0x76c80000 - 0x76ca8000 	C:\WINDOWS\system32\IMAGEHLP.dll
    0x30e30000 - 0x30e3d000 	C:\Documents and Settings\user\Local Settings\TEMP\ext6642486881680267660.dll
    0x76d30000 - 0x76d48000 	C:\WINDOWS\system32\MPRAPI.dll
    0x77cb0000 - 0x77ce2000 	C:\WINDOWS\system32\ACTIVEDS.dll
    0x76e00000 - 0x76e25000 	C:\WINDOWS\system32\adsldpc.dll
    0x314e0000 - 0x31551000 	C:\WINDOWS\system32\jscript.dll
    0x31e30000 - 0x32757000 	C:\WINDOWS\system32\Macromed\Flash\Flash11e.ocx
    0x317c0000 - 0x317cc000 	C:\WINDOWS\system32\ImgUtil.dll
    0x317f0000 - 0x317fe000 	C:\WINDOWS\system32\pngfilt.dll
    VM Arguments:
    USERNAME=user
    OS=Windows_NT
    Memory: 4k page, physical 2003012k(1084516k free), swap 3943588k(3060800k free)
    time: Sat Aug 24 21:05:22 2013
    elapsed time: 50 seconds
    install logs:
    !CONFIGURATION 1377354693968 Sat Aug 24 20:31:33 YEKST 2013
    !ACTIVITY 1377354806609 авг 24, 2013 20:33:26.609 file:/C:/ti/ccsv5/eclipse/ site-install success
    !CONFIGURATION 1377354833109 Sat Aug 24 20:33:53 YEKST 2013
    !ACTIVITY 1377354820578 авг 24, 2013 20:33:40.578 file:/C:/ti/grace_2_00_01_65/eclipse/ site-install success
    !ACTIVITY 1377354820890 авг 24, 2013 20:33:40.890 file:/C:/ti/xdctools_3_24_05_48/eclipse/ site-install success
    !ACTIVITY 1377354820921 авг 24, 2013 20:33:40.921 file:/C:/ti/ccsv5/ccs_base/msp430/msp430ware_1_25_00_30/eclipse/ site-install success
    :DIR C:/ti/ccsv5/tools
    :DIR C:/ti/ccsv5/tools/compiler
    :DIR C:/ti/ccsv5/tools/compiler/msp430_4.1.2
    :DIR C:/ti/ccsv5/tools/compiler/msp430_4.1.2/bin
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/bin/abs430.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/bin/acp430.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/bin/acpia430.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/bin/ar430.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/bin/asm430.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/bin/asm430_ltd.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/bin/cg430.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/bin/cl430.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/bin/cl430_ltd.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/bin/clist430.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/bin/dem430.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/bin/dis430.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/bin/embed430.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/bin/hex430.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/bin/ilk430.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/bin/libinfo430.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/bin/lnk430.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/bin/lnk430_ltd.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/bin/mk430.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/bin/nm430.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/bin/ofd430.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/bin/opt430.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/bin/strip430.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/bin/xref430.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/LICENSE.txt
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/RemoveRegistryKeys.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/SetupInCCSnRegistry.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/DefectHistory.txt
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/MSPEABI.txt
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/README.txt
    :DIR C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/_data_synch.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/_fmt_specifier.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/_isfuncdcl.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/_isfuncdef.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/_lock.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/_mutex.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/_pthread.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/_reg_mutex_api.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/_reg_synch_api.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/_tls.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/access.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/algorithm
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/assert.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/bitset
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/cassert
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/cctype
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/cerrno
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/cfloat
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/ciso646
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/climits
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/clocale
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/cmath
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/complex
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/cpp_inline_math.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/cpy_tbl.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/csetjmp
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/csignal
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/cstdarg
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/cstddef
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/cstdio
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/cstdlib
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/cstring
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/ctime
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/ctype.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/cwchar
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/cwctype
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/deque
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/elfnames.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/errno.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/exception
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/fenv.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/file.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/float.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/fstream
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/fstream.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/functional
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/hash_map
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/hash_set
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/intrinsics.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/inttypes.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/iomanip
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/iomanip.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/ios
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/iosfwd
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/iostream
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/iostream.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/iso646.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/istream
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/iterator
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/limits
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/limits.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/linkage.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/list
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/locale
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/locale.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/map
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/math.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/mathcpp.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/memory
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/new
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/new.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/numeric
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/ostream
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/queue
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/rope
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/set
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/setjmp.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/signal.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/slist
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/sstream
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/stack
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/stdarg.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/stdbool.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/stddef.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/stdexcept
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/stdint.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/stdio.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/stdiostream.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/stdlib.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/stl.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/streambuf
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/string
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/string.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/strstream
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/strstream.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/time.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/typeinfo
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/unaccess.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/utility
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/valarray
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/vector
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/wchar.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/wchar.hx
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/wctype.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/xcomplex
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/xdebug
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/xhash
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/xiosbase
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/xlocale
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/xlocinfo
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/xlocinfo.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/xlocmes
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/xlocmon
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/xlocnum
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/xloctime
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/xmemory
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/xstddef
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/xstring
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/xtree
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/xutility
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/xwcc.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/ymath.h
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/include/yvals.h
    :DIR C:/ti/ccsv5/tools/compiler/msp430_4.1.2/lib
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/lib/libc.a
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/lib/lnk.cmd
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/lib/lnkx.cmd
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/lib/lnkxl.cmd
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/lib/mklib
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/lib/mklib.c
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/lib/mklib.exe
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/lib/rts430.lib
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/lib/rts430_eabi.lib
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/lib/rts430x.lib
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/lib/rts430x_lc_rd.lib
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/lib/rts430x_lc_rd_eabi.lib
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/lib/rts430x_lc_sd_eabi.lib
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/lib/rtssrc.zip
    :FILE C:/ti/ccsv5/tools/compiler/msp430_4.1.2/install.log
    WinDbg call stack window screen shot:
    Something is going on inside the function code RtlValidateUnicodeString?
  • Hi Roman,
    our only suggestion is to try v5.4.  I would do this as a separate full fresh installation with antivirus off.
    Lisa
  • Hi Roman,
    I just thought I would check for any updates with your enquiry and whether things went better with v5.4.
    Lisa
  • Hi Lisa,
    Unfortunately I can not download the offline version 5.4 (from ti.com).
    After I had it installed, I'll let you know the results.
  • Hi Roman,
    are you seeing a specific issue downloading?  At any rate, please do keep us informed.
    Lisa
  • Hi Lisa,
    CodeComposer_v5.5.0.00077_win32 works fine. Bug fixed.
    Roman
  • HI Roman,
    great, glad to hear.  Thanks for the update and patience.
    All the best with development.
    LIsa
