Other Parts Discussed in Thread: CCSTUDIO, UNIFLASH
When I try to install CCS as directed, I end up with installation failure. It says installer failed to install Eclipse core correctly. Please suggest me a solution. Last few lines of log file:
08/30/2013 10:38:44AM - Date: Fri, 30 Aug 2013 05:08:39 GMT
08/30/2013 10:38:44AM - Connection: close
08/30/2013 10:38:44AM - done downloading rxtx_jre.zip
08/30/2013 10:38:44AM - downloaded rxtx_jre.zip
08/30/2013 10:38:44AM - making C:/ti/ccsv5/eclipse 2
08/30/2013 10:38:44AM - cmd = "C:/Users/pandia/AppData/Local/Temp/ijtmp_8EEBEDE0-6335-4D25-9AF7-70FDAD904F37/unzip.exe" -q -o -d "C:/ti/ccsv5/eclipse" "C:/Users/pandia/AppData/Local/Temp/ijtmp_8EEBEDE0-6335-4D25-9AF7-70FDAD904F37/baserepo/rxtx_jre.zip"
08/30/2013 10:38:44AM - successfully unzipped rxtx_jre.zip
08/30/2013 10:38:44AM - percent now 2
08/30/2013 10:38:44AM - checking ccstudiobin.zip
08/30/2013 10:38:44AM - Downloading ccstudiobin.zip to C:/Users/pandia/AppData/Local/Temp/ijtmp_8EEBEDE0-6335-4D25-9AF7-70FDAD904F37/baserepo
08/30/2013 10:38:44AM - encoding = cp1252
08/30/2013 10:38:44AM - http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/CCS5.4.0.00091_win32/baserepo/ccstudiobin.zip
08/30/2013 10:38:45AM - encoding = cp1252
08/30/2013 10:38:45AM - Date: Fri, 30 Aug 2013 05:08:40 GMT
08/30/2013 10:38:45AM - Server: Apache
08/30/2013 10:38:45AM - Location: http://downloads.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/CCS5.4.0.00091_win32/baserepo/ccstudiobin.zip
08/30/2013 10:38:45AM - Location:http://downloads.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/CCS5.4.0.00091_win32/baserepo/ccstudiobin.zip
08/30/2013 10:38:45AM - http://downloads.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/CCS5.4.0.00091_win32/baserepo/ccstudiobin.zip
08/30/2013 10:38:46AM - encoding = cp1252
08/30/2013 10:38:46AM - Server: Apache
08/30/2013 10:38:46AM - ETag: "0768b70c754afd1417c6b99c5491e684:1367586935"
08/30/2013 10:38:46AM - Last-Modified: Fri, 03 May 2013 12:21:36 GMT
08/30/2013 10:38:46AM - Accept-Ranges: bytes
08/30/2013 10:38:46AM - Content-Length: 42222
08/30/2013 10:38:46AM - Content-Type: application/zip
08/30/2013 10:38:46AM - Date: Fri, 30 Aug 2013 05:08:41 GMT
08/30/2013 10:38:46AM - Connection: close
08/30/2013 10:38:46AM - done downloading ccstudiobin.zip
08/30/2013 10:38:46AM - downloaded ccstudiobin.zip
08/30/2013 10:38:46AM - making C:/Users/pandia/AppData/Local/Temp/ijtmp_8EEBEDE0-6335-4D25-9AF7-70FDAD904F37 2
08/30/2013 10:38:46AM - cmd = "C:/Users/pandia/AppData/Local/Temp/ijtmp_8EEBEDE0-6335-4D25-9AF7-70FDAD904F37/unzip.exe" -q -o -d "C:/Users/pandia/AppData/Local/Temp/ijtmp_8EEBEDE0-6335-4D25-9AF7-70FDAD904F37" "C:/Users/pandia/AppData/Local/Temp/ijtmp_8EEBEDE0-6335-4D25-9AF7-70FDAD904F37/baserepo/ccstudiobin.zip"
08/30/2013 10:38:46AM - successfully unzipped ccstudiobin.zip
08/30/2013 10:38:46AM - percent now 2
08/30/2013 10:38:46AM - making C:/ti/ccsv5/install_logs
08/30/2013 10:38:46AM - MSVC80 checked out ok!
08/30/2013 10:38:46AM - MSVC2008 checked out ok!
08/30/2013 10:38:46AM - check_for_failures MSVC2012 "Microsoft Visual C++ 2012 Redistributable Package (x86)" do not install
08/30/2013 10:38:46AM - MSVC2012 checked out ok!
08/30/2013 10:38:46AM - installing JRE in C:/ti/ccsv5/eclipse
08/30/2013 10:38:46AM - from http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/CCS5.4.0.00091_win32/baserepo
08/30/2013 10:38:46AM - downloading jre_1.6.0_13.zip to C:/Users/pandia/AppData/Local/Temp/ijtmp_8EEBEDE0-6335-4D25-9AF7-70FDAD904F37/baserepo
08/30/2013 10:38:46AM - http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/CCS5.4.0.00091_win32/baserepo/jre_1.6.0_13.zip
08/30/2013 10:38:47AM - encoding = cp1252
08/30/2013 10:38:47AM - Date: Fri, 30 Aug 2013 05:08:42 GMT
08/30/2013 10:38:47AM - Server: Apache
08/30/2013 10:38:47AM - Location: http://downloads.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/CCS5.4.0.00091_win32/baserepo/jre_1.6.0_13.zip
08/30/2013 10:38:47AM - Location:http://downloads.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/CCS5.4.0.00091_win32/baserepo/jre_1.6.0_13.zip
08/30/2013 10:38:47AM - http://downloads.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/CCS5.4.0.00091_win32/baserepo/jre_1.6.0_13.zip
08/30/2013 10:40:02AM - encoding = cp1252
08/30/2013 10:40:02AM - Server: Apache
08/30/2013 10:40:02AM - ETag: "ca1c630273f9628ceb138f2e9ecbeed1:1367587100"
08/30/2013 10:40:02AM - Last-Modified: Fri, 03 May 2013 12:26:44 GMT
08/30/2013 10:40:02AM - Accept-Ranges: bytes
08/30/2013 10:40:02AM - Content-Length: 31364806
08/30/2013 10:40:02AM - Content-Type: application/zip
08/30/2013 10:40:02AM - Date: Fri, 30 Aug 2013 05:08:43 GMT
08/30/2013 10:40:02AM - Connection: close
08/30/2013 10:40:02AM - downloaded jre_1.6.0_13.zip
08/30/2013 10:40:02AM - 1 - 31364806
08/30/2013 10:40:02AM - making C:/ti/ccsv5/eclipse 3
08/30/2013 10:40:02AM - cmd = "C:/Users/pandia/AppData/Local/Temp/ijtmp_8EEBEDE0-6335-4D25-9AF7-70FDAD904F37/unzip.exe" -q -o -d "C:/ti/ccsv5/eclipse" "C:/Users/pandia/AppData/Local/Temp/ijtmp_8EEBEDE0-6335-4D25-9AF7-70FDAD904F37/baserepo/jre_1.6.0_13.zip"
08/30/2013 10:40:07AM - successfully unzipped jre_1.6.0_13.zip
08/30/2013 10:40:07AM - percent now 2
08/30/2013 10:40:07AM - JRE checked out ok!
08/30/2013 10:40:07AM - installing UNIFLASH in C:/ti/ccsv5
08/30/2013 10:40:07AM - component UNIFLASH doesn't exist
08/30/2013 10:40:07AM - UNIFLASH checked out ok!
08/30/2013 10:40:08AM - installing ECLIPSECORE in C:/Users/pandia/AppData/Local/Temp/ijtmp_8EEBEDE0-6335-4D25-9AF7-70FDAD904F37
08/30/2013 10:40:08AM - from http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/CCS5.4.0.00091_win32/baserepo
08/30/2013 10:40:08AM - downloading eclipse_core_3.7.2.zip to C:/Users/pandia/AppData/Local/Temp/ijtmp_8EEBEDE0-6335-4D25-9AF7-70FDAD904F37/baserepo
08/30/2013 10:40:08AM - percent now 2
08/30/2013 10:40:08AM - encoding = cp1252
08/30/2013 10:40:08AM - http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/CCS5.4.0.00091_win32/baserepo/eclipse_core_3.7.2.zip
08/30/2013 10:40:08AM - Date: Fri, 30 Aug 2013 05:10:04 GMT
08/30/2013 10:40:08AM - Server: Apache
08/30/2013 10:40:08AM - Location: http://downloads.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/CCS5.4.0.00091_win32/baserepo/eclipse_core_3.7.2.zip
08/30/2013 10:40:08AM - Location:http://downloads.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/CCS5.4.0.00091_win32/baserepo/eclipse_core_3.7.2.zip
08/30/2013 10:40:08AM - http://downloads.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/CCS5.4.0.00091_win32/baserepo/eclipse_core_3.7.2.zip
08/30/2013 10:42:39AM - encoding = cp1252
08/30/2013 10:42:39AM - Server: Apache
08/30/2013 10:42:39AM - ETag: "ec315c70b9f612c2e40cfa92cef91f27:1367586967"
08/30/2013 10:42:39AM - Last-Modified: Fri, 03 May 2013 12:24:38 GMT
08/30/2013 10:42:39AM - Accept-Ranges: bytes
08/30/2013 10:42:39AM - Content-Length: 52897237
08/30/2013 10:42:39AM - Content-Type: application/zip
08/30/2013 10:42:39AM - Date: Fri, 30 Aug 2013 05:10:08 GMT
08/30/2013 10:42:39AM - Connection: close
08/30/2013 10:42:39AM - downloaded file size doesn't match 2441085 52897237
08/30/2013 10:42:39AM - eclipse_core_3.7.2.zip doesn't exist ... Incomplete download.
