Problem with CCSv5 update
Guru 15520 points
I have a question about CCSv5.2.1 update.
When I try checking the update information from CCS,
the following error message occured:
'Contacting' Software Site's has encountered a problem.
Some sites could not be found. See the error log for more detail.
HTTP Proxy Authentication Required:
http://support.spectrumdigital.com/ccs51/Updates/content.xml
http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/Updates/simulation/p2win32/content.xml
http://software-dl.ti.com/sdoemb/sdoemb_public_sw/bios_mcsdk/eclipse/mcsdk2x/content.xml
http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5.1/Updates/Emulation/win32/full/content.xml
http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/Updates/content.xml
http://www.blackhawk-dsp.com/updates/ccsv52/content.xml
http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/TargetContent/Updates/full/content.xml
http://download.eclipse.org/eclipse/updates/3.7/content.xml
http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/DVT/CCS5.2/content.xml
http://software-dl.ti.com/sdoemb/sdoemb_public_sw/ti_emupack_keystone1/eclipse/content.xml
http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32/content.xml
I tried to access the upper URL from browser, but the result was "page not found".
How should this problem be solved?
May be I should update CCS version to newest v5.5 but I need to keep using v5.2.1.
Please give me an advise.
best regards,
g.f.
  • Hi g.f.
    Why don't you download a fresh copy of CCS v5.5 and install it in a different folder? In this way you can use both the versions.
    Gautam
  • GF,
    Your proxy configuration is such that Eclipse is unable to contact any of the update sites. The error message back from eclipse is a little bit misleading. The file in the error message is only the last file it tries and the file does not necessarily exist. If you try the same URL with "content.jar" in your browser, you will get a better idea if your browsers proxy configuration permits contacting the various update sites.
    While it is possible to configure specific proxies in Eclipse, you are probably going to run into other problems later due to proxy issues. You are probably best just to skip doing updates and use the full installs.
  • Hi Gautam and Andy,
    Thank you for the reply.
    So, I should skip the updating from CCS.
    I just want to update Keystone emulation package, so I will get from TI web site manually.
    best regards,
    g.f.
  • Hi gf,
    Sure, that seems like a good solution.
    Gautam
