Target: Finally find the way to install CCS 5.5.
(I'm trying to start with EK-TM4C123GXL)
Key trouble:
Well-known phrase - something like: "Unable to access http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/CCS5.5.0.00077_win32. Check your settings and try again."
appearing in the process of installation.
Pre-history:
I had CCS5.0.. installed (was downloaded from http://www.ti.com/tool/sw-ek-tm4c123gxl)
This one:
"EK-TM4C123GXL-CCS:
TivaWare for C Series and Code Composer Studio for the Tiva C Series TM4C123G LaunchPad"
First issue:
Guys, it seems to me this version of CCS which is included in this pack could not be used for this board. When I've tried to complete Project0 there were such issues: "When trying to import the projects, I was getting errors regarding the ARMv5 compiler" (i've just take this phrase from other post on forum). It is too old version for this eval. board. Is not it?
So', I 've found out, that I have to reinstall CCS to 5.5 (the latest one) to upgarde for being able to use my board.
Second issue:
This pestered phrase. "Unable to access http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/CCS5.5.0.00077_win32. Check your settings and try again."
Additional information:
1) I can't change my MAC because of using machine on job. (I've read about license issues)
2) I've tried to
-disable all services in msconfig
-clean my register for 5 or more times
-clean cache of chrome and all other brousers
-install to clear directory
-install fresh one (I mean distrib.)
-check logs, delete all temp files
There's log in attachment.
. Could you kindly help me?
I know, there are so many issues like this one, but it would be kind of you if you can help me.
Thank you.
7245.ccs_setup_5.5.0.00077_install.log
P.S. Right now I want to try offline installer.. But I'm not really sure if it could make sense for this issue..
