CCS5.4: can't set breakpoint in linked files
Guru 20075 points
Other Parts Discussed in Thread: TMS320F28335
I am using CCS5.4 and I am not able to set breakpoints in linked file.
Is this a bug?
Stephen
  • Hi Stephen,
    could you please elaborate a bit further?  What target and emulator are you using?  Have you tried other projects and the latest ccs version (v5.5)?
    I am successfully able to set a breakpoint in a linked in c file in v5.5.
    Lisa
  • Hello Lisa,
    I am using the XDS100V2 emulator.   I noticed two new CCS projects were having this problem.  I haven't had time to try any other projects.  It only happens when I am debugging, i.e. I have connected the emulator and downloaded the code to the target.  I am able to add a breakpoint before connecting the emulator and downloading the code to the target.
    Stephen
  • Hi Stephen,
    what target are you using?  It would help us to try and reproduce things here.   I added my breakpoint during debug, not before and had no issues.  I used an MSP430 FET.   It would be good to - try the latest ccs version if at all possible.
    Lisa
  • The target is a TMS320F28335.
  • Hello Lisa,
    I am trying to install CCSv55.  Why does the custom installation requires me to select all or none of processor architectures.  Also, a warning is displayed if I don't select any processor architecture.  The warning says:
    "Your CCS install has already been updated to included newer components.  This CCS installer cannot be used to add processor support because it does not include those components."
    Why am I not able to just install C28x 32-bit Real-time MCUs?
    Stephen
  • Hello Lisa,
    Changing to CCSv5.5 fixed the issue.
    Stephen
  • Hi Stephen,
    great, very glad to hear.  All the best with development.
    Lisa
  • Hello Lisa,
    I am having the issue again.  Now its happening with a file that not linked.
    The breakpoint is getting set as disabled and when I try to enable the breakpoint in the Breakpoint window a dialog box pops up saying "No code is associated with ..."
    Stephen
  • Disregard my last post.  I had commented out the call to the function I was trying to put a breakpoint in.
