Other Parts Discussed in Thread: CCSTUDIO
Dear Team TI,
I am writing a script to automate building of 4 projects. 2 are ARM projects and 2 are DSP projects. All of them are ccsv5 projects. I have written following script
# Build test project
# Constants
$SCRIPT_PATH = split-path -parent $MyInvocation.MyCommand.Definition
$ECLIPSE_CONSOLE_PATH = "$env:ECLIPSE_HOME\eclipsec.exe"
$LIB_ARM_PROJECT_NAME = "TicLibArm"
$LIB_ARM_PROJECT_FOLDER = "$SCRIPT_PATH/../src/main/libArm"
$ARM_PROJECT_NAME = "TicArm"
$ARM_PROJECT_FOLDER = "$SCRIPT_PATH/../src/main/arm"
$LIB_DSP_PROJECT_NAME = "TicLibDsp"
$LIB_DSP_PROJECT_FOLDER = "$SCRIPT_PATH/../src/main/libDsp"
$DSP_PROJECT_NAME = "TicDsp"
$DSP_PROJECT_FOLDER = "$SCRIPT_PATH/../src/main/dsp"
$WORKSPACE_FOLDER = "$SCRIPT_PATH\workspace"
# Check whether the needed environment variable is set
if (!(Test-Path Env:\ECLIPSE_HOME))
"Sorry dude, but you forgot to define the ECLIPSE_HOME environment variable in the Windows system settings."
exit 1
# Delete existing temporary workspace folder if existing
if (Test-Path $WORKSPACE_FOLDER)
Remove-Item $WORKSPACE_FOLDER -Force -Recurse
# Create new temporary workspace folder
New-Item -ItemType directory -Path $WORKSPACE_FOLDER | Out-Null
# Import TicLibArm project into temporary workspace
&$ECLIPSE_CONSOLE_PATH -nosplash -data $WORKSPACE_FOLDER -application com.ti.ccstudio.apps.projectImport –ccs.location $LIB_ARM_PROJECT_FOLDER
# Build TicLibArm project using the temporary workspace
&$ECLIPSE_CONSOLE_PATH -nosplash -data $WORKSPACE_FOLDER -application com.ti.ccstudio.apps.projectBuild -ccs.projects $LIB_ARM_PROJECT_NAME
# Cleanup
# Import TicArm project into temporary workspace
&$ECLIPSE_CONSOLE_PATH -nosplash -data $WORKSPACE_FOLDER -application com.ti.ccstudio.apps.projectImport –ccs.location $ARM_PROJECT_FOLDER
# Build TicArm project using the temporary workspace
&$ECLIPSE_CONSOLE_PATH -nosplash -data $WORKSPACE_FOLDER -application com.ti.ccstudio.apps.projectBuild -ccs.projects $ARM_PROJECT_NAME
# Cleanup
# Delete old source code
if (Test-Path $TARGET_FOLDER)
Remove-Item "$TARGET_FOLDER\*" -Include *.cpp,*.h -Force -Recurse
# Copy source code from TicLibArm project to TicLibDsp project and make it read-only
robocopy $LIB_ARM_PROJECT_FOLDER $LIB_DSP_PROJECT_FOLDER /MIR /S /IF *.cpp *.h /XD Debug Release .config .svn /A+:R | Out-Null
"Copied source code from TicLibArm project to TicLibDsp project."
# Import TicLibDsp project into temporary workspace
&$ECLIPSE_CONSOLE_PATH -nosplash -data $WORKSPACE_FOLDER -application com.ti.ccstudio.apps.projectImport –ccs.location $LIB_DSP_PROJECT_FOLDER
# Build TicLibDsp project using the temporary workspace
&$ECLIPSE_CONSOLE_PATH -nosplash -data $WORKSPACE_FOLDER -application com.ti.ccstudio.apps.projectBuild -ccs.projects $LIB_DSP_PROJECT_NAME
# Cleanup
# Import TicDsp project into temporary workspace
&$ECLIPSE_CONSOLE_PATH -nosplash -data $WORKSPACE_FOLDER -application com.ti.ccstudio.apps.projectImport –ccs.location $DSP_PROJECT_FOLDER
# Build TicDsp project using the temporary workspace
&$ECLIPSE_CONSOLE_PATH -nosplash -data $WORKSPACE_FOLDER -application com.ti.ccstudio.apps.projectBuild -ccs.projects $DSP_PROJECT_NAME
# Cleanup
Earlier I used cdt headless build command which was able to build libarm and lib dsp project but for arm and dsp projects gave error saying missing variable path include path missing.
I searched and read on your wiki that cdt headless build should only be used for C/C++ projects. So following your wiki I wrote the script that I have pasted above.
I get following error
Message in the log file is as follows:
!SESSION 2013-12-05 11:00:02.656 -----------------------------------------------
eclipse.buildId=I20120608-1200
java.version=1.6.0_13
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Framework arguments: -application com.ti.ccstudio.apps.projectImport â€ccs.location C:\projects\tic\swf/../src/main/libArm
&C:\ti\ccsv5\eclipse\eclipsec.exe -nosplash -data C:\projects\tic\swf\workspace -application com.ti.ccstudio.apps.projectBuild -ccs.projects TicLibArm
# Cleanup
Remove-Item C:\projects\tic\swf\workspace -Force -Recurse
if (Test-Path C:\projects\tic\swf\workspace)
New-Item -ItemType directory -Path C:\projects\tic\swf\workspace | Out-Null
&C:\ti\ccsv5\eclipse\eclipsec.exe -nosplash -data C:\projects\tic\swf\workspace -application com.ti.ccstudio.apps.projectImport â€ccs.location C:\projects\tic\swf/../src/main/arm
Command-line arguments: -os win32 -ws win32 -arch x86 -data C:\projects\tic\swf\workspace -application com.ti.ccstudio.apps.projectImport â€ccs.location C:\projects\tic\swf/../src/main/libArm
# Cleanup
!ENTRY org.eclipse.equinox.http.jetty 4 0 2013-12-05 11:00:03.444
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.equinox.http.jetty.internal.Activator.start() of bundle org.eclipse.equinox.http.jetty.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1177)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
Caused by: org.osgi.service.cm.ConfigurationException: default : Address already in use: bind
at org.eclipse.equinox.http.jetty.internal.HttpServerManager.updated(HttpServerManager.java:115)
at org.eclipse.equinox.http.jetty.internal.Activator.start(Activator.java:62)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
... 12 more
Caused by: java.net.BindException: Address already in use: bind
at sun.nio.ch.Net.bind(Native Method)
at sun.nio.ch.ServerSocketChannelImpl.bind(Unknown Source)
at sun.nio.ch.ServerSocketAdaptor.bind(Unknown Source)
at org.eclipse.jetty.server.nio.SelectChannelConnector.open(SelectChannelConnector.java:182)
at org.eclipse.jetty.server.AbstractConnector.doStart(AbstractConnector.java:311)
at org.eclipse.jetty.server.nio.SelectChannelConnector.doStart(SelectChannelConnector.java:260)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59)
at org.eclipse.jetty.server.Server.doStart(Server.java:273)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager.updated(HttpServerManager.java:113)
... 16 more
Root exception:
... 16 more
!ENTRY org.eclipse.osgi 4 0 2013-12-05 11:00:05.561
!MESSAGE Application error
!STACK 1
java.lang.NullPointerException
at com.ti.ccstudio.apps.internal.project.Import.getReturnCode(Import.java:196)
at com.ti.ccstudio.apps.internal.BaseHeadlessApp.start(BaseHeadlessApp.java:230)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
I able to build all the 4 projects in the studio but I need to automate the building of the project.
Looking forward to your help,
Dhara.
