unable to install ccsv5.5 on windows 8
hi, I'm unable to install CCSv5.5 on my PC with Windows 8. I'm getting "Error in Startup Script" when i press the ccs setup . I'm attaching the Installjammer registry file.
------ ccs_setup_5.5.0.00077 Installation -------------
12/06/2013 18:32:00PM -
12/06/2013 18:32:00PM - InstallID      : 2E9C2A34-EB33-4732-AA06-F6634419A2F1
12/06/2013 18:32:00PM - Installer      : F:\ccs_setup_5.5.0.00077.exe
12/06/2013 18:32:00PM - BuildName      : ccs_setup_5.5.0.00077.exe
12/06/2013 18:32:00PM - Install version: 5.5.0.00077
12/06/2013 18:32:00PM - Install source : F:\
12/06/2013 18:32:00PM - OS             : Windows
12/06/2013 18:32:00PM - UserName       : Akshay Kota
12/06/2013 18:32:00PM - Update?        : 0
12/06/2013 18:32:00PM - testmode       : false
12/06/2013 18:32:00PM - testurl        : <%testurl%>
12/06/2013 18:32:00PM - http info      : -accept */* -proxyfilter http::ProxyRequired -proxyhost {} -proxyport {} -urlencoding utf-8 -useragent {Tcl http client package 2.5.3}
12/06/2013 18:32:00PM - tmp dir        : C:/Users/AKSHAY~1/AppData/Local/Temp/ijtmp_5E4B1616-312F-4CFE-B11A-699910928D1E
12/06/2013 18:32:00PM - InstallURL     : <%InstallURL%>
12/06/2013 18:32:00PM - Command line   : /installkitvfs/main.tcl 0
12/06/2013 18:32:00PM - Executing action DAE6D44E-3DC2-4543-A1EB-001C5F515422 - Find NVidia
12/06/2013 18:32:00PM - Executing action B8763022-D5E2-4AA8-844A-EC7CFCAD7157 - Set answer (OK)
12/06/2013 18:32:00PM - Checking conditions for 27036D2D-68D1-4483-BE67-0FF19E850B0E - Message Box - Before Action is Executed
12/06/2013 18:32:00PM - Checking condition AD8FFE88-09C6-4C1A-B557-188632C09B2D - String Is Condition
12/06/2013 18:32:00PM - Checking to see if <%foundNVidia%> is true
12/06/2013 18:32:00PM - ** Checking to see if false is true
12/06/2013 18:32:00PM - Condition failed
12/06/2013 18:32:00PM - Skipping action 27036D2D-68D1-4483-BE67-0FF19E850B0E - Message Box - conditions failed
12/06/2013 18:32:00PM - Checking conditions for 73D33A11-6A32-4488-A6B1-9BB8ACD7372B - Exit (NVidia) - Before Action is Executed
12/06/2013 18:32:00PM - Checking condition 32FD86A1-3EC3-4270-9E8D-7476DE237A5E - String Equal Condition
12/06/2013 18:32:00PM - Checking to see if <%answer%> equals Cancel
12/06/2013 18:32:00PM - ** Checking to see if OK equals Cancel
12/06/2013 18:32:00PM - Skipping action 73D33A11-6A32-4488-A6B1-9BB8ACD7372B - Exit (NVidia) - conditions failed
12/06/2013 18:32:00PM - Checking conditions for B64D3D93-67B0-4BD9-9B1B-4264B8023A45 - Set Temp value - Before Action is Executed
12/06/2013 18:32:00PM - Checking condition 5401F86C-FE5E-4FF7-A77A-C4CBD8D576EB - Execute Script Condition
12/06/2013 18:32:00PM - Condition passed
12/06/2013 18:32:00PM - Executing action B64D3D93-67B0-4BD9-9B1B-4264B8023A45 - Set Temp value
12/06/2013 18:32:00PM - Executing action A2728FBB-5A26-4329-BFBE-DE6C9E246501 - Check Temp/Installsource value
12/06/2013 18:32:00PM - Checking conditions for 3A18DFFF-E127-407E-987E-23B777277223 - Check for McAfee - Before Action is Executed
12/06/2013 18:32:00PM - Checking condition 60C48044-51FA-4487-BFBF-5E5276E11AA6 - Platform Condition
12/06/2013 18:32:00PM - Checking to see if <%Platform%> is Windows
12/06/2013 18:32:00PM - ** Checking to see if Windows is Windows
12/06/2013 18:32:00PM - Executing action 3A18DFFF-E127-407E-987E-23B777277223 - Check for McAfee
12/06/2013 18:32:00PM - Registry key HKEY_LOCAL_MACHINE\SOFTWARE\McAfee does not exist unable to open key: The system cannot find the file specified.
12/06/2013 18:32:00PM - Checking conditions for 123EF823-0459-4F01-ABF1-BE12CCBD883C - Check for junctions (Windows) - Before Action is Executed
12/06/2013 18:32:00PM - Checking condition 9DA2DCAC-C1A2-4FA9-A505-21437A8B0431 - Platform Condition
12/06/2013 18:32:00PM - Executing action 123EF823-0459-4F01-ABF1-BE12CCBD883C - Check for junctions (Windows)
12/06/2013 18:32:00PM - checking C:/Users/AKSHAY~1/AppData/Local/Temp/ijtmp_5E4B1616-312F-4CFE-B11A-699910928D1E for links
12/06/2013 18:32:00PM - Checking conditions for 6D910536-6D94-48FC-9FB6-DEC5FBC0E6B9 - Set Update variables if needed - Before Action is Executed
12/06/2013 18:32:00PM - Checking condition A2DF4B22-7FD5-40DD-A8C7-744CDD290075 - String Equal Condition
12/06/2013 18:32:00PM - Checking to see if <%InstallPrefix%> equals ccs_update
12/06/2013 18:32:00PM - ** Checking to see if ccs_setup equals ccs_update
12/06/2013 18:32:00PM - Skipping action 6D910536-6D94-48FC-9FB6-DEC5FBC0E6B9 - Set Update variables if needed - conditions failed
12/06/2013 18:32:00PM - Checking conditions for FD9BA738-0681-4F8C-A99E-D9630FE9317A - Get InstallDir - Before Action is Executed
12/06/2013 18:32:00PM - Checking condition 96501BA3-2DAB-4133-BEAD-86FCA44BFE84 - String Is Condition
12/06/2013 18:32:00PM - Checking to see if <%UpdateMode%> is true
12/06/2013 18:32:00PM - ** Checking to see if 0 is true
12/06/2013 18:32:00PM - Skipping action FD9BA738-0681-4F8C-A99E-D9630FE9317A - Get InstallDir - conditions failed
12/06/2013 18:32:00PM - Checking conditions for 5A908E3F-6B9A-4311-B8CA-15578F03CEC9 - Set Native_Eclipse_Selected - Before Action is Executed
12/06/2013 18:32:00PM - Checking condition A2036039-9CCB-492A-8247-6D07128AEE2F - Command Line Test Condition
12/06/2013 18:32:00PM - Checking to see if eclipseprefix was passed on the command line
12/06/2013 18:32:00PM - Skipping action 5A908E3F-6B9A-4311-B8CA-15578F03CEC9 - Set Native_Eclipse_Selected - conditions failed
12/06/2013 18:32:00PM - Checking conditions for 99A470ED-DD5C-4D41-BA90-A04A061322EB - Set Native Eclipse Variable - Before Action is Executed
12/06/2013 18:32:00PM - Checking condition DF6C1A44-866A-4053-A6D4-D810A1260FFA - String Is Condition
12/06/2013 18:32:00PM - Skipping action 99A470ED-DD5C-4D41-BA90-A04A061322EB - Set Native Eclipse Variable - conditions failed
12/06/2013 18:32:00PM - Checking conditions for 0E76BDFA-AE33-4D11-80D4-021EEE28FADA - Set Valid Eclipse Variable - Before Action is Executed
12/06/2013 18:32:00PM - Checking condition A0F1E771-08C1-4655-89F3-A760BAE68E12 - String Is Condition
12/06/2013 18:32:00PM - Skipping action 0E76BDFA-AE33-4D11-80D4-021EEE28FADA - Set Valid Eclipse Variable - conditions failed
12/06/2013 18:32:00PM - Checking conditions for F0A046CD-8A59-4F7D-B025-7ED78FD8C0F3 - Execute Response File Action - Before Action is Executed
12/06/2013 18:32:00PM - Checking condition C434E3F3-C405-466D-9713-A8F99B3BCC12 - Command Line Test Condition
12/06/2013 18:32:00PM - Checking to see if response-file was passed on the command line
12/06/2013 18:32:00PM - Skipping action F0A046CD-8A59-4F7D-B025-7ED78FD8C0F3 - Execute Response File Action - conditions failed
12/06/2013 18:32:00PM - Checking conditions for 73286838-ADC5-44C6-9BF4-3D00C32317F7 - Set Windows information - Before Action is Executed
12/06/2013 18:32:00PM - Checking condition DDEDDBE3-895A-4F08-B242-B5CEB39360F2 - Platform Condition
12/06/2013 18:32:00PM - Executing action 73286838-ADC5-44C6-9BF4-3D00C32317F7 - Set Windows information
12/06/2013 18:32:00PM - Checking System Info...
12/06/2013 18:32:00PM - Registry key WindowsCSDVersionString does not exist
12/06/2013 18:32:00PM - Windows 8 matched .*\s*Windows 8.*
12/06/2013 18:32:00PM - WindowsProductName= Windows 8
  WindowsCurrentVersion= 6.2
  WindowsCSDVersionString= -
  WindowsCSDVersionDWord= 0
  WindowsPlatform= Windows
12/06/2013 18:32:00PM - Executing action 1409F691-5623-49F1-99EB-D4ED15870571 - Set BuildName (default)
