Windows 7 error in startup script
Hi
I have been having trouble installing ccsv5 5.5 0.0.000777 on Windows 7 .
I have done the usual.. remove the install jammer registry
remove firewalls, etc.
The Temp file referred to in the script seems OK. I have been in and cleaned it out....
regards
Jonathan
------ ccs_setup_5.5.0.00077 Installation -------------
01/07/2014 12:35:21PM -
01/07/2014 12:35:21PM - InstallID : E4D94104-3702-430D-A306-5BB3303EFEC9
01/07/2014 12:35:21PM - Installer : C:\Users\Jonathan\Desktop\ccs_setup_5.5.0.00077.exe
01/07/2014 12:35:21PM - BuildName : ccs_setup_5.5.0.00077.exe
01/07/2014 12:35:21PM - Install version: 5.5.0.00077
01/07/2014 12:35:21PM - Install source : C:\Users\Jonathan\Desktop
01/07/2014 12:35:21PM - OS : Windows
01/07/2014 12:35:21PM - UserName : Jonathan
01/07/2014 12:35:21PM - Update? : 0
01/07/2014 12:35:21PM - testmode : false
01/07/2014 12:35:21PM - testurl : <%testurl%>
01/07/2014 12:35:21PM - http info : -accept */* -proxyfilter http::ProxyRequired -proxyhost {} -proxyport {} -urlencoding utf-8 -useragent {Tcl http client package 2.5.3}
01/07/2014 12:35:21PM - tmp dir : C:/Users/Jonathan/AppData/Local/Temp/ijtmp_5129B72E-C0B8-4EB6-86DD-EADEB810CC7E
01/07/2014 12:35:21PM - InstallURL : <%InstallURL%>
01/07/2014 12:35:21PM - Command line : /installkitvfs/main.tcl 0
01/07/2014 12:35:21PM - Executing action DAE6D44E-3DC2-4543-A1EB-001C5F515422 - Find NVidia
01/07/2014 12:35:21PM - Windows 7 found: Microsoft Windows 7 Home Premium 64-bit
01/07/2014 12:35:21PM - 64-bit found: Microsoft Windows 7 Home Premium 64-bit
01/07/2014 12:35:21PM - no match: Description
01/07/2014 12:35:21PM - no match: AMD Radeon HD 7670M
01/07/2014 12:35:21PM - Executing action B8763022-D5E2-4AA8-844A-EC7CFCAD7157 - Set answer (OK)
01/07/2014 12:35:21PM - Checking conditions for 27036D2D-68D1-4483-BE67-0FF19E850B0E - Message Box - Before Action is Executed
01/07/2014 12:35:21PM - Checking condition AD8FFE88-09C6-4C1A-B557-188632C09B2D - String Is Condition
01/07/2014 12:35:21PM - Checking to see if <%foundNVidia%> is true
01/07/2014 12:35:21PM - ** Checking to see if false is true
01/07/2014 12:35:21PM - Condition failed
01/07/2014 12:35:21PM - Skipping action 27036D2D-68D1-4483-BE67-0FF19E850B0E - Message Box - conditions failed
01/07/2014 12:35:21PM - Checking conditions for 73D33A11-6A32-4488-A6B1-9BB8ACD7372B - Exit (NVidia) - Before Action is Executed
01/07/2014 12:35:21PM - Checking condition 32FD86A1-3EC3-4270-9E8D-7476DE237A5E - String Equal Condition
01/07/2014 12:35:21PM - Checking to see if <%answer%> equals Cancel
01/07/2014 12:35:21PM - ** Checking to see if OK equals Cancel
01/07/2014 12:35:21PM - Skipping action 73D33A11-6A32-4488-A6B1-9BB8ACD7372B - Exit (NVidia) - conditions failed
01/07/2014 12:35:21PM - Checking conditions for B64D3D93-67B0-4BD9-9B1B-4264B8023A45 - Set Temp value - Before Action is Executed
01/07/2014 12:35:21PM - Checking condition 5401F86C-FE5E-4FF7-A77A-C4CBD8D576EB - Execute Script Condition
01/07/2014 12:35:21PM - Condition passed
01/07/2014 12:35:21PM - Executing action B64D3D93-67B0-4BD9-9B1B-4264B8023A45 - Set Temp value
01/07/2014 12:35:21PM - Executing action A2728FBB-5A26-4329-BFBE-DE6C9E246501 - Check Temp/Installsource value
01/07/2014 12:35:21PM - Checking conditions for 3A18DFFF-E127-407E-987E-23B777277223 - Check for McAfee - Before Action is Executed
01/07/2014 12:35:21PM - Checking condition 60C48044-51FA-4487-BFBF-5E5276E11AA6 - Platform Condition
01/07/2014 12:35:21PM - Checking to see if <%Platform%> is Windows
01/07/2014 12:35:21PM - ** Checking to see if Windows is Windows
01/07/2014 12:35:21PM - Executing action 3A18DFFF-E127-407E-987E-23B777277223 - Check for McAfee
01/07/2014 12:35:21PM - Registry key HKEY_LOCAL_MACHINE\SOFTWARE\McAfee does not exist unable to open key: The system cannot find the file specified.
01/07/2014 12:35:21PM - Checking conditions for 123EF823-0459-4F01-ABF1-BE12CCBD883C - Check for junctions (Windows) - Before Action is Executed
01/07/2014 12:35:21PM - Checking condition 9DA2DCAC-C1A2-4FA9-A505-21437A8B0431 - Platform Condition
01/07/2014 12:35:21PM - Executing action 123EF823-0459-4F01-ABF1-BE12CCBD883C - Check for junctions (Windows)
01/07/2014 12:35:21PM - checking C:/Users/Jonathan/AppData/Local/Temp;C:/Users/Jonathan/adu;/ijtmp_5129B72E-C0B8-4EB6-86DD-EADEB810CC7E for links
01/07/2014 12:35:21PM - Checking conditions for 6D910536-6D94-48FC-9FB6-DEC5FBC0E6B9 - Set Update variables if needed - Before Action is Executed
01/07/2014 12:35:21PM - Checking condition A2DF4B22-7FD5-40DD-A8C7-744CDD290075 - String Equal Condition
01/07/2014 12:35:21PM - Checking to see if <%InstallPrefix%> equals ccs_update
01/07/2014 12:35:21PM - ** Checking to see if ccs_setup equals ccs_update
01/07/2014 12:35:21PM - Skipping action 6D910536-6D94-48FC-9FB6-DEC5FBC0E6B9 - Set Update variables if needed - conditions failed
01/07/2014 12:35:21PM - Checking conditions for FD9BA738-0681-4F8C-A99E-D9630FE9317A - Get InstallDir - Before Action is Executed
01/07/2014 12:35:21PM - Checking condition 96501BA3-2DAB-4133-BEAD-86FCA44BFE84 - String Is Condition
01/07/2014 12:35:21PM - Checking to see if <%UpdateMode%> is true
01/07/2014 12:35:21PM - ** Checking to see if 0 is true
01/07/2014 12:35:21PM - Skipping action FD9BA738-0681-4F8C-A99E-D9630FE9317A - Get InstallDir - conditions failed
01/07/2014 12:35:21PM - Checking conditions for 5A908E3F-6B9A-4311-B8CA-15578F03CEC9 - Set Native_Eclipse_Selected - Before Action is Executed
01/07/2014 12:35:21PM - Checking condition A2036039-9CCB-492A-8247-6D07128AEE2F - Command Line Test Condition
01/07/2014 12:35:21PM - Checking to see if eclipseprefix was passed on the command line
01/07/2014 12:35:21PM - Skipping action 5A908E3F-6B9A-4311-B8CA-15578F03CEC9 - Set Native_Eclipse_Selected - conditions failed
01/07/2014 12:35:21PM - Checking conditions for 99A470ED-DD5C-4D41-BA90-A04A061322EB - Set Native Eclipse Variable - Before Action is Executed
01/07/2014 12:35:21PM - Checking condition DF6C1A44-866A-4053-A6D4-D810A1260FFA - String Is Condition
01/07/2014 12:35:21PM - Skipping action 99A470ED-DD5C-4D41-BA90-A04A061322EB - Set Native Eclipse Variable - conditions failed
01/07/2014 12:35:21PM - Checking conditions for 0E76BDFA-AE33-4D11-80D4-021EEE28FADA - Set Valid Eclipse Variable - Before Action is Executed
01/07/2014 12:35:21PM - Checking condition A0F1E771-08C1-4655-89F3-A760BAE68E12 - String Is Condition
01/07/2014 12:35:21PM - Skipping action 0E76BDFA-AE33-4D11-80D4-021EEE28FADA - Set Valid Eclipse Variable - conditions failed
01/07/2014 12:35:21PM - Checking conditions for F0A046CD-8A59-4F7D-B025-7ED78FD8C0F3 - Execute Response File Action - Before Action is Executed
01/07/2014 12:35:21PM - Checking condition C434E3F3-C405-466D-9713-A8F99B3BCC12 - Command Line Test Condition
01/07/2014 12:35:21PM - Checking to see if response-file was passed on the command line
01/07/2014 12:35:21PM - Skipping action F0A046CD-8A59-4F7D-B025-7ED78FD8C0F3 - Execute Response File Action - conditions failed
01/07/2014 12:35:21PM - Checking conditions for 73286838-ADC5-44C6-9BF4-3D00C32317F7 - Set Windows information - Before Action is Executed
01/07/2014 12:35:21PM - Checking condition DDEDDBE3-895A-4F08-B242-B5CEB39360F2 - Platform Condition
01/07/2014 12:35:21PM - Executing action 73286838-ADC5-44C6-9BF4-3D00C32317F7 - Set Windows information
01/07/2014 12:35:21PM - Checking System Info...
01/07/2014 12:35:21PM - Registry key WindowsCSDVersionString does not exist
01/07/2014 12:35:21PM - Windows 7 Home Premium matched .*\s*Windows 7.*
01/07/2014 12:35:21PM - WindowsProductName= Windows 7 Home Premium
WindowsCurrentVersion= 6.1
WindowsCSDVersionString= -
WindowsCSDVersionDWord= 256
WindowsPlatform= Windows7
01/07/2014 12:35:21PM - Executing action 1409F691-5623-49F1-99EB-D4ED15870571 - Set BuildName (default)
