CCSV5.4 installation problem at windows7
http://e2e.ti.com/cfs-file.ashx/__key/communityserver-discussions-components-files/81/1220.60556FE5_2D00_C1A1_2D00_4061_2D00_8DF8_2D00_FFB8393BAE2D.7z
I can install CCS5.3.0.00090_win32 successfully but always fail when install CCS5.4.0.00091_win32
    Right click on the setup file and click on "Run as administrator"
    This would surely solve your problem. If the problem still exist then try the same but now by changing the installation directory.
    Gautam
    1  "Right click on the setup file and click on "Run as administrator"", it has message as below
    Error in action ExecuteAction
    Error in action ExecuteScript
    Error in action ExecuteExternalProgram_Join
    couldn't execute "C:\ti\ccsv5\eclipse\downloads\ti_dspack_ibsetup_5.4.0.279.exe": no such file or directory
        while executing
    "::InstallJammer::actions::$component $this"
        while executing
        while executing
    "$obj execute"
        (procedure "::InstallJammer::ExecuteActions" line 69)
        invoked from within
    "::InstallJammer::ExecuteActions $action -parent $id -conditions $eval"
        (procedure "::InstallJammer::actions::ExecuteAction" line 35)
        invoked from within
        while executing
    "$obj execute"
        invoked from within
        invoked from within
        while executing
        while executing
        while executing
    "$obj execute"
        invoked from within
        invoked from within
        while executing
    "$obj execute"
        invoked from within
        invoked from within
        while executing
    "$obj execute"
        invoked from within
    "::InstallJammer::ExecuteActions $id -when $when"
        (procedure "::InstallJammer::RaiseEventHandler" line 93)
        invoked from within
    "::InstallJammer::RaiseEventHandler  .wizard"
        (command bound to event)
    2 "Right click on the setup file and click on "Run as administrator" and change the installation", it has error as log
    3463.ccs_setup_5.4.0.00091_install.log
    Elaine
  • I guess the setup file might be corrupted. Why don't you try downloading the offline setup again. Maybe this might solve your problem.
    Gautam
  • Hi Elaine,
    a few comments here.
    - if you don't need the older version, I would remove it.   It is also never a good idea to install over an older version
    - I would recommend going to the latest, v5.5 and doing a full fresh installation with antivirus disabled
    Please keep us informed.  If you have further issues, please send in the updated installjammer logs.
    LIsa
  • Hi Lisa,
    I try to remove V5.3.  It has message as below
    couldn't open "C:\ti/ccsv5/eclipse/ccs_config.xml": no such file or directory
        while executing
        while executing
    "$obj execute"
        invoked from within
        invoked from within
        while executing
        while executing
    "$obj execute"
        invoked from within
        invoked from within
        while executing
    "$obj execute"
        invoked from within
        invoked from within
    I try to install V5.5 directly.  It has a message :
    Reboot Pending
    The installer has detected a pendinf reboot.  This may cause unexpected problems during the install.  Do you wish to continue?
    I had restart my computer, it still had same issue
  • Hi Elaine,
    you need to manually uninstall by simply deleting all the directory structure for ccs.  I would also do this with your v5.5 attempt.
    Then I would reboot and try v5.5 again with the full installer, full permissions and antivirus off.
    If that fails, please send us the logs from the installjammer registry directory.  You may want to clear out the current logs as well.  the directory is under program files or program files (x86).
    Lisa
  • Hi Lisa,
    After I deleted css folder ans reboot, it still had this message "
    Reboot Pending
    The installer has detected a pending reboot.  This may cause unexpected problems during the install.  Do you wish to continue?"
     I selected "continue" and then the v5.5 had installed successfully
    Thank you.
    Elaine
  • Hi Elaine,
    glad to hear and sorry for the inconvenience.  All the best with development.
    Lisa
