Other Parts Discussed in Thread: CCSTUDIO
I am trying to debug my DSS script using CCS as described here:
http://wiki.davincidsp.com/index.php/Debugging_Your_DSS_Script_Using_CCStudio_v4
I am getting the following error after the script executes the line:
var server = env.getServer("CCSServer.1").openSession(".*");
Do you have any ideas to fix this?
Will
--BEGIN DSS ERROR--
Setting up debug enviornment...
isus.UpdateServiceException: Not Connected or Update Service is not available
at isus.rpc.RPCObject.ExecuteWithPost(Unknown Source)
at isus.rpc.RPCObject.Execute(Unknown Source)
at isus.rpc.RPCSendProfiles.Run(Unknown Source)
at isus.ProfileManager.synchProfiles(Unknown Source)
at isus.ProfileMgr.uploadCollection(Unknown Source)
at com.ti.ccstudio.update.CCEUpdateStartup.heartbeat(CCEUpdateStartup.java:51)
at com.ti.ccstudio.update.CCEUpdateStartup.earlyStartup(CCEUpdateStartup.java:13)
at org.eclipse.ui.internal.EarlyStartupRunnable.runEarlyStartup(EarlyStartupRunnable.java:87)
at org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartupRunnable.java:66)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.ui.internal.Workbench$20.run(Workbench.java:1759)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
java.lang.UnsatisfiedLinkError: Can't load library: /C:/Program%20Files/Texas%20Instruments/ccsv4/eclipse/plugins/com.ti.dvt.tidisassembly_1.0.0.200910161644/os/win32/dvt_tpiarm.dll
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.load0(Unknown Source)
at java.lang.System.load(Unknown Source)
at com.ti.dvt.tidisassembly.TIDisassemblyJNI.<clinit>(TIDisassemblyJNI.java:74)
at com.ti.dvt.tidisassembly.TIDisassembly.CoffClose(TIDisassembly.java:47)
at com.ti.dvt.datamodel.core.SymbolicOperator.finalize(SymbolicOperator.java:224)
at java.lang.ref.Finalizer.invokeFinalizeMethod(Native Method)
at java.lang.ref.Finalizer.runFinalizer(Unknown Source)
at java.lang.ref.Finalizer.access$100(Unknown Source)
at java.lang.ref.Finalizer$FinalizerThread.run(Unknown Source)
