relocation from function ... to symbol ...
I am tring to link with some libraries in neardata mode on DM8127 (C674x)  IPNC RDK 3.5, and get errors almost same as http://e2e.ti.com/support/development_tools/compiler/f/343/t/129681.aspx
Here is the info.
ERROR MESSAGE
error #17003-D:
relocation from function "DSKT2_cfgInit" to symbol "DSKT2_eprogHeap"
overflowed; the 18-bit relocated address 0x2fd0a is too large to encode in
the 15-bit unsigned field (type = 'R_C6000_SBR_U15_W' (13), file =
"/ipnc_rdk/../ipnc_rdk/ipnc_mcfw/build/ipnc_rdk/obj/ti814x-evm/c6xdsp/release/MAIN_APP_c6xdsp_pe674.oe674", offset
= 0x00000008, section = ".text:DSKT2_cfgInit")
SOURCE CODE(only an empty line between definition and access)
xdc_runtime_IHeap_Handle DSKT2_daram0Heap = NULL;
xdc_runtime_IHeap_Handle DSKT2_daram1Heap = NULL;
xdc_runtime_IHeap_Handle DSKT2_daram2Heap = NULL;
xdc_runtime_IHeap_Handle DSKT2_saram0Heap = NULL;
xdc_runtime_IHeap_Handle DSKT2_saram1Heap = NULL;
xdc_runtime_IHeap_Handle DSKT2_saram2Heap = NULL;
xdc_runtime_IHeap_Handle DSKT2_iprogHeap = NULL;
xdc_runtime_IHeap_Handle DSKT2_eprogHeap = NULL;
xdc_runtime_IHeap_Handle DSKT2_esdataHeap = NULL;
xdc_runtime_IHeap_Handle _DSKT2_heap = NULL;
Void DSKT2_cfgInit()
DSKT2_daram0Heap = (xdc_runtime_IHeap_Handle)DSP_HEAPINT_MEM;
DSKT2_daram1Heap = (xdc_runtime_IHeap_Handle)DSP_HEAPINT_MEM;
DSKT2_daram2Heap = (xdc_runtime_IHeap_Handle)DSP_HEAPINT_MEM;
DSKT2_saram0Heap = (xdc_runtime_IHeap_Handle)DSP_HEAPEXT_MEM;
DSKT2_saram1Heap = (xdc_runtime_IHeap_Handle)DSP_HEAPEXT_MEM;
DSKT2_saram2Heap = (xdc_runtime_IHeap_Handle)DSP_HEAPEXT_MEM;
DSKT2_iprogHeap = (xdc_runtime_IHeap_Handle)DSP_HEAPEXT_MEM;
DSKT2_eprogHeap = (xdc_runtime_IHeap_Handle)DSP_HEAPEXT_MEM;
DSKT2_esdataHeap = (xdc_runtime_IHeap_Handle)DSP_HEAPEXT_MEM;
_DSKT2_heap = (xdc_runtime_IHeap_Handle)DSP_HEAPEXT_MEM;
LINK CMD
.bss:extMemNonCache:remoteDebugCoreShm: load >> REMOTE_DEBUG_MEM
GROUP: load > DSP_CODE_MEM
.bss: {*(.bss)}
.rodata: {*(.rodata)}
.neardata: {*(.neardata)}
.text:DSKT2_cfgInit:
.text:
.far: {
*(.far)
} load > DSP_CODE_MEM
MAP
run origin load origin length init length attrs members
90000000 90000000 006bf070 00000000 rw-
90000000 90000000 00600000 00000000 rw- .systemHeap
90600000 90600000 000bf070 00000000 rw- .bss
906bf070 906bf070 0000000c 0000000c r--
906bf070 906bf070 0000000c 0000000c r-- .rodata
906bf07c 906bf07c 000006d5 000006d5 rw-
906bf07c 906bf07c 000006d5 000006d5 rw- .neardata
906bf760 906bf760 00516d00 00516d00 r-x
906bf760 906bf760 00000040 00000040 r-x .text:DSKT2_cfgInit
906bf7a0 906bf7a0 00516cc0 00516cc0 r-x .text
90bd6460 90bd6460 00313893 00000000 rw-
90bd6460 90bd6460 00313893 00000000 rw- .far
90ee9cf8 90ee9cf8 00020000 00000000 rw-
90ee9cf8 90ee9cf8 00020000 00000000 rw- .internalHeap
90f09d00 90f09d00 00006140 00006140 r-x
90f09d00 90f09d00 00003d40 00003d40 r-x .scd_core
906bf760   DSKT2_cfgInit
906bf40c DSKT2_daram0Heap
906bf410 DSKT2_daram1Heap
906bf414 DSKT2_daram2Heap
906bf418 DSKT2_saram0Heap
906bf41c DSKT2_saram1Heap
906bf420 DSKT2_saram2Heap
906bf424 DSKT2_iprogHeap
906bf428 DSKT2_eprogHeap
906bf42c DSKT2_esdataHeap
906bf430 _DSKT2_heap
ASS
.global DSKT2_eprogHeap
.sect ".neardata", RW
.align 4
.elfsym DSKT2_eprogHeap,SYM_SIZE(4)
DSKT2_eprogHeap:
.field 0,32 ; DSKT2_eprogHeap @ 0
DSKT2_cfgInit:
;* 5206 ----------------------- DSKT2_daram0Heap = C$2 = (struct dc_runtime_IHeap___Object *)(C$1 = &ti_sysbios_heaps_HeapMem_Object__table__V)+20;
;* 5207 ----------------------- DSKT2_daram1Heap = C$2;
;* 5208 ----------------------- DSKT2_daram2Heap = C$2;
;* 5209 ----------------------- DSKT2_saram0Heap = (struct dc_runtime_IHeap___Object *)C$1;
;* 5210 ----------------------- DSKT2_saram1Heap = (struct dc_runtime_IHeap___Object *)C$1;
;* 5211 ----------------------- DSKT2_saram2Heap = (struct dc_runtime_IHeap___Object *)C$1;
;* 5212 ----------------------- DSKT2_iprogHeap = (struct dc_runtime_IHeap___Object *)C$1;
;* 5213 ----------------------- DSKT2_eprogHeap = (struct dc_runtime_IHeap___Object *)C$1;
;* 5214 ----------------------- DSKT2_esdataHeap = (struct dc_runtime_IHeap___Object *)C$1;
;* 5215 ----------------------- _DSKT2_heap = (struct dc_runtime_IHeap___Object *)C$1;
;** ----------------------- return;
MVKL .S1 ti_sysbios_heaps_HeapMem_Object__table__V,A3
MVKH .S1 ti_sysbios_heaps_HeapMem_Object__table__V,A3
STW .D2T1 A3,*+DP(DSKT2_eprogHeap) ; |5213|
STW .D2T1 A3,*+DP(DSKT2_iprogHeap) ; |5212|
STW .D2T1 A3,*+DP(DSKT2_saram2Heap) ; |5211|
STW .D2T1 A3,*+DP(DSKT2_saram1Heap) ; |5210|
$C$DW$6367 .dwtag DW_TAG_TI_branch
.dwattr $C$DW$6367, DW_AT_low_pc(0x00)
.dwattr $C$DW$6367, DW_AT_TI_return
RET .S2 B3 ; |5216|
|| STW .D2T1 A3,*+DP(DSKT2_esdataHeap) ; |5214|
STW .D2T1 A3,*+DP(DSKT2_saram0Heap) ; |5209|
ADD .D1 A3,20,A3 ; |5206|
|| STW .D2T1 A3,*+DP(_DSKT2_heap) ; |5215|
STW .D2T1 A3,*+DP(DSKT2_daram0Heap) ; |5206|
STW .D2T1 A3,*+DP(DSKT2_daram1Heap) ; |5207|
I have tried to modify mem-model to near, far, far_aggregates, and can't work.
so, someone can help me?
ps:
what's the meaning of the address 0x2fd0a(the 18-bit relocated address, how to calculate), I have changed the postion of .neardata and .text:cfgInit by link file, but the address is unchangable.
Frank
  • Your map file shows that your .bss (which contains near variables) is of size 0x000bf070, which is much too large to be accessed with near access.  You will most likely need to use far mode to compile the entire program.  You must recompile at least the modules that have lots of global variables.
    The error message tells you that address 0x2fd0a represents variable DSKT2_eprogHeap. Function DSKT2_cfgInit is trying to access variable DSKT2_eprogHeap with near addressing, but it is too far away from the start of .bss, probably because .bss is too large.
  • Please see this wiki article for background on the topic.  I'm pretty sure the definition and declarations of DSKT2_eprogHeap are not in full agreement.  Keep in mind that any explicit use of "near" or "far" keywords in the source overrides any command line setting.
    Thanks and regards,
    -George
  • Hi, Archaeologist,
    I have tried to move some section from .bss to .fardata, the size of .bss section  was shrinked to 0x10, and the problem is resolved.
    Thanks.
    Frank
