CCS v5 compiler error - WARNING: more than one source file is specified
I could not figure out the following compiling error.  Please help.
Thank you
Allyson
>> Compilation failure
gmake: *** [DLS4/FreeRTOS_portable/MemMang/heap_3.obj] Error 1
'Building file: ../DLS4/FreeRTOS_portable/MemMang/heap_4.c'
'Invoking: ARM Compiler'
"C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/usblib" --include_path="C:/Project Program/EDL1/usblib/device" --include_path="C:/Project Program/EDL1" --include_path="C:/Project Program/EDL1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLS4/src" --include_path="C:/Project Program/EDL1/driverlib" --include_path="C:/Project Program/EDL1/DLS4/drivers" --include_path="C:/Project Program/EDL1/inc" --include_path="C:/Project Program/EDL1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/utils" --include_path="C:/Project Program/EDL1/DLS4/src/third_party/fatfs/src" --include_path="C:/Project Program/EDL1/utils/lwip" -g --define=ccs --verbose_diagnostics --diag_warning=5 --gen_aux_user_info --write_diagnostics_file --diag_remark=5 --diag_error=5 --display_error_number --diag_suppress=5 --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/FreeRTOS_portable/MemMang/heap_4.pp" --obj_directory="DLS4/FreeRTOS_portable/MemMang" "../DLS4/FreeRTOS_portable/MemMang/heap_4.c"
>> WARNING: more than one source file is specified; preprocessor output will be generated for last file only
  • Allyson,
    It seems the build output is incomplete, as the error is reported for the file heap_3 but the snippet only shows the heap_4 output.
    Rafael
  • Rafael:
    I do not get any error when I built my project.  But the compilation failed.  Below is the entire copy from Console window.
    Thank you for the help
    Allyson
    gmake: *** [DLS4/src/USB_BOOT.obj] Error 1
    'Building file: ../DLS4/src/WH_Log.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/WH_Log.pp" --obj_directory="DLS4/src" "../DLS4/src/WH_Log.c"
    Fatal error #1965: cannot open source file "="
    1 catastrophic error detected in the compilation of "=".
    Compilation terminated.
    >> Compilation failure
    gmake: *** [DLS4/src/WH_Log.obj] Error 1
    'Building file: ../DLS4/src/WH_Params.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/WH_Params.pp" --obj_directory="DLS4/src" "../DLS4/src/WH_Params.c"
    >> Compilation failure
    gmake: *** [DLS4/src/WH_Params.obj] Error 1
    'Building file: ../DLS4/src/WH_SD_Card.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/WH_SD_Card.pp" --obj_directory="DLS4/src" "../DLS4/src/WH_SD_Card.c"
    >> Compilation failure
    gmake: *** [DLS4/src/WH_SD_Card.obj] Error 1
    'Building file: ../DLS4/src/WH_Trend.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/WH_Trend.pp" --obj_directory="DLS4/src" "../DLS4/src/WH_Trend.c"
    >> Compilation failure
    gmake: *** [DLS4/src/WH_Trend.obj] Error 1
    'Building file: ../DLS4/src/WarehouseTask.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/WarehouseTask.pp" --obj_directory="DLS4/src" "../DLS4/src/WarehouseTask.c"
    >> Compilation failure
    gmake: *** [DLS4/src/WarehouseTask.obj] Error 1
    'Building file: ../DLS4/src/cr_startup_c.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/cr_startup_c.pp" --obj_directory="DLS4/src" "../DLS4/src/cr_startup_c.c"
    >> Compilation failure
    gmake: *** [DLS4/src/cr_startup_c.obj] Error 1
    'Building file: ../DLS4/src/main.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/main.pp" --obj_directory="DLS4/src" "../DLS4/src/main.c"
    >> Compilation failure
    gmake: *** [DLS4/src/main.obj] Error 1
    'Building file: ../DLS4/src/watchdog.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/watchdog.pp" --obj_directory="DLS4/src" "../DLS4/src/watchdog.c"
    >> Compilation failure
    gmake: *** [DLS4/src/watchdog.obj] Error 1
    'Building file: ../DLS4/src/third_party/fatfs/src/cc932.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/third_party/fatfs/src/cc932.pp" --obj_directory="DLS4/src/third_party/fatfs/src" "../DLS4/src/third_party/fatfs/src/cc932.c"
    gmake: *** [DLS4/src/third_party/fatfs/src/cc932.obj] Error 1
    >> Compilation failure
    'Building file: ../DLS4/src/third_party/fatfs/src/ff.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/third_party/fatfs/src/ff.pp" --obj_directory="DLS4/src/third_party/fatfs/src" "../DLS4/src/third_party/fatfs/src/ff.c"
    >> Compilation failure
    gmake: *** [DLS4/src/third_party/fatfs/src/ff.obj] Error 1
    'Building file: ../DLS4/src/third_party/fatfs/src/mmc-dk-lm3s9b96.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/third_party/fatfs/src/mmc-dk-lm3s9b96.pp" --obj_directory="DLS4/src/third_party/fatfs/src" "../DLS4/src/third_party/fatfs/src/mmc-dk-lm3s9b96.c"
    >> Compilation failure
    gmake: *** [DLS4/src/third_party/fatfs/src/mmc-dk-lm3s9b96.obj] Error 1
    'Building file: ../DLS4/src/USB/utils/uartstdio.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/USB/utils/uartstdio.pp" --obj_directory="DLS4/src/USB/utils" "../DLS4/src/USB/utils/uartstdio.c"
    >> Compilation failure
    gmake: *** [DLS4/src/USB/utils/uartstdio.obj] Error 1
    'Building file: ../DLS4/src/USB/usb_dev_msc.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/USB/usb_dev_msc.pp" --obj_directory="DLS4/src/USB" "../DLS4/src/USB/usb_dev_msc.c"
    >> Compilation failure
    gmake: *** [DLS4/src/USB/usb_dev_msc.obj] Error 1
    'Building file: ../DLS4/src/USB/usb_msc_structs.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/USB/usb_msc_structs.pp" --obj_directory="DLS4/src/USB" "../DLS4/src/USB/usb_msc_structs.c"
    >> Compilation failure
    gmake: *** [DLS4/src/USB/usb_msc_structs.obj] Error 1
    'Building file: ../DLS4/src/USB/usbdsdcard.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/USB/usbdsdcard.pp" --obj_directory="DLS4/src/USB" "../DLS4/src/USB/usbdsdcard.c"
    >> Compilation failure
    gmake: *** [DLS4/src/USB/usbdsdcard.obj] Error 1
    'Building file: ../DLS4/src/Screens/KPD_Screen_Ctrl.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/Screens/KPD_Screen_Ctrl.pp" --obj_directory="DLS4/src/Screens" "../DLS4/src/Screens/KPD_Screen_Ctrl.c"
    >> Compilation failure
    gmake: *** [DLS4/src/Screens/KPD_Screen_Ctrl.obj] Error 1
    'Building file: ../DLS4/src/Screens/KPD_Scrn_Logs.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/Screens/KPD_Scrn_Logs.pp" --obj_directory="DLS4/src/Screens" "../DLS4/src/Screens/KPD_Scrn_Logs.c"
    >> Compilation failure
    gmake: *** [DLS4/src/Screens/KPD_Scrn_Logs.obj] Error 1
    'Building file: ../DLS4/src/Screens/KPD_Scrn_Par.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/Screens/KPD_Scrn_Par.pp" --obj_directory="DLS4/src/Screens" "../DLS4/src/Screens/KPD_Scrn_Par.c"
    >> Compilation failure
    gmake: *** [DLS4/src/Screens/KPD_Scrn_Par.obj] Error 1
    'Building file: ../DLS4/src/Screens/KPD_Scrn_Settings.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/Screens/KPD_Scrn_Settings.pp" --obj_directory="DLS4/src/Screens" "../DLS4/src/Screens/KPD_Scrn_Settings.c"
    >> Compilation failure
    gmake: *** [DLS4/src/Screens/KPD_Scrn_Settings.obj] Error 1
    'Building file: ../DLS4/src/Screens/KPD_Scrn_Trend.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/Screens/KPD_Scrn_Trend.pp" --obj_directory="DLS4/src/Screens" "../DLS4/src/Screens/KPD_Scrn_Trend.c"
    >> Compilation failure
    gmake: *** [DLS4/src/Screens/KPD_Scrn_Trend.obj] Error 1
    'Building file: ../DLS4/src/LCD/LCD_com.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/LCD/LCD_com.pp" --obj_directory="DLS4/src/LCD" "../DLS4/src/LCD/LCD_com.c"
    >> Compilation failure
    gmake: *** [DLS4/src/LCD/LCD_com.obj] Error 1
    'Building file: ../DLS4/src/LCD/LCD_drawlib.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/LCD/LCD_drawlib.pp" --obj_directory="DLS4/src/LCD" "../DLS4/src/LCD/LCD_drawlib.c"
    >> Compilation failure
    gmake: *** [DLS4/src/LCD/LCD_drawlib.obj] Error 1
    'Building file: ../DLS4/src/LCD/LCD_fonts.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/LCD/LCD_fonts.pp" --obj_directory="DLS4/src/LCD" "../DLS4/src/LCD/LCD_fonts.c"
    >> Compilation failure
    gmake: *** [DLS4/src/LCD/LCD_fonts.obj] Error 1
    'Building file: ../DLS4/src/LCD/LCD_layouts.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/LCD/LCD_layouts.pp" --obj_directory="DLS4/src/LCD" "../DLS4/src/LCD/LCD_layouts.c"
    >> Compilation failure
    gmake: *** [DLS4/src/LCD/LCD_layouts.obj] Error 1
    'Building file: ../DLS4/src/LCD/LCD_messaging.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/LCD/LCD_messaging.pp" --obj_directory="DLS4/src/LCD" "../DLS4/src/LCD/LCD_messaging.c"
    >> Compilation failure
    gmake: *** [DLS4/src/LCD/LCD_messaging.obj] Error 1
    'Building file: ../DLS4/src/LCD/LCD_strings.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/LCD/LCD_strings.pp" --obj_directory="DLS4/src/LCD" "../DLS4/src/LCD/LCD_strings.c"
    >> Compilation failure
    gmake: *** [DLS4/src/LCD/LCD_strings.obj] Error 1
    'Building file: ../DLS4/src/DriveComs/DriveComs.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/DriveComs/DriveComs.pp" --obj_directory="DLS4/src/DriveComs" "../DLS4/src/DriveComs/DriveComs.c"
    >> Compilation failure
    gmake: *** [DLS4/src/DriveComs/DriveComs.obj] Error 1
    'Building file: ../DLS4/src/DriveComs/SerialTask.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/DriveComs/SerialTask.pp" --obj_directory="DLS4/src/DriveComs" "../DLS4/src/DriveComs/SerialTask.c"
    >> Compilation failure
    gmake: *** [DLS4/src/DriveComs/SerialTask.obj] Error 1
    'Building file: ../DLS4/src/DriveComs/subseqAlarm.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/DriveComs/subseqAlarm.pp" --obj_directory="DLS4/src/DriveComs" "../DLS4/src/DriveComs/subseqAlarm.c"
    >> Compilation failure
    gmake: *** [DLS4/src/DriveComs/subseqAlarm.obj] Error 1
    'Building file: ../DLS4/src/DriveComs/subseqDownload.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/DriveComs/subseqDownload.pp" --obj_directory="DLS4/src/DriveComs" "../DLS4/src/DriveComs/subseqDownload.c"
    >> Compilation failure
    gmake: *** [DLS4/src/DriveComs/subseqDownload.obj] Error 1
    'Building file: ../DLS4/src/DriveComs/subseqFault.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/DriveComs/subseqFault.pp" --obj_directory="DLS4/src/DriveComs" "../DLS4/src/DriveComs/subseqFault.c"
    >> Compilation failure
    gmake: *** [DLS4/src/DriveComs/subseqFault.obj] Error 1
    'Building file: ../DLS4/src/DriveComs/subseqGetDrvInf.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/DriveComs/subseqGetDrvInf.pp" --obj_directory="DLS4/src/DriveComs" "../DLS4/src/DriveComs/subseqGetDrvInf.c"
    >> Compilation failure
    gmake: *** [DLS4/src/DriveComs/subseqGetDrvInf.obj] Error 1
    'Building file: ../DLS4/src/DriveComs/subseqLog.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/DriveComs/subseqLog.pp" --obj_directory="DLS4/src/DriveComs" "../DLS4/src/DriveComs/subseqLog.c"
    >> Compilation failure
    gmake: *** [DLS4/src/DriveComs/subseqLog.obj] Error 1
    'Building file: ../DLS4/src/DriveComs/subseqUpload.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/src/DriveComs/subseqUpload.pp" --obj_directory="DLS4/src/DriveComs" "../DLS4/src/DriveComs/subseqUpload.c"
    >> Compilation failure
    gmake: *** [DLS4/src/DriveComs/subseqUpload.obj] Error 1
    'Building file: ../DLS4/drivers/set_pinout.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/drivers/set_pinout.pp" --obj_directory="DLS4/drivers" "../DLS4/drivers/set_pinout.c"
    >> Compilation failure
    gmake: *** [DLS4/drivers/set_pinout.obj] Error 1
    'Building file: ../DLS4/FreeRTOS_src/croutine.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/FreeRTOS_src/croutine.pp" --obj_directory="DLS4/FreeRTOS_src" "../DLS4/FreeRTOS_src/croutine.c"
    >> Compilation failure
    gmake: *** [DLS4/FreeRTOS_src/croutine.obj] Error 1
    'Building file: ../DLS4/FreeRTOS_src/list.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/FreeRTOS_src/list.pp" --obj_directory="DLS4/FreeRTOS_src" "../DLS4/FreeRTOS_src/list.c"
    >> Compilation failure
    gmake: *** [DLS4/FreeRTOS_src/list.obj] Error 1
    'Building file: ../DLS4/FreeRTOS_src/queue.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/FreeRTOS_src/queue.pp" --obj_directory="DLS4/FreeRTOS_src" "../DLS4/FreeRTOS_src/queue.c"
    >> Compilation failure
    gmake: *** [DLS4/FreeRTOS_src/queue.obj] Error 1
    'Building file: ../DLS4/FreeRTOS_src/tasks.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/FreeRTOS_src/tasks.pp" --obj_directory="DLS4/FreeRTOS_src" "../DLS4/FreeRTOS_src/tasks.c"
    >> Compilation failure
    gmake: *** [DLS4/FreeRTOS_src/tasks.obj] Error 1
    'Building file: ../DLS4/FreeRTOS_src/timers.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/FreeRTOS_src/timers.pp" --obj_directory="DLS4/FreeRTOS_src" "../DLS4/FreeRTOS_src/timers.c"
    >> Compilation failure
    gmake: *** [DLS4/FreeRTOS_src/timers.obj] Error 1
    'Building file: ../DLS4/FreeRTOS_portable/port.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/FreeRTOS_portable/port.pp" --obj_directory="DLS4/FreeRTOS_portable" "../DLS4/FreeRTOS_portable/port.c"
    >> Compilation failure
    gmake: *** [DLS4/FreeRTOS_portable/port.obj] Error 1
    'Building file: ../DLS4/FreeRTOS_portable/MemMang/heap_1.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/FreeRTOS_portable/MemMang/heap_1.pp" --obj_directory="DLS4/FreeRTOS_portable/MemMang" "../DLS4/FreeRTOS_portable/MemMang/heap_1.c"
    >> Compilation failure
    gmake: *** [DLS4/FreeRTOS_portable/MemMang/heap_1.obj] Error 1
    'Building file: ../DLS4/FreeRTOS_portable/MemMang/heap_2.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/FreeRTOS_portable/MemMang/heap_2.pp" --obj_directory="DLS4/FreeRTOS_portable/MemMang" "../DLS4/FreeRTOS_portable/MemMang/heap_2.c"
    >> Compilation failure
    gmake: *** [DLS4/FreeRTOS_portable/MemMang/heap_2.obj] Error 1
    'Building file: ../DLS4/FreeRTOS_portable/MemMang/heap_3.c'
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/FreeRTOS_portable/MemMang/heap_3.pp" --obj_directory="DLS4/FreeRTOS_portable/MemMang" "../DLS4/FreeRTOS_portable/MemMang/heap_3.c"
    >> Compilation failure
    "C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/Project Program/EDL1/DLCCS1" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_include" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/src" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/FreeRTOS_portable" --include_path="C:/Project Program/EDL1/DLCCS1/driverlib" --include_path="C:/Project Program/EDL1/DLCCS1/inc" --include_path="C:/Project Program/EDL1/DLCCS1/DLS4/drivers" -g --gcc --define=ccs="ccs" --diag_warning=225 --display_error_number --diag_wrap=off --asm_define=__TI_EABI_ASSEMBLER = 1 --preproc_with_compile --preproc_dependency="DLS4/FreeRTOS_portable/MemMang/heap_4.pp" --obj_directory="DLS4/FreeRTOS_portable/MemMang" "../DLS4/FreeRTOS_portable/MemMang/heap_4.c"
    >> Compilation failure
    gmake: *** [DLS4/FreeRTOS_portable/MemMang/heap_4.obj] Error 1
    gmake: Target `all' not remade because of errors.
    **** Build Finished ****
  • I believe the error is due to the extra spaces you have in the --asm_define option. See this related thread for similar errors.
    So change:
    to:
    --asm_define=__TI_EABI_ASSEMBLER=1
    and let us know if it resolves the errors.
    I think the compile error is caused by the definition of the predefined assembly name __TI_EABI_ASSEMBLER in the project properties.
    In the command line output there is are spaces between the __TI_EABI_ASSEMBLER name the equals and the value one. i.e. under CCS project properties -> Build -> ARM Compiler -> Advanced Options -> Assembler Options the following has been added as a "Pre-define assembly symbol NAME (--asm_define, -ad)
    __TI_EABI_ASSEMBLER<space>=<space>1
    The spaces then cause the compiler to attempt to compile a non-existent source file called "=". Try removing the spaces from the pre-define assembly symbol NAME, i.e.:
  • if you get the error of [su011] fatal error more than one file specified .
    Make sure that the code your trying to compile is residing on a location on you disk which does not have any spaces in the location.
    that fixed it for me.
