I got error message when i tried to install ccs_setup_5.2.1.00018 about uninstalled features
I
The install started and then stopped part way through. The error is as below:
Checking to see if <%EclipseDir%>/downloads/.ijrunning.txt exists
01/31/2014 13:05:00PM - ** Checking to see if /downloads/.ijrunning.txt exists
01/31/2014 13:05:00PM - Condition failed
01/31/2014 13:05:00PM - Skipping action 1160585F-F26F-4111-911E-B0D10C849C31 - Remove .ij_running.txt - conditions failed
  • Hi Hany,
    first, I would very strongly recommend the latest version, v5.5.  I would clean out your attempted installation first, and no matter what version, ensure antivirus is disabled.
    THen, if you still have errors please send the isntallation logs from the installjammer registry directory.  It is located under program files or program files (x86) and may be hidden.
    Lisa
  • Hi Hany,
    just thought I would check for any updates/install logs to help you.
    Lisa
