Hi all, we are using cgtools 5.2.3 and get segmentation faults at different C files for every build. We are doing the build with gnu make, calling the cgtools from the command line (inside make). INTERNAL ERROR: c:\ti33\c2000\cgtools_5_2_3\bin\cl2000 experienced a segmentation fault while processing This is a serious problem. Please contact Customer Support with this message and a copy of the input file and help us to continue to make the tools more robust. On every build, a different file causes the segmentation fault. Has anyone else experienced this problem? Is this a known bug - and is there a solution?
The error is
I am now using cgtools 5.2.3, but the error appeared from time to time since my switch from 4.1.3.
I have several different compiler versions installed on my PC for the different projects.
