HEllo,
After rehosting my license server, I have a problem when starting the license server. I followed those guidelines: http://processors.wiki.ti.com/index.php/License_Server_Administration_for_CCS
I have no file in /usr/local/flexlm neither in my old server thats works fine nor my new server.
Hereunder the log :
9:54:15 (lmgrd) Server's System Date and Time: Wed Feb 05 2014 09:54:15 CET
9:54:15 (lmgrd) SLOG: Summary LOG statistics is enabled.
9:54:15 (lmgrd) The license server manager (lmgrd) running as root:
9:54:15 (lmgrd) This is a potential security problem
9:54:15 (lmgrd) and is not recommended.
9:54:15 (lmgrd) FlexNet Licensing (v11.12.0.0 build 136775 x64_lsb) started on localhost (linux) (2/5/2014)
9:54:15 (lmgrd) Copyright (c) 1988-2013 Flexera Software LLC. All Rights Reserved.
9:54:15 (lmgrd) World Wide Web: http://www.flexerasoftware.com
9:54:15 (lmgrd) License file(s): /opt/code_composer_license_server/licenses/TMDSCCS-ALLF03-v5.lic
9:54:15 (lmgrd) lmgrd tcp-port 27000
9:54:15 (lmgrd) (@lmgrd-SLOG@) ===============================================
9:54:15 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
9:54:15 (lmgrd) (@lmgrd-SLOG@) Start-Date: Wed Feb 05 2014 09:54:15 CET
9:54:15 (lmgrd) (@lmgrd-SLOG@) PID: 2243
9:54:15 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.12.0.0 build 136775 x64_lsb ( build 136775 (ipv6))
9:54:15 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
9:54:15 (lmgrd) (@lmgrd-SLOG@) Socket interface: IPV6
9:54:15 (lmgrd) (@lmgrd-SLOG@) Listening port: 27000
9:54:15 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
9:54:15 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
9:54:15 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c /opt/code_composer_license_server/licenses/TMDSCCS-ALLF03-v5.lic -l /opt/code_composer_license_server/logs/tidspssw.log
9:54:15 (lmgrd) (@lmgrd-SLOG@) License file(s) used: /opt/code_composer_license_server/licenses/TMDSCCS-ALLF03-v5.lic
9:54:15 (lmgrd) Starting vendor daemons ...
9:54:15 (lmgrd) Started tidspssw (internet tcp_port 57136 pid 2244)
9:54:15 (tidspssw) FLEXnet Licensing version v11.4.100.0 build 50818 i86_re3
9:54:15 (tidspssw) lmgrd version 11.12, tidspssw version 11.4
9:54:15 (tidspssw) Cannot open license file /usr/local/flexlm/licenses/license.dat
9:54:15 (tidspssw) EXITING DUE TO SIGNAL 52 Exit reason 20
9:54:15 (lmgrd) tidspssw exited with status 52 (No license file)
9:54:15 (lmgrd) Please correct problem and restart daemons
Do you have any idea of what happenned?
Thanks in advance.
