Code Composer Studio on Fedora 20 (Heisenbug) 64 bits
Other Parts Discussed in Thread: CCSTUDIO, UNIFLASH
I'm trying to use Code Composer Studio v5 on a Fedora 20 64 bits.
i have visited http://processors.wiki.ti.com/index.php/Linux_Host_Support which explains what should be done to use it on 64 bits.
I have managed to install it, but when I try to run it, a segmentation fault occurs.
When I run the script "generate_depends.sh" (retrieved from http://processors.wiki.ti.com/index.php/Checking_Linux_Dependencies_for_CCS), execution works.
But if I try to run "check_depends.sh", a segmentation fault occurs. Same for "testprog" binary. I guess that's because some 32 bits librairies are missing.
I compiled "test.cpp" and ran it, the following output is displayed :
Checking availability of librairies in ext-depends.txt ...
Failed to find lib: ld-linux.so.2
Failed to find lib: libgnomevfs-2.so.0
Failed to find lib: libORBit-2.so.0
Done.
After checking in my "/lib" and "/lib64" directories, here is what I could find:
/lib : /lib/ld-linux.so.2 /lib/libgnomevfs-2.so.0 /lib/libORBit-2.so.0
/lib64 : /lib/ld-linux-x86-64.so.2
If my understanding is correct, concerned librairies should be found in /lib directory ?
Can anyone help me ?
Please tell me if you any additional information.
Thank you in advance.
    I now only have ld-linux.so.2 that fails.
    I tried to investigate with gdb why it fails. the variable _dlfcn_hook variable in function __dlopen is NULL, which causes the function to fail and return NULL.
    I also tried to compile with g++ -m32 the test.cpp file, with success.
    When I run it, a Segmentation Fault occurs, I looked with gcc and it seems that the Seg Fault occurs from the function pthread_once.
    I really do not understand what is happening, if anyone has any idea.
    Thank you.
  • I don't have access to v5.5 at the moment, but I did try a CCSv6 beta on Fedora 20 after installing the dependencies and did not see the seg fault issue you mention.  Would you be open to trying the v6 beta 4 (located here: http://processors.wiki.ti.com/index.php/Category:Code_Composer_Studio_v6) ?
    Thank you for your answer.
    I'm willing to try yes. I will give feedback as soon as I tried it.
    But before that, could please confirm that :
      - When you say "installing the dependencies", you are talking about the dependencies mentioned in the page http://processors.wiki.ti.com/index.php/Linux_Host_Support ?
      - Did you do something else ?
      - Is it a 64 bits Fedora ?
      - Did you try CCS' features like build, debug... ?
    Thank you.
  • >>   - When you say "installing the dependencies", you are talking about the dependencies mentioned in the page http://processors.wiki.ti.com/index.php/Linux_Host_Support ?
    Correct.
    There is a change other software was installed on this PC before CCS.  I can't be 100% certain.
    Yes. uname -r returns: 3.13.3-201.fc20.x86_64
    I created an MSP430 project, compiled it, and attempted to launch it. The launch failed because I do not have an MSP FET conntected.
  • Thank you.
    I am actually trying right now to make it work.
    My Fedora installation is completely clean, I just did it.
    I ran yum upgrade
    I installed NVidia Drivers
    I downloaded the dependency checker.
    I ran the yum install "i686_libs..." described in the web page.
    I tried to run check_depends.sh and I still have the same issue :
    ./check_depends.sh: line 19: 4604 Segmentation fault (core dumped) ./testprog > /dev/null 2> /dev/null
    Please ensure the ia32 libraries are installed and re-run this script.
    Do you have an idea ? Do you need some addditional information ?
    Thank you.
  • The installation of CCSv6 succeeded but when I try to run it, I get a Segmentation Fault too.
    Could you tell me which software that could be relevant have been added to your system ?
    Or maybe provide me a list of 32 bits libs you have ? Also your environment variables could be relevant.
    Thank you.
    EDIT:
    Here is my configuration:
    uname -r : 3.13.6-200.fc20.x86_64
    CCS : CCS6.0.0.00156 according to the archive name
    Content of /lib :
    alsa
    alsa-lib
    audit
    binfmt.d
    cpp
    crda
    cups
    debug
    dracut
    firewalld
    firmware
    games
    gcc
    GConf
    gconv
    gdk-pixbuf-2.0
    gio
    girepository-1.0
    gnome-settings-daemon-3.0
    gnome-vfs-2.0
    grub
    gstreamer-1.0
    gtk-2.0
    gtk-3.0
    i686
    java
    java-1.5.0
    java-1.6.0
    java-1.7.0
    java-1.8.0
    java-ext
    jvm
    jvm-commmon
    jvm-exports
    jvm-private
    kbd
    kdump
    kernel
    krb5
    ld-2.18.so
    ld-linux.so.2
    libacl.so.1
    libacl.so.1.1.0
    libanl-2.18.so
    libanl.so.1
    libasound.so.2
    libasound.so.2.0.0
    libasyncns.so.0
    libasyncns.so.0.3.1
    libatk-1.0.so.0
    libatk-1.0.so.0.21009.1
    libatk-bridge-2.0.so.0
    libatk-bridge-2.0.so.0.0.0
    libatspi.so.0
    libatspi.so.0.0.1
    libattr.so.1
    libattr.so.1.1.0
    libaudit.so.1
    libaudit.so.1.0.0
    libauparse.so.0
    libauparse.so.0.0.0
    libavahi-client.so.3
    libavahi-client.so.3.2.9
    libavahi-common.so.3
    libavahi-common.so.3.5.3
    libavahi-glib.so.1
    libavahi-glib.so.1.0.2
    libBrokenLocale-2.18.so
    libBrokenLocale.so.1
    libbz2.so.1
    libbz2.so.1.0.6
    libc-2.18.so
    libcairo-gobject.so.2
    libcairo-gobject.so.2.11301.0
    libcairo-script-interpreter.so.2
    libcairo-script-interpreter.so.2.11301.0
    libcairo.so.2
    libcairo.so.2.11301.0
    libcanberra-0.30
    libcanberra-gtk3.so.0
    libcanberra-gtk3.so.0.1.9
    libcanberra-gtk.so.0
    libcanberra-gtk.so.0.1.9
    libcanberra.so.0
    libcanberra.so.0.2.5
    libcap.so.2
    libcap.so.2.22
    libcidn-2.18.so
    libcidn.so.1
    libcolordprivate.so.2
    libcolordprivate.so.2.0.1
    libcolord.so.2
    libcolord.so.2.0.1
    libcolorhug.so.2
    libcolorhug.so.2.0.1
    libcom_err.so.2
    libcom_err.so.2.1
    libcrack.so.2
    libcrack.so.2.9.0
    libcrypt-2.18.so
    libcrypto.so.10
    libcrypto.so.1.0.1e
    libcrypt.so.1
    libc.so.6
    libcuda.so
    libcuda.so.1
    libcuda.so.331.49
    libcupscgi.so.1
    libcupsimage.so.2
    libcupsmime.so.1
    libcupsppdc.so.1
    libcups.so.2
    libdb-5.3.so
    libdb-5.so
    libdbus-1.so.3
    libdbus-1.so.3.7.4
    libdbus-glib-1.so.2
    libdbus-glib-1.so.2.2.2
    libdl-2.18.so
    libdl.so.2
    libdrm_intel.so.1
    libdrm_intel.so.1.0.0
    libdrm_nouveau.so.2
    libdrm_nouveau.so.2.0.0
    libdrm_radeon.so.1
    libdrm_radeon.so.1.0.1
    libdrm.so.2
    libdrm.so.2.4.0
    libEGL.so
    libEGL.so.1
    libEGL.so.1.0.0
    libEGL.so.331.49
    libexpat.so.1
    libexpat.so.1.6.0
    libfam.so.0
    libfam.so.0.0.0
    libffi.so.6
    libffi.so.6.0.1
    libFLAC++.so.6
    libFLAC++.so.6.3.0
    libFLAC.so.8
    libFLAC.so.8.3.0
    libfontconfig.so.1
    libfontconfig.so.1.8.0
    libform.so.5
    libform.so.5.9
    libformw.so.5
    libformw.so.5.9
    libfreebl3.chk
    libfreebl3.so
    libfreetype.so.6
    libfreetype.so.6.10.2
    libftd2xx.so
    libftd2xx.so.1.1.12
    libgailutil-3.so.0
    libgailutil-3.so.0.0.0
    libgailutil.so.18
    libgailutil.so.18.0.1
    libgamin-1.so.0
    libgamin-1.so.0.1.10
    libgbm.so.1
    libgbm.so.1.0.0
    libgcc_s-4.8.2-20131212.so.1
    libgcc_s.so.1
    libgconf-2.so.4
    libgconf-2.so.4.1.5
    libgcrypt.so.11
    libgcrypt.so.11.8.2
    libgdk-3.so.0
    libgdk-3.so.0.1000.6
    libgdk_pixbuf-2.0.so.0
    libgdk_pixbuf-2.0.so.0.3000.3
    libgdk_pixbuf_xlib-2.0.so.0
    libgdk_pixbuf_xlib-2.0.so.0.3000.3
    libgdk-x11-2.0.so.0
    libgdk-x11-2.0.so.0.2400.22
    libgio-2.0.so.0
    libgio-2.0.so.0.3800.2
    libglapi.so.0
    libglapi.so.0.0.0
    libGLESv1_CM.so
    libGLESv1_CM.so.1
    libGLESv1_CM.so.331.49
    libGLESv2.so
    libGLESv2.so.2
    libGLESv2.so.331.49
    libglib-2.0.so.0
    libglib-2.0.so.0.3800.2
    libGL.la
    libGL.so
    libGL.so.1
    libGL.so.1.2.0
    libGL.so.331.49
    libgmodule-2.0.so.0
    libgmodule-2.0.so.0.3800.2
    libgnomevfs-2.so.0
    libgnomevfs-2.so.0.2400.4
    libgobject-2.0.so.0
    libgobject-2.0.so.0.3800.2
    libgpg-error.so.0
    libgpg-error.so.0.10.0
    libgraphite2.so.3
    libgraphite2.so.3.0.1
    libgsm.so.1
    libgsm.so.1.0.12
    libgssapi_krb5.so.2
    libgssapi_krb5.so.2.2
    libgssrpc.so.4
    libgssrpc.so.4.1
    libgstbase-1.0.so.0
    libgstbase-1.0.so.0.203.0
    libgstcheck-1.0.so.0
    libgstcheck-1.0.so.0.203.0
    libgstcontroller-1.0.so.0
    libgstcontroller-1.0.so.0.203.0
    libgstnet-1.0.so.0
    libgstnet-1.0.so.0.203.0
    libgstreamer-1.0.so.0
    libgstreamer-1.0.so.0.203.0
    libgthread-2.0.so.0
    libgthread-2.0.so.0.3800.2
    libgtk-3.so.0
    libgtk-3.so.0.1000.6
    libgtk-x11-2.0.so.0
    libgtk-x11-2.0.so.0.2400.22
    libgudev-1.0.so.0
    libgudev-1.0.so.0.1.3
    libgusb.so.2
    libgusb.so.2.0.3
    libharfbuzz.so.0
    libharfbuzz.so.0.926.0
    libICE.so.6
    libICE.so.6.3.0
    libIDL-2.so.0
    libIDL-2.so.0.0.0
    libjasper.so.1
    libjasper.so.1.0.0
    libjbig85.so.2.0
    libjbig.so.2.0
    libjpeg.so.62
    libjpeg.so.62.1.0
    libjson-c.so.2
    libjson-c.so.2.0.1
    libjson.so.0
    libjson.so.0.1.0
    libk5crypto.so.3
    libk5crypto.so.3.1
    libkadm5clnt_mit.so.8
    libkadm5clnt_mit.so.8.0
    libkadm5srv_mit.so.8
    libkadm5srv_mit.so.8.0
    libkdb5.so.7
    libkdb5.so.7.0
    libkeyutils.so.1
    libkeyutils.so.1.5
    libkms.so.1
    libkms.so.1.0.0
    libkrad.so.0
    libkrad.so.0.0
    libkrb5.so.3
    libkrb5.so.3.3
    libkrb5support.so.0
    libkrb5support.so.0.1
    liblcms2.so.2
    liblcms2.so.2.0.5
    libltdl.so.7
    libltdl.so.7.3.0
    liblzma.so.5
    liblzma.so.5.0.99
    libm-2.18.so
    libmemusage.so
    libmenu.so.5
    libmenu.so.5.9
    libmenuw.so.5
    libmenuw.so.5.9
    libmozjs-17.0.so
    libm.so.6
    libncurses.so.5
    libncurses++.so.5
    libncurses.so.5.9
    libncurses++.so.5.9
    libncurses++w.so.5
    libncursesw.so.5
    libncurses++w.so.5.9
    libncursesw.so.5.9
    libnsl-2.18.so
    libnsl.so.1
    libnspr4.so
    libnss_compat-2.18.so
    libnss_compat.so.2
    libnss_db-2.18.so
    libnss_db.so.2
    libnss_dns-2.18.so
    libnss_dns.so.2
    libnss_files-2.18.so
    libnss_files.so.2
    libnss_hesiod-2.18.so
    libnss_hesiod.so.2
    libnss_myhostname.so.2
    libnss_nis-2.18.so
    libnss_nisplus-2.18.so
    libnss_nisplus.so.2
    libnss_nis.so.2
    libnvcuvid.so
    libnvcuvid.so.1
    libnvcuvid.so.331.49
    libnvidia-compiler.so.331.49
    libnvidia-eglcore.so.331.49
    libnvidia-encode.so
    libnvidia-encode.so.1
    libnvidia-encode.so.331.49
    libnvidia-glcore.so.331.49
    libnvidia-glsi.so.331.49
    libnvidia-ifr.so
    libnvidia-ifr.so.1
    libnvidia-ifr.so.331.49
    libnvidia-ml.so
    libnvidia-ml.so.1
    libnvidia-ml.so.331.49
    libnvidia-opencl.so.1
    libnvidia-opencl.so.331.49
    libnvidia-tls.so.331.49
    libogg.so.0
    libogg.so.0.8.0
    libOpenCL.so
    libOpenCL.so.1
    libOpenCL.so.1.0
    libOpenCL.so.1.0.0
    libORBit-2.so.0
    libORBit-2.so.0.1.0
    libORBitCosNaming-2.so.0
    libORBitCosNaming-2.so.0.1.0
    libORBit-imodule-2.so.0
    libORBit-imodule-2.so.0.0.0
    libpamc.so.0
    libpamc.so.0.82.1
    libpam_misc.so.0
    libpam_misc.so.0.82.0
    libpam.so.0
    libpam.so.0.83.1
    libpanel.so.5
    libpanel.so.5.9
    libpanelw.so.5
    libpanelw.so.5.9
    libpango-1.0.so.0
    libpango-1.0.so.0.3600.1
    libpangocairo-1.0.so.0
    libpangocairo-1.0.so.0.3600.1
    libpangoft2-1.0.so.0
    libpangoft2-1.0.so.0.3600.1
    libpangoxft-1.0.so.0
    libpangoxft-1.0.so.0.3600.1
    libpciaccess.so.0
    libpciaccess.so.0.11.1
    libpcprofile.so
    libpcre16.so.0
    libpcre16.so.0.2.1
    libpcre32.so.0
    libpcre32.so.0.0.1
    libpcrecpp.so.0
    libpcrecpp.so.0.0.0
    libpcreposix.so.0
    libpcreposix.so.0.0.2
    libpcre.so.1
    libpcre.so.1.2.1
    libpixman-1.so.0
    libpixman-1.so.0.30.0
    libplc4.so
    libplds4.so
    libpng12.so.0
    libpng12.so.0.50.0
    libpng16.so.16
    libpng16.so.16.3.0
    libpolkit-agent-1.so.0
    libpolkit-agent-1.so.0.0.0
    libpolkit-gobject-1.so.0
    libpolkit-gobject-1.so.0.0.0
    libpthread-2.18.so
    libpthread.so.0
    libpulse-simple.so.0
    libpulse-simple.so.0.0.4
    libpulse.so.0
    libpulse.so.0.16.2
    libresolv-2.18.so
    libresolv.so.2
    librt-2.18.so
    librt.so.1
    libSegFault.so
    libselinux.so.1
    libSM.so.6
    libSM.so.6.0.1
    libsndfile.so.1
    libsndfile.so.1.0.25
    libssl.so.10
    libssl.so.1.0.1e
    libstdc++.so.6
    libstdc++.so.6.0.19
    libsystemd-daemon.so.0
    libsystemd-daemon.so.0.0.10
    libsystemd-id128.so.0
    libsystemd-id128.so.0.0.26
    libsystemd-journal.so.0
    libsystemd-journal.so.0.11.3
    libsystemd-login.so.0
    libsystemd-login.so.0.9.1
    libtdb.so.1
    libtdb.so.1.2.12
    libthai.so.0
    libthai.so.0.2.0
    libthread_db-1.0.so
    libthread_db.so.1
    libtic.so.5
    libtic.so.5.9
    libtiff.so.5
    libtiff.so.5.2.0
    libtiffxx.so.5
    libtiffxx.so.5.2.0
    libtinfo.so.5
    libtinfo.so.5.9
    libudev.so.1
    libudev.so.1.4.0
    libusb-0.1.so.4
    libusb-0.1.so.4.4.4
    libusb-1.0.so.0
    libusb-1.0.so.0.1.0
    libutil-2.18.so
    libutil.so.1
    libuuid.so.1
    libuuid.so.1.3.0
    libvdpau_nvidia.so
    libverto.so.1
    libverto.so.1.0.0
    libvorbisenc.so.2
    libvorbisenc.so.2.0.10
    libvorbisfile.so.3
    libvorbisfile.so.3.3.6
    libvorbis.so.0
    libvorbis.so.0.4.7
    libwayland-client.so.0
    libwayland-client.so.0.1.0
    libwayland-cursor.so.0
    libwayland-cursor.so.0.0.0
    libwayland-server.so.0
    libwayland-server.so.0.1.0
    libwrap.so.0
    libwrap.so.0.7.6
    libX11.so.6
    libX11.so.6.3.0
    libX11-xcb.so.1
    libX11-xcb.so.1.0.0
    libXau.so.6
    libXau.so.6.0.0
    libxcb-composite.so.0
    libxcb-composite.so.0.0.0
    libxcb-damage.so.0
    libxcb-damage.so.0.0.0
    libxcb-dpms.so.0
    libxcb-dpms.so.0.0.0
    libxcb-dri2.so.0
    libxcb-dri2.so.0.0.0
    libxcb-glx.so.0
    libxcb-glx.so.0.0.0
    libxcb-randr.so.0
    libxcb-randr.so.0.1.0
    libxcb-record.so.0
    libxcb-record.so.0.0.0
    libxcb-render.so.0
    libxcb-render.so.0.0.0
    libxcb-res.so.0
    libxcb-res.so.0.0.0
    libxcb-screensaver.so.0
    libxcb-screensaver.so.0.0.0
    libxcb-shape.so.0
    libxcb-shape.so.0.0.0
    libxcb-shm.so.0
    libxcb-shm.so.0.0.0
    libxcb.so.1
    libxcb.so.1.1.0
    libxcb-sync.so.0
    libxcb-sync.so.0.0.0
    libxcb-xevie.so.0
    libxcb-xevie.so.0.0.0
    libxcb-xf86dri.so.0
    libxcb-xf86dri.so.0.0.0
    libxcb-xfixes.so.0
    libxcb-xfixes.so.0.0.0
    libxcb-xinerama.so.0
    libxcb-xinerama.so.0.0.0
    libxcb-xkb.so.0
    libxcb-xkb.so.0.0.0
    libxcb-xselinux.so.0
    libxcb-xselinux.so.0.0.0
    libxcb-xtest.so.0
    libxcb-xtest.so.0.0.0
    libxcb-xvmc.so.0
    libxcb-xvmc.so.0.0.0
    libxcb-xv.so.0
    libxcb-xv.so.0.0.0
    libXcomposite.so.1
    libXcomposite.so.1.0.0
    libXcursor.so.1
    libXcursor.so.1.0.2
    libXdamage.so.1
    libXdamage.so.1.1.0
    libXevie.so.1
    libXevie.so.1.0.0
    libXext.so.6
    libXext.so.6.4.0
    libXfixes.so.3
    libXfixes.so.3.1.0
    libXft.so.2
    libXft.so.2.3.1
    libXinerama.so.1
    libXinerama.so.1.0.0
    libXi.so.6
    libXi.so.6.1.0
    libxkbcommon.so.0
    libxkbcommon.so.0.0.0
    libxml2.so.2
    libxml2.so.2.9.1
    libXrandr.so.2
    libXrandr.so.2.2.0
    libXrender.so.1
    libXrender.so.1.3.0
    libXt.so.6
    libXt.so.6.0.0
    libXtst.so.6
    libXtst.so.6.1.0
    libXxf86vm.so.1
    libXxf86vm.so.1.0.0
    libz.so.1
    libz.so.1.2.8
    locale
    lsb
    modprobe.d
    modules
    modules-load.d
    mozilla
    openssl
    orbit-2.0
    pango
    polkit-1
    pulseaudio
    python2.7
    python3.3
    rpm
    rtkaio
    security
    sse2
    sysctl.d
    systemd
    tmpfiles.d
    udev
    udisks2
    vdpau
    yum-plugins
    Content of /lib64 :
    alsa-lib
    ao
    audit
    avahi
    bluetooth
    brltty
    cifs-utils
    colord-plugins
    colord-sensors
    cracklib_dict.hwm
    cracklib_dict.pwd
    cracklib_dict.pwi
    crt1.o
    crti.o
    crtn.o
    dbus-1
    device-mapper
    dri
    ebtables
    elfutils
    empathy
    enchant
    evince
    evolution
    evolution-data-server
    farstream-0.1
    farstream-0.2
    festival
    fipscheck
    firefox
    folks
    freerdp
    frei0r-1
    games
    gawk
    GConf
    gconv
    gcrt1.o
    gdk-pixbuf-2.0
    gedit
    gettext
    ghostscript
    gio
    girepository-1.0
    gjs
    glade
    gnome-bluetooth
    gnome-documents
    gnome-keyring
    gnome-online-miners
    gnome-shell
    grilo-0.2
    gs-plugins
    gstreamer-0.10
    gstreamer-1.0
    gtk-2.0
    gtk-3.0
    gupnp-dlna
    gutenprint
    ibus-hangul
    iscsi
    krb5
    ld-2.18.so
    ldb
    ld-lsb-x86-64.so.3
    libabrt_dbus.so.0
    libabrt_dbus.so.0.0.1
    libabrt_gui.so.0
    libabrt_gui.so.0.0.1
    libabrt-java-connector.so
    libabrt.so.0
    libabrt.so.0.0.1
    libabw-0.0.so.0
    libabw-0.0.so.0.0.2
    libaccountsservice.so.0
    libaccountsservice.so.0.0.0
    libacl.so.1
    libacl.so.1.1.0
    libaio.so.1
    libaio.so.1.0.0
    libaio.so.1.0.1
    libAnacondaWidgets.so.1
    libAnacondaWidgets.so.1.0.0
    libanl-2.18.so
    libanl.so
    libanl.so.1
    libao.so.4
    libao.so.4.0.0
    libapol.so.4
    libapol.so.4.3
    libarchive.so.13
    libarchive.so.13.1.2
    libargyllicc.so.0
    libargyllicc.so.0.0.0
    libargyll.so.0
    libargyll.so.0.0.0
    libasm-0.158.so
    libasm.so.1
    libasound.so.2
    libasound.so.2.0.0
    libasprintf.so.0
    libasprintf.so.0.0.0
    libassuan.so.0
    libassuan.so.0.4.0
    libasyncns.so.0
    libasyncns.so.0.3.1
    libatasmart.so.4
    libatasmart.so.4.0.5
    libatk-1.0.so.0
    libatkmm-1.6.so.1
    libatkmm-1.6.so.1.1.0
    libatm.so.1
    libatm.so.1.0.0
    libatspi.so.0
    libatspi.so.0.0.1
    libattr.so.1
    libattr.so.1.1.0
    libaudit.so.1
    libaudit.so.1.0.0
    libaugeas.so.0
    libaugeas.so.0.18.0
    libauparse.so.0
    libauparse.so.0.0.0
    libavahi-core.so.7
    libavahi-core.so.7.0.2
    libavahi-glib.so.1
    libavahi-gobject.so.0
    libavahi-gobject.so.0.0.4
    libavahi-ui-gtk3.so.0
    libavahi-ui-gtk3.so.0.1.4
    libavc1394.so.0
    libavc1394.so.0.3.0
    libbasicobjects.so.0
    libbasicobjects.so.0.0.0
    libbfd-2.23.2.so
    libbind9.so.90
    libbind9.so.90.0.8
    libblkid.so.1
    libblkid.so.1.1.0
    libbluray.so.1
    libbluray.so.1.5.0
    libboost_date_time.so.1.54.0
    libboost_system.so.1.54.0
    libbrasero-burn3.so.1
    libbrasero-burn3.so.1.2.4
    libbrasero-media3.so.1
    libbrasero-media3.so.1.2.4
    libbrasero-utils3.so.1
    libbrasero-utils3.so.1.2.4
    libbrlapi.so.0.6
    libbrlapi.so.0.6.0
    libBrokenLocale.so
    libbsd.a
    libbsd-compat.a
    libbsd.so.0
    libbsd.so.0.6.0
    libbtrfs.so.0
    libbtrfs.so.0.1
    libbz2.so.1
    libbz2.so.1.0.6
    libc-2.18.so
    libcacard.so.0
    libcacard.so.0.0.0
    libcairomm-1.0.so.1
    libcairomm-1.0.so.1.4.0
    libcairo.so.2
    libcamel-1.2.so.45
    libcamel-1.2.so.45.0.0
    libcanberra-0.30
    libcanberra.so.0
    libcap-ng.so.0
    libcap-ng.so.0.0.0
    libcap.so.2
    libcap.so.2.22
    libcares.so.2
    libcares.so.2.1.0
    libcaribou.so.0
    libcaribou.so.0.0.0
    libcdda_interface.so.0
    libcdda_interface.so.0.10.2
    libcdda_paranoia.so.0
    libcdda_paranoia.so.0.10.2
    libcdio_cdda.so.1
    libcdio_cdda.so.1.0.0
    libcdio_paranoia.so.1
    libcdio_paranoia.so.1.0.0
    libcdio++.so.0
    libcdio++.so.0.0.2
    libcdio.so.14
    libcdio.so.14.0.0
    libcdr-0.0.so.0
    libcdr-0.0.so.0.0.14
    libcelt051.so.0
    libcelt051.so.0.0.0
    libcgroup.so.1
    libcgroup.so.1.0.38
    libchamplain-0.12.so.0
    libchamplain-0.12.so.0.3.2
    libchamplain-gtk-0.12.so.0
    libchamplain-gtk-0.12.so.0.3.2
    libcheese-gtk.so.23
    libcheese-gtk.so.23.0.17
    libcheese.so.7
    libcheese.so.7.0.17
    libchewing
    libchewing.so.3
    libchewing.so.3.1.0
    libchromeXvMCPro.so.1
    libchromeXvMCPro.so.1.0.0
    libchromeXvMC.so.1
    libchromeXvMC.so.1.0.0
    libcidn-2.18.so
    libcidn.so
    libcidn.so.1
    libclucene-contribs-lib.so.1
    libclucene-contribs-lib.so.2.3.3.4
    libclucene-core.so.1
    libclucene-core.so.2.3.3.4
    libclucene-shared.so.1
    libclucene-shared.so.2.3.3.4
    libclutter-1.0.so.0
    libclutter-1.0.so.0.1600.2
    libclutter-glx-1.0.so.0
    libclutter-gst-2.0.so.0
    libclutter-gst-2.0.so.0.10.0
    libclutter-gtk-1.0.so.0
    libclutter-gtk-1.0.so.0.0.0
    libcmis-0.4.so.4
    libcmis-0.4.so.4.0.1
    libcmis-c-0.4.so.4
    libcmis-c-0.4.so.4.0.1
    libc_nonshared.a
    libcogl-pango.so.15
    libcogl-pango.so.15.3.0
    libcogl.so.15
    libcogl.so.15.3.0
    libcollection.so.2
    libcollection.so.2.1.0
    libcolord-gtk.so.1
    libcolord-gtk.so.1.0.2
    libcolord.so.2
    libcolord.so.2.0.1
    libcolorhug.so.2
    libcom_err.so.2
    libcom_err.so.2.1
    libcomps.so.0.1.4
    libconfig.so.9
    libconfig++.so.9
    libconfig.so.9.1.3
    libconfig++.so.9.1.3
    libcrack.so.2
    libcrack.so.2.9.0
    libcroco-0.6.so.3
    libcroco-0.6.so.3.0.1
    libcrypt-2.18.so
    libcrypto.so.10
    libcrypto.so.1.0.1e
    libcryptsetup.so.4
    libcryptsetup.so.4.5.0
    libcrypt.so
    libcrypt.so.1
    libc.so
    libc.so.6
    libcuda.so
    libcuda.so.1
    libcuda.so.331.49
    libcue.so.1
    libcue.so.1.0.4
    libcupscgi.so.1
    libcupsfilters.so.1
    libcupsfilters.so.1.0.0
    libcupsimage.so.2
    libcupsmime.so.1
    libcupsppdc.so.1
    libcups.so.2
    libcurl.so.4
    libcurl.so.4.3.0
    libdaemon.so.0
    libdaemon.so.0.5.0
    libdb-5.3.so
    libdb-5.so
    libdb.so
    libdbus-1.so.3
    libdbus-1.so.3.7.4
    libdbus-glib-1.so.2
    libdcerpc-atsvc.so.0
    libdcerpc-atsvc.so.0.0.1
    libdcerpc-binding.so.0
    libdcerpc-binding.so.0.0.1
    libdcerpc-samr.so.0
    libdcerpc-samr.so.0.0.1
    libdcerpc.so.0
    libdcerpc.so.0.0.1
    libdconf-dbus-1.so.0
    libdconf-dbus-1.so.0.0.0
    libdconf.so.1
    libdconf.so.1.0.0
    libdevmapper-event-lvm2mirror.so
    libdevmapper-event-lvm2raid.so
    libdevmapper-event-lvm2snapshot.so
    libdevmapper-event-lvm2.so.2.02
    libdevmapper-event-lvm2thin.so
    libdevmapper-event.so.1.02
    libdevmapper.so.1.02
    libdhash.so.1
    libdhash.so.1.0.1
    libdhcpctl.so.0
    libdhcpctl.so.0.0.0
    libdl-2.18.so
    libdl.so
    libdl.so.2
    libdmapsharing-3.0.so.2
    libdmapsharing-3.0.so.2.9.24
    libdmraid-events-isw.so
    libdmraid-events-isw.so.1
    libdmraid-events-isw.so.1.0.0.rc16
    libdmraid.so
    libdmraid.so.1
    libdmraid.so.1.0.0.rc16
    libdmx.so.1
    libdmx.so.1.0.0
    libdnet.so.1
    libdnet.so.1.0.1
    libdns-export.so.100
    libdns-export.so.100.1.1
    libdns.so.100
    libdns.so.100.1.1
    libdotconf.so.0
    libdotconf.so.0.0.1
    libdrm_intel.so.1
    libdrm_nouveau.so.2
    libdrm_radeon.so.1
    libdrm.so.2
    libdrm.so.2.4.0
    libdvdnavmini.so.4
    libdvdnavmini.so.4.2.1
    libdvdnav.so.4
    libdvdnav.so.4.2.1
    libdvdread.so.4
    libdvdread.so.4.2.1
    libdv.so.4
    libdv.so.4.0.3
    libdw-0.158.so
    libdw.so.1
    libe2p.so.2
    libe2p.so.2.3
    libebackend-1.2.so.7
    libebackend-1.2.so.7.0.0
    libe-book-0.0.so.0
    libe-book-0.0.so.0.0.3
    libebook-1.2.so.14
    libebook-1.2.so.14.3.1
    libebook-contacts-1.2.so.0
    libebook-contacts-1.2.so.0.0.0
    libebtc.so
    libecal-1.2.so.16
    libecal-1.2.so.16.0.0
    libedata-book-1.2.so.20
    libedata-book-1.2.so.20.0.0
    libedata-cal-1.2.so.23
    libedata-cal-1.2.so.23.0.0
    libedataserver-1.2.so.18
    libedataserver-1.2.so.18.0.0
    libedit.so.0
    libedit.so.0.0.43
    libEGL.so.1
    libEGL.so.1.0.0
    libelf-0.158.so
    libelf.so.1
    libenca.so.0
    libenca.so.0.5.1
    libenchant.so.1
    libenchant.so.1.6.0
    libeot.so.0
    libeot.so.0.0.0
    libespeak.so.1
    libespeak.so.1.1.47
    libestbase.so.1.2.96.1
    libestools.so.1.2.96.1
    libeststring.so.1.2
    libetonyek-0.0.so.0
    libetonyek-0.0.so.0.0.3
    libevdev.so.1
    libevdev.so.1.0.0
    libevdocument3.so.4
    libevdocument3.so.4.0.0
    libevent-2.0.so.5
    libevent-2.0.so.5.1.9
    libevent_core-2.0.so.5
    libevent_core-2.0.so.5.1.9
    libevent_extra-2.0.so.5
    libevent_extra-2.0.so.5.1.9
    libevent_openssl-2.0.so.5
    libevent_openssl-2.0.so.5.1.9
    libevent_pthreads-2.0.so.5
    libevent_pthreads-2.0.so.5.1.9
    libevview3.so.3
    libevview3.so.3.0.0
    libexempi.so.3
    libexempi.so.3.2.3
    libexif.so.12
    libexif.so.12.3.3
    libexiv2.so.12
    libexiv2.so.12.0.0
    libexpat.so.1
    libexpat.so.1.6.0
    libexslt.so.0
    libexslt.so.0.8.17
    libext2fs.so.2
    libext2fs.so.2.4
    libexttextcat-2.0.so.0
    libexttextcat-2.0.so.0.0.0
    libfarstream-0.1.so.0
    libfarstream-0.1.so.0.0.1
    libfarstream-0.2.so.2
    libfarstream-0.2.so.2.1.0
    libfa.so.1
    libfa.so.1.4.0
    libfbembed.so.2.5
    libfbembed.so.2.5.2
    libFestival.so.1.96.0
    libffi.so.6
    libffi.so.6.0.1
    libfftw3_omp.so.3
    libfftw3_omp.so.3.3.2
    libfftw3.so.3
    libfftw3.so.3.3.2
    libfftw3_threads.so.3
    libfftw3_threads.so.3.3.2
    libfipscheck.so.1
    libfipscheck.so.1.2.1
    libFLAC++.so.6
    libFLAC++.so.6.3.0
    libFLAC.so.8
    libFLAC.so.8.3.0
    libflite_cmulex.so.1
    libflite_cmulex.so.1.3
    libflite_cmu_time_awb.so.1
    libflite_cmu_time_awb.so.1.3
    libflite_cmu_us_kal16.so.1
    libflite_cmu_us_kal16.so.1.3
    libflite_cmu_us_kal.so.1
    libflite_cmu_us_kal.so.1.3
    libflite.so.1
    libflite.so.1.3
    libflite_usenglish.so.1
    libflite_usenglish.so.1.3
    libfolks-eds.so.25
    libfolks-eds.so.25.16.1
    libfolks.so.25
    libfolks.so.25.16.1
    libfolks-telepathy.so.25
    libfolks-telepathy.so.25.16.1
    libfontconfig.so.1
    libfontembed.so.1
    libfontembed.so.1.0.0
    libfontenc.so.1
    libfontenc.so.1.0.0
    libform.so.5
    libform.so.5.9
    libformw.so.5
    libformw.so.5.9
    libfprint.so.0
    libfprint.so.0.0.0
    libfreebl3.chk
    libfreebl3.so
    libfreehand-0.0.so.0
    libfreehand-0.0.so.0.0.0
    libfreerdp-cache.so.1.0
    libfreerdp-cache.so.1.0.2
    libfreerdp-channels.so.1.0
    libfreerdp-channels.so.1.0.2
    libfreerdp-codec.so.1.0
    libfreerdp-codec.so.1.0.2
    libfreerdp-core.so.1.0
    libfreerdp-core.so.1.0.2
    libfreerdp-gdi.so.1.0
    libfreerdp-gdi.so.1.0.2
    libfreerdp-kbd.so.1.0
    libfreerdp-kbd.so.1.0.2
    libfreerdp-rail.so.1.0
    libfreerdp-rail.so.1.0.2
    libfreerdp-utils.so.1.0
    libfreerdp-utils.so.1.0.2
    libfreetype.so.6
    libfuse.so.2
    libfuse.so.2.9.3
    libg.a
    libgadu.so.3
    libgadu.so.3.13.0
    libgailutil-3.so.0
    libgailutil.so.18
    libgavl.so.1
    libgavl.so.1.0.0
    libgbm.so.1
    libgbm.so.1.0.0
    libgcc_s.so.1
    libgck-1.so.0
    libgck-1.so.0.0.0
    libgconf-2.so.4
    libgconf-2.so.4.1.5
    libgcr-3.so.1
    libgcr-3.so.1.0.0
    libgcr-base-3.so.1
    libgcr-base-3.so.1.0.0
    libgcr-ui-3.so.1
    libgcr-ui-3.so.1.0.0
    libgcrypt.so.11
    libgcrypt.so.11.8.2
    libgdata.so.13
    libgdata.so.13.5.3
    libgdbm_compat.so
    libgdbm_compat.so.4
    libgdbm_compat.so.4.0.0
    libgdbm.so
    libgdbm.so.4
    libgdbm.so.4.0.0
    libgdither.so.1
    libgdither.so.1.0
    libgdk-3.so.0
    libgdkmm-2.4.so.1
    libgdkmm-2.4.so.1.1.0
    libgdkmm-3.0.so.1
    libgdkmm-3.0.so.1.1.0
    libgdk-x11-2.0.so.0
    libgdm.so
    libgdm.so.1
    libgdm.so.1.0.0
    libgd.so.3
    libgd.so.3.0.0
    libgee-0.8.so.2
    libgee-0.8.so.2.3.0
    libgee.so.2
    libgee.so.2.0.0
    libgensec.so.0
    libgensec.so.0.0.1
    libgeoclue.so.0
    libgeoclue.so.0.0.0
    libgeocode-glib.so.0
    libgeocode-glib.so.0.0.0
    libgettextlib-0.18.3.so
    libgettextpo.so.0
    libgettextpo.so.0.5.2
    libgettextsrc-0.18.3.so
    libgexiv2.so.2
    libgexiv2.so.2.0.0
    libgif.so.4
    libgif.so.4.1.6
    libgio-2.0.so.0
    libgiomm-2.4.so.1
    libgiomm-2.4.so.1.3.0
    libgirepository-1.0.so.1
    libgirepository-1.0.so.1.0.0
    libgjs.so.0
    libgjs.so.0.0.0
    libglade
    libglade-2.0.so.0
    libglade-2.0.so.0.0.7
    libgladeui-2.so.6
    libgladeui-2.so.6.0.3
    libglamor.so.0
    libglamor.so.0.0.0
    libglapi.so.0
    libglapi.so.0.0.0
    libglib-2.0.so.0
    libglibmm-2.4.so.1
    libglibmm-2.4.so.1.3.0
    libglibmm_generate_extra_defs-2.4.so.1
    libglibmm_generate_extra_defs-2.4.so.1.3.0
    libGL.la
    libGL.so
    libGL.so.1
    libGL.so.331.49
    libGLU.so.1
    libGLU.so.1.3.1
    libgmime-2.6.so.0
    libgmime-2.6.so.0.619.0
    libgmodule-2.0.so.0
    libgmp.so.10
    libgmp.so.10.1.2
    libgmpxx.so.4
    libgmpxx.so.4.3.2
    libgnome-bluetooth.so.12
    libgnome-bluetooth.so.12.0.0
    libgnome-desktop-3.so.8
    libgnome-desktop-3.so.8.0.0
    libgnomekbd.so.8
    libgnomekbd.so.8.0.0
    libgnomekbdui.so.8
    libgnomekbdui.so.8.0.0
    libgnome-keyring.so.0
    libgnome-keyring.so.0.2.0
    libgnome-menu-3.so.0
    libgnome-menu-3.so.0.0.1
    libgnutls.so.28
    libgnutls.so.28.21.0
    libgnutls-xssl.so.0
    libgnutls-xssl.so.0.0.0
    libgoa-1.0.so.0
    libgoa-1.0.so.0.0.0
    libgoa-backend-1.0.so.1
    libgoa-backend-1.0.so.1.0.0
    libgobject-2.0.so.0
    libgomp.so.1
    libgomp.so.1.0.0
    libgpg-error.so.0
    libgpgme-pthread.so.11
    libgpgme-pthread.so.11.8.1
    libgpgme.so.11
    libgpgme.so.11.8.1
    libgphoto2
    libgphoto2_port
    libgphoto2_port.so.10
    libgphoto2_port.so.10.1.1
    libgphoto2.so.6
    libgphoto2.so.6.0.0
    libgpod
    libgpod.so.4
    libgpod.so.4.3.2
    libgraphite2.so.3
    libgrilo-0.2.so.1
    libgrilo-0.2.so.1.5.1
    libgrlnet-0.2.so.0
    libgrlnet-0.2.so.0.1.6
    libgrlpls-0.2.so.0
    libgrlpls-0.2.so.0.0.1
    libgsf-1.so.114
    libgsf-1.so.114.0.29
    libgsm.so.1
    libgsm.so.1.0.12
    libgssapi_krb5.so.2
    libgssdp-1.0.so.3
    libgssdp-1.0.so.3.0.0
    libgs.so.9
    libgs.so.9.10
    libgssrpc.so.4
    libgssrpc.so.4.1
    libgstallocators-1.0.so.0
    libgstallocators-1.0.so.0.203.0
    libgstapp-0.10.so.0
    libgstapp-0.10.so.0.25.0
    libgstapp-1.0.so.0
    libgstapp-1.0.so.0.203.0
    libgstaudio-0.10.so.0
    libgstaudio-0.10.so.0.25.0
    libgstaudio-1.0.so.0
    libgstaudio-1.0.so.0.203.0
    libgstbase-0.10.so.0
    libgstbase-0.10.so.0.30.0
    libgstbase-1.0.so.0
    libgstbasecamerabinsrc-0.10.so.23
    libgstbasecamerabinsrc-0.10.so.23.0.0
    libgstbasecamerabinsrc-1.0.so.0
    libgstbasecamerabinsrc-1.0.so.0.203.0
    libgstbasevideo-0.10.so.23
    libgstbasevideo-0.10.so.23.0.0
    libgstcdda-0.10.so.0
    libgstcdda-0.10.so.0.25.0
    libgstcodecparsers-0.10.so.23
    libgstcodecparsers-0.10.so.23.0.0
    libgstcodecparsers-1.0.so.0
    libgstcodecparsers-1.0.so.0.203.0
    libgstcontroller-0.10.so.0
    libgstcontroller-0.10.so.0.30.0
    libgstdataprotocol-0.10.so.0
    libgstdataprotocol-0.10.so.0.30.0
    libgstegl-1.0.so.0
    libgstegl-1.0.so.0.203.0
    libgstfft-0.10.so.0
    libgstfft-0.10.so.0.25.0
    libgstfft-1.0.so.0
    libgstfft-1.0.so.0.203.0
    libgstinsertbin-1.0.so.0
    libgstinsertbin-1.0.so.0.203.0
    libgstinterfaces-0.10.so.0
    libgstinterfaces-0.10.so.0.25.0
    libgstmpegts-1.0.so.0
    libgstmpegts-1.0.so.0.203.0
    libgstnet-0.10.so.0
    libgstnet-0.10.so.0.30.0
    libgstnet-1.0.so.0
    libgstnetbuffer-0.10.so.0
    libgstnetbuffer-0.10.so.0.25.0
    libgstpbutils-0.10.so.0
    libgstpbutils-0.10.so.0.25.0
    libgstpbutils-1.0.so.0
    libgstpbutils-1.0.so.0.203.0
    libgstphotography-0.10.so.23
    libgstphotography-0.10.so.23.0.0
    libgstphotography-1.0.so.0
    libgstphotography-1.0.so.0.203.0
    libgstreamer-0.10.so.0
    libgstreamer-0.10.so.0.30.0
    libgstriff-0.10.so.0
    libgstriff-0.10.so.0.25.0
    libgstriff-1.0.so.0
    libgstriff-1.0.so.0.203.0
    libgstrtp-0.10.so.0
    libgstrtp-0.10.so.0.25.0
    libgstrtp-1.0.so.0
    libgstrtp-1.0.so.0.203.0
    libgstrtsp-0.10.so.0
    libgstrtsp-0.10.so.0.25.0
    libgstrtsp-1.0.so.0
    libgstrtsp-1.0.so.0.203.0
    libgstsdp-0.10.so.0
    libgstsdp-0.10.so.0.25.0
    libgstsdp-1.0.so.0
    libgstsdp-1.0.so.0.203.0
    libgstsignalprocessor-0.10.so.23
    libgstsignalprocessor-0.10.so.23.0.0
    libgsttag-0.10.so.0
    libgsttag-0.10.so.0.25.0
    libgsttag-1.0.so.0
    libgsttag-1.0.so.0.203.0
    libgsturidownloader-1.0.so.0
    libgsturidownloader-1.0.so.0.203.0
    libgstvdp-0.10.so.23
    libgstvdp-0.10.so.23.0.0
    libgstvideo-0.10.so.0
    libgstvideo-0.10.so.0.25.0
    libgstvideo-1.0.so.0
    libgstvideo-1.0.so.0.203.0
    libgthread-2.0.so.0
    libgtk-3.so.0
    libgtkhtml-4.0.so.0
    libgtkhtml-4.0.so.0.0.0
    libgtkhtml-editor-4.0.so.0
    libgtkhtml-editor-4.0.so.0.0.0
    libgtkmm-2.4.so.1
    libgtkmm-2.4.so.1.1.0
    libgtkmm-3.0.so.1
    libgtkmm-3.0.so.1.1.0
    libgtksourceview-3.0.so.1
    libgtksourceview-3.0.so.1.1.0
    libgtk-vnc-2.0.so.0
    libgtk-vnc-2.0.so.0.0.2
    libgtk-x11-2.0.so.0
    libgtop-2.0.so.7
    libgtop-2.0.so.7.2.0
    libgucharmap_2_90.so.7
    libgucharmap_2_90.so.7.0.0
    libgudev-1.0.so.0
    libguestlib.so.0
    libguestlib.so.0.0.0
    libgupnp-1.0.so.4
    libgupnp-1.0.so.4.0.0
    libgupnp-av-1.0.so.2
    libgupnp-av-1.0.so.2.0.0
    libgupnp-dlna-2.0.so.3
    libgupnp-dlna-2.0.so.3.0.0
    libgupnp-dlna-gst-2.0.so.3
    libgupnp-dlna-gst-2.0.so.3.0.0
    libgupnp-igd-1.0.so.4
    libgupnp-igd-1.0.so.4.1.1
    libgusb.so.2
    libgusb.so.2.0.3
    libgutenprint.so.2
    libgutenprint.so.2.1.0
    libgutenprintui2.so.1
    libgutenprintui2.so.1.0.0
    libgvfscommon.so.0
    libgvfscommon.so.0.0.0
    libgvnc-1.0.so.0
    libgvnc-1.0.so.0.0.1
    libgweather-3.so.6
    libgweather-3.so.6.0.1
    libgxps.so.2
    libgxps.so.2.1.1
    libhandle.so.1
    libhandle.so.1.0.3
    libhangul.so.1
    libhangul.so.1.0.0
    libharfbuzz-icu.so.0
    libharfbuzz-icu.so.0.926.0
    libharfbuzz.so.0
    libhawkey.so.0
    libHBAAPI.so.2
    libHBAAPI.so.2.0.2
    libhbalinux.so.2
    libhbalinux.so.2.0.2
    libhgfs.so.0
    libhgfs.so.0.0.0
    libhistory.so.6
    libhistory.so.6.2
    libhogweed.so.2
    libhogweed.so.2.5
    libhpip.so.0
    libhpip.so.0.0.1
    libhpmud.so
    libhpmud.so.0
    libhpmud.so.0.0.6
    libhunspell-1.3.so.0
    libhunspell-1.3.so.0.0.0
    libhyphen.so.0
    libhyphen.so.0.2.1
    libibus-1.0.so.5
    libibus-1.0.so.5.0.505
    libical.so.1
    libical.so.1.0.0
    libicalss.so.1
    libicalss.so.1.0.0
    libicalvcal.so.1
    libicalvcal.so.1.0.0
    libICE.so.6
    libICE.so.6.3.0
    libicudata.so.50
    libicudata.so.50.1.2
    libicui18n.so.50
    libicui18n.so.50.1.2
    libicuio.so.50
    libicuio.so.50.1.2
    libicule.so.50
    libicule.so.50.1.2
    libiculx.so.50
    libiculx.so.50.1.2
    libicutest.so.50
    libicutest.so.50.1.2
    libicutu.so.50
    libicutu.so.50.1.2
    libicuuc.so.50
    libicuuc.so.50.1.2
    libidn.so.11
    libidn.so.11.6.11
    libiec61883.so.0
    libiec61883.so.0.1.1
    libieee1284.so.3
    libieee1284.so.3.2.2
    libieee.a
    libijs-0.35.so
    libimobiledevice.so.4
    libimobiledevice.so.4.0.1
    libini_config.so.3
    libini_config.so.3.1.0
    libIntelXvMC.so.1
    libIntelXvMC.so.1.0.0
    libip4tc.so.0
    libip4tc.so.0.1.0
    libip6tc.so.0
    libip6tc.so.0.1.0
    libipa_hbac.so.0
    libipa_hbac.so.0.0.1
    libiptcdata.so.0
    libiptcdata.so.0.3.3
    libiptc.so.0
    libiptc.so.0.0.0
    libirs-export.so.90
    libirs-export.so.90.0.1
    libisccc.so.90
    libisccc.so.90.0.4
    libisccfg-export.so.90
    libisccfg-export.so.90.0.7
    libisccfg.so.90
    libisccfg.so.90.0.7
    libisc-export.so.95
    libisc-export.so.95.2.1
    libiscsi.so.0
    libisc.so.95
    libisc.so.95.2.1
    libiso9660++.so.0
    libiso9660++.so.0.0.0
    libiso9660.so.8
    libiso9660.so.8.0.0
    libiw.so.29
    libjansson.so.4
    libjansson.so.4.6.0
    libjasper.so.1
    libjasper.so.1.0.0
    libjavascriptcoregtk-3.0.so.0
    libjavascriptcoregtk-3.0.so.0.15.11
    libjbig85.so.2.0
    libjbig.so.2.0
    libjpeg.so.62
    libjpeg.so.62.1.0
    libjson-c.so.2
    libjson-c.so.2.0.1
    libjson-glib-1.0.so.0
    libjson-glib-1.0.so.0.1600.2
    libjson.so.0
    libjson.so.0.1.0
    libk5crypto.so.3
    libk5crypto.so.3.1
    libkdb5.so.7
    libkdb5.so.7.0
    libkeyutils.so.1
    libkeyutils.so.1.5
    libkkc
    libkkc.so.2
    libkkc.so.2.0.0
    libkmod.so.2
    libkmod.so.2.2.5
    libkms.so.1
    libkms.so.1.0.0
    libkrad.so.0
    libkrad.so.0.0
    libkrb5.so.3
    libkrb5.so.3.3
    libkrb5support.so.0
    liblangtag
    liblangtag.so.1
    liblangtag.so.1.2.0
    liblber-2.4.so.2
    liblber-2.4.so.2.10.2
    liblcms2.so.2
    liblcms2.so.2.0.5
    liblcms.so.1
    liblcms.so.1.0.19
    libldap-2.4.so.2
    libldap-2.4.so.2.10.2
    libldap_r-2.4.so.2
    libldap_r-2.4.so.2.10.2
    libldb.so.1
    libldb.so.1.1.16
    libldns.so.1
    libldns.so.1.6.16
    liblldp_clif.so.1
    liblldp_clif.so.1.0.0
    liblockdev.so.1
    liblockdev.so.1.0.0
    liblouis.so.2
    liblouis.so.2.3.3
    liblpsolve55.so
    libltdl.so.7
    libltdl.so.7.3.0
    liblua-5.2.so
    liblvm2app.so.2.2
    liblvm2cmd.so.2.02
    liblwres.so.90
    liblwres.so.90.0.5
    liblzma.so.5
    liblzma.so.5.0.99
    liblzo2.so.2
    liblzo2.so.2.0.0
    libm17n-core.so.0
    libm17n-core.so.0.4.0
    libm17n-flt.so.0
    libm17n-flt.so.0.4.0
    libm17n.so.0
    libm17n.so.0.4.0
    libm-2.18.so
    libmagic.so.1
    libmagic.so.1.0.0
    libmarisa.so.0
    libmarisa.so.0.0.0
    libmash-0.2.so.0
    libmash-0.2.so.0.0.0
    libmbim-glib.so.0
    libmbim-glib.so.0.2.0
    libmcheck.a
    libmcpp.so.0
    libmcpp.so.0.3.0
    libmeanwhile.so.1
    libmeanwhile.so.1.1.0
    libmemusage.so
    libmenu.so.5
    libmenu.so.5.9
    libmenuw.so.5
    libmenuw.so.5.9
    libmetalink.so.3
    libmetalink.so.3.0.0
    libmission-control-plugins.so.0
    libmission-control-plugins.so.0.5.1
    libmm-glib.so.0
    libmm-glib.so.0.0.0
    libmng.so.1
    libmng.so.1.0.0
    libmnl.so.0
    libmnl.so.0.1.0
    libmodman.so.1
    libmodman.so.1.0.0
    libmount.so.1
    libmount.so.1.1.0
    libmozjs-17.0.so
    libmpathpersist.so
    libmpathpersist.so.0
    libmpcdec.so.5
    libmpcdec.so.5.0.2
    libmpc.so.3
    libmpc.so.3.0.0
    libmpfr.so.4
    libmpfr.so.4.1.2
    libm.so
    libm.so.6
    libmspack.so.0
    libmspack.so.0.1.0
    libmspub-0.0.so.0
    libmspub-0.0.so.0.0.6
    libmtdev.so.1
    libmtdev.so.1.0.0
    libmtp.so.9
    libmtp.so.9.1.0
    libmultipath.so
    libmultipath.so.0
    libmusicbrainz5.so.0
    libmusicbrainz5.so.0.0.1
    libmutter.so.0
    libmutter.so.0.0.0
    libmutter-wayland.so.0
    libmutter-wayland.so.0.0.0
    libmwaw-0.2.so.2
    libmwaw-0.2.so.2.0.0
    libmx-1.0.so.2
    libmx-1.0.so.2.405.0
    libmx-gtk-1.0.so.0
    libmx-gtk-1.0.so.0.0.0
    libmythes-1.2.so.0
    libmythes-1.2.so.0.0.0
    libnautilus-extension.so.1
    libnautilus-extension.so.1.4.0
    libncurses.so.5
    libncurses++.so.5
    libncurses.so.5.9
    libncurses++.so.5.9
    libncurses++w.so.5
    libncursesw.so.5
    libncursesw.so.5.9
    libndp.so.0
    libndp.so.0.0.0
    libndr-krb5pac.so.0
    libndr-krb5pac.so.0.0.1
    libndr-nbt.so.0
    libndr-nbt.so.0.0.1
    libndr.so.0
    libndr.so.0.0.2
    libndr-standard.so.0
    libndr-standard.so.0.0.1
    libneon.so.27
    libneon.so.27.3.0
    libnetapi.so.0
    libnetfilter_conntrack.so.3
    libnetfilter_conntrack.so.3.5.0
    libnetsnmp.so.30
    libnetsnmp.so.30.0.2
    libnettle.so.4
    libnettle.so.4.7
    libnewt.so.0.52
    libnewt.so.0.52.16
    libnfnetlink.so.0
    libnfnetlink.so.0.2.0
    libnice.so.10
    libnice.so.10.2.0
    libnl
    libnl-3.so.200
    libnl-3.so.200.19.0
    libnl-cli-3.so.200
    libnl-cli-3.so.200.19.0
    libnl-genl-3.so.200
    libnl-genl-3.so.200.19.0
    libnl-idiag-3.so.200
    libnl-idiag-3.so.200.19.0
    libnl-nf-3.so.200
    libnl-nf-3.so.200.19.0
    libnl-route-3.so.200
    libnl-route-3.so.200.19.0
    libnl.so.1
    libnl.so.1.1.4
    libnm-glib.so.4
    libnm-glib.so.4.7.0
    libnm-glib-vpn.so.1
    libnm-glib-vpn.so.1.1.0
    libnm-gtk.so.0
    libnm-gtk.so.0.0.0
    libnm-util.so.2
    libnm-util.so.2.5.0
    libnotify.so.4
    libnotify.so.4.0.0
    libnsl-2.18.so
    libnsl.so
    libnsl.so.1
    libnspr4.so
    libnss3.so
    libnssckbi.so
    libnss_compat.so
    libnss_compat.so.2
    libnss_db-2.18.so
    libnssdbm3.chk
    libnssdbm3.so
    libnss_db.so
    libnss_db.so.2
    libnss_dns-2.18.so
    libnss_dns.so
    libnss_dns.so.2
    libnss_files.so
    libnss_files.so.2
    libnss_hesiod.so
    libnss_hesiod.so.2
    libnss_mdns4_minimal.so.2
    libnss_mdns4.so.2
    libnss_mdns6_minimal.so.2
    libnss_mdns6.so.2
    libnss_mdns_minimal.so.2
    libnss_mdns.so.2
    libnss_nis-2.18.so
    libnss_nisplus.so
    libnss_nisplus.so.2
    libnss_nis.so
    libnss_nis.so.2
    libnsspem.so
    libnss_sss.so.2
    libnsssysinit.so
    libnssutil3.so
    libntfs-3g.so.85
    libntfs-3g.so.85.0.0
    libnuma.so.1
    libnvcuvid.so
    libnvcuvid.so.1
    libnvidia-cfg.so
    libnvidia-cfg.so.1
    libnvidia-cfg.so.331.49
    libnvidia-encode.so
    libnvidia-fbc.so
    libnvidia-fbc.so.1
    libnvidia-fbc.so.331.49
    libnvidia-ifr.so
    libnvidia-ifr.so.1
    libnvidia-ml.so
    libnvidia-ml.so.1
    liboath.so.0
    liboath.so.0.1.3
    liboauth.so.0
    liboauth.so.0.8.5
    libodfgen-0.0.so.0
    libodfgen-0.0.so.0.0.4
    libofa.so.0
    libofa.so.0.0.0
    libogg.so.0
    libogg.so.0.8.0
    libomapi.so.0
    libomapi.so.0.0.0
    libopcodes-2.23.2.so
    libopencc.so.1
    libopencc.so.1.0.0
    libOpenCL.so
    libOpenCL.so.1
    libOpenCL.so.1.0
    libOpenCL.so.1.0.0
    libopenconnect.so.2
    libopenconnect.so.2.2.0
    libopenjpeg.so.1
    libopenjpeg.so.1.5.1
    libopus.so.0
    libopus.so.0.5.0
    liborc-0.4.so.0
    liborc-0.4.so.0.18.0
    liborc-test-0.4.so.0
    liborc-test-0.4.so.0.18.0
    liborcus-0.6.so.0
    liborcus-0.6.so.0.0.0
    liborcus-mso-0.6.so.0
    liborcus-mso-0.6.so.0.0.0
    liborcus-parser-0.6.so.0
    liborcus-parser-0.6.so.0.0.0
    libosinfo-1.0.so.0
    libosinfo-1.0.so.0.2.8
    libp11-kit.so.0
    libp11-kit.so.0.0.0
    libpackagekit-glib2.so.16
    libpackagekit-glib2.so.16.3.0
    libpakchois.so.0
    libpakchois.so.0.1.0
    libpamc.so.0
    libpamc.so.0.82.1
    libpam_misc.so.0
    libpam.so.0
    libpam.so.0.83.1
    libpanel.so.5
    libpanel.so.5.9
    libpanelw.so.5
    libpanelw.so.5.9
    libpango-1.0.so.0
    libpangomm-1.4.so.1
    libpangomm-1.4.so.1.0.30
    libpaps.so.0
    libpaps.so.0.0.0
    libparted-fs-resize.so
    libparted-fs-resize.so.0
    libparted-fs-resize.so.0.0.0
    libparted.so.2
    libparted.so.2.0.0
    libpasswdqc.so.0
    libpath_utils.so.1
    libpath_utils.so.1.0.0
    libpcap.so.1
    libpcap.so.1.5.3
    libpciaccess.so.0
    libpci.so.3
    libpci.so.3.2.1
    libpcprofile.so
    libpcre16.so.0
    libpcre16.so.0.2.1
    libpcre32.so.0
    libpcre32.so.0.0.1
    libpcrecpp.so.0
    libpcrecpp.so.0.0.0
    libpcreposix.so.0
    libpcre.so.1
    libpcre.so.1.2.1
    libpcsclite.so.1
    libpcsclite.so.1.0.0
    libpdb.so.0
    libpeas-1.0
    libpeas-1.0.so.0
    libpeas-1.0.so.0.900.0
    libpeas-gtk-1.0.so.0
    libpeas-gtk-1.0.so.0.900.0
    libperl.so
    libperl.so.5.18
    libperl.so.5.18.2
    libpinyin
    libpinyin.so.4
    libpinyin.so.4.0.0
    libpipeline.so.1
    libpipeline.so.1.2.4
    libpixman-1.so.0
    libpkcs11-helper.so.1
    libpkcs11-helper.so.1.0.0
    libplc4.so
    libplds4.so
    libplist.so.1
    libplist++.so.1
    libplist.so.1.1.10
    libplist++.so.1.1.10
    libply-boot-client.so.2
    libply-boot-client.so.2.1.0
    libply.so.2
    libply.so.2.1.0
    libply-splash-core.so.2
    libply-splash-core.so.2.1.0
    libply-splash-graphics.so.2
    libply-splash-graphics.so.2.1.0
    libpng12.so.0
    libpng12.so.0.50.0
    libpng16.so.16
    libpng16.so.16.3.0
    libpoldiff.so.1
    libpoldiff.so.1.3.2
    libpoppler-glib.so.8
    libpoppler-glib.so.8.6.0
    libpoppler.so.43
    libpoppler.so.43.0.0
    libpopt.so.0
    libpopt.so.0.0.0
    libprocps.so.1
    libprocps.so.1.1.2
    libprotobuf-c.so.0
    libprotobuf-c.so.0.0.0
    libprotobuf.so.8
    libprotobuf.so.8.0.0
    libprotoc.so.8
    libprotoc.so.8.0.0
    libproxy
    libproxy.so.1
    libproxy.so.1.0.0
    libpthread-2.18.so
    libpthread_nonshared.a
    libpthread.so
    libpthread.so.0
    libpth.so.20
    libpth.so.20.0.27
    libpulsecore-4.0.so
    libpulse-mainloop-glib.so.0
    libpulse-mainloop-glib.so.0.0.4
    libpulse.so.0
    libpulse.so.0.16.2
    libpurple-client.so.0
    libpurple-client.so.0.10.9
    libpurple.so.0
    libpurple.so.0.10.9
    libpwquality.so.1
    libpwquality.so.1.0.2
    libpyglib-2.0-python.so
    libpyglib-2.0-python.so.0
    libpyglib-2.0-python.so.0.0.0
    libpyglib-gi-2.0-python3.so
    libpyglib-gi-2.0-python3.so.0
    libpyglib-gi-2.0-python3.so.0.0.0
    libpyglib-gi-2.0-python.so
    libpyglib-gi-2.0-python.so.0
    libpyglib-gi-2.0-python.so.0.0.0
    libpytalloc-util.so.2
    libpytalloc-util.so.2.1.0
    libpython2.7.so.1.0
    libpython3.3m.so.1.0
    libpython3.so
    libqmi-glib.so.1
    libqmi-glib.so.1.0.0
    libqpdf.so.13
    libqpdf.so.13.1.1
    libqpol.so.1
    libqpol.so.1.6
    libqrencode.so.3
    libqrencode.so.3.4.2
    libQt3Support.so.4
    libQt3Support.so.4.8
    libQt3Support.so.4.8.5
    libQtCLucene.so.4
    libQtCLucene.so.4.8
    libQtCLucene.so.4.8.5
    libQtCore.so.4
    libQtCore.so.4.8
    libQtCore.so.4.8.5
    libQtDBus.so.4
    libQtDBus.so.4.8
    libQtDBus.so.4.8.5
    libQtDeclarative.so.4
    libQtDeclarative.so.4.8
    libQtDeclarative.so.4.8.5
    libQtDesignerComponents.so.4
    libQtDesignerComponents.so.4.8
    libQtDesignerComponents.so.4.8.5
    libQtDesigner.so.4
    libQtDesigner.so.4.8
    libQtDesigner.so.4.8.5
    libQtGui.so.4
    libQtGui.so.4.8
    libQtGui.so.4.8.5
    libQtHelp.so.4
    libQtHelp.so.4.8
    libQtHelp.so.4.8.5
    libQtMultimedia.so.4
    libQtMultimedia.so.4.8
    libQtMultimedia.so.4.8.5
    libQtNetwork.so.4
    libQtNetwork.so.4.8
    libQtNetwork.so.4.8.5
    libQtOpenGL.so.4
    libQtOpenGL.so.4.8
    libQtOpenGL.so.4.8.5
    libQtScript.so.4
    libQtScript.so.4.8
    libQtScript.so.4.8.5
    libQtScriptTools.so.4
    libQtScriptTools.so.4.8
    libQtScriptTools.so.4.8.5
    libQtSql.so.4
    libQtSql.so.4.8
    libQtSql.so.4.8.5
    libQtSvg.so.4
    libQtSvg.so.4.8
    libQtSvg.so.4.8.5
    libQtTest.so.4
    libQtTest.so.4.8
    libQtTest.so.4.8.5
    libQtXmlPatterns.so.4
    libQtXmlPatterns.so.4.8
    libQtXmlPatterns.so.4.8.5
    libQtXml.so.4
    libQtXml.so.4.8
    libQtXml.so.4.8.5
    libquvi-0.9-0.9.2.so
    libraptor2.so.0
    libraptor2.so.0.0.0
    librasqal.so.3
    librasqal.so.3.0.0
    libraw1394.so.11
    libraw1394.so.11.1.0
    libraw_r.so.9
    libraw_r.so.9.0.0
    libraw.so.9
    libraw.so.9.0.0
    librdf.so.0
    librdf.so.0.0.0
    libreadline.so.6
    libreadline.so.6.2
    libref_array.so.1
    libref_array.so.1.1.0
    libregistry.so.0
    libregistry.so.0.0.1
    libreoffice
    libreport-gtk.so.0
    libreport-gtk.so.0.0.1
    libreport.so.0
    libreport.so.0.0.1
    libreport-web.so.0
    libreport-web.so.0.0.1
    librepo.so.0
    libresolv-2.18.so
    libresolv.so
    libresolv.so.2
    librest-0.7.so.0
    librest-0.7.so.0.0.0
    librest-extras-0.7.so.0
    librest-extras-0.7.so.0.0.0
    librhythmbox-core.so
    librhythmbox-core.so.8
    librhythmbox-core.so.8.0.0
    librom1394.so.0
    librom1394.so.0.3.0
    librpcsvc.a
    librpmbuild.so.3
    librpmbuild.so.3.2.1
    librpmio.so.3
    librpmio.so.3.2.1
    librpmsign.so.1
    librpmsign.so.1.2.1
    librpm.so.3
    librpm.so.3.2.1
    librsvg-2.so.2
    librsvg-2.so.2.40.1
    librt-2.18.so
    librt.so
    librt.so.1
    librygel-core-2.0.so.1
    librygel-core-2.0.so.1.0.0
    librygel-renderer-2.0.so.1
    librygel-renderer-2.0.so.1.0.0
    librygel-renderer-gst-2.0.so.1
    librygel-renderer-gst-2.0.so.1.0.0
    librygel-server-2.0.so.1
    librygel-server-2.0.so.1.0.0
    libsamba-credentials.so.0
    libsamba-credentials.so.0.0.1
    libsamba-hostconfig.so.0
    libsamba-hostconfig.so.0.0.1
    libsamba-policy.so.0
    libsamba-policy.so.0.0.1
    libsamba-util.so.0
    libsamba-util.so.0.0.1
    libsamdb.so.0
    libsamdb.so.0.0.1
    libsamplerate.so.0
    libsamplerate.so.0.1.8
    libsane.so.1
    libsane.so.1.0.24
    libsasl2.so.3
    libsasl2.so.3.0.0
    libsatyr.so.3
    libsatyr.so.3.0.0
    libsbc.so.1
    libsbc.so.1.2.0
    libSDL-1.2.so.0
    libSDL-1.2.so.0.11.4
    libseaudit.so.4
    libseaudit.so.4.4
    libsecret-1.so.0
    libsecret-1.so.0.0.0
    libseed-gtk3.so.0
    libseed-gtk3.so.0.0.0
    libsefs.so.4
    libsefs.so.4.0.3
    libSegFault.so
    libselinux.so.1
    libsemanage.so.1
    libsepol.so.1
    libsgutils2.so.2
    libsgutils2.so.2.0.0
    libshout.so.3
    libshout.so.3.2.0
    libsigc-2.0.so.0
    libsigc-2.0.so.0.0.0
    libsilc-1.1.so.2
    libsilc-1.1.so.2.1.0
    libsilcclient-1.1.so.3
    libsilcclient-1.1.so.3.0.0
    libslang.so.2
    libslang.so.2.2.4
    libslapi-2.4.so.2
    libslapi-2.4.so.2.10.2
    libsmbclient-raw.so.0
    libsmbclient-raw.so.0.0.1
    libsmbclient.so.0
    libsmbclient.so.0.2.1
    libsmbconf.so.0
    libsmbldap.so.0
    libsmbsharemodes.so.0
    libsmime3.so
    libSM.so.6
    libSM.so.6.0.1
    libsnappy.so.1
    libsnappy.so.1.1.4
    libsndfile.so.1
    libsoftokn3.chk
    libsoftokn3.so
    libsolvext.so.0
    libsolv.so.0
    libSoundTouch.so.1
    libSoundTouch.so.1.4.0
    libsoup-2.4.so.1
    libsoup-2.4.so.1.7.0
    libsoup-gnome-2.4.so.1
    libsoup-gnome-2.4.so.1.7.0
    libsox.so.2
    libsox.so.2.0.1
    libspectre.so.1
    libspectre.so.1.1.7
    libspeechd.so.2
    libspeechd.so.2.4.0
    libspeexdsp.so.1
    libspeexdsp.so.1.5.0
    libspeex.so.1
    libspeex.so.1.5.0
    libspice-client-glib-2.0.so.8
    libspice-client-glib-2.0.so.8.5.0
    libspice-client-gtk-3.0.so.4
    libspice-client-gtk-3.0.so.4.0.0
    libspice-controller.so.0
    libspice-controller.so.0.0.0
    libsqlite3.so.0
    libsqlite3.so.0.8.6
    libsrtp.so.0
    libsrtp.so.0.0.0
    libssh2.so.1
    libssh2.so.1.0.1
    libssl3.so
    libssl.so.10
    libssl.so.1.0.1e
    libsss_idmap.so.0
    libsss_idmap.so.0.3.0
    libsss_nss_idmap.so.0
    libsss_nss_idmap.so.0.0.1
    libss.so.2
    libss.so.2.0
    libsss_sudo.so
    libstartup-notification-1.so.0
    libstartup-notification-1.so.0.0.0
    libstdc++.so.6
    libstdc++.so.6.0.19
    libstoken.so.1
    libstoken.so.1.1.0
    libsysfs.so.2
    libsysfs.so.2.0.1
    libtag_c.so.0
    libtag_c.so.0.0.0
    libtag.so.1
    libtag.so.1.14.0
    libtalloc.so.2
    libtalloc.so.2.1.0
    libtar.so.1
    libtar.so.1.2.11
    libtasn1.so.6
    libtasn1.so.6.1.1
    libtdb.so.1
    libtdb.so.1.2.12
    libteamdctl.so.0
    libteamdctl.so.0.1.0
    libteam.so.5
    libteam.so.5.0.0
    libtelepathy-farstream.so.3
    libtelepathy-farstream.so.3.0.1
    libtelepathy-glib.so.0
    libtelepathy-glib.so.0.80.1
    libtelepathy-logger.so.3
    libtelepathy-logger.so.3.3.0
    libtevent.so.0
    libtevent.so.0.9.20
    libtevent-util.so.0
    libtevent-util.so.0.0.1
    libthai.so.0
    libthai.so.0.2.0
    libtheoradec.so.1
    libtheoradec.so.1.1.4
    libtheoraenc.so.1
    libtheoraenc.so.1.1.2
    libtheora.so.0
    libtheora.so.0.3.10
    libthread_db-1.0.so
    libthread_db.so
    libthread_db.so.1
    libtic.so.5
    libtic.so.5.9
    libtiff.so.5
    libtiff.so.5.2.0
    libtiffxx.so.5
    libtiffxx.so.5.2.0
    libtinfo.so.5
    libtinfo.so.5.9
    libtomcrypt.so.0
    libtomcrypt.so.0.0.117
    libtommath.so.0
    libtommath.so.0.0.41
    libtotem-plparser-mini.so.18
    libtotem-plparser-mini.so.18.0.0
    libtotem-plparser.so.18
    libtotem-plparser.so.18.0.0
    libtotem.so.0
    libtotem.so.0.0.0
    libtracker-extract-0.16.so.0
    libtracker-extract-0.16.so.0.1600.4
    libtracker-miner-0.16.so.0
    libtracker-miner-0.16.so.0.1600.4
    libtracker-sparql-0.16.so.0
    libtracker-sparql-0.16.so.0.1600.4
    libtspi.so.1
    libtspi.so.1.2.0
    libudev.so.1
    libudev.so.1.4.0
    libudf.so.0
    libudf.so.0.0.0
    libudisks2.so.0
    libudisks2.so.0.0.0
    libulockmgr.so.1
    libulockmgr.so.1.0.1
    libunbound.so.2
    libunbound.so.2.2.1
    libungif.so.4
    libungif.so.4.1.6
    libuniconf.so.4.6
    libunistring.so.0
    libunistring.so.0.1.2
    libunwind-coredump.so.0
    libunwind-coredump.so.0.0.0
    libunwind.so.8
    libunwind.so.8.0.1
    libunwind-x86_64.so.8
    libunwind-x86_64.so.8.0.1
    libupower-glib.so.1
    libupower-glib.so.1.0.4
    libusb-0.1.so.4
    libusb-0.1.so.4.4.4
    libusb-1.0.so.0
    libusb-1.0.so.0.1.0
    libusbmuxd.so.1.0.8
    libusbmuxd.so.2
    libusbredirhost.so.1
    libusbredirhost.so.1.0.0
    libusbredirparser.so.1
    libusbredirparser.so.1.0.0
    libuser
    libuser.so.1
    libuser.so.1.5.0
    libustr-1.0.so.1
    libustr-1.0.so.1.0.4
    libutempter.so.0
    libutempter.so.1.1.6
    libutil-2.18.so
    libutil.so
    libutil.so.1
    libuuid.so.1
    libuuid.so.1.3.0
    libv4l
    libv4l1.so.0
    libv4l1.so.0.0.0
    libv4l2rds.so.0
    libv4l2rds.so.0.0.0
    libv4l2.so.0
    libv4l2.so.0.0.0
    libv4lconvert.so.0
    libv4lconvert.so.0.0.0
    libvdpau_nvidia.so
    libvdpau.so.1
    libvdpau.so.1.0.0
    libverto.so.1
    libverto.so.1.0.0
    libvisio-0.0.so.0
    libvisio-0.0.so.0.0.31
    libvisual-0.4.so.0
    libvisual-0.4.so.0.0.0
    libvmtools.so.0
    libvmtools.so.0.0.0
    libvorbisenc.so.2
    libvorbisfile.so.3
    libvorbis.so.0
    libvorbis.so.0.4.7
    libvpx.so.1
    libvpx.so.1.3
    libvpx.so.1.3.0
    libvte2_90.so.9
    libvte2_90.so.9.3400.9
    libwacom.so.2
    libwacom.so.2.1.0
    libwavpack.so.1
    libwavpack.so.1.1.5
    libwayland-egl.so.1
    libwayland-egl.so.1.0.0
    libwbclient.so.0
    libwbclient.so.0.11
    libwebkitgtk-3.0.so.0
    libwebkitgtk-3.0.so.0.19.14
    libwebpdemux.so.0
    libwebpdemux.so.0.0.1
    libwebpmux.so.0
    libwebpmux.so.0.0.1
    libwebp.so.4
    libwebp.so.4.0.3
    libwebrtc_audio_processing.so.0
    libwebrtc_audio_processing.so.0.0.0
    libwnck-3.so.0
    libwnck-3.so.0.2.2
    libwpd-0.9.so.9
    libwpd-0.9.so.9.0.9
    libwpd-stream-0.9.so.9
    libwpd-stream-0.9.so.9.0.9
    libwpg-0.2.so.2
    libwpg-0.2.so.2.0.2
    libwps-0.2.so.2
    libwps-0.2.so.2.0.9
    libwrap.so.0
    libwrap.so.0.7.6
    libwvbase.so.4.6
    libwvdbus.so.4.6
    libwvstreams.so.4.6
    libwvutils.so.4.6
    libX11.so.6
    libX11.so.6.3.0
    libX11-xcb.so.1
    libX11-xcb.so.1.0.0
    libxatracker.so.2
    libxatracker.so.2.0.0
    libXau.so.6
    libXau.so.6.0.0
    libxcb-damage.so.0
    libxcb-dpms.so.0
    libxcb-dri2.so.0
    libxcb-glx.so.0
    libxcb-glx.so.0.0.0
    libxcb-randr.so.0
    libxcb-record.so.0
    libxcb-render.so.0
    libxcb-res.so.0
    libxcb-res.so.0.0.0
    libxcb-shape.so.0
    libxcb-shm.so.0
    libxcb-shm.so.0.0.0
    libxcb.so.1
    libxcb.so.1.1.0
    libxcb-sync.so.0
    libxcb-util.so.1
    libxcb-util.so.1.0.0
    libxcb-xevie.so.0
    libxcb-xf86dri.so.0
    libxcb-xfixes.so.0
    libxcb-xkb.so.0
    libxcb-xkb.so.0.0.0
    libxcb-xtest.so.0
    libxcb-xvmc.so.0
    libxcb-xv.so.0
    libxcb-xv.so.0.0.0
    libXcomposite.so.1
    libXcursor.so.1
    libXcursor.so.1.0.2
    libXdamage.so.1
    libXdamage.so.1.1.0
    libXdmcp.so.6
    libXdmcp.so.6.0.0
    libXevie.so.1
    libXevie.so.1.0.0
    libXext.so.6
    libXext.so.6.4.0
    libXfixes.so.3
    libXfixes.so.3.1.0
    libXfont.so.1
    libXfont.so.1.4.1
    libXft.so.2
    libXft.so.2.3.1
    libXinerama.so.1
    libXi.so.6
    libXi.so.6.1.0
    libxkbcommon.so.0
    libxkbfile.so.1
    libxkbfile.so.1.0.2
    libxklavier.so.16
    libxklavier.so.16.4.0
    libxml2.so.2
    libxml2.so.2.9.1
    libxmlrpc_abyss.so.3
    libxmlrpc_abyss.so.3.32
    libxmlrpc_client.so.3
    libxmlrpc_client.so.3.32
    libxmlrpc_server_abyss.so.3
    libxmlrpc_server_abyss.so.3.32
    libxmlrpc_server_cgi.so.3
    libxmlrpc_server_cgi.so.3.32
    libxmlrpc_server.so.3
    libxmlrpc_server.so.3.32
    libxmlrpc.so.3
    libxmlrpc.so.3.32
    libxmlrpc_util.so.3
    libxmlrpc_util.so.3.32
    libXmu.so.6
    libXmu.so.6.2.0
    libXmuu.so.1
    libXmuu.so.1.0.0
    libXpm.so.4
    libXpm.so.4.11.0
    libXrandr.so.2
    libXrandr.so.2.2.0
    libXrender.so.1
    libXrender.so.1.3.0
    libXRes.so.1
    libXRes.so.1.0.0
    libxslt-plugins
    libxslt.so.1
    libxslt.so.1.1.28
    libXss.so.1
    libXss.so.1.0.0
    libxtables.so.10
    libxtables.so.10.0.0
    libXt.so.6
    libXt.so.6.0.0
    libXtst.so.6
    libXtst.so.6.1.0
    libXvMC.so.1
    libXvMC.so.1.0.0
    libXvMCW.so.1
    libXvMCW.so.1.0.0
    libXv.so.1
    libXv.so.1.0.0
    libXxf86dga.so.1
    libXxf86dga.so.1.0.0
    libXxf86misc.so.1
    libXxf86misc.so.1.1.0
    libXxf86vm.so.1
    libXxf86vm.so.1.0.0
    libyajl.so.2
    libyajl.so.2.0.4
    libyelp.so.0
    libyelp.so.0.0.0
    libzapojit-0.0.so.0
    libzapojit-0.0.so.0.0.0
    libzeitgeist-2.0.so.0
    libzeitgeist-2.0.so.0.0.0
    libz.so.1
    libz.so.1.2.8
    llvm
    lua
    m17n
    man-db
    Mcrt1.o
    mission-control-plugins.0
    ModemManager
    mozilla
    multipath
    mutter
    mutter-wayland
    nautilus
    NetworkManager
    nss
    openssl
    open-vm-tools
    openvpn
    p11-kit
    p11-kit-proxy.so
    p11-kit-trust.so
    packagekit-backend
    packagekit-plugins
    pam_pkcs11
    pango
    perl5
    pkcs11
    pkgconfig
    plymouth
    pm-utils
    pppd
    pulse-4.0
    pulseaudio
    purple-2
    pygtk
    python2.7
    python3.3
    qt-3.3
    qt4
    realmd
    redland
    rhythmbox
    rtkaio
    rygel-2.0
    samba
    sane
    sasl2
    Scrt1.o
    seahorse
    security
    seed-gtk3
    shotwell
    silc
    sox
    speech-dispatcher
    speech-dispatcher-modules
    sse2
    sssd
    stunnel
    sushi
    tc
    telepathy
    tls
    totem
    tracker-0.16
    vdpau
    vte-2.90
    X11
    xorg
    xtables
    xulrunner
    Environment variables :
    declare -x COLORTERM="gnome-terminal"
    declare -x DBUS_SESSION_BUS_ADDRESS="unix:abstract=/tmp/dbus-46FEIwotyS,guid=ab4e6f7233e98047eee8f92053330e03"
    declare -x DESKTOP_SESSION="gnome"
    declare -x DISPLAY=":0"
    declare -x GDMSESSION="gnome"
    declare -x GDM_LANG="en_US.UTF-8"
    declare -x GJS_DEBUG_OUTPUT="stderr"
    declare -x GJS_DEBUG_TOPICS="JS ERROR;JS LOG"
    declare -x GNOME_DESKTOP_SESSION_ID="this-is-deprecated"
    declare -x GNOME_KEYRING_CONTROL="/run/user/1000/keyring-86u6l9"
    declare -x GNOME_KEYRING_PID="1530"
    declare -x GPG_AGENT_INFO="/run/user/1000/keyring-86u6l9/gpg:0:1"
    declare -x HISTCONTROL="ignoredups"
    declare -x HISTSIZE="1000"
    declare -x HOME="/home/cbonniot"
    declare -x HOSTNAME="cbonniot"
    declare -x LANG="en_US.UTF-8"
    declare -x LESSOPEN="||/usr/bin/lesspipe.sh %s"
    declare -x LOGNAME="cbonniot"
    declare -x LS_COLORS="rs=0:di=38;5;27:ln=38;5;51:mh=44;38;5;15:pi=40;38;5;11:so=38;5;13:do=38;5;5:bd=48;5;232;38;5;11:cd=48;5;232;38;5;3:or=48;5;232;38;5;9:mi=05;48;5;232;38;5;15:su=48;5;196;38;5;15:sg=48;5;11;38;5;16:ca=48;5;196;38;5;226:tw=48;5;10;38;5;16:ow=48;5;10;38;5;21:st=48;5;21;38;5;15:ex=38;5;34:*.tar=38;5;9:*.tgz=38;5;9:*.arc=38;5;9:*.arj=38;5;9:*.taz=38;5;9:*.lha=38;5;9:*.lzh=38;5;9:*.lzma=38;5;9:*.tlz=38;5;9:*.txz=38;5;9:*.tzo=38;5;9:*.t7z=38;5;9:*.zip=38;5;9:*.z=38;5;9:*.Z=38;5;9:*.dz=38;5;9:*.gz=38;5;9:*.lrz=38;5;9:*.lz=38;5;9:*.lzo=38;5;9:*.xz=38;5;9:*.bz2=38;5;9:*.bz=38;5;9:*.tbz=38;5;9:*.tbz2=38;5;9:*.tz=38;5;9:*.deb=38;5;9:*.rpm=38;5;9:*.jar=38;5;9:*.war=38;5;9:*.ear=38;5;9:*.sar=38;5;9:*.rar=38;5;9:*.alz=38;5;9:*.ace=38;5;9:*.zoo=38;5;9:*.cpio=38;5;9:*.7z=38;5;9:*.rz=38;5;9:*.cab=38;5;9:*.jpg=38;5;13:*.jpeg=38;5;13:*.gif=38;5;13:*.bmp=38;5;13:*.pbm=38;5;13:*.pgm=38;5;13:*.ppm=38;5;13:*.tga=38;5;13:*.xbm=38;5;13:*.xpm=38;5;13:*.tif=38;5;13:*.tiff=38;5;13:*.png=38;5;13:*.svg=38;5;13:*.svgz=38;5;13:*.mng=38;5;13:*.pcx=38;5;13:*.mov=38;5;13:*.mpg=38;5;13:*.mpeg=38;5;13:*.m2v=38;5;13:*.mkv=38;5;13:*.ogm=38;5;13:*.mp4=38;5;13:*.m4v=38;5;13:*.mp4v=38;5;13:*.vob=38;5;13:*.qt=38;5;13:*.nuv=38;5;13:*.wmv=38;5;13:*.asf=38;5;13:*.rm=38;5;13:*.rmvb=38;5;13:*.flc=38;5;13:*.avi=38;5;13:*.fli=38;5;13:*.flv=38;5;13:*.gl=38;5;13:*.dl=38;5;13:*.xcf=38;5;13:*.xwd=38;5;13:*.yuv=38;5;13:*.cgm=38;5;13:*.emf=38;5;13:*.axv=38;5;13:*.anx=38;5;13:*.ogv=38;5;13:*.ogx=38;5;13:*.aac=38;5;45:*.au=38;5;45:*.flac=38;5;45:*.mid=38;5;45:*.midi=38;5;45:*.mka=38;5;45:*.mp3=38;5;45:*.mpc=38;5;45:*.ogg=38;5;45:*.ra=38;5;45:*.wav=38;5;45:*.axa=38;5;45:*.oga=38;5;45:*.spx=38;5;45:*.xspf=38;5;45:"
    declare -x MAIL="/var/spool/mail/cbonniot"
    declare -x OLDPWD="/home/cbonniot"
    declare -x PATH="/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/sbin:/home/cbonniot/.local/bin:/home/cbonniot/bin"
    declare -x PWD="/home/cbonniot/downloads/ccs/ccs"
    declare -x QT_IM_MODULE="ibus"
    declare -x SESSION_MANAGER="local/unix:@/tmp/.ICE-unix/1589,unix/unix:/tmp/.ICE-unix/1589"
    declare -x SHELL="/bin/bash"
    declare -x SHLVL="2"
    declare -x SSH_AUTH_SOCK="/run/user/1000/keyring-86u6l9/ssh"
    declare -x TERM="xterm-256color"
    declare -x USER="cbonniot"
    declare -x USERNAME="cbonniot"
    declare -x VTE_VERSION="3409"
    declare -x WINDOWID="35651590"
    declare -x WINDOWPATH="1"
    declare -x XAUTHORITY="/run/gdm/auth-for-cbonniot-SjEUaw/database"
    declare -x XDG_MENU_PREFIX="gnome-"
    declare -x XDG_RUNTIME_DIR="/run/user/1000"
    declare -x XDG_SEAT="seat0"
    declare -x XDG_SESSION_ID="1"
    declare -x XDG_VTNR="1"
    declare -x XMODIFIERS="@im=ibus"
    If you need any additional information, please tell me.
    Thank you
  • In /lib, the only package I have that you do not is dkms. I don't think it would matter. You have some libs that I do not have installed.
    In /lib64 there are more differences, but I don't think these would matter as we run CCS as a 32bit process.
    Into what folder did you install CCS? Also, did you run the install with user or root privileges? Can you try renaming the ~/.ti folder to something else and see if that makes any difference? If the install folder is read-only, does it make any difference if you make the install folder writable?
  • Hello Andy,
    My hope was in the lib directory...
    I'll try installing the dkms package, just to be sure...
    I agree with you about the "lib64" direcetory.
    I installed CCS with root privileges, it is located at "/opt/ti/ccsv6/..."
    None of the directories are read only, I tried to to rename the "~/ti" folder and I still have my seg fault.
    I have no idea about what could be the cause of the problem. When I use "ldd" with "ccstudio" binary, every linked lib is found. I even made sure it uses the java libs located in the "jre" folder of "ccsv6/eclipse".
    Do you have an idea about the cause of the issue here ?
    Thank you.
  • I tried to run ccstudio with gdb, here is the backtrace of the seg fault:
    #0 0x00000000 in ?? ()
    #1 0xf7fc8d78 in pthread_once () from /lib/libpthread.so.0
    #2 0xf6e2fd56 in ?? () from /lib/libGL.so.1
    #3 0xf6e30822 in ?? () from /lib/libGL.so.1
    #4 0xf7feb45a in call_init.part.0 () from /lib/ld-linux.so.2
    #5 0xf7feb594 in _dl_init_internal () from /lib/ld-linux.so.2
    #6 0xf7fef954 in dl_open_worker () from /lib/ld-linux.so.2
    #7 0xf7feb32a in _dl_catch_error () from /lib/ld-linux.so.2
    #8 0xf7fef014 in _dl_open () from /lib/ld-linux.so.2
    #9 0xf7fb8cbc in dlopen_doit () from /lib/libdl.so.2
    #10 0xf7feb32a in _dl_catch_error () from /lib/ld-linux.so.2
    #11 0xf7fb93cc in _dlerror_run () from /lib/libdl.so.2
    #12 0xf7fb8d71 in dlopen@@GLIBC_2.1 () from /lib/libdl.so.2
    #13 0xf7bf5f89 in loadGtk () at eclipseGtkInit.c:109
    #14 0xf7bf5c53 in initWindowSystem (pArgc=0xf7bf7af8 <initialArgc>, argv=0x804e830, showSplash=1) at eclipseGtkCommon.c:73
    #15 0xf7bf19f0 in showSplash (featureImage=0x80572e0 "/opt/ti/ccsv6/eclipse//plugins/com.ti.ccstudio.branding_6.0.0.201403071400/splash.bmp") at eclipseGtk.c:243
    #16 0xf7bedfbd in _run (argc=3, argv=0x804f8a8, vmArgs=0x8054f30) at ../eclipse.c:573
    #17 0xf7bedbe3 in run (argc=3, argv=0x804f8a8, vmArgs=0x8050250) at ../eclipse.c:462
    #18 0x080497a9 in main (argc=12, argv=0x804f8a8) at ../eclipseMain.c:332
  • Could you please provide with the version of the glibc installed on your system ?
    Mine is 2.18-12.fc20.i686 and 2.18-12.fc20.x86_64
    Thank you.
  • I tried to install and run uniflash v3.
    The seg fault occurs, I have basically the same backtrace than with ccs.
    Apparently, when the program wants to display the splash screen, it tries to load GTK's libs and dlopen fails which drives the program to go to pthread_once which causes the seg fault (I have no idea why pthread_once would, excet maybe if called with a NULL argument).
    Maybe my problem is with my GTK version...
    yum provides gtk2:
    gtk2-2.24.22-2.fc20.i686 : The GIMP ToolKit (GTK+), a library for creating GUIs for X
    Repo : fedora
    gtk2-2.24.22-2.fc20.x86_64 : The GIMP ToolKit (GTK+), a library for creating GUIs for X
    Repo : fedora
    Repo : @fedora
    Repo : @koji-override-0/$releasever
    yum provides gtk3:
    gtk3-3.10.4-1.fc20.i686 : The GIMP ToolKit (GTK+), a library for creating GUIs for X
    Repo : fedora
    gtk3-3.10.4-1.fc20.x86_64 : The GIMP ToolKit (GTK+), a library for creating GUIs for X
    Repo : fedora
    gtk3-3.10.6-1.fc20.i686 : The GIMP ToolKit (GTK+), a library for creating GUIs for X
    Repo : updates
    gtk3-3.10.6-1.fc20.x86_64 : The GIMP ToolKit (GTK+), a library for creating GUIs for X
    Repo : updates
    Repo : @updates
    Repo : @updates
    Thank you.
  • Here's what I've got for libc and gtk2.  gtk3 is version 3.10.6.
    GNU C Library (GNU libc) stable release version 2.18, by Roland McGrath et al.
    Copyright (C) 2013 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions.
    There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
    PARTICULAR PURPOSE.
    Compiled by GNU CC version 4.8.2 20131212 (Red Hat 4.8.2-7).
    Compiled on a Linux 3.12.8 system on 2014-01-23.
    $ yum info gtk2
    Loaded plugins: langpacks, refresh-packagekit
    Installed Packages
    Arch : i686
    Version : 2.24.22
    Release : 2.fc20
    Repo : installed
    From repo : fedora
    Summary : The GIMP ToolKit (GTK+), a library for creating GUIs for X
    URL : http://www.gtk.org
    License : LGPLv2+
    Description : GTK+ is a multi-platform toolkit for creating graphical user
    : interfaces. Offering a complete set of widgets, GTK+ is suitable for
    : projects ranging from small one-off tools to complete application
    : suites.
    Arch : x86_64
    Version : 2.24.22
    Release : 2.fc20
    Repo : installed
    From repo : koji-override-0
    License : LGPLv2+
    : suites.
    I have exactly the same thing...
  • It may not help, but as I'm running out of ideas perhaps you could capture an strace log for the process to the point where is crashes and post it here. The file access are probably the most useful so something like:
    strace -f -e trace=file -o /tmp/log.txt ./ccstudio
  • I am also running out of ideas.
    Here is the output of strace : 6765.strace.log.txt
    Thank you.
  • On this first log, I did not ran it from "/opt/ti/ccsv6/eclipse". I noticed it uses relative path to find some java libs.
    Here is the strace's log when I run it from "/opt/ti/ccsv6/eclipse" : 8321.strace2.log.txt
  • I rietrieved information from "dmesg" :
    [ 6026.556912] ld-linux.so.2[12337]: segfault at f776e35c ip 00000000f7776612 sp 00000000fffc7cf0 error 7 in ld-2.18.so[f7770000+1f000]
    [ 6026.620423] ld-linux-x86-64[12341]: segfault at 7fecb64f2480 ip 00007fecb64fa5cd sp 00007fff53892840 error 7 in ld-2.18.so[7fecb64f4000+20000]
    [ 6047.890140] ld-linux.so.2[15977]: segfault at f77c035c ip 00000000f77c8612 sp 00000000fffbeec0 error 7 in ld-2.18.so[f77c2000+1f000]
    [ 6047.982510] ld-linux-x86-64[15981]: segfault at 7f4b4e7f4480 ip 00007f4b4e7fc5cd sp 00007fff448cc740 error 7 in ld-2.18.so[7f4b4e7f6000+20000]
    It seems, if I'm reading it right, that the program is using the 64bits ld-linux.so version. Do you agree ?
    If it is the issue here, I don't know how to make him use the 32bits version, do you ?
    Thank you.
  • I'm not sure the 64-bit loader is being used. I did have a look through the strace logs and a lot of 32-bit libraries are loaded before it crashes so I think the loader is working as expected. The main difference I see in your strace log vs mine is the presence of libnvidia* libraries. These seem to be NVidia libraries used by OpenGL. Given this and the previous gdb call stack you posted, my working theory is a bug in the NVidia drivers or OpenGL is causing this.
    Could you check if you have the latest available NVidia package installed? I see there is a Feb/2014 beta version on their download site but I'm not sure if it applies to your hardware. Could you also see if there are any NVidia options that make a difference (IE, like disabling acceleration, disabling secondary monitors, etc)?
    I wanted to test everything before posting something and so far so good. I just have the debug functionnality left to test.
    It was in fact the NVidia drivers that were causing the segmentation fault. I supressed them and installed others not from nvidia website (I 'm not sure but I think that I was using the ones you are talking about since I downloaded them from NVidia 3 days ago) and it worked without any issue.
    I'll mark this subject as resolved and open a new one if I have another issue.
    I thank you for your support and your time.
  • Excellent! I'm glad we were able to get to the bottom of this.
