Debugging DSS Script with CCS
I am trying to open a CCS session from the DSS script as described here:
http://wiki.davincidsp.com/index.php/Debug_Server_Scripting#Debugging_Your_JavaScript
My script executes the following:
server = env.getServer("CCSServer.1");
session = server.openSession(".*");
// A breakpoint is inserted here before the script is run and waits until CCS is opened
// Next it tries to reset and load the target
session.target.reset();
session.memory.loadProgram(DSPProgramDirectory + programName);
The reset() or loadProgram() commands do not work as the script reports the exception that the functions are not found.
Please let me know if you need more information.  I tried this is CCS v4.1 and 4.0.2 with the same results.
  • You cannot use the CCS session for your DSS calls. You still need to get the Debug Server and over a debug session to it:
    var env= ScriptingEnvironment.instance()
    debugServer = env.getServer("DebugServer.1"); // You still need to get the Debug Server
    debugSession = debugServer.openSession(".*"); // You still need to open a Debug Session!
    debugSession .target.reset(); // Use debugSession and NOT session
    debugSession .memory.loadProgram(DSPProgramDirectory + programName); // Use debugSession!
    Basically your script is exactly the same as if you were just running DSS only, except you added the below:
    ki
