CCS V5 (latest version) install failing.
Hi, Ive been having some problems installing the latest version on CCS.
I was using the offline installer (as ive treid in the online one already)
keep getting the same issue.
Please see the attached logs.
Any help would be much apprietiated.
!SESSION 2014-04-16 13:42:18.862 -----------------------------------------------
eclipse.buildId=M20120914-1540
java.version=1.6.0_13
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Framework arguments:  -application com.ti.ccstudio.p2app -repository file:/C:/Users/155mm Carrier/Documents/Robinson,J/CCS5.5.0.00077_win32/CCS5.5.0.00077_win32/featurerepo -installIU com.ti.ccstudio.installer.win32.feature.group
Command-line arguments:  -os win32 -ws win32 -arch x86 -application com.ti.ccstudio.p2app -repository file:/C:/Users/155mm Carrier/Documents/Robinson,J/CCS5.5.0.00077_win32/CCS5.5.0.00077_win32/featurerepo -installIU com.ti.ccstudio.installer.win32.feature.group
!ENTRY org.eclipse.equinox.p2.artifact.repository 4 1000 2014-04-16 13:42:22.422
!MESSAGE No repository found at file:/C:/Users/155mm%20Carrier/Documents/Robinson.
!ENTRY org.eclipse.osgi 4 0 2014-04-16 13:42:23.072
!MESSAGE Application error
!STACK 1
java.lang.IllegalArgumentException: Location must be absolute: J/CCS5.5.0.00077_win32/CCS5.5.0.00077_win32/featurerepo
	at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.checkValidLocation(AbstractRepositoryManager.java:739)
	at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.contains(AbstractRepositoryManager.java:251)
	at com.ti.ccstudio.p2app.DirectorApplication.initializeRepositories(DirectorApplication.java:736)
	at com.ti.ccstudio.p2app.DirectorApplication.run(DirectorApplication.java:1368)
	at com.ti.ccstudio.p2app.DirectorApplication.start(DirectorApplication.java:1561)
	at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
!SESSION 2014-04-16 13:43:37.232 -----------------------------------------------
!ENTRY org.eclipse.equinox.p2.artifact.repository 4 1000 2014-04-16 13:43:38.492
!ENTRY org.eclipse.osgi 4 0 2014-04-16 13:43:39.122
!STACK 1
!SESSION 2014-04-16 13:43:53.952 -----------------------------------------------
!ENTRY org.eclipse.equinox.p2.artifact.repository 4 1000 2014-04-16 13:43:55.222
!ENTRY org.eclipse.osgi 4 0 2014-04-16 13:43:55.852
!STACK 1
J
  • Hi Jamillah,
    Eclipse is unable to handle the , in the temporary directory path. Could you please try resetting the TEMP and TMP environment variables, clean out the install directory and try the install again?
    Danish
  • Hi Danish,
    Thanks for your reply, I treid resetting the environments, now i get this error at the biginning.
    Error in action ExecuteAction
    Error in action UnzipFile
    couldn't open "C:/ti/C/TEMP/ijtmp_4B5562BF-E7A5-47EC-BFA0-13892F1216BF/p2.app.zip": no such file or directory
        while executing
    "zvfs::mount $zip $mnt"
        (procedure "::InstallJammer::actions::UnzipFile" line 12)
        invoked from within
    "::InstallJammer::actions::$component $this"
        while executing
    "$obj execute"
        (procedure "::InstallJammer::ExecuteActions" line 69)
        invoked from within
    "::InstallJammer::ExecuteActions $action -parent $id -conditions $eval"
        (procedure "::InstallJammer::actions::ExecuteAction" line 35)
        invoked from within
        while executing
        invoked from within
        while executing
    "$obj execute"
        invoked from within
        invoked from within
        while executing
    "$obj execute"
        invoked from within
    "::InstallJammer::ExecuteActions $id -when $when"
        (procedure "::InstallJammer::RaiseEventHandler" line 93)
        invoked from within
    "::InstallJammer::RaiseEventHandler  .wizard"
        (command bound to event)
    J
    Could you zip up the contents of c:\program files\installjammer registry\ccsv5 (program files (x86) if using a 64 bit machine) and post them here? Note, installjammer registry is a hidden folder.
    I'll take a look and get you sorted out. Sorry for the trouble.
    Danish
  • 4643.zipped1.zip
    Danish,
    Thanks for helping out.
    J
  • Hi Jamillah,
    I'm not sure I understand what's going on, on your machine. Did you set the TEMP variable to c:\temp or c\temp - no :? Could you double check this? If the TEMP is incorrectly set (without the :), please set it, delete the files in c:\ti\ccsv5 and try again.  You can clean out the contents of the installjammer registry folder, so we have fewer logs to go through next time.
    If that's not the problem, I think your safest bet is to create a temporary user with a simple user name like guest, and install ccs for all users.
    Keep me posted.
    Danish
  • Hi Danish,
    My apologies, I had used the wrong slash.
    I tried the install again and it got a lot further before it crashed (approx half way)
    attached is the new logs.
    Thanks again for your helo so far, much apprietiated.
    J5123.InstallJammer1.zip
  • Jamillah,
    I'm very sorry, but we're experiencing issues with the web site so the web installer's hitting timeouts when trying to install. Your best bet would be to download the offline installer if you can't wait for the web issues to be resolved. I don't have an estimate as to when this will be fixed.
    Again, sorry for the trouble.
    Danish
