Other Parts Discussed in Thread: CCSTUDIO
I have installed CCS on a computer with no c: drive only a d: drive. I am also running xp64 bit. I am using the Blackhawk usb-2000 attached to the F28027 Experimenters Kit.
When building the FlashingLEDs example code after using the migration tool, I get the following error message in the console during the build.
D:\Program Files (x86)\Texas Instruments\ccsv4\utils\gmake\gmake: *** No rule to make target `C:/CCStudio_v3.3/C2000/cgtools/lib/rts2800_ml.lib', needed by `../2802x_RAM/FlashingLeds.out'.
Is this a problem due to the fact that I have no c: drive. I have tride the same thing on an older pc running xp32 bit with a c: drive with no problem.
Can you give me some pointers to see if I can get this to work on the xp64 bit pc/
