I'm having a piccolo TMDXCNCD28035/TI and uses a USB2000 JTAG from Blackhawk, but facing some problems with the "On-chip flash programmer", witch do not support the f2803x device.
When trying to use the tool with a self created board (In the CCS setup, i've created my own f28035 board) I get this message:
Then I tried select a F28xx controller in the Parallel debug manager with an attached f28035.gel file witch helped me a little farther.... Strange....
As you see, the API interface file is correct (the black box), but can't select the correct dsp device to program (the red box).
CCS info:
Integrated development: 5.98.0419 texas instruments
vers: 3.3.83.16
Bios: 5.33.05
Code generation tool: V5.1.3
When do you (texas) have a update ready for this issue?
