Other Parts Discussed in Thread: TMS320C6713B
I don't understand the .cmd and .asm files in ccs3.3 about c6000 dsp.Is there any useful books or files can help me?
Please see pages 28, 29 and 30 of the TM320C6000 DSP/BIOS User's guide.
Now , i attach vecs_timer1.asm:
* Copyright (C) 2003 Texas Instruments Incorporated
* All Rights Reserved
*---------vecs_timer1.asm---------
* Assembly file to set up interrupt service table (IST)
* Global symbols defined here and exported out of this file
.global _vectors
.global _c_int00
.global _vector1
.global _vector2
.global _vector3
.global _vector4
.global _vector5
.global _vector6
.global _vector7
.global _vector8
.global _vector9
.global _vector10
.global _vector11
.global _vector12
.global _vector13
.global _c_int14 ; Hookup the c_int14 ISR in main()
.global _vector15
* Global symbols referenced in this file but defined somewhere else.
* Remember that your interrupt service routines need to be referenced here.
.ref _c_int00
* This is a macro that instantiates one entry in the interrupt service table.
VEC_ENTRY .macro addr
STW B0,*--B15
MVKL addr,B0
MVKH addr,B0
B B0
LDW *B15++,B0
NOP 2
NOP
NOP
.endm
* This is a dummy interrupt service routine used to initialize the IST.
_vec_dummy:
B B3
NOP 5
* This is the actual interrupt service table (IST). It is properly aligned and
* is located in the subsection .text:vecs. This means if you don't explicitly
* specify this section in your linker command file, it will default and link
* into the .text section. Remember to set the ISTP register to point to this
* table.
.sect ".text:vecs"
.align 1024
_vectors:
_vector0: VEC_ENTRY _c_int00 ;RESET
_vector1: VEC_ENTRY _vec_dummy ;NMI
_vector2: VEC_ENTRY _vec_dummy ;RSVD
_vector3: VEC_ENTRY _vec_dummy
_vector4: VEC_ENTRY _vec_dummy
_vector5: VEC_ENTRY _vec_dummy
_vector6: VEC_ENTRY _vec_dummy
_vector7: VEC_ENTRY _vec_dummy
_vector8: VEC_ENTRY _vec_dummy
_vector9: VEC_ENTRY _vec_dummy
_vector10: VEC_ENTRY _vec_dummy
_vector11: VEC_ENTRY _vec_dummy
_vector12: VEC_ENTRY _vec_dummy
_vector13: VEC_ENTRY _vec_dummy
_vector14: VEC_ENTRY _c_int14 ; Hookup the c_int14 ISR in main()
_vector15: VEC_ENTRY _vec_dummy
1 Hi,I don't understand the programme in vecs_timer1.asm file as follows.
STW B0,*--B15
MVKL addr,B0
MVKH addr,B0
B B0
LDW *B15++,B0
NOP 2
NOP
NOP
.endm
2 What's the functions about B0 and B15?
When isr return,are there must 5 instructions followed that are LDW *B15++,B0 NOW 2 NOP NOP?
Is there must return instruction in the end of isr (c programme)?
3 And in time1.c programme,i don't understand the programme set IRQ as follows:
extern far void vectors();
IRQ_setVecs(vectors);
I want to know what's the value about ISTP that is the address of IST.
4 Now i use tms320c6713b and I think DSP/BIOS is os on dsp, can i do my work without dsp/bios? What's the difference between DSP/BIOS and no DSP/BIOS project?
