I am using CCSv6.0.0.00190.
Changing the path variable in the Linked Resources does not change the build variable that has the same name.
Is this a bug?
Stephen
Stephen,
This works for me. What is the exact procedure you are using?
For details, check:
http://processors.wiki.ti.com/index.php/Portable_Projects#Portable_Projects_in_CCSv6
Rafael
Hi Stephen,
I am not sure why they separated out the path for linked resources but I can tell you is a behaviour inherited from Eclipse.
Note both these can be set at the workspace level if this makes is a small amount more convenient. Window->Preferences .. you can do a filter on var for build variables and linked for linked resources.
Lisa
