CCS 6.0, which I have been using without problems, is now crashing when I try to launch it. I've tried both a reboot and uninstalling/reinstalling it without luck. My problems started when I tried to start a debug download. It didn't start. I exited CCS. I've been unable to run CCS since then. I'm attaching the log file.
!SESSION 2014-08-06 17:15:52.381 ----------------------------------------------- eclipse.buildId=4.3.0.M20130911-1000 java.version=1.6.0_13 java.vendor=Sun Microsystems Inc. BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US Framework arguments: -product com.ti.ccstudio.branding.product Command-line arguments: -os win32 -ws win32 -arch x86 -product com.ti.ccstudio.branding.product !ENTRY org.eclipse.core.resources 2 10035 2014-08-06 17:15:57.841 !MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes. !ENTRY org.eclipse.osgi 4 0 2014-08-06 17:16:01.773 !MESSAGE Application error !STACK 1 org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException) at org.eclipse.swt.SWT.error(SWT.java:4397) at org.eclipse.swt.SWT.error(SWT.java:4312) at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:138) at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4145) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3762) at org.eclipse.swt.widgets.Display.release(Display.java:3815) at org.eclipse.swt.graphics.Device.dispose(Device.java:295) at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:140) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591) at org.eclipse.equinox.launcher.Main.run(Main.java:1450) Caused by: java.lang.NullPointerException at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1376) at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.java:1369) at org.eclipse.cdt.codan.internal.ui.cxx.Startup$1.run(Startup.java:39) at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35) at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135) ... 17 more !ENTRY org.eclipse.ui.workbench 4 2 2014-08-06 17:16:02.163 !MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench". !STACK 0 java.lang.NullPointerException at org.eclipse.equinox.internal.p2.core.helpers.ServiceHelper.getService(ServiceHelper.java:74) at org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.updateRoamingProfile(SimpleProfileRegistry.java:156) at org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.updateSelfProfile(SimpleProfileRegistry.java:147) at org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.getProfileMap(SimpleProfileRegistry.java:344) at org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.internalGetProfile(SimpleProfileRegistry.java:248) at org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.getProfile(SimpleProfileRegistry.java:178) at org.eclipse.equinox.internal.p2.ui.sdk.scheduler.AutomaticUpdateScheduler.earlyStartup(AutomaticUpdateScheduler.java:88) at org.eclipse.ui.internal.EarlyStartupRunnable.runEarlyStartup(EarlyStartupRunnable.java:87) at org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartupRunnable.java:66) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42) at org.eclipse.ui.internal.Workbench$55.run(Workbench.java:2551) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53) !ENTRY org.eclipse.core.jobs 4 2 2014-08-06 17:16:02.163 !MESSAGE An internal error occurred during: "Workbench early startup". !STACK 0 java.lang.NullPointerException at org.eclipse.core.internal.runtime.InternalPlatform.getLog(InternalPlatform.java:354) at org.eclipse.core.runtime.Plugin.getLog(Plugin.java:291) at org.eclipse.ui.internal.WorkbenchPlugin.log(WorkbenchPlugin.java:818) at org.eclipse.ui.internal.EarlyStartupRunnable.handleException(EarlyStartupRunnable.java:81) at org.eclipse.core.runtime.SafeRunner.handleException(SafeRunner.java:75) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:44) at org.eclipse.ui.internal.Workbench$55.run(Workbench.java:2551) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53) !ENTRY org.eclipse.core.jobs 2 2 2014-08-06 17:16:02.303 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$9 !ENTRY org.eclipse.core.jobs 2 2 2014-08-06 17:16:02.303 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$9 !ENTRY org.eclipse.core.jobs 2 2 2014-08-06 17:16:02.303 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$9 !ENTRY org.eclipse.core.jobs 2 2 2014-08-06 17:16:02.303 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$9 !ENTRY org.eclipse.core.jobs 2 2 2014-08-06 17:16:02.303 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$9 !ENTRY org.eclipse.core.jobs 2 2 2014-08-06 17:16:02.303 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$9 !ENTRY org.eclipse.core.jobs 2 2 2014-08-06 17:16:02.303 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$9 !ENTRY org.eclipse.core.jobs 2 2 2014-08-06 17:16:02.303 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$9 !ENTRY org.eclipse.core.jobs 2 2 2014-08-06 17:16:02.303 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$9 !SESSION 2014-08-06 17:18:43.718 ----------------------------------------------- eclipse.buildId=4.3.0.M20130911-1000 java.version=1.6.0_13 java.vendor=Sun Microsystems Inc. BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US Framework arguments: -product com.ti.ccstudio.branding.product Command-line arguments: -os win32 -ws win32 -arch x86 -product com.ti.ccstudio.branding.product !ENTRY org.eclipse.core.resources 2 10035 2014-08-06 17:18:45.309 !MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes. !ENTRY org.eclipse.osgi 4 0 2014-08-06 17:18:49.261 !MESSAGE Application error !STACK 1 org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException) at org.eclipse.swt.SWT.error(SWT.java:4397) at org.eclipse.swt.SWT.error(SWT.java:4312) at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:138) at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4145) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3762) at org.eclipse.swt.widgets.Display.release(Display.java:3815) at org.eclipse.swt.graphics.Device.dispose(Device.java:295) at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:140) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591) at org.eclipse.equinox.launcher.Main.run(Main.java:1450) Caused by: java.lang.NullPointerException at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1376) at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.java:1369) at org.eclipse.cdt.codan.internal.ui.cxx.Startup$1.run(Startup.java:39) at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35) at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135) ... 17 more !ENTRY org.eclipse.ui.workbench 4 2 2014-08-06 17:18:49.651 !MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench". !STACK 0 java.lang.NullPointerException at org.eclipse.equinox.internal.p2.core.helpers.ServiceHelper.getService(ServiceHelper.java:74) at org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.updateRoamingProfile(SimpleProfileRegistry.java:156) at org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.updateSelfProfile(SimpleProfileRegistry.java:147) at org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.getProfileMap(SimpleProfileRegistry.java:344) at org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.internalGetProfile(SimpleProfileRegistry.java:248) at org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.getProfile(SimpleProfileRegistry.java:178) at org.eclipse.equinox.internal.p2.ui.sdk.scheduler.AutomaticUpdateScheduler.earlyStartup(AutomaticUpdateScheduler.java:88) at org.eclipse.ui.internal.EarlyStartupRunnable.runEarlyStartup(EarlyStartupRunnable.java:87) at org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartupRunnable.java:66) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42) at org.eclipse.ui.internal.Workbench$55.run(Workbench.java:2551) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53) !ENTRY org.eclipse.core.jobs 4 2 2014-08-06 17:18:49.651 !MESSAGE An internal error occurred during: "Workbench early startup". !STACK 0 java.lang.NullPointerException at org.eclipse.core.internal.runtime.InternalPlatform.getLog(InternalPlatform.java:354) at org.eclipse.core.runtime.Plugin.getLog(Plugin.java:291) at org.eclipse.ui.internal.WorkbenchPlugin.log(WorkbenchPlugin.java:818) at org.eclipse.ui.internal.EarlyStartupRunnable.handleException(EarlyStartupRunnable.java:81) at org.eclipse.core.runtime.SafeRunner.handleException(SafeRunner.java:75) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:44) at org.eclipse.ui.internal.Workbench$55.run(Workbench.java:2551) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53) !ENTRY org.eclipse.core.jobs 2 2 2014-08-06 17:18:49.791 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$9 !ENTRY org.eclipse.core.jobs 2 2 2014-08-06 17:18:49.791 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$9 !ENTRY org.eclipse.core.jobs 2 2 2014-08-06 17:18:49.791 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$9 !ENTRY org.eclipse.core.jobs 2 2 2014-08-06 17:18:49.791 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$9 !ENTRY org.eclipse.core.jobs 2 2 2014-08-06 17:18:49.791 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$9 !ENTRY org.eclipse.core.jobs 2 2 2014-08-06 17:18:49.791 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$9 !ENTRY org.eclipse.core.jobs 2 2 2014-08-06 17:18:49.791 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$9 !ENTRY org.eclipse.core.jobs 2 2 2014-08-06 17:18:49.791 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$9 !ENTRY org.eclipse.core.jobs 2 2 2014-08-06 17:18:49.791 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$9
