Other Parts Discussed in Thread: OMAPL138, CCSTUDIO
I am trying to create my first project with CCS 5.3 for the OMAPL138 6748 DSP. I have recently installed CCS 5.3 along with CCS 6.0.1 . My eval board instructions use CCS 5.3 so I'm using this version to create the project.
After setting up the new project with the template (File --> New --> CCS Project) with the following parameters:
- Family: C6000
- Variant: Generic Devices
- Generic C674x Device
- Project Template : DSP/BIOS v5.xx Examples --> evmOMAPL138 Examples --> hello example
I click on Finish and get the popup below
The log file listing for this looks like:
!SESSION 2014-08-12 09:02:24.620 -----------------------------------------------
eclipse.buildId=I20120608-1200
java.version=1.6.0_13
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Framework arguments: -product com.ti.ccstudio.branding.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product com.ti.ccstudio.branding.product
!ENTRY org.eclipse.ui 2 0 2014-08-12 09:03:08.055
!MESSAGE Warnings while parsing the viewer contributions from the 'org.eclipse.ui.popupMenus' extension point
!SUBENTRY 1 org.eclipse.ui 2 0 2014-08-12 09:03:08.055
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.CEditorRulerActions/org.eclipse.cdt.debug.internal.ui.actions.CBreakpointPropertiesRulerActionDelegate'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.CEditorRulerActions/org.eclipse.cdt.debug.internal.ui.actions.EnableDisableBreakpointRulerActionDelegate'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.CEditorRulerActions/org.eclipse.cdt.debug.ui.actions.RulerCreateBreakpointInteractiveAction'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.AsmEditorRulerActions/org.eclipse.cdt.debug.internal.ui.actions.asm.CBreakpointPropertiesRulerActionDelegate'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.AsmEditorRulerActions/org.eclipse.cdt.debug.internal.ui.actions.asm.EnableDisableBreakpointRulerActionDelegate'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.AsmEditorRulerActions/org.eclipse.cdt.debug.ui.actions.asm.RulerCreateBreakpointInteractiveAction'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.dsf.ui', id='AUTOGEN:::org.eclipse.cdt.dsf.debug.ui.disassemblyRulerActions/org.eclipse.debug.ui.actions.RulerAddBreakpointAction'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.dsf.ui', id='org.eclipse.cdt.dsf.debug.ui.disassembly.commands.rulerToggleBreakpoint'
!ENTRY com.ti.gde.adapter.c6flo 1 0 2014-08-12 09:04:21.212
!MESSAGE install directory: C:\ti\ccsv5\eclipse
!MESSAGE blocksDirectory directory: C:\ti\ccsv5\ccs_base\c6flo_1.0.0.201209281235\Blocks
!ENTRY com.ti.gde.adapter.c6flo 1 0 2014-08-12 09:04:21.275
!MESSAGE xdcToolLocation directory: C:/ti/xdctools_3_30_03_47_core
!ENTRY com.ti.gde.diagram 1 0 2014-08-12 09:04:21.291
!MESSAGE GDE adapter found: com.ti.gde.adapter.c6flo.C6floAdapter Supporting extensions: [c6flo] PluginID=com.ti.gde.adapter.c6flo
!ENTRY org.eclipse.osgi 2 1 2014-08-12 09:04:53.264
!MESSAGE NLS unused message: Checking in: com.ti.ccstudio.project.ui.internal.messages
!ENTRY com.ti.common.project.core 4 0 2014-08-12 09:05:41.976
!MESSAGE org.eclipse.rtsc.project.core.extdiscovery.ExtensionSiteDiscoveryManager.findContributingSite(Lorg/osgi/framework/Bundle;)Ljava/io/File;
!STACK 0
java.lang.NoSuchMethodError: org.eclipse.rtsc.project.core.extdiscovery.ExtensionSiteDiscoveryManager.findContributingSite(Lorg/osgi/framework/Bundle;)Ljava/io/File;
at org.eclipse.rtsc.xdctools.ui.registry.RtscProductRegistry.findContributingSite(Unknown Source)
at org.eclipse.rtsc.xdctools.ui.registry.RtscProductRegistry.<init>(Unknown Source)
at org.eclipse.rtsc.xdctools.ui.registry.RtscProductRegistry.<clinit>(Unknown Source)
at org.eclipse.rtsc.xdctools.ui.utils.XDCUtils.getRtscPackageRepositories(Unknown Source)
at org.eclipse.rtsc.xdctools.ui.RTSCUtilsServer2.getRTSCPackageRepositories(Unknown Source)
at org.eclipse.rtsc.xdctools.managedbuild.core.RTSCServer.getPackageRepositories(RTSCServer.java:181)
at org.eclipse.rtsc.xdctools.managedbuild.core.products.RTSCProductDescriptor.getPackageRepositories(RTSCProductDescriptor.java:110)
at org.eclipse.rtsc.builddefinitions.dspbios.services.DSPBIOSProjectModificationCommandExtension$1.resolveLocation(DSPBIOSProjectModificationCommandExtension.java:89)
at com.ti.ccstudio.project.core.services.ProjectModifier$2.resolveLocation(ProjectModifier.java:678)
at com.ti.common.project.core.templates.IProjectTemplate$FileData.getLocation(IProjectTemplate.java:160)
at com.ti.ccstudio.project.core.services.ProjectModifier$CCSProjectModificationCommand.getInitializerData(ProjectModifier.java:498)
at com.ti.ccstudio.project.core.services.ProjectCreator.internalCreateCCSProject(ProjectCreator.java:783)
at com.ti.ccstudio.project.core.services.ProjectCreator.access$0(ProjectCreator.java:755)
at com.ti.ccstudio.project.core.services.ProjectCreator$1.run(ProjectCreator.java:718)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
at com.ti.ccstudio.project.core.services.ProjectCreator.createCCSProject(ProjectCreator.java:716)
at com.ti.ccstudio.project.ui.internal.wizards.project.NewCCSProjectWizard.createProject(NewCCSProjectWizard.java:204)
at com.ti.ccstudio.project.ui.internal.wizards.project.NewCCSProjectWizard.access$0(NewCCSProjectWizard.java:196)
at com.ti.ccstudio.project.ui.internal.wizards.project.NewCCSProjectWizard$1.execute(NewCCSProjectWizard.java:153)
at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:106)
at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1028)
at com.ti.ccstudio.project.ui.internal.wizards.project.NewCCSProjectWizard.performFinish(NewCCSProjectWizard.java:150)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.actions.NewWizardShortcutAction.run(NewWizardShortcutAction.java:135)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
!ENTRY org.eclipse.cdt.core 1 0 2014-08-12 09:05:42.727
!MESSAGE Indexed 'HelloWorldDSP' (0 sources, 0 headers) in 0.02 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0.00%)
!ENTRY com.ti.common.project.core 4 0 2014-08-12 09:20:53.905
!MESSAGE Could not initialize class org.eclipse.rtsc.xdctools.ui.registry.RtscProductRegistry
!STACK 0
java.lang.NoClassDefFoundError: Could not initialize class org.eclipse.rtsc.xdctools.ui.registry.RtscProductRegistry
!ENTRY org.eclipse.cdt.core 1 0 2014-08-12 09:20:53.952
!MESSAGE Indexed 'HelloWorldDSP' (0 sources, 0 headers) in 0.00 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0.00%)
I've also tried the Basic Examples --> Hello World template and was able to create that project with no project creation errors. However, at this point I'm stuck at the starting line for the OMAPL138 hello world example.
Any suggestions for environment settings, java version/update requirements are appreciated.
Doug
