Other Parts Discussed in Thread: CCSTUDIO
I am using CCS 3.3.82.13 with normal User privileges on Windows XP SP2. When I load a Project, I get the following warnings in pop-up windows:
"CRegistryInfo::GetSABiosRegKey() could not find BIOS registry entries."
and
"Incorrect %BIOS_INSTALL_DIR% variable setting detected."
I do not get these warnings when running as an Administrator.
My TI Apps engineer told me to use regedt32 to modify some registry entries to give "User" "Full Permission". But modifying HKEY_CLASSES_ROOT in this way, causes irrepairable damage to my computers. Specifically, many of my machine services cannot run including my wireless application. The only way to "fix" these problems is to restore the registry, just changing the permissions back is not enough.
My local IT person said:
"Modifying permissions at the root level of the Registry (HKCR) will overwrite other special permissions that are assigned down level. The vendor should provide you a listing of the specific keys their application needs permissions to and I bet you won’t have the other side effects."
But so far my TI Apps engineer has been unable to get any information on the specific keys.
Can anyone help me out?
Thanks!
Kevin Kaster
