5.1.1.00031 crashes always as soon as it starts running in debugger mode .
Other Parts Discussed in Thread: CCSTUDIO
I have some trouble working with CCS Debugger. As soon as CCS starts running in the debugger mode it crashes with the exception logs generated which I have shared with this ticket. I have also re-installed the CCS on my desktop again but still the CCS crashes with the same set of exception logs.
I am running on the desktop with the following Configuration :
1.  Windows 7 Professional Service pack 1
2. Intel i-5 - 3470 CPU @ 3.20 GHz.
3. RAM : 32 GB
4. 32 bit operating System.
These are the error logs that I got after the CCS crashes :
# An unexpected error has been detected by Java Runtime Environment:
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x31664778, pid=3460, tid=2256
# Java VM: Java HotSpot(TM) Client VM (11.3-b02 mixed mode windows-x86)
# Problematic frame:
# C  0x31664778
# If you would like to submit a bug report, please visit:
#   http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
---------------  T H R E A D  ---------------
Current thread (0x005c9000):  JavaThread "main" [_thread_in_native, id=2256, stack(0x00030000,0x00130000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x00000000
Registers:
EAX=0x00000000, EBX=0x0012f198, ECX=0x00000009, EDX=0x00278504
ESP=0x0012f184, EBP=0x0012f19c, ESI=0x8000ffff, EDI=0x00000000
EIP=0x31664778, EFLAGS=0x00210246
Top of Stack: (sp=0x0012f184)
0x0012f184:   0123b788 0122da48 0124d46c 316646c4
0x0012f194:   0124d464 00000000 0012f1a4 316646a6
0x0012f1a4:   0012f1b8 64de0f3b 00278504 0122da48
0x0012f1b4:   0124d464 0012f1cc 64c6484b 000003e8
0x0012f1c4:   00000001 0124d464 0012f1fc 64c64963
0x0012f1d4:   000003e8 00000001 8b127280 0012f284
0x0012f1e4:   00000113 00000000 0124d46c 0012f29c
0x0012f1f4:   64e5b2a8 00000000 0012f208 652ff2e0
Instructions: (pc=0x31664778)
0x31664768:   8b f8 85 ff 0f 84 b0 54 1c 00 33 f6 39 37 74 0a
0x31664778:   8b 0f 8b c6 5f 5e 89 0b 5b c3 6a 10 6a 08 ff 15
Stack: [0x00030000,0x00130000],  sp=0x0012f184,  free space=1020k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C  0x31664778
C  0x316646a6
C  0x64de0f3b
C  0x64c6484b
C  0x64c64963
C  0x652ff2e0
C  [USER32.dll+0x1c4e7]
C  [USER32.dll+0x1c5e7]
C  [USER32.dll+0x1cc19]
C  [USER32.dll+0x1cc70]
C  [swt-win32-3738.dll+0x39da]
J  org.eclipse.swt.internal.win32.OS.DispatchMessageW(Lorg/eclipse/swt/internal/win32/MSG;)I
J  org.eclipse.swt.widgets.Display.readAndDispatch()Z
j  org.eclipse.ui.internal.Workbench.runEventLoop(Lorg/eclipse/jface/window/Window$IExceptionHandler;Lorg/eclipse/swt/widgets/Display;)V+9
j  org.eclipse.ui.internal.Workbench.runUI()I+555
j  org.eclipse.ui.internal.Workbench.access$4(Lorg/eclipse/ui/internal/Workbench;)I+1
j  org.eclipse.ui.internal.Workbench$7.run()V+55
j  org.eclipse.core.databinding.observable.Realm.runWithDefault(Lorg/eclipse/core/databinding/observable/Realm;Ljava/lang/Runnable;)V+12
j  org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+18
j  org.eclipse.ui.PlatformUI.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+2
j  org.eclipse.ui.internal.ide.application.IDEApplication.start(Lorg/eclipse/equinox/app/IApplicationContext;)Ljava/lang/Object;+108
j  org.eclipse.equinox.internal.app.EclipseAppHandle.run(Ljava/lang/Object;)Ljava/lang/Object;+135
j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(Ljava/lang/Object;)Ljava/lang/Object;+103
j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ljava/lang/Object;)Ljava/lang/Object;+29
j  org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/lang/Object;)Ljava/lang/Object;+149
j  org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/lang/String;Ljava/lang/Runnable;)Ljava/lang/Object;+183
v  ~StubRoutines::call_stub
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j  sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+0
j  sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+87
j  sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+6
j  java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+161
j  org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lang/String;[Ljava/net/URL;)V+211
j  org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/String;)V+126
j  org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+4
---------------  P R O C E S S  ---------------
Java Threads: ( => current thread )
  0x31195800 JavaThread "[ThreadPool Manager] - Idle Thread" daemon [_thread_blocked, id=2492, stack(0x39640000,0x39740000)]
  0x31194c00 JavaThread "Scripting Console - Rhino" [_thread_blocked, id=684, stack(0x2fa70000,0x2fb70000)]
  0x31194000 JavaThread "Timer-0" daemon [_thread_blocked, id=3676, stack(0x33c80000,0x33d80000)]
  0x31193c00 JavaThread "31995269@qtp-30472005-1 - Acceptor0 SelectChannelConnector@127.0.0.1:49564" [_thread_in_native, id=2388, stack(0x33a80000,0x33b80000)]
  0x31193400 JavaThread "26681190@qtp-30472005-0" [_thread_blocked, id=4024, stack(0x33980000,0x33a80000)]
  0x31193000 JavaThread "Worker-11" [_thread_blocked, id=3616, stack(0x33880000,0x33980000)]
  0x2da6e000 JavaThread "Worker-9" [_thread_in_native, id=704, stack(0x33480000,0x33580000)]
  0x2da6dc00 JavaThread "Worker-8" [_thread_blocked, id=548, stack(0x33380000,0x33480000)]
  0x2da6d400 JavaThread "Worker-7" [_thread_blocked, id=1108, stack(0x33280000,0x33380000)]
  0x2da6c800 JavaThread "Worker-5" [_thread_blocked, id=3852, stack(0x33080000,0x33180000)]
  0x2da6c400 JavaThread "Worker-4" [_thread_blocked, id=2868, stack(0x32f80000,0x33080000)]
  0x2da6c000 JavaThread "Worker-3" [_thread_blocked, id=412, stack(0x32e80000,0x32f80000)]
  0x2da6ac00 JavaThread "Worker-2" [_thread_blocked, id=1212, stack(0x32d80000,0x32e80000)]
  0x2da6b400 JavaThread "Bundle File Closer" daemon [_thread_blocked, id=1140, stack(0x327e0000,0x328e0000)]
  0x2d977400 JavaThread "Worker-1" [_thread_in_native, id=2536, stack(0x30b60000,0x30c60000)]
  0x2ccdd000 JavaThread "Worker-0" [_thread_blocked, id=2464, stack(0x2d480000,0x2d580000)]
  0x2d69ac00 JavaThread "Worker-JM" [_thread_blocked, id=2620, stack(0x2da80000,0x2db80000)]
  0x2ccf0800 JavaThread "[Timer] - Main Queue Handler" daemon [_thread_blocked, id=3608, stack(0x2d580000,0x2d680000)]
  0x2ccf7c00 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=4088, stack(0x2d380000,0x2d480000)]
  0x2cc53c00 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=392, stack(0x2d280000,0x2d380000)]
  0x2ccf1800 JavaThread "State Data Manager" daemon [_thread_blocked, id=2836, stack(0x2d180000,0x2d280000)]
  0x2cc78c00 JavaThread "Framework Active Thread" [_thread_blocked, id=1032, stack(0x2d080000,0x2d180000)]
  0x02021c00 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=3456, stack(0x2c980000,0x2ca80000)]
  0x0201d800 JavaThread "CompilerThread0" daemon [_thread_blocked, id=880, stack(0x2c880000,0x2c980000)]
  0x02018000 JavaThread "Attach Listener" daemon [_thread_blocked, id=1020, stack(0x2c780000,0x2c880000)]
  0x0200d800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=744, stack(0x2c680000,0x2c780000)]
  0x01ffd400 JavaThread "Finalizer" daemon [_thread_blocked, id=1576, stack(0x2c580000,0x2c680000)]
  0x01ff8c00 JavaThread "Reference Handler" daemon [_thread_blocked, id=3872, stack(0x2c480000,0x2c580000)]
=>0x005c9000 JavaThread "main" [_thread_in_native, id=2256, stack(0x00030000,0x00130000)]
Other Threads:
  0x01ff4000 VMThread [stack: 0x2c380000,0x2c480000] [id=2252]
  0x02022c00 WatcherThread [stack: 0x2ca80000,0x2cb80000] [id=1376]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
 def new generation   total 8128K, used 3464K [0x040e0000, 0x049b0000, 0x05e60000)
  eden space 7232K,  43% used [0x040e0000, 0x043f0f10, 0x047f0000)
  from space 896K,  36% used [0x048d0000, 0x04921270, 0x049b0000)
  to   space 896K,   0% used [0x047f0000, 0x047f0000, 0x048d0000)
 tenured generation   total 106844K, used 99917K [0x05e60000, 0x0c6b7000, 0x1c0e0000)
   the space 106844K,  93% used [0x05e60000, 0x0bff3400, 0x0bff3400, 0x0c6b7000)
 compacting perm gen  total 59648K, used 59487K [0x1c0e0000, 0x1fb20000, 0x2c0e0000)
   the space 59648K,  99% used [0x1c0e0000, 0x1faf7e60, 0x1faf8000, 0x1fb20000)
No shared spaces configured.
Dynamic libraries:
0x00400000 - 0x0040d000     C:\ti\ccsv5\eclipse\ccstudio.exe
0x77d50000 - 0x77e8c000     C:\Windows\SYSTEM32\ntdll.dll
0x77850000 - 0x77924000     C:\Windows\system32\kernel32.dll
0x75f10000 - 0x75f5b000     C:\Windows\system32\KERNELBASE.dll
0x763b0000 - 0x76479000     C:\Windows\system32\USER32.dll
0x779d0000 - 0x77a1e000     C:\Windows\system32\GDI32.dll
0x77e90000 - 0x77e9a000     C:\Windows\system32\LPK.dll
0x77930000 - 0x779cd000     C:\Windows\system32\USP10.dll
0x77710000 - 0x777bc000     C:\Windows\system32\msvcrt.dll
0x70160000 - 0x701e4000     C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.7601.18201_none_ec80f00e8593ece5\COMCTL32.dll
0x76310000 - 0x763b0000     C:\Windows\system32\ADVAPI32.dll
0x76480000 - 0x76499000     C:\Windows\SYSTEM32\sechost.dll
0x76250000 - 0x762f2000     C:\Windows\system32\RPCRT4.dll
0x77690000 - 0x776af000     C:\Windows\system32\IMM32.DLL
0x77eb0000 - 0x77f7c000     C:\Windows\system32\MSCTF.dll
0x72000000 - 0x7200d000     C:\ti\ccsv5\eclipse\plugins\org.eclipse.equinox.launcher.win32.win32.x86_1.1.100.v20110502\eclipse_1406.dll
0x75250000 - 0x75259000     C:\Windows\system32\VERSION.dll
0x74be0000 - 0x74c20000     C:\Windows\system32\uxtheme.dll
0x6e250000 - 0x6e267000     C:\Users\Administrator\AppData\Local\AskPartnerNetwork\Toolbar\Updater\IDC\IdcSrvStub.dll
0x77b50000 - 0x77ba7000     C:\Windows\system32\SHLWAPI.dll
0x73ee0000 - 0x73efc000     C:\Windows\system32\IPHLPAPI.DLL
0x76300000 - 0x76306000     C:\Windows\system32\NSI.dll
0x73e20000 - 0x73e27000     C:\Windows\system32\WINNSI.DLL
0x77ea0000 - 0x77ea5000     C:\Windows\system32\PSAPI.DLL
0x73940000 - 0x73952000     C:\Windows\system32\dhcpcsvc.DLL
0x76830000 - 0x76865000     C:\Windows\system32\WS2_32.dll
0x75220000 - 0x75241000     C:\Windows\system32\ntmarta.dll
0x76200000 - 0x76245000     C:\Windows\system32\WLDAP32.dll
0x766d0000 - 0x7682c000     C:\Windows\system32\ole32.dll
0x75cc0000 - 0x75ccc000     C:\Windows\system32\CRYPTBASE.dll
0x777c0000 - 0x77843000     C:\Windows\system32\CLBCatQ.DLL
0x76140000 - 0x761cf000     C:\Windows\system32\OLEAUT32.dll
0x6d800000 - 0x6da56000     C:\ti\ccsv5\eclipse\jre\bin\client\jvm.dll
0x743f0000 - 0x74422000     C:\Windows\system32\WINMM.dll
0x7c340000 - 0x7c396000     C:\ti\ccsv5\eclipse\jre\bin\MSVCR71.dll
0x75c40000 - 0x75c8c000     C:\Windows\system32\apphelp.dll
0x6d290000 - 0x6d298000     C:\ti\ccsv5\eclipse\jre\bin\hpi.dll
0x6d7b0000 - 0x6d7bc000     C:\ti\ccsv5\eclipse\jre\bin\verify.dll
0x6d330000 - 0x6d34f000     C:\ti\ccsv5\eclipse\jre\bin\java.dll
0x6d7f0000 - 0x6d7ff000     C:\ti\ccsv5\eclipse\jre\bin\zip.dll
0x757b0000 - 0x757c6000     C:\Windows\system32\CRYPTSP.dll
0x75550000 - 0x7558b000     C:\Windows\system32\rsaenh.dll
0x75e80000 - 0x75e97000     C:\Windows\system32\USERENV.dll
0x75db0000 - 0x75dbb000     C:\Windows\system32\profapi.dll
0x6d610000 - 0x6d623000     C:\ti\ccsv5\eclipse\jre\bin\net.dll
0x75770000 - 0x757ac000     C:\Windows\system32\mswsock.dll
0x75760000 - 0x75766000     C:\Windows\System32\wship6.dll
0x742a0000 - 0x742b0000     C:\Windows\system32\NLAapi.dll
0x70500000 - 0x70510000     C:\Windows\system32\napinsp.dll
0x704e0000 - 0x704f2000     C:\Windows\system32\pnrpnsp.dll
0x75630000 - 0x75674000     C:\Windows\system32\DNSAPI.dll
0x704d0000 - 0x704d8000     C:\Windows\System32\winrnr.dll
0x752e0000 - 0x752e5000     C:\Windows\System32\wshtcpip.dll
0x71380000 - 0x71386000     C:\Windows\system32\rasadhlp.dll
0x73bf0000 - 0x73c28000     C:\Windows\System32\fwpuclnt.dll
0x6d630000 - 0x6d639000     C:\ti\ccsv5\eclipse\jre\bin\nio.dll
0x2cfc0000 - 0x2d02e000     C:\ti\ccsv5\eclipse\configuration\org.eclipse.osgi\bundles\274\1\.cp\swt-win32-3738.dll
0x760c0000 - 0x7613b000     C:\Windows\system32\comdlg32.dll
0x74cb0000 - 0x74e4e000     C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_41e6975e2bd6f2b2\COMCTL32.dll
0x76870000 - 0x774ba000     C:\Windows\system32\SHELL32.dll
0x71390000 - 0x713e1000     C:\Windows\system32\WINSPOOL.DRV
0x774c0000 - 0x77682000     C:\Windows\system32\WININET.dll
0x75e70000 - 0x75e74000     C:\Windows\system32\api-ms-win-downlevel-user32-l1-1-0.dll
0x75f00000 - 0x75f04000     C:\Windows\system32\api-ms-win-downlevel-shlwapi-l1-1-0.dll
0x76080000 - 0x76084000     C:\Windows\system32\api-ms-win-downlevel-version-l1-1-0.dll
0x75ee0000 - 0x75ee3000     C:\Windows\system32\api-ms-win-downlevel-normaliz-l1-1-0.dll
0x764a0000 - 0x764a3000     C:\Windows\system32\normaliz.DLL
0x764b0000 - 0x766cb000     C:\Windows\system32\iertutil.dll
0x75ef0000 - 0x75ef5000     C:\Windows\system32\api-ms-win-downlevel-advapi32-l1-1-0.dll
0x75f60000 - 0x76080000     C:\Windows\system32\CRYPT32.dll
0x75da0000 - 0x75dac000     C:\Windows\system32\MSASN1.dll
0x74620000 - 0x74633000     C:\Windows\system32\dwmapi.dll
0x749d0000 - 0x74ac5000     C:\Windows\system32\propsys.dll
0x01a30000 - 0x01a36000     C:\ti\ccsv5\ccs_base\DebugServer\bin\win32\LibraryLoader.dll
0x6cf30000 - 0x6cfb7000     C:\Windows\WinSxS\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.6195_none_d09154e044272b9a\MSVCP80.dll
0x6ce90000 - 0x6cf2b000     C:\Windows\WinSxS\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.6195_none_d09154e044272b9a\MSVCR80.dll
0x2de30000 - 0x2e022000     C:\ti\ccsv5\ccs_base\common\bin\xerces-c_2_5_0.dll
0x2cd80000 - 0x2cda0000     C:\ti\ccsv5\ccs_base\common\bin\ti_logger.dll
0x2dbd0000 - 0x2dc45000     C:\ti\ccsv5\ccs_base\common\bin\C4DLL.DLL
0x01ab0000 - 0x01ac0000     C:\ti\ccsv5\ccs_base\common\bin\CCReg.dll
0x2dc90000 - 0x2dcd2000     C:\ti\ccsv5\ccs_base\common\bin\fsutil.dll
0x2cdd0000 - 0x2cdd8000     C:\ti\ccsv5\ccs_base\common\bin\fsutiljni.dll
0x2ce30000 - 0x2ce39000     C:\ti\ccsv5\ccs_base\common\bin\MiniDump.dll
0x2e130000 - 0x2e1c3000     C:\ti\ccsv5\ccs_base\common\bin\rtdx.dll
0x2e1f0000 - 0x2e360000     C:\ti\ccsv5\ccs_base\common\bin\setup_parser.dll
0x2ce60000 - 0x2ce6d000     C:\ti\ccsv5\ccs_base\common\bin\ti_targetdb_parser.dll
0x6ce00000 - 0x6ce8e000     C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57\MSVCP90.dll
0x721b0000 - 0x72253000     C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57\MSVCR90.dll
0x725f0000 - 0x725f8000     C:\ti\ccsv5\ccs_base\DebugServer\win32\javaxpcomglue.dll
0x69ae0000 - 0x69b0a000     C:\ti\ccsv5\ccs_base\DebugServer\win32\nspr4.dll
0x70340000 - 0x70347000     C:\Windows\system32\WSOCK32.dll
0x725e0000 - 0x725e7000     C:\ti\ccsv5\ccs_base\DebugServer\win32\plc4.dll
0x6cdf0000 - 0x6cdf7000     C:\ti\ccsv5\ccs_base\DebugServer\win32\plds4.dll
0x69a60000 - 0x69adb000     C:\ti\ccsv5\ccs_base\DebugServer\win32\sqlite3.dll
0x69a40000 - 0x69a54000     C:\ti\ccsv5\ccs_base\DebugServer\win32\nssutil3.dll
0x69a10000 - 0x69a36000     C:\ti\ccsv5\ccs_base\DebugServer\win32\softokn3.dll
0x68bf0000 - 0x68c8d000     C:\ti\ccsv5\ccs_base\DebugServer\win32\nss3.dll
0x699e0000 - 0x69a01000     C:\ti\ccsv5\ccs_base\DebugServer\win32\ssl3.dll
0x699c0000 - 0x699d8000     C:\ti\ccsv5\ccs_base\DebugServer\win32\smime3.dll
0x67380000 - 0x67d6e000     C:\ti\ccsv5\ccs_base\DebugServer\win32\xul.dll
0x672a0000 - 0x67371000     C:\ti\ccsv5\ccs_base\DebugServer\win32\js3250.dll
0x70350000 - 0x70355000     C:\Windows\system32\MSIMG32.dll
0x6f900000 - 0x6f9eb000     C:\Windows\system32\DBGHELP.DLL
0x6d4b0000 - 0x6d4b7000     C:\ti\ccsv5\ccs_base\DebugServer\win32\xpcom.dll
0x73a00000 - 0x73a0d000     C:\Windows\system32\dhcpcsvc6.DLL
0x2edc0000 - 0x2ef5d000     C:\ti\ccsv5\ccs_base\DebugServer\win32\components\mdex.dll
0x73f40000 - 0x73f51000     C:\Windows\system32\NETAPI32.dll
0x73f30000 - 0x73f39000     C:\Windows\system32\netutils.dll
0x75a70000 - 0x75a89000     C:\Windows\system32\srvcli.dll
0x73f20000 - 0x73f2f000     C:\Windows\system32\wkscli.dll
0x2ef60000 - 0x2f1dd000     C:\ti\ccsv5\ccs_base\DebugServer\license\mdexutil.dll
0x71240000 - 0x71249000     C:\Windows\system32\snmpapi.dll
0x77bb0000 - 0x77d4d000     C:\Windows\system32\SETUPAPI.dll
0x76090000 - 0x760b7000     C:\Windows\system32\CFGMGR32.dll
0x75dc0000 - 0x75dd2000     C:\Windows\system32\DEVOBJ.dll
0x71860000 - 0x7186a000     C:\Windows\system32\wbem\wbemprox.dll
0x71aa0000 - 0x71afc000     C:\Windows\system32\wbemcomn.dll
0x75eb0000 - 0x75ede000     C:\Windows\system32\WINTRUST.dll
0x75d30000 - 0x75d3e000     C:\Windows\system32\RpcRtRemote.dll
0x717b0000 - 0x717bf000     C:\Windows\system32\wbem\wbemsvc.dll
0x71910000 - 0x719a6000     C:\Windows\system32\wbem\fastprox.dll
0x71840000 - 0x71858000     C:\Windows\system32\NTDSAPI.dll
0x691f0000 - 0x691f3000     C:\Windows\system32\icmp.Dll
0x75c20000 - 0x75c3b000     C:\Windows\system32\SspiCli.dll
0x2f300000 - 0x2f31d000     C:\ti\ccsv5\eclipse\configuration\org.eclipse.osgi\bundles\274\1\.cp\swt-gdip-win32-3738.dll
0x74840000 - 0x749d0000     C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.18455_none_72d576ad8665e853\gdiplus.dll
0x744c0000 - 0x745f0000     C:\Windows\system32\WindowsCodecs.dll
0x2f3a0000 - 0x2f3ae000     C:\ti\ccsv5\eclipse\configuration\org.eclipse.osgi\bundles\85\1\.cp\os\win32\x86\localfile_1_0_0.dll
VM Arguments:
jvm_args: -Dosgi.requiredJavaVersion=1.5 -Xms40m -Xmx384m -XX:ErrorFile=C:\Users\ADMINI~1\AppData\Local\.TI\213602635\0\dmp\hs_err_%p.log -XX:MaxPermSize=256M
java_command: <unknown>
Launcher Type: generic
Environment Variables:
PATH=C:\ti\ccsv5\ccs_base\common\bin;C:\ti\ccsv5\ccs_base\common\uscif;C:\ti\ccsv5\ccs_base\DebugServer\license;C:/ti/ccsv5/eclipse/jre/bin/client;C:/ti/ccsv5/eclipse/jre/bin;C:/ti/ccsv5/eclipse/jre/lib/i386;C:/Program Files/Texas Instruments/xdctools_3_23_03_53;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\TortoiseSVN\bin;C:/Program Files/Texas Instruments/xdctools_3_23_03_53;C:\ti\ccsv5\eclipse;;C:\ti\ccsv5\ccs_base\emulation\analysis\bin\.;C:\ti\ccsv5\ccs_base\emulation\analysis\bin\../xmldb/aet_config;C:\ti\ccsv5\ccs_base\emulation\analysis\bin\../xmldb/trace_config/setup;C:\ti\ccsv5\ccs_base\emulation\analysis\bin\../xmldb/trace_config/devices;C:\ti\ccsv5\ccs_base\emulation\analysis\bin\../../../common/bin;C:\ti\ccsv5\ccs_base\emulation\analysis\bin\../../../common/uscif;C:\ti\ccsv5\ccs_base\emulation\analysis\bin\../../tpi
USERNAME=Administrator
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 6 Model 58 Stepping 9, GenuineIntel
---------------  S Y S T E M  ---------------
OS: Windows NT 6.1 Build 7601 Service Pack 1
CPU:total 4 (8 cores per cpu, 2 threads per core) family 6 model 10 stepping 9, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, ht
Memory: 4k page, physical 2097151k(1787900k free), swap 4194303k(4194303k free)
vm_info: Java HotSpot(TM) Client VM (11.3-b02) for windows-x86 JRE (1.6.0_13-b03), built on Mar  9 2009 01:15:24 by "java_re" with MS VC++ 7.1
time: Fri Sep 26 09:47:56 2014
elapsed time: 417 seconds
Anybody,Please help me in resolving this issue. Please let me know if you need more information.
Mohit
