I see that the GEL function GEL_AddSrc function is no longer supported is there any support for adding source directories to search via the DSS API?
There is no specific DSS API for this. What is your use case? Are you running a DSS script from within the CCS IDE via the Scripting Console?
thanks
ki
Yes, when you launch code composer from DSS, I don't know how the software decides where to look for source. Currently, it just always looks into some directory that I used a while ago. Right now I can't even seem to update this from the GUI (Edit source lookup). Ideally, I wouldn't even need to do this and could either set this in code, or have it look in the current directory. Do you know where code composer looks for source when launched from DSS, and how to change this, either through the GUI or script?
Murph612 said:ight now I can't even seem to update this from the GUI (Edit source lookup).
See the below presentation starting at slide 53:
software-dl.ti.com/ccs/esd/training/CCSv6-TipsAndTricks.pptx
There isn't a way to script this however.
ki
