CCSv6.01.00040: CCS stops responding at Build Project: (50%)
Guru 20045 points
Other Parts Discussed in Thread: CCSTUDIO
I am running CCSv6.01.00040 on windows 7.
Every once and a while (actually quite often) CCSv6.01.00040 stops responding when the build reaches 50%, i.e. Build Project (50%).  It quite annoying since I have to close and restart CCS.  Its even more annoying since I have another issue with CCS taking 35 seconds to start up (http://e2e.ti.com/support/development_tools/code_composer_studio/f/81/t/374079.aspx?pi296443=1)
To perform a build,  I select the project and then select Build Project from the Project Menu.  I am in debug mode when CCS stops responding.  Also, I am using a XDS100v2 debugger.
I believe the build reaches 50% almost immediately after selecting Build Project.
Does anyone have a fix for this issue?
Stephen
Update: In addition, I believe this issue only happens in debug mode when I am connected to the target.
Update #2: The compiler version is v6.2.8.  Actually, the project's advanced settings show TI v6.2.8 [TI v6.2.9].
  • Hi Stephen,
    Try creating a new workspace and build your project there. Let me know what you observe.
    Gautam
    So CCS stops responding only when you try to build the project when you are connected to the target and in a debug session, is that corect? If you teminate the debug session and then Build Project does it build fast?
    Which target are you connected to?
    Does this issue happen only with this one project or with several? If it is a small project you could share, we could see if the behavior is reproducible at our end.
  • Hello AartiG,
    Ki told me to do a Eclipse java thread dump when happened again.  Please see Java thread dump below.
    Stephen
    2014-11-05 13:04:29
    Full thread dump Java HotSpot(TM) Client VM (24.71-b01 mixed mode, sharing):
    "RMI TCP Connection(idle)" daemon prio=6 tid=0x0683fc00 nid=0x2b64 waiting on condition [0x3d2df000]
    java.lang.Thread.State: TIMED_WAITING (parking)
    at sun.misc.Unsafe.park(Native Method)
    - parking to wait for <0x11446eb8> (a java.util.concurrent.SynchronousQueue$TransferStack)
    at java.util.concurrent.locks.LockSupport.parkNanos(Unknown Source)
    at java.util.concurrent.SynchronousQueue$TransferStack.awaitFulfill(Unknown Source)
    at java.util.concurrent.SynchronousQueue$TransferStack.transfer(Unknown Source)
    at java.util.concurrent.SynchronousQueue.poll(Unknown Source)
    at java.util.concurrent.ThreadPoolExecutor.getTask(Unknown Source)
    at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
    at java.lang.Thread.run(Unknown Source)
    Locked ownable synchronizers:
    - None
    "JMX server connection timeout 568" daemon prio=6 tid=0x0683bc00 nid=0x2940 in Object.wait() [0x3d1df000]
    java.lang.Thread.State: TIMED_WAITING (on object monitor)
    at java.lang.Object.wait(Native Method)
    at com.sun.jmx.remote.internal.ServerCommunicatorAdmin$Timeout.run(Unknown Source)
    - locked <0x11600538> (a [I)
    - None
    "RMI Scheduler(0)" daemon prio=6 tid=0x0a017800 nid=0x2a08 waiting on condition [0x3d01f000]
    - parking to wait for <0x114574c0> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
    at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(Unknown Source)
    at java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(Unknown Source)
    - None
    "RMI TCP Connection(1)-10.2.0.21" daemon prio=6 tid=0x0a014c00 nid=0x28a4 runnable [0x3cf1f000]
    java.lang.Thread.State: RUNNABLE
    at java.net.SocketInputStream.socketRead0(Native Method)
    at java.net.SocketInputStream.read(Unknown Source)
    at java.io.BufferedInputStream.fill(Unknown Source)
    at java.io.BufferedInputStream.read(Unknown Source)
    - locked <0x115a5de8> (a java.io.BufferedInputStream)
    at java.io.FilterInputStream.read(Unknown Source)
    at sun.rmi.transport.tcp.TCPTransport.handleMessages(Unknown Source)
    at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(Unknown Source)
    at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(Unknown Source)
    - <0x11573010> (a java.util.concurrent.ThreadPoolExecutor$Worker)
    "RMI TCP Accept-0" daemon prio=6 tid=0x0a014800 nid=0x26c0 runnable [0x3ce1f000]
    at java.net.DualStackPlainSocketImpl.accept0(Native Method)
    at java.net.DualStackPlainSocketImpl.socketAccept(Unknown Source)
    at java.net.AbstractPlainSocketImpl.accept(Unknown Source)
    at java.net.PlainSocketImpl.accept(Unknown Source)
    - locked <0x1145b0a0> (a java.net.SocksSocketImpl)
    at java.net.ServerSocket.implAccept(Unknown Source)
    at java.net.ServerSocket.accept(Unknown Source)
    at sun.management.jmxremote.LocalRMIServerSocketFactory$1.accept(Unknown Source)
    at sun.rmi.transport.tcp.TCPTransport$AcceptLoop.executeAcceptLoop(Unknown Source)
    at sun.rmi.transport.tcp.TCPTransport$AcceptLoop.run(Unknown Source)
    - None
    "org.eclipse.cdt.internal.ui.text.CReconciler" daemon prio=2 tid=0x0a015800 nid=0x2a5c in Object.wait() [0x3c5bf000]
    at org.eclipse.jface.text.reconciler.AbstractReconciler$BackgroundThread.run(AbstractReconciler.java:179)
    - locked <0x146800d0> (a org.eclipse.jface.text.reconciler.DirtyRegionQueue)
    - None
    "org.eclipse.cdt.internal.ui.text.CReconciler" daemon prio=2 tid=0x0a014000 nid=0x23bc in Object.wait() [0x3cadf000]
    - locked <0x1db95480> (a org.eclipse.jface.text.reconciler.DirtyRegionQueue)
    - None
    "org.eclipse.cdt.internal.ui.text.CReconciler" daemon prio=2 tid=0x0a015400 nid=0x2164 in Object.wait() [0x3c99f000]
    - locked <0x1db0f740> (a org.eclipse.jface.text.reconciler.DirtyRegionQueue)
    - None
    "org.eclipse.cdt.internal.ui.text.CReconciler" daemon prio=2 tid=0x0a016800 nid=0x1fd4 in Object.wait() [0x3c6bf000]
    - locked <0x1da57be0> (a org.eclipse.jface.text.reconciler.DirtyRegionQueue)
    - None
    "org.eclipse.cdt.internal.ui.text.CReconciler" daemon prio=2 tid=0x099ec800 nid=0x185c in Object.wait() [0x1055f000]
    - locked <0x1d579bf8> (a org.eclipse.jface.text.reconciler.DirtyRegionQueue)
    - None
    "org.eclipse.cdt.internal.ui.text.CReconciler" daemon prio=2 tid=0x099ed800 nid=0x20f4 in Object.wait() [0x1035f000]
    - locked <0x1d479360> (a org.eclipse.jface.text.reconciler.DirtyRegionQueue)
    - None
    "org.eclipse.jface.text.reconciler.MonoReconciler" daemon prio=2 tid=0x099ed400 nid=0x1ddc in Object.wait() [0x1045f000]
    - locked <0x1d27de98> (a org.eclipse.jface.text.reconciler.DirtyRegionQueue)
    - None
    "TimerQueue" daemon prio=6 tid=0x099ebc00 nid=0xbe8 waiting on condition [0x0ff3f000]
    java.lang.Thread.State: WAITING (parking)
    - parking to wait for <0x1d1d3f00> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
    at java.util.concurrent.locks.LockSupport.park(Unknown Source)
    at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(Unknown Source)
    at java.util.concurrent.DelayQueue.take(Unknown Source)
    at javax.swing.TimerQueue.run(Unknown Source)
    - <0x1d1e43d8> (a java.util.concurrent.locks.ReentrantLock$NonfairSync)
    "Target Capture" prio=6 tid=0x099eb400 nid=0x16f0 in Object.wait() [0x0f31f000]
    at com.ti.dvt.debug.server.extensions.ExtDspUser$Listener_OnMemoryUpdate.waitForResponse(ExtDspUser.java:105)
    - locked <0x1d0f4a20> (a com.ti.dvt.debug.server.extensions.ExtDspUser$Listener_OnMemoryUpdate)
    at com.ti.dvt.debug.server.extensions.ExtDspUser.syncMemoryRead(ExtDspUser.java:532)
    - locked <0x1cf21ae8> (a com.ti.dvt.debug.server.extensions.ExtDspUser)
    at com.ti.dvt.ccstudioideadapter.CCStudioIDECPUAdapter.readData(CCStudioIDECPUAdapter.java:1111)
    at com.ti.dvt.ccstudioideadapter.CCStudioIDECPUAdapter.readMemory(CCStudioIDECPUAdapter.java:1066)
    at com.ti.dvt.ideadapter.IDECPU.readMemory(IDECPU.java:735)
    at com.ti.dvt.datamodel.ccsgraphs.CCSGraphsJtagDataSource.readSingleBlock(CCSGraphsJtagDataSource.java:307)
    at com.ti.dvt.datamodel.ccsgraphs.CCSGraphsJtagDataSource.access$3(CCSGraphsJtagDataSource.java:284)
    at com.ti.dvt.datamodel.ccsgraphs.CCSGraphsJtagDataSource$TargetReaderThread.readMemory(CCSGraphsJtagDataSource.java:450)
    at com.ti.dvt.datamodel.ccsgraphs.CCSGraphsJtagDataSource$TargetReaderThread.run(CCSGraphsJtagDataSource.java:486)
    - <0x1d13d3d8> (a java.util.concurrent.locks.ReentrantLock$FairSync)
    "Target Capture" prio=6 tid=0x099ea800 nid=0x13f4 waiting on condition [0x0f11f000]
    java.lang.Thread.State: TIMED_WAITING (sleeping)
    at java.lang.Thread.sleep(Native Method)
    at com.ti.dvt.datamodel.ccsgraphs.CCSGraphsJtagDataSource$TargetReaderThread.run(CCSGraphsJtagDataSource.java:530)
    - None
    "AWT-Windows" daemon prio=6 tid=0x099eac00 nid=0x14ec runnable [0x0f21f000]
    at sun.awt.windows.WToolkit.eventLoop(Native Method)
    at sun.awt.windows.WToolkit.run(Unknown Source)
    - None
    "Java2D Disposer" daemon prio=10 tid=0x06840000 nid=0x1140 in Object.wait() [0x0ee4f000]
    java.lang.Thread.State: WAITING (on object monitor)
    at java.lang.ref.ReferenceQueue.remove(Unknown Source)
    - locked <0x1d0e1748> (a java.lang.ref.ReferenceQueue$Lock)
    at sun.java2d.Disposer.run(Unknown Source)
    - None
    "Continuous Refresh Thread" daemon prio=6 tid=0x09c67400 nid=0xd6c in Object.wait() [0x0ed4f000]
    at java.lang.Object.wait(Object.java:503)
    at java.util.TimerThread.mainLoop(Unknown Source)
    - locked <0x1d03fc90> (a java.util.TaskQueue)
    at java.util.TimerThread.run(Unknown Source)
    - None
    "Worker-14" prio=6 tid=0x09c65400 nid=0x12b0 in Object.wait() [0x0da7f000]
    at org.eclipse.core.internal.jobs.WorkerPool.sleep(WorkerPool.java:188)
    - locked <0x19478e90> (a org.eclipse.core.internal.jobs.WorkerPool)
    at org.eclipse.core.internal.jobs.WorkerPool.startJob(WorkerPool.java:220)
    at org.eclipse.core.internal.jobs.Worker.run(Worker.java:50)
    - None
    "Worker-13" prio=6 tid=0x09c66000 nid=0x440 in Object.wait() [0x0d93f000]
    - None
    "SystemAnalyzer.stringQueue" prio=6 tid=0x099ea000 nid=0x854 in Object.wait() [0x1016f000]
    at com.ti.uia.autostart.ConsoleMonitor$ConsoleStringHandler.run(ConsoleMonitor.java:38)
    - locked <0x1cedff90> (a com.ti.uia.autostart.ConsoleMonitor$ConsoleStringHandler)
    - None
    "pool-1-thread-1" prio=6 tid=0x0a017400 nid=0x1a7c in Object.wait() [0x0e7ff000]
    at org.eclipse.core.internal.jobs.Semaphore.acquire(Semaphore.java:39)
    - locked <0x14684200> (a org.eclipse.core.internal.jobs.Semaphore)
    at org.eclipse.core.internal.jobs.OrderedLock.doAcquire(OrderedLock.java:176)
    at org.eclipse.core.internal.jobs.OrderedLock.acquire(OrderedLock.java:110)
    at org.eclipse.core.internal.jobs.OrderedLock.acquire(OrderedLock.java:84)
    at org.eclipse.core.internal.resources.WorkManager.checkIn(WorkManager.java:119)
    at org.eclipse.core.internal.resources.Workspace.prepareOperation(Workspace.java:2283)
    at org.eclipse.core.internal.resources.Marker.setAttribute(Marker.java:234)
    at org.eclipse.core.internal.resources.Marker.setAttribute(Marker.java:223)
    at com.ti.ccstudio.debug.internal.breakpoint.utils.CCSBreakpointUtils.setIconMask(CCSBreakpointUtils.java:196)
    at com.ti.ccstudio.debug.internal.breakpoint.BreakpointManagerListener.doClearTriggeredBps(BreakpointManagerListener.java:601)
    at com.ti.ccstudio.debug.internal.breakpoint.BreakpointManagerListener.handleTargetRunning(BreakpointManagerListener.java:575)
    at com.ti.ccstudio.debug.internal.breakpoint.BreakpointManagerListener.access$3(BreakpointManagerListener.java:574)
    at com.ti.ccstudio.debug.internal.breakpoint.BreakpointManagerListener$4$1.run(BreakpointManagerListener.java:258)
    - <0x1cee0068> (a java.util.concurrent.ThreadPoolExecutor$Worker)
    "Thread-30" daemon prio=6 tid=0x0a016000 nid=0x12a8 runnable [0x00000000]
    - None
    "com.ti.ccstudio.debug.debugModel - 0" prio=6 tid=0x06839400 nid=0x16b4 in Object.wait() [0x090af000]
    - locked <0x14684518> (a org.eclipse.core.internal.jobs.Semaphore)
    at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2340)
    at com.ti.ccstudio.debug.internal.breakpoint.BreakpointManagerListener.handleBreakpointChanged(BreakpointManagerListener.java:547)
    at com.ti.ccstudio.debug.internal.breakpoint.BreakpointManagerListener$8$1.safeRun(BreakpointManagerListener.java:367)
    at com.ti.ccstudio.debug.SafeRunnable.run(SafeRunnable.java:30)
    at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
    at java.util.concurrent.FutureTask.run(Unknown Source)
    at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source)
    at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
    - <0x1cc73220> (a java.util.concurrent.ThreadPoolExecutor$Worker)
    "[ThreadPool Manager] - Idle Thread" daemon prio=6 tid=0x0683b000 nid=0x1210 in Object.wait() [0x0ba1f000]
    at org.eclipse.equinox.internal.util.impl.tpt.threadpool.Executor.run(Executor.java:106)
    - locked <0x1c966818> (a org.eclipse.equinox.internal.util.impl.tpt.threadpool.Executor)
    - None
    "Worker-10" prio=6 tid=0x09c64c00 nid=0x538 in Object.wait() [0x0d12f000]
    - None
    "Worker-9" prio=6 tid=0x09c64800 nid=0x14ac in Object.wait() [0x0cfef000]
    at org.eclipse.ui.internal.Semaphore.acquire(Semaphore.java:43)
    - locked <0x146845d0> (a org.eclipse.ui.internal.Semaphore)
    at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:168)
    at org.eclipse.swt.widgets.Display.syncExec(Display.java:4688)
    at com.ti.dvt.util.SolutionHelper.processPendingProbePointRegistration(SolutionHelper.java:659)
    at com.ti.dvt.util.SolutionHelper.onIDECPUEvent(SolutionHelper.java:466)
    at com.ti.dvt.ideadapter.IDECPU.fireEvent(IDECPU.java:1109)
    at com.ti.dvt.ideadapter.IDECPU.fireEvent(IDECPU.java:1084)
    at com.ti.dvt.ideadapter.AbstractIDECPUAdapter.targetProgramLoaded(AbstractIDECPUAdapter.java:122)
    at com.ti.dvt.ccstudioideadapter.CCStudioIDECPUAdapter.handleSyncEvent(CCStudioIDECPUAdapter.java:360)
    at com.ti.dvt.ccstudioideadapter.CCStudioIDECPUAdapter$MyDspUserListener.asyncHandleEvent(CCStudioIDECPUAdapter.java:178)
    at com.ti.dvt.debug.server.extensions.events.AsyncEventJob.run(AsyncEventJob.java:87)
    at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
    - None
    "Worker-8" prio=6 tid=0x09c64000 nid=0x6d0 in Object.wait() [0x0ceef000]
    - None
    "Worker-7" prio=6 tid=0x09c63c00 nid=0x52c in Object.wait() [0x0cdef000]
    - locked <0x14684660> (a org.eclipse.ui.internal.Semaphore)
    at com.ti.ccstudio.project.ui.internal.ProjectStateListener.showMarkersView(ProjectStateListener.java:166)
    at com.ti.ccstudio.project.ui.internal.ProjectStateListener.onProjectBuild_Post(ProjectStateListener.java:89)
    at com.ti.common.project.core.internal.events.ProjectStateMonitor$ResourceChangeListener$6.visit(ProjectStateMonitor.java:332)
    at com.ti.common.project.core.internal.events.ProjectStateMonitor.notifyListeners(ProjectStateMonitor.java:600)
    at com.ti.common.project.core.internal.events.ProjectStateMonitor.access$2(ProjectStateMonitor.java:594)
    at com.ti.common.project.core.internal.events.ProjectStateMonitor$ResourceChangeListener.resourceChanged(ProjectStateMonitor.java:330)
    at org.eclipse.core.internal.events.NotificationManager$1.run(NotificationManager.java:291)
    at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
    at org.eclipse.core.internal.events.NotificationManager.notify(NotificationManager.java:285)
    at org.eclipse.core.internal.events.NotificationManager.broadcastChanges(NotificationManager.java:149)
    at org.eclipse.core.internal.resources.Workspace.broadcastBuildEvent(Workspace.java:382)
    at org.eclipse.core.internal.resources.Workspace.buildInternal(Workspace.java:523)
    at org.eclipse.core.internal.resources.Workspace.build(Workspace.java:433)
    at org.eclipse.ui.actions.BuildAction$1.runInWorkspace(BuildAction.java:305)
    at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:38)
    - None
    "Worker-6" prio=6 tid=0x0683d000 nid=0x19c4 in Object.wait() [0x0ccef000]
    at org.eclipse.core.internal.jobs.ThreadJob.waitForRun(ThreadJob.java:270)
    - locked <0x1dc6aa78> (a java.lang.Object)
    at org.eclipse.core.internal.jobs.ThreadJob.joinRun(ThreadJob.java:197)
    at org.eclipse.core.internal.jobs.ImplicitJobs.begin(ImplicitJobs.java:92)
    at org.eclipse.core.internal.jobs.JobManager.beginRule(JobManager.java:286)
    at org.eclipse.ui.internal.ide.ContentTypeDecorator.decorate(ContentTypeDecorator.java:57)
    at org.eclipse.ui.internal.decorators.LightweightDecoratorDefinition.decorate(LightweightDecoratorDefinition.java:269)
    at org.eclipse.ui.internal.decorators.LightweightDecoratorManager$LightweightRunnable.run(LightweightDecoratorManager.java:81)
    at org.eclipse.ui.internal.decorators.LightweightDecoratorManager.decorate(LightweightDecoratorManager.java:365)
    at org.eclipse.ui.internal.decorators.LightweightDecoratorManager.getDecorations(LightweightDecoratorManager.java:347)
    at org.eclipse.ui.internal.decorators.DecorationScheduler$1.ensureResultCached(DecorationScheduler.java:371)
    at org.eclipse.ui.internal.decorators.DecorationScheduler$1.run(DecorationScheduler.java:331)
    - None
    "org.eclipse.cdt.internal.ui.text.CReconciler" daemon prio=2 tid=0x0683f400 nid=0x1ba4 in Object.wait() [0x0c9af000]
    - locked <0x1b81d360> (a org.eclipse.jface.text.reconciler.DirtyRegionQueue)
    - None
    "org.eclipse.cdt.internal.ui.text.CReconciler" daemon prio=2 tid=0x0683e800 nid=0x1b9c in Object.wait() [0x0c6af000]
    - locked <0x1b7ab370> (a org.eclipse.jface.text.reconciler.DirtyRegionQueue)
    - None
    "org.eclipse.cdt.internal.ui.text.CReconciler" daemon prio=2 tid=0x0683e000 nid=0x1b64 in Object.wait() [0x0c5af000]
    - locked <0x1b852090> (a org.eclipse.jface.text.reconciler.DirtyRegionQueue)
    - None
    "org.eclipse.cdt.internal.ui.text.CReconciler" daemon prio=2 tid=0x0683d400 nid=0x1b7c in Object.wait() [0x0bf2f000]
    - locked <0x1b852110> (a org.eclipse.jface.text.reconciler.DirtyRegionQueue)
    - None
    "org.eclipse.cdt.internal.ui.text.CReconciler" daemon prio=2 tid=0x0683dc00 nid=0x1b74 in Object.wait() [0x0c4af000]
    - locked <0x1b852190> (a org.eclipse.jface.text.reconciler.DirtyRegionQueue)
    - None
    "DVT Disk Space Monitor" prio=6 tid=0x0683c000 nid=0x1ad4 runnable [0x0b38f000]
    at java.io.FileInputStream.readBytes(Native Method)
    at java.io.FileInputStream.read(Unknown Source)
    at java.io.BufferedInputStream.read1(Unknown Source)
    - locked <0x13578670> (a java.io.BufferedInputStream)
    at sun.nio.cs.StreamDecoder.readBytes(Unknown Source)
    at sun.nio.cs.StreamDecoder.implRead(Unknown Source)
    at sun.nio.cs.StreamDecoder.read(Unknown Source)
    - locked <0x1357a788> (a java.io.InputStreamReader)
    at java.io.InputStreamReader.read(Unknown Source)
    at java.io.BufferedReader.fill(Unknown Source)
    at java.io.BufferedReader.readLine(Unknown Source)
    at org.apache.commons.io.FileSystemUtils.performCommand(FileSystemUtils.java:409)
    at org.apache.commons.io.FileSystemUtils.freeSpaceWindows(FileSystemUtils.java:225)
    at org.apache.commons.io.FileSystemUtils.freeSpaceOS(FileSystemUtils.java:194)
    at org.apache.commons.io.FileSystemUtils.freeSpaceKb(FileSystemUtils.java:166)
    at com.ti.util.diskspacemonitor.DiskSpaceMonitor$DiskSpaceMonitorThread.run(DiskSpaceMonitor.java:153)
    - None
    "polling thread" daemon prio=2 tid=0x0683c800 nid=0x11e8 runnable [0x0b12f000]
    at com.ti.xpcom.internal.XPCOMJavaProxy.callXPCOMMethod(Native Method)
    at com.ti.xpcom.internal.XPCOMJavaProxy.invoke(XPCOMJavaProxy.java:105)
    at com.sun.proxy.$Proxy18.pollThreadMain(Unknown Source)
    at com.ti.debug.engine.cce.CCEDebugEngine.pollThreadMain(CCEDebugEngine.java:106)
    at com.ti.debug.engine.cce.CCEDebugEngine$PollingThread.run(CCEDebugEngine.java:171)
    - None
    "Scripting Console - Rhino" prio=2 tid=0x0683b400 nid=0x77c waiting on condition [0x0c06f000]
    - parking to wait for <0x1b1cdc08> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
    at java.util.concurrent.LinkedBlockingQueue.take(Unknown Source)
    at com.ti.ccstudio.rhino.internal.RhinoThreadExecutor$RhinoThread.run(RhinoThreadExecutor.java:88)
    - None
    "org.eclipse.cdt.internal.ui.text.CReconciler" daemon prio=2 tid=0x0683a800 nid=0x260 in Object.wait() [0x0aa8f000]
    - locked <0x1adb22a0> (a org.eclipse.jface.text.reconciler.DirtyRegionQueue)
    - None
    "xpcom dispose thread" daemon prio=6 tid=0x06839c00 nid=0x182c in Object.wait() [0x0804f000]
    - locked <0x1ac73498> (a java.lang.ref.ReferenceQueue$Lock)
    at com.ti.xpcom.internal.NativeXPCOMInterface$DisposeThread.run(NativeXPCOMInterface.java:57)
    - None
    "Worker-4" prio=6 tid=0x0683a400 nid=0x19dc in Object.wait() [0x0a17f000]
    - None
    "Worker-2" prio=6 tid=0x06839000 nid=0x1864 in Object.wait() [0x0787f000]
    - None
    "EMF Reference Cleaner" daemon prio=6 tid=0x06838800 nid=0x1680 in Object.wait() [0x075ef000]
    - locked <0x198be390> (a java.lang.ref.ReferenceQueue$Lock)
    at org.eclipse.emf.common.util.CommonUtil$1ReferenceClearingQueuePollingThread.run(CommonUtil.java:70)
    - None
    "Worker-1" prio=6 tid=0x0673c000 nid=0x132c in Object.wait() [0x065af000]
    at org.eclipse.core.internal.resources.WorkManager.checkIn(WorkManager.java:118)
    at org.eclipse.core.internal.resources.Resource.refreshLocal(Resource.java:1691)
    at org.eclipse.core.internal.refresh.RefreshJob.runInWorkspace(RefreshJob.java:167)
    - None
    "Provisioning Event Dispatcher" daemon prio=6 tid=0x06620000 nid=0x1ac8 in Object.wait() [0x0736f000]
    at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.getNextEvent(EventManager.java:400)
    - locked <0x19505cd0> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread)
    at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:336)
    - None
    "Worker-JM" prio=6 tid=0x065d8000 nid=0x1270 in Object.wait() [0x070ef000]
    at org.eclipse.core.internal.jobs.InternalWorker.run(InternalWorker.java:58)
    - locked <0x19478f28> (a java.util.ArrayList)
    - None
    "[Timer] - Main Queue Handler" daemon prio=6 tid=0x0609e000 nid=0x1b28 in Object.wait() [0x06eef000]
    at org.eclipse.equinox.internal.util.impl.tpt.timer.TimerImpl.run(TimerImpl.java:141)
    - locked <0x18cad348> (a java.lang.Object)
    - None
    "Bundle File Closer" daemon prio=6 tid=0x0613c000 nid=0x7a0 in Object.wait() [0x0646f000]
    - locked <0x187ef400> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread)
    - None
    "Start Level Event Dispatcher" daemon prio=6 tid=0x05721800 nid=0x1ab4 in Object.wait() [0x05f6f000]
    - locked <0x186f0240> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread)
    - None
    "Framework Event Dispatcher" daemon prio=6 tid=0x0571ec00 nid=0xd8c in Object.wait() [0x05e6f000]
    - locked <0x186f0528> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread)
    - None
    "Framework Active Thread" prio=6 tid=0x056bb800 nid=0x1bc4 in Object.wait() [0x05c5f000]
    at org.eclipse.osgi.framework.internal.core.Framework.run(Framework.java:1862)
    - locked <0x186f0340> (a org.eclipse.osgi.framework.internal.core.Framework)
    - None
    "Service Thread" daemon prio=6 tid=0x0293b800 nid=0x1a48 runnable [0x00000000]
    - None
    "C1 CompilerThread0" daemon prio=10 tid=0x0293a000 nid=0x1a90 waiting on condition [0x00000000]
    - None
    "Attach Listener" daemon prio=10 tid=0x02935800 nid=0x1a6c waiting on condition [0x00000000]
    - None
    "Signal Dispatcher" daemon prio=10 tid=0x028c6400 nid=0x1320 runnable [0x00000000]
    - None
    "Finalizer" daemon prio=8 tid=0x028c0400 nid=0x1a54 in Object.wait() [0x04f5f000]
    - locked <0x18613478> (a java.lang.ref.ReferenceQueue$Lock)
    at java.lang.ref.Finalizer$FinalizerThread.run(Unknown Source)
    - None
    "Reference Handler" daemon prio=10 tid=0x028be800 nid=0x1a78 in Object.wait() [0x04e5f000]
    at java.lang.ref.Reference$ReferenceHandler.run(Unknown Source)
    - locked <0x18613508> (a java.lang.ref.Reference$Lock)
    - None
    "main" prio=6 tid=0x029ee000 nid=0x1b48 in Object.wait() [0x0018f000]
    at org.eclipse.cdt.dsf.concurrent.Query.get(Query.java:106)
    - locked <0x146847e0> (a org.eclipse.cdt.dsf.concurrent.Query$QueryRm)
    at org.eclipse.cdt.dsf.debug.internal.ui.actions.ResumeAtLine.canResumeAtLine(ResumeAtLine.java:72)
    at org.eclipse.cdt.debug.internal.ui.actions.ResumeAtLineAdapter.canResumeAtLine(ResumeAtLineAdapter.java:141)
    at org.eclipse.cdt.debug.internal.ui.actions.ResumeAtLineActionDelegate$1.run(ResumeAtLineActionDelegate.java:123)
    at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
    at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
    - locked <0x14684c10> (a org.eclipse.swt.widgets.RunnableLock)
    at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4145)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3762)
    at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
    at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
    at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
    at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
    at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
    at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
    at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
    at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
    at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    at java.lang.reflect.Method.invoke(Unknown Source)
    at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
    at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
    at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
    - None
    "VM Thread" prio=10 tid=0x028bd000 nid=0x15a4 runnable
    "VM Periodic Task Thread" prio=10 tid=0x02951c00 nid=0x808 waiting on condition
    JNI global references: 714
  • Hello Ki,
    The other person (I can't remember his name) in the phone meeting for the CCSv6.0.1.00040: 35 seconds to load workbench issue  (http://e2e.ti.com/support/development_tools/code_composer_studio/f/81/p/374079/1334537.aspx#1334537) mentioned that I should post a thread dump if the build stops at 50% again.
    Should I capture any other data for this issue?
    Stephen
  • Hi Stephen,
    I've forwarded the log you posted above to Martin for analysis.
    thanks
    ki
  • Hello Ki,
    Has Martin had a chance to look at this issue.
    Stephen
  • Hi Stephen,
    Yes, it looks like a bug. It has been filed as: SDSCM00051173.
    It is still under investigation.
    ki
