How to import system variables using DSS
I am looking for information on how do I import system variable into the DSS script. It would help to make my script portable.
Earlier, with CCSv3.3, used perl based scripting and used something like "my $dir_name = $ENV{LTELIB_DIR};" to import the values. I want to know how to achieve the same.
  • If you simply want to use a system environment variable in your javascript, you can use java.lang.System.getenv() to read the variable:
    var myEnvVar= java.lang.System.getenv("ENVIRONMENT_VARIABLE");
    Note that this is not a DSS specific but can be used with generic javascript.
    ki
