Other Parts Discussed in Thread: CCSTUDIO
Sir,
While trying to run GUI Composer from Motorware...I am Getting An Error " Unable to Locate GUI Composer Server to Launch this Application".How to resolve??
Bipin
Hi Bipin,
Bipin Patil said:While trying to run GUI Composer from Motorware...I am Getting An Error " Unable to Locate GUI Composer Server to Launch this Application".How to resolve??
Have you already installed GUI composer? If not then please do go to App center (In CCS v6) and install Gui Composer.
Gautam
Hello Sir,
Actually The GUI was Working at First and even I ran the Motor with it..
After Executing all the labs in Motor Ware.......Now again when i try to Run the GUI it Gives an error "Unable to Locate GUI Composer Server to Launch this Application".
Bipin Patil said:After Executing all the labs in Motor Ware.......Now again when i try to Run the GUI it Gives an error "Unable to Locate GUI Composer Server to Launch this Application".
Seems like some kind of instability. Anyways I'm forwarding your query to a GUI expert.
Gautam
Bipin Patil said:How to Solve This Sir...
Kindly be patient, you'll receive help soon.
Gautam
Bipin Patil said:Pardon Me Sir, but when can i get the answer....
It seems like the respective person might be on a holiday. In any case I've pinged him again.; just in case he might've missed.
Gautam
Bipin,
Which .exe did you use run the application. Did you use the executable inside the GUI application folder?
Patrick
Sir,
Following is the path of the executable file use to run the GUI...
C:\ti\guicomposer\webapps\InstaSPIN_MOTION_F2806xM\InstaSPIN_MOTION_F2806xM.exe
Bipin
Hi Bipin,
I am not completely sure why you are get this error message. Can you try to reinstall GUI composer and run it again? If you still get the same error message, can you zip up the webapps folder and attach it to this thread?
Patrick
I am facing the same problem. Error message "Unable to locate the GUI composer server to launch the application " waiting for guidance.
Sanjay
Hi Bipin, Sanjay,
I am able to launch the webapp, where do you place the webapp folder(s). Are they placed within the guicomposer/webapps folder?
Patrick
Please try to run the included "modem_m3" example application and see if that work.
Make sure you unzip the exported project into the webapps folder. i.e c:\ti\guicomposer\webapps\myapp. There should be a launcher.exe in myapp folder. Use this exe to launch your application. Let me know whether this work or not.
Patrick
