Does anyone know how one would change the filename's extension for the motorola output? *.m3 does not follow the standard I am aware of, which is *.s37.
I presume you are using a hex conversion utility such as armhex or hex6x. The option --outfile=filename can be used to name the output file.
Thanks and regards,
-George
I found that -outfile=filename was rejected when placed in the "Set Additional Flags..." section of ARM Hex Utility under CCS Build (found under project properties). I ended up finding the equivalent fix under "ARM Hex Utility" -> "General Options" -> "Specify output file names" and it resolved my issue.
